> Lancement de l'installation/mise à jour des dépendances openzwave
> Get:1 LIEN://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
> Get:2 LIEN://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
> Get:3 LIEN://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
> Get:4 LIEN://archive.raspberrypi.org/debian buster/main armhf Packages [330 kB]
> Get:5 LIEN://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.7 kB]
> Error: Timeout was reached
> Fetched 13.4 MB in 19s (713 kB/s)
> Reading package lists...
> Installation des dependances
> Building dependency tree...
> Reading state information...
> build-essential is already the newest version (12.6).
> g++ is already the newest version (4:8.3.0-1+rpi2).
> gcc is already the newest version (4:8.3.0-1+rpi2).
> git is already the newest version (1:2.20.1-2+deb10u3).
> libjpeg-dev is already the newest version (1:1.5.2-2).
> libudev-dev is already the newest version (241-7~deb10u4+rpi1).
> make is already the newest version (4.2.1-1.2).
> python-dev is already the newest version (2.7.16-1).
> python-louie is already the newest version (1.1-4).
> python-lxml is already the newest version (4.3.2-1).
> python-pyudev is already the newest version (0.21.0-1).
> python-requests is already the newest version (2.21.0-1).
> python-serial is already the newest version (3.4-4).
> python-setuptools is already the newest version (40.8.0-1).
> unzip is already the newest version (6.0-23+deb10u1).
> python-pip is already the newest version (18.1-5+rpt1).
> The following package was automatically installed and is no longer required:
> rpi-eeprom-images
> Use 'sudo apt autoremove' to remove it.
> 0 upgraded, 0 newly installed, 0 to remove and 63 not upgraded.
> Installation des dependances Python
> Looking in indexes: LIENs://pypi.org/simple, LIENs://www.piwheels.org/simple
> Requirement already satisfied: urwid in /usr/local/lib/python3.7/dist-packages (2.1.0)
> WARNING: You are using pip version 20.1.1; however, version 20.2 is available.
> You should consider upgrading via the '/usr/bin/python3 -m pip install --upgrade pip' command.
> Requirement already satisfied: louie in /usr/local/lib/python3.7/dist-packages (2.0)
> Requirement already satisfied: six in /usr/lib/python3/dist-packages (1.12.0)
> Collecting tornado
> Using cached LIENs://www.piwheels.org/simple/tornado/tornado-6.0.4-cp37-cp37m-linux_armv7l.whl (428 kB)
> Installing collected packages: tornado
> Successfully installed tornado-6.0.4
> mkdir: cannot create directory '/opt': File exists
> Désinstallation de la version précédente
> Installation de Python-OpenZwave
> Found existing installation: Cython 0.29.2
> ERROR: Cannot uninstall 'Cython'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.
> apt-get install --force-yes -y cython
> cython is already the newest version (0.29.2-2).
> rpi-eeprom-images
> W: --force-yes is deprecated, use one of the options starting with --allow instead.
> Installing dependencies for python : 2 7 16
> apt-get install --force-yes -y python-pip python-dev python-docutils python-setuptools python-louie
> python-docutils is already the newest version (0.14+dfsg-4).
