idem pour moi tout est vert mais aucune activité dans le log
Killed
> zigbee2mqtt@1.33.0 start
> node index.js
Zigbee2MQTT:debug 2023-09-20 14:30:19: Loaded state from file /var/www/html/plugins/z2m/data/state.json
Zigbee2MQTT:info 2023-09-20 14:30:19: Logging to console and directory: '/var/www/html/plugins/z2m/data/log/2023-09-20.14-30-19' filename: log.txt
Zigbee2MQTT:debug 2023-09-20 14:30:19: Removing old log directory '/var/www/html/plugins/z2m/data/log/2023-09-18.21-30-06'
Zigbee2MQTT:info 2023-09-20 14:30:19: Starting Zigbee2MQTT version 1.33.0 (commit #f224ef7)
Zigbee2MQTT:info 2023-09-20 14:30:19: Starting zigbee-herdsman (0.18.5)
Zigbee2MQTT:debug 2023-09-20 14:30:19: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","databasePath":"/var/www/html/plugins/z2m/data/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"deconz","path":"/dev/ttyACM0"}}'
Zigbee2MQTT:info 2023-09-20 14:30:19: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2023-09-20 14:30:19: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":120,"product":0,"revision":"0x26780700","transportrev":0},"type":"ConBee2/RaspBee2"}'
Zigbee2MQTT:debug 2023-09-20 14:30:19: Zigbee network parameters: {"channel":11,"extendedPanID":"0xdddddddddddddddd","panID":6754}
Zigbee2MQTT:info 2023-09-20 14:30:19: Currently 7 devices are joined:
Zigbee2MQTT:info 2023-09-20 14:30:19: Ecran_Salon (0x54ef4410002a6c65): VOCKQJK11LM - Xiaomi Aqara TVOC air quality monitor (EndDevice)
Zigbee2MQTT:info 2023-09-20 14:30:19: Volet_Fenetre_Cuisine (0x0004740000a40d3f): K4027C/L4027C/N4027C/NT4027C - BTicino Shutter SW with level control (Router)
Zigbee2MQTT:info 2023-09-20 14:30:19: Linky Meter (0xa4c1386d63db3f33): PJ-1203A - TuYa Bidirectional energy meter with 80A current clamp (Router)
Zigbee2MQTT:info 2023-09-20 14:30:19: Volet_Salon (0x0004740000a40d58): K4027C/L4027C/N4027C/NT4027C - BTicino Shutter SW with level control (Router)
Zigbee2MQTT:info 2023-09-20 14:30:19: Volet_Salle_Manger (0x0004740000a40ce0): K4027C/L4027C/N4027C/NT4027C - BTicino Shutter SW with level control (Router)
Zigbee2MQTT:info 2023-09-20 14:30:19: Volet_Porte_Cuisine (0x0004740000a42fe0): K4027C/L4027C/N4027C/NT4027C - BTicino Shutter SW with level control (Router)
Zigbee2MQTT:info 2023-09-20 14:30:19: Recharge_VE (0xe0798dfffe51d7cc): TS011F_din_smart_relay_polling - TuYa Din smart relay (with power monitoring via polling) (Router)
Zigbee2MQTT:info 2023-09-20 14:30:19: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2023-09-20 14:30:20: Connecting to MQTT server at mqtt://127.0.0.1:1883
Zigbee2MQTT:debug 2023-09-20 14:30:20: Using MQTT login with username: jeedom
Zigbee2MQTT:info 2023-09-20 14:30:21: Connected to MQTT server
Zigbee2MQTT:info 2023-09-20 14:30:21: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2023-09-20 14:30:21: Started frontend on port 0.0.0.0:8080
Zigbee2MQTT:debug 2023-09-20 14:30:21: Received MQTT message on 'zigbee2mqtt/bridge/config' with data '{"commit":"f224ef7","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":120,"product":0,"revision":"0x26780700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"debug","network":{"channel":11,"extendedPanID":"0xdddddddddddddddd","panID":6754},"permit_join":false,"version":"1.33.0"}'
Zigbee2MQTT:info 2023-09-20 14:30:21: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"f224ef7","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":120,"product":0,"revision":"0x26780700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"debug","network":{"channel":11,"extendedPanID":"0xdddddddddddddddd","panID":6754},"permit_join":false,"version":"1.33.0"}'
Zigbee2MQTT:info 2023-09-20 14:30:21: MQTT publish: topic 'zigbee2mqtt/Ecran_Salon', payload '{"battery":100,"device":{"applicationVersion":29,"dateCode":"20220222","friendlyName":"Ecran_Salon","hardwareVersion":1,"ieeeAddr":"0x54ef4410002a6c65","manufacturerID":4447,"manufacturerName":"LUMI","model":"VOCKQJK11LM","networkAddress":34427,"powerSource":"Battery","softwareBuildID":"2020\u0000www.","stackVersion":2,"type":"EndDevice","zclVersion":3},"device_temperature":24,"humidity":56,"last_seen":"2023-09-20T11:29:36.340Z","linkquality":255,"power_outage_count":50,"property":68,"temperature":24.9,"update":{"installed_version":29,"latest_version":29,"state":"idle"},"update_available":false,"voc":40,"voltage":3072}'
