Sur mon installation RPI3 avec cle Zwave Everspring le démon Zwave ne veut plus se lancer, l’installation des dépendances semble bien se passer :
Lancement de l'installation/mise à jour des dépendances openzwave
Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:3 https://deb.nodesource.com/node_12.x stretch InRelease
Fetched 25.4 kB in 6s (4036 B/s)
Reading package lists...
Installation des dependances
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.3).
g++ is already the newest version (4:6.3.0-4).
gcc is already the newest version (4:6.3.0-4).
git is already the newest version (1:2.11.0-3+deb9u6).
libjpeg-dev is already the newest version (1:1.5.1-2+deb9u1).
libudev-dev is already the newest version (232-25+deb9u12).
make is already the newest version (4.1-9.1).
python-dev is already the newest version (2.7.13-2).
python-setuptools is already the newest version (33.1.1-1).
unzip is already the newest version (6.0-21+deb9u2).
python-pip is already the newest version (9.0.1-2+rpt2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Installation des dependances Python
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: urwid in /usr/local/lib/python2.7/dist-packages (2.0.1)
Requirement already satisfied: louie in /usr/lib/python2.7/dist-packages (1.1)
Requirement already satisfied: nose>=0.8.3 in /usr/lib/python2.7/dist-packages (from louie) (1.3.7)
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (1.12.0)
Requirement already satisfied: tornado in /usr/local/lib/python2.7/dist-packages (5.1.1)
Requirement already satisfied: singledispatch in /usr/local/lib/python2.7/dist-packages (from tornado) (3.4.0.3)
Requirement already satisfied: futures in /usr/local/lib/python2.7/dist-packages (from tornado) (3.3.0)
Requirement already satisfied: backports-abc>=0.4 in /usr/local/lib/python2.7/dist-packages (from tornado) (0.5)
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (from singledispatch->tornado) (1.12.0)
mkdir: cannot create directory '/opt': File exists
Désinstallation de la version précédente
Installation de Python-OpenZwave
Found existing installation: Cython 0.25.2
ERROR: Cannot uninstall 'Cython'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.
apt-get install --force-yes -y cython
cython is already the newest version (0.25.2-1).
Installing dependencies for python : 2 7 13
apt-get install --force-yes -y python-pip python-dev python-docutils python-setuptools python-louie
apt-get install --force-yes -y build-essential libudev-dev g++
pip install nose-html
Requirement already satisfied: nose-html in /usr/local/lib/python2.7/dist-packages (1.1)
Requirement already satisfied: nose>=0.11.1 in /usr/lib/python2.7/dist-packages (from nose-html) (1.3.7)
pip install nose-progressive
Requirement already satisfied: nose-progressive in /usr/local/lib/python2.7/dist-packages (1.5.2)
Requirement already satisfied: blessings<2.0,>=1.3 in /usr/local/lib/python2.7/dist-packages (from nose-progressive) (1.7)
Requirement already satisfied: nose>=1.2.1 in /usr/lib/python2.7/dist-packages (from nose-progressive) (1.3.7)
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (from blessings<2.0,>=1.3->nose-progressive) (1.12.0)
pip install coverage
Requirement already satisfied: coverage in /usr/local/lib/python2.7/dist-packages (4.5.4)
pip install nose
Requirement already satisfied: nose in /usr/lib/python2.7/dist-packages (1.3.7)
pip install pylint
Requirement already satisfied: pylint in /usr/local/lib/python2.7/dist-packages (1.9.5)
Requirement already satisfied: singledispatch; python_version < "3.4" in /usr/local/lib/python2.7/dist-packages (from pylint) (3.4.0.3)
Requirement already satisfied: backports.functools-lru-cache; python_version == "2.7" in /usr/local/lib/python2.7/dist-packages (from pylint) (1.6.1)
Requirement already satisfied: configparser; python_version == "2.7" in /usr/local/lib/python2.7/dist-packages (from pylint) (4.0.2)
Requirement already satisfied: mccabe in /usr/local/lib/python2.7/dist-packages (from pylint) (0.6.1)
Requirement already satisfied: astroid<2.0,>=1.6 in /usr/local/lib/python2.7/dist-packages (from pylint) (1.6.6)
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (from pylint) (1.12.0)
Requirement already satisfied: isort>=4.2.5 in /usr/local/lib/python2.7/dist-packages (from pylint) (4.3.21)
Requirement already satisfied: wrapt in /usr/local/lib/python2.7/dist-packages (from astroid<2.0,>=1.6->pylint) (1.11.2)
