Bonsoir
Effectivement il y a un comportement diffèrent !
Désormais seuls les ports de la cle GSM tombent et remontent , les autres semblent rester stables , de plus les ports usb ne s’incrementent plus en device id sauf celui de la cle huawei. !
C’est nettement mieux , meme si il reste ce défaut.
Didier
[12040.871836] usb 1-1.5.3: USB disconnect, device number 17
[12040.873413] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[12040.873528] option 1-1.5.3:1.0: device disconnected
[12040.877115] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[12040.877232] option 1-1.5.3:1.1: device disconnected
[12040.878823] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
[12040.878946] option 1-1.5.3:1.2: device disconnected
[12054.578713] usb 1-1.5.3: new high-speed USB device number 18 using dwc_otg
[12054.819946] usb 1-1.5.3: New USB device found, idVendor=12d1, idProduct=1f01, bcdDevice= 1.02
[12054.819982] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[12054.819996] usb 1-1.5.3: Product: HUAWEI Mobile
[12054.820009] usb 1-1.5.3: Manufacturer: HUAWEI
[12054.820022] usb 1-1.5.3: SerialNumber: FFFFFFFFFFFFFFFF
[12054.865430] usb-storage 1-1.5.3:1.0: USB Mass Storage device detected
[12054.866256] scsi host0: usb-storage 1-1.5.3:1.0
[12055.978846] usb 1-1.5.3: USB disconnect, device number 18
[12057.398765] usb 1-1.5.3: new high-speed USB device number 19 using dwc_otg
[12057.629985] usb 1-1.5.3: New USB device found, idVendor=12d1, idProduct=1001, bcdDevice= 1.02
[12057.630011] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[12057.630024] usb 1-1.5.3: Product: HUAWEI Mobile
[12057.630037] usb 1-1.5.3: Manufacturer: HUAWEI
[12057.894941] option 1-1.5.3:1.0: GSM modem (1-port) converter detected
[12057.895457] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB2
[12057.896158] option 1-1.5.3:1.1: GSM modem (1-port) converter detected
[12057.896632] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB3
[12057.897263] option 1-1.5.3:1.2: GSM modem (1-port) converter detected
[12057.897744] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB4
[12581.037281] usb 1-1.5.3: USB disconnect, device number 19
[12581.038732] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[12581.038867] option 1-1.5.3:1.0: device disconnected
[12581.039918] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[12581.040048] option 1-1.5.3:1.1: device disconnected
[12581.041096] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
[12581.041311] option 1-1.5.3:1.2: device disconnected
[12594.743451] usb 1-1.5.3: new high-speed USB device number 20 using dwc_otg
[12594.974643] usb 1-1.5.3: New USB device found, idVendor=12d1, idProduct=1f01, bcdDevice= 1.02
[12594.974663] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[12594.974677] usb 1-1.5.3: Product: HUAWEI Mobile
[12594.974689] usb 1-1.5.3: Manufacturer: HUAWEI
[12594.974702] usb 1-1.5.3: SerialNumber: FFFFFFFFFFFFFFFF
[12595.019943] usb-storage 1-1.5.3:1.0: USB Mass Storage device detected
[12595.020890] scsi host0: usb-storage 1-1.5.3:1.0
[12595.887824] usb 1-1.5.3: USB disconnect, device number 20
[12597.563448] usb 1-1.5.3: new high-speed USB device number 21 using dwc_otg
[12597.794746] usb 1-1.5.3: New USB device found, idVendor=12d1, idProduct=1001, bcdDevice= 1.02
[12597.794772] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[12597.794786] usb 1-1.5.3: Product: HUAWEI Mobile
[12597.794798] usb 1-1.5.3: Manufacturer: HUAWEI
[12598.059715] option 1-1.5.3:1.0: GSM modem (1-port) converter detected
[12598.060232] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB2
[12598.060925] option 1-1.5.3:1.1: GSM modem (1-port) converter detected
[12598.061370] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB3
[12598.061982] option 1-1.5.3:1.2: GSM modem (1-port) converter detected
[12598.062380] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB4
[14593.969913] usb 1-1.5.3: USB disconnect, device number 21
[14593.971518] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[14593.971635] option 1-1.5.3:1.0: device disconnected
[14593.973003] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[14593.973173] option 1-1.5.3:1.1: device disconnected
[14593.974454] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
[14593.974670] option 1-1.5.3:1.2: device disconnected
[14608.450826] usb 1-1.5.3: new high-speed USB device number 22 using dwc_otg
[14608.682043] usb 1-1.5.3: New USB device found, idVendor=12d1, idProduct=1f01, bcdDevice= 1.02
[14608.682068] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[14608.682082] usb 1-1.5.3: Product: HUAWEI Mobile
[14608.682109] usb 1-1.5.3: Manufacturer: HUAWEI
[14608.682122] usb 1-1.5.3: SerialNumber: FFFFFFFFFFFFFFFF
[14608.727437] usb-storage 1-1.5.3:1.0: USB Mass Storage device detected
[14608.729417] scsi host0: usb-storage 1-1.5.3:1.0
[14609.844828] usb 1-1.5.3: USB disconnect, device number 22