> rpi-eeprom-images
> apt-get install --force-yes -y build-essential libudev-dev g++
> rpi-eeprom-images
> rpi-eeprom-images
> pip install nose-html
> Requirement already satisfied: nose-html in /usr/local/lib/python3.7/dist-packages (1.1)
> Requirement already satisfied: nose>=0.11.1 in /usr/local/lib/python3.7/dist-packages (from nose-html) (1.3.7)
> pip install nose-progressive
> Requirement already satisfied: nose-progressive in /usr/local/lib/python3.7/dist-packages (1.5.2)
> Requirement already satisfied: blessings<2.0,>=1.3 in /usr/local/lib/python3.7/dist-packages (from nose-progressive) (1.7)
> Requirement already satisfied: nose>=1.2.1 in /usr/local/lib/python3.7/dist-packages (from nose-progressive) (1.3.7)
> Requirement already satisfied: six in /usr/lib/python3/dist-packages (from blessings<2.0,>=1.3->nose-progressive) (1.12.0)
> pip install coverage
> Requirement already satisfied: coverage in /usr/local/lib/python3.7/dist-packages (5.1)
> pip install nose
> Requirement already satisfied: nose in /usr/local/lib/python3.7/dist-packages (1.3.7)
> pip install pylint
> Requirement already satisfied: pylint in /usr/local/lib/python3.7/dist-packages (2.5.2)
> Requirement already satisfied: toml>=0.7.1 in /usr/local/lib/python3.7/dist-packages (from pylint) (0.10.1)
> Requirement already satisfied: astroid<=2.5,>=2.4.0 in /usr/local/lib/python3.7/dist-packages (from pylint) (2.4.1)
> Requirement already satisfied: mccabe<0.7,>=0.6 in /usr/local/lib/python3.7/dist-packages (from pylint) (0.6.1)
> Requirement already satisfied: isort<5,>=4.2.5 in /usr/local/lib/python3.7/dist-packages (from pylint) (4.3.21)
> Requirement already satisfied: six~=1.12 in /usr/lib/python3/dist-packages (from astroid<=2.5,>=2.4.0->pylint) (1.12.0)
> Requirement already satisfied: typed-ast<1.5,>=1.4.0; implementation_name == "cpython" and python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from astroid<=2.5,>=2.4.0->pylint) (1.4.1)
> Requirement already satisfied: wrapt~=1.11 in /usr/local/lib/python3.7/dist-packages (from astroid<=2.5,>=2.4.0->pylint) (1.12.1)
> Requirement already satisfied: lazy-object-proxy==1.4.* in /usr/local/lib/python3.7/dist-packages (from astroid<=2.5,>=2.4.0->pylint) (1.4.3)
> #pip install docutils
> #pip install setuptools
> #The following line crashes with a core dump
> #pip install "Cython==0.22"
> Dependencies for users installed (python 2 7 16)
> sed -i -e '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
> cd openzwave && make
> make[1]: Entering directory '/opt/python-openzwave/openzwave'
> CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
> make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
> Building OpenZWave Version 1.4.-1
> Building tinystr.o
> Building tinyxmlerror.o
> Building tinyxml.o
> Building tinyxmlparser.o
> Building hid.o
> Building aeskey.o
> Building aescrypt.o
> Building aestab.o
> Building aes_modes.o
> Building Security.o
> Building Proprietary.o
> Building ClimateControlSchedule.o
> Building BarrierOperator.o
> Building ThermostatFanMode.o
> Building ControllerReplication.o
> Building BasicWindowCovering.o
> Building Color.o
> Building ZWavePlusInfo.o
> Building SoundSwitch.o
> Building CRC16Encap.o
> Building MeterPulse.o
> Building SensorBinary.o
> Building Configuration.o
> Building CommandClass.o
> Building SwitchToggleBinary.o
> Building ThermostatMode.o
> Building Battery.o
> Building TimeParameters.o
> Building UserCode.o
> Building CentralScene.o
> Building SwitchMultilevel.o
> Building ThermostatFanState.o
> Building DoorLock.o
> Building SwitchToggleMultilevel.o
> Building ApplicationStatus.o
> Building DoorLockLogging.o
> /opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp: In member function 'virtual bool OpenZWave::DoorLockLogging::HandleMsg(const uint8*, uint32, uint32)':
> /opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp:312:15: warning: passing argument 1 to restrict-qualified parameter aliases with argument 4 [-Wrestrict]
> snprintf(usercode, sizeof(usercode), "%s %d", usercode, (int)_data[12+i]);
> Building SensorAlarm.o
> Building NodeNaming.o
> Building WakeUp.o
> Building ManufacturerProprietary.o
> Building SwitchAll.o
> Building Lock.o
> Building Association.o
> Building MultiCmd.o
> Building Clock.o
> Building Powerlevel.o
> Building Meter.o
> Building AssociationCommandConfiguration.o
> Building SensorMultilevel.o
> Building ThermostatOperatingState.o
> Building MultiChannelAssociation.o
> Building Indicator.o
> Building SceneActivation.o
> Building MultiInstance.o
> Building Language.o
> Building Version.o
> Building Alarm.o
> Building Basic.o
> Building CommandClasses.o
> Building ManufacturerSpecific.o
> In file included from /usr/include/c++/8/map:60,