Requirement already satisfied: enum34>=1.1.3; python_version < "3.4" in /usr/lib/python2.7/dist-packages (from astroid<2.0,>=1.6->pylint) (1.1.6)
Requirement already satisfied: lazy-object-proxy in /usr/local/lib/python2.7/dist-packages (from astroid<2.0,>=1.6->pylint) (0.0.0)
Requirement already satisfied: futures; python_version < "3.2" in /usr/local/lib/python2.7/dist-packages (from isort>=4.2.5->pylint) (3.3.0)
#pip install docutils
#pip install setuptools
#The following line crashes with a core dump
#pip install "Cython==0.22"
Dependencies for users installed (python 2 7 13)
sed -i -e '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory '/opt/python-openzwave/openzwave'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
Building OpenZWave Version 1.4.-1
Building tinystr.o
Building tinyxmlerror.o
Building tinyxml.o
Building tinyxmlparser.o
Building hid.o
Building aeskey.o
Building aescrypt.o
Building aestab.o
Building aes_modes.o
Building Proprietary.o
Building DoorLock.o
Building Language.o
Building ZWavePlusInfo.o
Building Configuration.o
Building ManufacturerSpecific.o
In file included from /usr/include/c++/6/map:60:0,
from /opt/python-openzwave/openzwave/cpp/src/command_classes/CommandClasses.h:32,
from /opt/python-openzwave/openzwave/cpp/src/command_classes/ManufacturerSpecific.cpp:28:
/usr/include/c++/6/bits/stl_tree.h: In function 'std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::iterator std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_M_emplace_hint_unique(std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::const_iterator, _Args&& ...) [with _Args = {const std::piecewise_construct_t&, std::tuple<long long int&&>, std::tuple<>}; _Key = long long int; _Val = std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>; _KeyOfValue = std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >; _Compare = std::less<long long int>; _Alloc = std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >]':
/usr/include/c++/6/bits/stl_tree.h:2193:7: note: parameter passing for argument of type 'std::_Rb_tree<long long int, std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>, std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >, std::less<long long int>, std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> > >::const_iterator {aka std::_Rb_tree_const_iterator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >}' will change in GCC 7.1
In file included from /usr/include/c++/6/map:61:0,
/usr/include/c++/6/bits/stl_map.h: In static member function 'static bool OpenZWave::ManufacturerSpecific::LoadProductXML()':
/usr/include/c++/6/bits/stl_map.h:502:4: note: parameter passing for argument of type 'std::_Rb_tree<long long int, std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>, std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >, std::less<long long int>, std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> > >::const_iterator {aka std::_Rb_tree_const_iterator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >}' will change in GCC 7.1
__i = _M_t._M_emplace_hint_unique(__i, std::piecewise_construct,
Building SensorBinary.o
Building SwitchBinary.o
Building Node.o
Building Manager.o
Building Msg.o
Building Notification.o
Creating vers.cpp
Building vers.o
Linking Static Library
Linking Shared Library
Making ozw_config file
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/examples/MinOZW/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
Building Main.o
Linking /opt/python-openzwave/openzwave/.lib/MinOZW
g++ -o /opt/python-openzwave/openzwave/.lib/MinOZW /opt/python-openzwave/openzwave/.lib/Main.o /opt/python-openzwave/openzwave/libopenzwave.so -pthread
Creating Temporary Shell Launch Script
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
make[1]: Leaving directory '/opt/python-openzwave/openzwave'
python setup-lib.py build
running build
running build_ext
cythoning src-lib/libopenzwave/libopenzwave.pyx to src-lib/libopenzwave/libopenzwave.cpp
building 'libopenzwave' extension
creating build
creating build/temp.linux-armv7l-2.7
creating build/temp.linux-armv7l-2.7/src-lib
creating build/temp.linux-armv7l-2.7/src-lib/libopenzwave