Zigbee2MQTT:info 2023-09-20 14:30:21: MQTT publish: topic 'zigbee2mqtt/Volet_Fenetre_Cuisine', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221202\u0000\u0000\u0000\u0000\u0000","friendlyName":"Volet_Fenetre_Cuisine","hardwareVersion":1,"ieeeAddr":"0x0004740000a40d3f","manufacturerID":4129,"manufacturerName":" Legrand","model":"K4027C/L4027C/N4027C/NT4027C","networkAddress":39718,"powerSource":"Mains (single phase)","softwareBuildID":"0036","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2023-09-20T11:30:38.791Z","led_in_dark":"OFF","linkquality":255,"position":100,"state":"OPEN","tilt":100,"update":{"installed_version":3556351,"latest_version":3555843,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2023-09-20 14:30:21: MQTT publish: topic 'zigbee2mqtt/Linky Meter', payload '{"ac_frequency":49.32,"current_A":0,"current_B":0.163,"current_a":0,"current_b":5.494,"device":{"applicationVersion":74,"dateCode":"","friendlyName":"Linky Meter","hardwareVersion":1,"ieeeAddr":"0xa4c1386d63db3f33","manufacturerID":4417,"manufacturerName":"_TZE204_81yrt3lo","model":"PJ-1203A","networkAddress":25019,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy_a":0,"energy_b":693.11,"energy_flow_b":"consuming","energy_forward_A":0,"energy_forward_B":0,"energy_produced_A":0,"energy_produced_B":0.98,"energy_produced_a":0,"energy_produced_b":50.79,"energy_reverse_A":0,"energy_reverse_B":0.01,"last_seen":"2023-09-20T11:35:03.722Z","linkquality":255,"power_a":0,"power_ab":282.4,"power_b":282.4,"power_direction B":1,"power_factor_A":1,"power_factor_B":0.77,"power_factor_a":1,"power_factor_b":0.21,"total_power_A":0,"total_power_AB":-29.9,"total_power_B":29.9,"update_frequency":10,"voltage":233.9}'
Zigbee2MQTT:info 2023-09-20 14:30:21: MQTT publish: topic 'zigbee2mqtt/Volet_Salon', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221205\u0000\u0000\u0000\u0000\u0000","friendlyName":"Volet_Salon","hardwareVersion":1,"ieeeAddr":"0x0004740000a40d58","manufacturerID":4129,"manufacturerName":" Legrand","model":"K4027C/L4027C/N4027C/NT4027C","networkAddress":11606,"powerSource":"Mains (single phase)","softwareBuildID":"0036","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2023-09-20T11:32:30.184Z","linkquality":255,"position":50,"state":"CLOSE","tilt":100,"update":{"installed_version":3556351,"latest_version":3555843,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2023-09-20 14:30:21: MQTT publish: topic 'zigbee2mqtt/Volet_Salle_Manger', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221202\u0000\u0000\u0000\u0000\u0000","friendlyName":"Volet_Salle_Manger","hardwareVersion":1,"ieeeAddr":"0x0004740000a40ce0","manufacturerID":4129,"manufacturerName":" Legrand","model":"K4027C/L4027C/N4027C/NT4027C","networkAddress":704,"powerSource":"Mains (single phase)","softwareBuildID":"0036","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2023-09-20T11:33:00.317Z","led_in_dark":"OFF","linkquality":232,"position":100,"state":"OPEN","tilt":100,"update":{"installed_version":3556351,"latest_version":3555843,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2023-09-20 14:30:21: MQTT publish: topic 'zigbee2mqtt/Volet_Porte_Cuisine', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020230209\u0000\u0000\u0000\u0000\u0000","friendlyName":"Volet_Porte_Cuisine","hardwareVersion":4,"ieeeAddr":"0x0004740000a42fe0","manufacturerID":4129,"manufacturerName":" Legrand","model":"K4027C/L4027C/N4027C/NT4027C","networkAddress":20855,"powerSource":"Mains (single phase)","softwareBuildID":"0036","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2023-09-20T11:32:53.128Z","led_in_dark":"OFF","linkquality":255,"position":100,"state":"OPEN","tilt":100,"update":{"installed_version":3556351,"latest_version":3555843,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2023-09-20 14:30:21: MQTT publish: topic 'zigbee2mqtt/Recharge_VE', payload '{"current":5.52,"device":{"applicationVersion":67,"dateCode":"","friendlyName":"Recharge_VE","hardwareVersion":1,"ieeeAddr":"0xe0798dfffe51d7cc","manufacturerID":4098,"manufacturerName":"_TZ3000_qeuvnohg","model":"TS011F_din_smart_relay_polling","networkAddress":32887,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":86.11,"indicator_mode":"on_off","last_seen":"2023-09-20T11:35:04.602Z","linkquality":255,"power":1243,"power_outage_memory":"off","state":"ON","update":{"state":"idle"},"update_available":false,"voltage":235}'
Zigbee2MQTT:info 2023-09-20 14:30:21: Zigbee2MQTT started!
Zigbee2MQTT:debug 2023-09-20 14:35:19: Saving state to file /var/www/html/plugins/z2m/data/state.json