> from /opt/python-openzwave/openzwave/cpp/src/command_classes/CommandClasses.h:32,
> from /opt/python-openzwave/openzwave/cpp/src/command_classes/ManufacturerSpecific.cpp:28:
> /usr/include/c++/8/bits/stl_tree.h: In function 'std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::iterator std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_M_emplace_hint_unique(std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::const_iterator, _Args&& ...) [with _Args = {const std::piecewise_construct_t&, std::tuple<long long int&&>, std::tuple<>}; _Key = long long int; _Val = std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>; _KeyOfValue = std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >; _Compare = std::less<long long int>; _Alloc = std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >]':
> /usr/include/c++/8/bits/stl_tree.h:2411:7: note: parameter passing for argument of type 'std::_Rb_tree<long long int, std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>, std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >, std::less<long long int>, std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> > >::const_iterator' {aka 'std::_Rb_tree_const_iterator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >'} changed in GCC 7.1
> In file included from /usr/include/c++/8/map:61,
> /usr/include/c++/8/bits/stl_map.h: In static member function 'static bool OpenZWave::ManufacturerSpecific::LoadProductXML()':
> /usr/include/c++/8/bits/stl_map.h:518:8: note: parameter passing for argument of type 'std::_Rb_tree<long long int, std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>, std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >, std::less<long long int>, std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> > >::const_iterator' {aka 'std::_Rb_tree_const_iterator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >'} changed in GCC 7.1
> __i = _M_t._M_emplace_hint_unique(__i, std::piecewise_construct,
> Building ThermostatSetpoint.o
> Building NoOperation.o
> Building EnergyProduction.o
> Building DeviceResetLocally.o
> Building Hail.o
> Building Protection.o
> Building SwitchBinary.o
> Building Value.o
> Building ValueList.o
> Building ValueButton.o
> Building ValueInt.o
> Building ValueStore.o
> Building ValueDecimal.o
> Building ValueRaw.o
> Building ValueString.o
> Building ValueByte.o
> Building ValueBool.o
> Building ValueSchedule.o
> Building ValueShort.o
> Building Controller.o
> Building Wait.o
> Building Thread.o
> Building Stream.o
> Building Log.o
> Building HidController.o
> Building Mutex.o
> Building SerialController.o
> Building Event.o
> Building FileOps.o
> Building TimeStamp.o
> Building FileOpsImpl.o
> Building TimeStampImpl.o
> Building WaitImpl.o
> Building ThreadImpl.o
> Building LogImpl.o
> Building MutexImpl.o
> Building SerialControllerImpl.o
> Building EventImpl.o
> Building Options.o
> Building Scene.o
> Building Utils.o
> Building Driver.o
> Building ZWSecurity.o
> Building Group.o
> Building Node.o
> Building Manager.o
> Building Msg.o
> Building Notification.o
> Creating vers.cpp
> Building vers.o
> Linking Static Library
> Linking Shared Library
> Making ozw_config file
> make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
> CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/examples/MinOZW/ -w
> make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
> Building Main.o
> Linking /opt/python-openzwave/openzwave/.lib/MinOZW
> g++ -o /opt/python-openzwave/openzwave/.lib/MinOZW /opt/python-openzwave/openzwave/.lib/Main.o /opt/python-openzwave/openzwave/libopenzwave.so -pthread
> Creating Temporary Shell Launch Script
> make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
> make[1]: Leaving directory '/opt/python-openzwave/openzwave'
> python setup-lib.py build
> running build
> running build_ext
> cythoning src-lib/libopenzwave/libopenzwave.pyx to src-lib/libopenzwave/libopenzwave.cpp
> /usr/lib/python2.7/dist-packages/Cython/Compiler/Main.py:367: FutureWarning: Cython directive 'language_level' not set, using 2 for now (Py2). This will change in a later release! File: /opt/python-openzwave/src-lib/libopenzwave/libopenzwave.pyx
> tree = Parsing.p_module(s, pxd, full_module_name)
> building 'libopenzwave' extension
> creating build
> creating build/temp.linux-armv7l-2.7
> creating build/temp.linux-armv7l-2.7/src-lib
> creating build/temp.linux-armv7l-2.7/src-lib/libopenzwave
> arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-InigCj/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DPY_SSIZE_T_CLEAN=1 -Iopenzwave/cpp/src/ -Iopenzwave/cpp/src/value_classes/ -Iopenzwave/cpp/src/platform/ -Iopenzwave/cpp/build/linux/ -I/usr/include/python2.7 -c src-lib/libopenzwave/libopenzwave.cpp -o build/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o