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-ajc2xi/python2.7-2.7.13=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DPY_SSIZE_T_CLEAN=1 -Iopenzwave/cpp/src/ -Iopenzwave/cpp/src/value_classes/ -Iopenzwave/cpp/src/platform/ -Iopenzwave/cpp/build/linux/ -I/usr/include/python2.7 -c src-lib/libopenzwave/libopenzwave.cpp -o build/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o
cc1plus: warning: command line option '-Wstrict-prototypes' is valid for C/ObjC but not for C++
src-lib/libopenzwave/libopenzwave.cpp:3:0: warning: "PY_SSIZE_T_CLEAN" redefined
#define PY_SSIZE_T_CLEAN
<command-line>:0:0: note: this is the location of the previous definition
In file included from openzwave/cpp/src/aes/aescpp.h:26:0,
from openzwave/cpp/src/Driver.h:42,
from src-lib/libopenzwave/libopenzwave.cpp:459:
openzwave/cpp/src/aes/aes.h:75:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( disable : 4324 )
openzwave/cpp/src/aes/aes.h:93:0: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( default : 4324 )
src-lib/libopenzwave/libopenzwave.cpp: In function 'PyObject* __pyx_pf_12libopenzwave_9PyManager_268beginControllerCommand(__pyx_obj_12libopenzwave_PyManager*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*)':
src-lib/libopenzwave/libopenzwave.cpp:29891:204: warning: 'bool OpenZWave::Manager::BeginControllerCommand(uint32, OpenZWave::Driver::ControllerCommand, OpenZWave::Driver::pfnControllerCallback_t, void*, bool, uint8, uint8)' is deprecated [-Wdeprecated-declarations]
__pyx_t_6 = __Pyx_PyBool_FromLong(__pyx_v_self->manager->BeginControllerCommand(__pyx_t_1, __pyx_t_2, __pyx_f_12libopenzwave_ctrl_callback, ((void *)__pyx_v_pythonfunc), __pyx_t_3, __pyx_t_4, __pyx_t_5)); if (unlikely(!__pyx_t_6)) __PYX_ERR(0, 4120, __pyx_L1_error)
src-lib/libopenzwave/libopenzwave.cpp:545:36: note: in definition of macro '__Pyx_PyBool_FromLong'
#define __Pyx_PyBool_FromLong(b) ((b) ? __Pyx_NewRef(Py_True) : __Pyx_NewRef(Py_False))
In file included from src-lib/libopenzwave/libopenzwave.cpp:464:0:
openzwave/cpp/src/Manager.h:1731:19: note: declared here
DEPRECATED bool BeginControllerCommand( uint32 const _homeId, Driver::ControllerCommand _command, Driver::pfnControllerCallback_t _callback = NULL, void* _context = NULL, bool _highPower = false, uint8 _nodeId = 0xff, uint8 _arg = 0 );
creating build/lib.linux-armv7l-2.7
arm-linux-gnueabihf-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-ajc2xi/python2.7-2.7.13=. -fstack-protector-strong -Wformat -Werror=format-security -Wl,-z,relro -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-ajc2xi/python2.7-2.7.13=. -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o openzwave/libopenzwave.a -ludev -lstdc++ -o build/lib.linux-armv7l-2.7/libopenzwave.so
python setup-lib.py install
running install
running bdist_egg
running egg_info
creating src-lib/libopenzwave.egg-info
writing requirements to src-lib/libopenzwave.egg-info/requires.txt
writing src-lib/libopenzwave.egg-info/PKG-INFO
writing top-level names to src-lib/libopenzwave.egg-info/top_level.txt
writing dependency_links to src-lib/libopenzwave.egg-info/dependency_links.txt
writing manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
reading manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_ext
skipping 'src-lib/libopenzwave/libopenzwave.cpp' Cython extension (up-to-date)
creating build/bdist.linux-armv7l
creating build/bdist.linux-armv7l/egg
copying build/lib.linux-armv7l-2.7/libopenzwave.so -> build/bdist.linux-armv7l/egg
creating stub loader for libopenzwave.so
byte-compiling build/bdist.linux-armv7l/egg/libopenzwave.py to libopenzwave.pyc
installing package data to build/bdist.linux-armv7l/egg
running install_data
creating build/bdist.linux-armv7l/egg/config
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
writing build/bdist.linux-armv7l/egg/EGG-INFO/native_libs.txt
creating dist
creating 'dist/libopenzwave-0.3.1-py2.7-linux-armv7l.egg' and adding 'build/bdist.linux-armv7l/egg' to it
removing 'build/bdist.linux-armv7l/egg' (and everything under it)
Processing libopenzwave-0.3.1-py2.7-linux-armv7l.egg
creating /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
Extracting libopenzwave-0.3.1-py2.7-linux-armv7l.egg to /usr/local/lib/python2.7/dist-packages
Adding libopenzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
Processing dependencies for libopenzwave==0.3.1
Searching for six==1.12.0
Best match: six 1.12.0
Adding six 1.12.0 to easy-install.pth file
Using /usr/lib/python2.7/dist-packages
Finished processing dependencies for libopenzwave==0.3.1
Installation of lib finished.