[14611.260823] usb 1-1.5.3: new high-speed USB device number 23 using dwc_otg
[14611.492073] usb 1-1.5.3: New USB device found, idVendor=12d1, idProduct=1001, bcdDevice= 1.02
[14611.492112] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[14611.492126] usb 1-1.5.3: Product: HUAWEI Mobile
[14611.492138] usb 1-1.5.3: Manufacturer: HUAWEI
[14611.757038] option 1-1.5.3:1.0: GSM modem (1-port) converter detected
[14611.757585] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB2
[14611.758266] option 1-1.5.3:1.1: GSM modem (1-port) converter detected
[14611.758708] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB3
[14611.759288] option 1-1.5.3:1.2: GSM modem (1-port) converter detected
[14611.759709] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB4
[18236.854871] usb 1-1.5.3: USB disconnect, device number 23
[18236.856523] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[18236.856628] option 1-1.5.3:1.0: device disconnected
[18236.860539] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[18236.860671] option 1-1.5.3:1.1: device disconnected
[18236.861448] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
[18236.861593] option 1-1.5.3:1.2: device disconnected
[18250.572252] usb 1-1.5.3: new high-speed USB device number 24 using dwc_otg
[18250.813494] usb 1-1.5.3: New USB device found, idVendor=12d1, idProduct=1f01, bcdDevice= 1.02
[18250.813537] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[18250.813551] usb 1-1.5.3: Product: HUAWEI Mobile
[18250.813564] usb 1-1.5.3: Manufacturer: HUAWEI
[18250.813576] usb 1-1.5.3: SerialNumber: FFFFFFFFFFFFFFFF
[18250.858713] usb-storage 1-1.5.3:1.0: USB Mass Storage device detected
[18250.862464] scsi host0: usb-storage 1-1.5.3:1.0
[18251.961855] usb 1-1.5.3: USB disconnect, device number 24
[18253.642297] usb 1-1.5.3: new high-speed USB device number 25 using dwc_otg
[18253.873591] usb 1-1.5.3: New USB device found, idVendor=12d1, idProduct=1001, bcdDevice= 1.02
[18253.873627] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[18253.873640] usb 1-1.5.3: Product: HUAWEI Mobile
[18253.873653] usb 1-1.5.3: Manufacturer: HUAWEI
[18254.138655] option 1-1.5.3:1.0: GSM modem (1-port) converter detected
[18254.139167] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB2
[18254.139894] option 1-1.5.3:1.1: GSM modem (1-port) converter detected
[18254.140307] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB3
[18254.140935] option 1-1.5.3:1.2: GSM modem (1-port) converter detected
[18254.141336] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB4
[19758.523863] usb 1-1.5.3: USB disconnect, device number 25
[19758.524922] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[19758.525005] option 1-1.5.3:1.0: device disconnected
[19758.529061] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[19758.529174] option 1-1.5.3:1.1: device disconnected
[19758.529997] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
[19758.530086] option 1-1.5.3:1.2: device disconnected
[19772.235467] usb 1-1.5.3: new high-speed USB device number 26 using dwc_otg
[19772.466761] usb 1-1.5.3: New USB device found, idVendor=12d1, idProduct=1f01, bcdDevice= 1.02
[19772.466783] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[19772.466797] usb 1-1.5.3: Product: HUAWEI Mobile
[19772.466809] usb 1-1.5.3: Manufacturer: HUAWEI
[19772.466822] usb 1-1.5.3: SerialNumber: FFFFFFFFFFFFFFFF
[19772.512072] usb-storage 1-1.5.3:1.0: USB Mass Storage device detected
[19772.515156] scsi host0: usb-storage 1-1.5.3:1.0
[19773.374770] usb 1-1.5.3: USB disconnect, device number 26
[19775.305485] usb 1-1.5.3: new high-speed USB device number 27 using dwc_otg
[19775.536767] usb 1-1.5.3: New USB device found, idVendor=12d1, idProduct=1001, bcdDevice= 1.02
[19775.536793] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[19775.536806] usb 1-1.5.3: Product: HUAWEI Mobile
[19775.536819] usb 1-1.5.3: Manufacturer: HUAWEI
[19775.801919] option 1-1.5.3:1.0: GSM modem (1-port) converter detected
[19775.802431] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB2
[19775.803162] option 1-1.5.3:1.1: GSM modem (1-port) converter detected
[19775.803643] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB3
[19775.804272] option 1-1.5.3:1.2: GSM modem (1-port) converter detected
[19775.804716] usb 1-1.5.3: GSM modem (1-port) converter now attached to ttyUSB4
jeedom@rasp00:~ $
jeedom@rasp00:~ $
jeedom@rasp00:~ $ lsusb
Bus 001 Device 009: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 008: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
Bus 001 Device 007: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 027: ID 12d1:1001 Huawei Technologies Co., Ltd. E161/E169/E620/E800 HSDPA Modem
Bus 001 Device 006: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 005: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 004: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
