Voici le log zigbee_packages:
ERROR: Failed building wheel for cffi
Running setup.py clean for cffi
Failed to build cffi
Installing collected packages: wheel, typing-extensions, setuptools, semantic-version, pycparser, setuptools-rust, cffi
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
error: subprocess-exited-with-error
× Running setup.py install for cffi did not run successfully.
│ exit code: 1
╰─> [60 lines of output]
Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing `libffi.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libffi' found
/usr/local/lib/python3.7/dist-packages/setuptools/config/setupcfg.py:463: SetuptoolsDeprecationWarning: The license_file parameter is deprecated, use license_files instead.
warnings.warn(msg, warning_class)
running install
/usr/local/lib/python3.7/dist-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
setuptools.SetuptoolsDeprecationWarning,
running build
running build_py
creating build
creating build/lib.linux-armv7l-cpython-37
creating build/lib.linux-armv7l-cpython-37/cffi
copying cffi/api.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/recompiler.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/pkgconfig.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/error.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/ffiplatform.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/cparser.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/vengine_gen.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/commontypes.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/verifier.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/model.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/__init__.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/lock.py -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/_cffi_include.h -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/parse_c_type.h -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/_embedding.h -> build/lib.linux-armv7l-cpython-37/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-cpython-37/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-armv7l-cpython-37
creating build/temp.linux-armv7l-cpython-37/c
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -flto -fuse-linker-plugin -ffat-lto-objects -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python3.7m -c c/_cffi_backend.c -o build/temp.linux-armv7l-cpython-37/c/_cffi_backend.o
c/_cffi_backend.c:15:10: fatal error: ffi.h: No such file or directory
#include <ffi.h>
compilation terminated.
error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: legacy-install-failure
× Encountered error while trying to install package.
╰─> cffi
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure.
[end of output]
× pip subprocess to install build dependencies did not run successfully.
│ exit code: 1
╰─> See above for output.
+ echo 16
+ sudo pip3 install --force-reinstall --upgrade bellows==0.30.0
Collecting bellows==0.30.0
Using cached bellows-0.30.0-py3-none-any.whl (171 kB)
Collecting voluptuous
Using cached voluptuous-0.13.1-py3-none-any.whl (29 kB)
Collecting click-log>=0.2.1
Using cached click_log-0.4.0-py2.py3-none-any.whl (4.3 kB)
Collecting pyserial
Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
Collecting click
Using cached click-8.1.3-py3-none-any.whl (96 kB)
Collecting zigpy>=0.37.0
Using cached zigpy-0.47.0-py3-none-any.whl (150 kB)
Collecting pyserial-asyncio
Using cached pyserial_asyncio-0.6-py3-none-any.whl (7.6 kB)
Collecting pure-pcapy3==1.0.1
Using cached pure-pcapy3-1.0.1.tar.gz (5.9 kB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Collecting setuptools
Using cached setuptools-62.6.0-py3-none-any.whl (1.2 MB)
Collecting cryptography
Using cached cryptography-37.0.2.tar.gz (585 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'error'
│ exit code: 1
╰─> [166 lines of output]
Collecting setuptools!=60.9.0,>=40.6.0
Collecting wheel
Using cached wheel-0.37.1-py2.py3-none-any.whl (35 kB)
Collecting cffi>=1.12
Using cached cffi-1.15.0.tar.gz (484 kB)
Collecting setuptools-rust>=0.11.4
Using cached setuptools_rust-1.3.0-py3-none-any.whl (21 kB)
Collecting pycparser
Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
Collecting semantic-version<3,>=2.8.2
Using cached semantic_version-2.10.0-py2.py3-none-any.whl (15 kB)
Collecting typing-extensions>=3.7.4.3
Using cached typing_extensions-4.2.0-py3-none-any.whl (24 kB)
Building wheels for collected packages: cffi
Building wheel for cffi (setup.py): started
Building wheel for cffi (setup.py): finished with status 'error'
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [58 lines of output]
running bdist_wheel
running build
running build_py
creating build
running build_ext
#include <ffi.h>
[end of output]
│ exit code: 1
running install
running build
running build_py
creating build
running build_ext
#include <ffi.h>
[end of output]
╰─> cffi
[end of output]
│ exit code: 1
+ echo 17
+ sudo pip3 install --force-reinstall --upgrade zigpy==0.46.0
Collecting zigpy==0.46.0
Using cached zigpy-0.46.0-py3-none-any.whl (146 kB)
│ exit code: 1
Collecting wheel
│ exit code: 1
running bdist_wheel
running build
running build_py
creating build
running build_ext
#include <ffi.h>
[end of output]
│ exit code: 1
running install
running build
running build_py
creating build
running build_ext
#include <ffi.h>
[end of output]
╰─> cffi
[end of output]
│ exit code: 1
+ echo 18
+ sudo pip3 install --force-reinstall --upgrade xmodem
Collecting xmodem
Using cached xmodem-0.4.6-py3-none-any.whl
Installing collected packages: xmodem
Attempting uninstall: xmodem
Found existing installation: xmodem 0.4.6
Uninstalling xmodem-0.4.6:
Successfully uninstalled xmodem-0.4.6
Successfully installed xmodem-0.4.6
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 19
+ sudo pip3 install --force-reinstall --upgrade pycrypto
Collecting pycrypto
Using cached pycrypto-2.6.1-cp37-cp37m-linux_armv7l.whl
Installing collected packages: pycrypto
Attempting uninstall: pycrypto
Found existing installation: pycrypto 2.6.1
Uninstalling pycrypto-2.6.1:
Successfully uninstalled pycrypto-2.6.1
Successfully installed pycrypto-2.6.1
+ echo 20
+ sudo pip3 install --force-reinstall --upgrade charset-normalizer==2.0.12
Collecting charset-normalizer==2.0.12
Using cached charset_normalizer-2.0.12-py3-none-any.whl (39 kB)
Installing collected packages: charset-normalizer
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 2.0.12
Uninstalling charset-normalizer-2.0.12:
Successfully uninstalled charset-normalizer-2.0.12
Successfully installed charset-normalizer-2.0.12
+ echo 21
+ sudo chmod +x /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
Launch post-install of zigbee dependancy
+ echo 22
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end zigbee
+ rm /tmp/jeedom_install_in_progress_zigbee