python setup-api.py install
running install
running bdist_egg
running egg_info
creating src-api/openzwave.egg-info
writing requirements to src-api/openzwave.egg-info/requires.txt
writing src-api/openzwave.egg-info/PKG-INFO
writing top-level names to src-api/openzwave.egg-info/top_level.txt
writing dependency_links to src-api/openzwave.egg-info/dependency_links.txt
writing manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
reading manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
running install_lib
running build_py
creating build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/option.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/value.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/scene.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/group.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/node.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/network.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/__init__.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/object.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/singleton.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/controller.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/command.py -> build/lib.linux-armv7l-2.7/openzwave
creating build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/option.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/value.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/scene.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/group.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/node.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/network.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/__init__.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/object.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/singleton.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/controller.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/command.py -> build/bdist.linux-armv7l/egg/openzwave
byte-compiling build/bdist.linux-armv7l/egg/openzwave/option.py to option.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/value.py to value.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/scene.py to scene.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/group.py to group.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/node.py to node.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/network.py to network.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/__init__.py to __init__.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/object.py to object.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/singleton.py to singleton.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/controller.py to controller.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/command.py to command.pyc
copying src-api/openzwave.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
creating 'dist/openzwave-0.3.1-py2.7.egg' and adding 'build/bdist.linux-armv7l/egg' to it
Processing openzwave-0.3.1-py2.7.egg
creating /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Extracting openzwave-0.3.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Adding openzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Processing dependencies for openzwave==0.3.1
Searching for libopenzwave==0.3.1
Best match: libopenzwave 0.3.1
libopenzwave 0.3.1 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
Searching for Louie==1.1
Best match: Louie 1.1
Adding Louie 1.1 to easy-install.pth file
Searching for nose==1.3.7
Best match: nose 1.3.7
Adding nose 1.3.7 to easy-install.pth file
Installing nosetests script to /usr/local/bin
Installing nosetests-2.7 script to /usr/local/bin
Finished processing dependencies for openzwave==0.3.1
Installation of API finished.
sed: can't read /etc/inittab: No such file or directory
Raspberry Pi 3 Detected. If you use a Razberry board you must Disabling Bluetooth
Please add 'dtoverlay=pi3-miniuart-bt' to the end of the file /boot/config.txt
And reboot your Raspberry Pi
Everything is successfully installed!
Et la clé est bien vue par le système lorsque je lance la commande lsusb:
pi@raspberrypi:~ $ lsusb
Bus 001 Device 005: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 007: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Bus 001 Device 008: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 006: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@raspberrypi:~ $
Mais le démon ne veut toujours pas se lancer:
[2020-08-24 17:59:53][INFO] : Lancement démon openzwave : /usr/bin/python /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py --device auto --loglevel debug --port 8083 --config_folder /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/config --data_folder /var/www/html/plugins/openzwave/core/class/../../data --callback http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php --apikey XXXXXX --suppressRefresh 0 --cycle 0.3 --pid /tmp/jeedom/openzwave/deamon.pid
[2020-08-24 18:00:05][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2020-08-24 17:59:52
[2020-08-24 18:00:23][ERROR] : Impossible de lancer le démon openzwave, relancer le démon en debug et vérifiez la log
J’ai fais les mises à jour du système et je ne peux plus revenir en arrière car pas d’anciennes sauvegardes… J’ai vérifié la clé sur un autre système et elle fonctionne. J’ai essayé la procédure Zwave Demon NOK sans succès. Je ne suis pas tres à l’aise avec la lecture des logs, peut etre que quelque chose m’échappe… Avez-vous une idée d’où peut venir mon problème ?