> cc1plus: warning: command line option '-Wstrict-prototypes' is valid for C/ObjC but not for C++
> src-lib/libopenzwave/libopenzwave.cpp:3: warning: "PY_SSIZE_T_CLEAN" redefined
> #define PY_SSIZE_T_CLEAN
> <command-line>: note: this is the location of the previous definition
> In file included from openzwave/cpp/src/aes/aescpp.h:26,
> from openzwave/cpp/src/Driver.h:42,
> from src-lib/libopenzwave/libopenzwave.cpp:638:
> openzwave/cpp/src/aes/aes.h:75: warning: ignoring #pragma warning [-Wunknown-pragmas]
> #pragma warning( disable : 4324 )
> openzwave/cpp/src/aes/aes.h:93: warning: ignoring #pragma warning [-Wunknown-pragmas]
> #pragma warning( default : 4324 )
> src-lib/libopenzwave/libopenzwave.cpp: In function 'PyObject* __pyx_pf_12libopenzwave_9PyManager_268beginControllerCommand(__pyx_obj_12libopenzwave_PyManager*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*)':
> src-lib/libopenzwave/libopenzwave.cpp:30325:204: warning: 'bool OpenZWave::Manager::BeginControllerCommand(uint32, OpenZWave::Driver::ControllerCommand, OpenZWave::Driver::pfnControllerCallback_t, void*, bool, uint8, uint8)' is deprecated [-Wdeprecated-declarations]
> __pyx_t_6 = __Pyx_PyBool_FromLong(__pyx_v_self->manager->BeginControllerCommand(__pyx_t_1, __pyx_t_2, __pyx_f_12libopenzwave_ctrl_callback, ((void *)__pyx_v_pythonfunc), __pyx_t_3, __pyx_t_4, __pyx_t_5)); if (unlikely(!__pyx_t_6)) __PYX_ERR(0, 4120, __pyx_L1_error)
> In file included from src-lib/libopenzwave/libopenzwave.cpp:643:
> openzwave/cpp/src/Manager.h:1731:19: note: declared here
> DEPRECATED bool BeginControllerCommand( uint32 const _homeId, Driver::ControllerCommand _command, Driver::pfnControllerCallback_t _callback = NULL, void* _context = NULL, bool _highPower = false, uint8 _nodeId = 0xff, uint8 _arg = 0 );
> creating build/lib.linux-armv7l-2.7
> arm-linux-gnueabihf-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-InigCj/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -Wl,-z,relro -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-InigCj/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o openzwave/libopenzwave.a -ludev -lstdc++ -o build/lib.linux-armv7l-2.7/libopenzwave.so
> python setup-lib.py install
> running install
> running bdist_egg
> running egg_info
> creating src-lib/libopenzwave.egg-info
> writing requirements to src-lib/libopenzwave.egg-info/requires.txt
> writing src-lib/libopenzwave.egg-info/PKG-INFO
> writing top-level names to src-lib/libopenzwave.egg-info/top_level.txt
> writing dependency_links to src-lib/libopenzwave.egg-info/dependency_links.txt
> writing manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
> reading manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
> installing library code to build/bdist.linux-armv7l/egg
> running install_lib
> running build_ext
> skipping 'src-lib/libopenzwave/libopenzwave.cpp' Cython extension (up-to-date)
> creating build/bdist.linux-armv7l
> creating build/bdist.linux-armv7l/egg
> copying build/lib.linux-armv7l-2.7/libopenzwave.so -> build/bdist.linux-armv7l/egg
> creating stub loader for libopenzwave.so
> byte-compiling build/bdist.linux-armv7l/egg/libopenzwave.py to libopenzwave.pyc
> installing package data to build/bdist.linux-armv7l/egg
> running install_data
> creating build/bdist.linux-armv7l/egg/config
> creating build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-lib/libopenzwave.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-lib/libopenzwave.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-lib/libopenzwave.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-lib/libopenzwave.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-lib/libopenzwave.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-lib/libopenzwave.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
> writing build/bdist.linux-armv7l/egg/EGG-INFO/native_libs.txt
> creating dist
> creating 'dist/libopenzwave-0.3.1-py2.7-linux-armv7l.egg' and adding 'build/bdist.linux-armv7l/egg' to it
> removing 'build/bdist.linux-armv7l/egg' (and everything under it)
> Processing libopenzwave-0.3.1-py2.7-linux-armv7l.egg
> creating /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
> Extracting libopenzwave-0.3.1-py2.7-linux-armv7l.egg to /usr/local/lib/python2.7/dist-packages
> Adding libopenzwave 0.3.1 to easy-install.pth file
> Installed /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
> Processing dependencies for libopenzwave==0.3.1
> Searching for six==1.12.0
> Best match: six 1.12.0
> Adding six 1.12.0 to easy-install.pth file
> Using /usr/lib/python2.7/dist-packages
> Finished processing dependencies for libopenzwave==0.3.1
> Installation of lib finished.
> python setup-api.py install
> running install
> running bdist_egg
> running egg_info
> creating src-api/openzwave.egg-info
> writing requirements to src-api/openzwave.egg-info/requires.txt
> writing src-api/openzwave.egg-info/PKG-INFO
> writing top-level names to src-api/openzwave.egg-info/top_level.txt
> writing dependency_links to src-api/openzwave.egg-info/dependency_links.txt
> writing manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
> reading manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
> running install_lib
> running build_py
> creating build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/group.py -> build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/scene.py -> build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/option.py -> build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/object.py -> build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/value.py -> build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/command.py -> build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/network.py -> build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/controller.py -> build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/singleton.py -> build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/node.py -> build/lib.linux-armv7l-2.7/openzwave
> copying src-api/openzwave/__init__.py -> build/lib.linux-armv7l-2.7/openzwave
> creating build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/group.py -> build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/scene.py -> build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/option.py -> build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/object.py -> build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/value.py -> build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/command.py -> build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/network.py -> build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/controller.py -> build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/singleton.py -> build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/node.py -> build/bdist.linux-armv7l/egg/openzwave
> copying build/lib.linux-armv7l-2.7/openzwave/__init__.py -> build/bdist.linux-armv7l/egg/openzwave
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/group.py to group.pyc
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/scene.py to scene.pyc
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/option.py to option.pyc
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/object.py to object.pyc
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/value.py to value.pyc
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/command.py to command.pyc
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/network.py to network.pyc
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/controller.py to controller.pyc
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/singleton.py to singleton.pyc
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/node.py to node.pyc
> byte-compiling build/bdist.linux-armv7l/egg/openzwave/__init__.py to __init__.pyc
> copying src-api/openzwave.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-api/openzwave.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-api/openzwave.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-api/openzwave.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-api/openzwave.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
> copying src-api/openzwave.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
> creating 'dist/openzwave-0.3.1-py2.7.egg' and adding 'build/bdist.linux-armv7l/egg' to it
> Processing openzwave-0.3.1-py2.7.egg
> creating /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
> Extracting openzwave-0.3.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
> Adding openzwave 0.3.1 to easy-install.pth file
> Installed /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
> Processing dependencies for openzwave==0.3.1
> Searching for libopenzwave==0.3.1
> Best match: libopenzwave 0.3.1
> libopenzwave 0.3.1 is already the active version in easy-install.pth
> Using /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
> Searching for Louie==1.1
> Best match: Louie 1.1
> Adding Louie 1.1 to easy-install.pth file
> Finished processing dependencies for openzwave==0.3.1
> Installation of API finished.
> sed: can't read /etc/inittab: No such file or directory
> Failed to get properties: Connection timed out
> Failed to stop serial-getty@ttyAMA0.service: Connection timed out
> See system logs and 'systemctl status serial-getty@ttyAMA0.service' for details.
> Failed to disable unit: Connection timed out
> Raspberry Pi 3 Detected. If you use a Razberry board you must Disabling Bluetooth
> Please add 'dtoverlay=pi3-miniuart-bt' to the end of the file /boot/config.txt
> And reboot your Raspberry Pi
> Everything is successfully installed!
PS : j’ai tapé LIEN au lieu d’HTTP car étant nouveau membre, je ne pouvais pas poster plus de 2 liens^^
