Sur une installation toute fraiche du plugin Xiaomi sur une jeedom a jour en 3.3.45. Sur une Smart.
D’abort un problème sur installation des dépendance (daemon qui ne voulait pas demarer)
reinstallation, puis redemarage,
Daemon ok
Plugin Xiaomi demare enfin!
mais rien y fait impossible de commander mon Roborock
(supressionn du robot, redemarage, remise en place du robot)
Impossible de commander mon roborock.vacuum.s5
j’ai recupéré le token via la methode « iphone »
Et vérifier avec la methode « apk modifié »
Ci joint un log.
Des avis?
[2020-04-10 00:16:12][DEBUG] : execute : action wifi start
[2020-04-09 22:16:12][DEBUG] : Client connected to [127.0.0.1:44656]
[2020-04-09 22:16:12][DEBUG] : Message read from socket: {"apikey":"pPh82pe0pxjqXXXXXXXXXXXXXXXXXXXX","type":"wifi","cmd":"send","model":"vacuum2","dest":"","token":"524a44715577XXXXXXXXXXXXXXXXXXXX","devtype":"","serial":"","method":"app_start","param":""}
[2020-04-09 22:16:12][DEBUG] : Client disconnected from [127.0.0.1:44656]
[2020-04-09 22:16:12][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-04-09 22:16:12][DEBUG] : Received command from jeedom : send
[2020-04-09 22:16:12][DEBUG] : Executing action on : vacuum2
[2020-04-09 22:16:17][DEBUG] : Timeout
[2020-04-09 22:16:17][DEBUG] : local variable 'd' referenced before assignment
[2020-04-10 00:20:08][DEBUG] : Rafraîchissement de XiaomiWifi : Aspirateur RDC
[2020-04-09 22:20:08][DEBUG] : Client connected to [127.0.0.1:44995]
[2020-04-09 22:20:08][DEBUG] : Message read from socket: {"apikey":"pPh82pe0pxjqXXXXXXXXXXXXXXXXXXXX","type":"wifi","cmd":"refresh","model":"vacuum2","dest":"","token":"524a44715577XXXXXXXXXXXXXXXXXXXX","devtype":"","serial":""}
[2020-04-09 22:20:08][DEBUG] : Client disconnected from [127.0.0.1:44995]
[2020-04-09 22:20:08][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-04-09 22:20:08][DEBUG] : Received command from jeedom : refresh
[2020-04-09 22:20:08][DEBUG] : Refreshing : vacuum2
[2020-04-09 22:20:13][DEBUG] : Timeout
[2020-04-09 22:20:15][ERROR] : Exception on socket : local variable 'd' referenced before assignment
[2020-04-10 00:27:09][DEBUG] : Rafraîchissement de XiaomiWifi : Aspirateur RDC
[2020-04-09 22:27:09][DEBUG] : Client connected to [127.0.0.1:46417]
[2020-04-09 22:27:09][DEBUG] : Message read from socket: {"apikey":"pPh82pe0pxjqXXXXXXXXXXXXXXXXXXXX","type":"wifi","cmd":"refresh","model":"vacuum2","dest":"","token":"524a44715577XXXXXXXXXXXXXXXXXXXX","devtype":"","serial":""}
[2020-04-09 22:27:09][DEBUG] : Client disconnected from [127.0.0.1:46417]
[2020-04-09 22:27:09][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-04-09 22:27:09][DEBUG] : Received command from jeedom : refresh
[2020-04-09 22:27:09][DEBUG] : Refreshing : vacuum2
[2020-04-09 22:27:14][DEBUG] : Timeout
[2020-04-09 22:27:14][ERROR] : Exception on socket : local variable 'd' referenced before assignment
[2020-04-10 00:28:34][DEBUG] : execute : action wifi start
[2020-04-09 22:28:34][DEBUG] : Client connected to [127.0.0.1:46525]
[2020-04-09 22:28:34][DEBUG] : Message read from socket: {"apikey":"pPh82pe0pxjqXXXXXXXXXXXXXXXXXXXX","type":"wifi","cmd":"send","model":"vacuum2","dest":"","token":"524a44715577XXXXXXXXXXXXXXXXXXXX","devtype":"","serial":"","method":"app_start","param":""}
[2020-04-09 22:28:34][DEBUG] : Client disconnected from [127.0.0.1:46525]
[2020-04-09 22:28:34][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-04-09 22:28:34][DEBUG] : Received command from jeedom : send
[2020-04-09 22:28:34][DEBUG] : Executing action on : vacuum2
[2020-04-10 00:28:38][DEBUG] : execute : action wifi refresh
[2020-04-09 22:28:38][DEBUG] : Client connected to [127.0.0.1:46530]
[2020-04-09 22:28:38][DEBUG] : Message read from socket: {"apikey":"pPh82pe0pxjqXXXXXXXXXXXXXXXXXXXX","type":"wifi","cmd":"refresh","model":"vacuum2","dest":"","token":"524a44715577XXXXXXXXXXXXXXXXXXXX","devtype":"","serial":""}
[2020-04-09 22:28:38][DEBUG] : Client disconnected from [127.0.0.1:46530]
[2020-04-09 22:28:39][DEBUG] : Timeout
[2020-04-09 22:28:39][DEBUG] : local variable 'd' referenced before assignment
[2020-04-09 22:28:39][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-04-09 22:28:39][DEBUG] : Received command from jeedom : refresh
[2020-04-09 22:28:39][DEBUG] : Refreshing : vacuum2
[2020-04-09 22:28:44][DEBUG] : Timeout
[2020-04-09 22:28:44][ERROR] : Exception on socket : local variable 'd' referenced before assignment
[2020-04-10 00:31:02][DEBUG] : execute : action wifi start
[2020-04-10 00:31:15][INFO] : Lancement démon xiaomihome : /usr/bin/python /var/www/html/plugins/xiaomihome/resources/xiaomihomed/xiaomihomed.py --loglevel debug --socketport 55019 --callback http://192.168.1.200:80/plugins/xiaomihome/core/php/jeeXiaomiHome.php --apikey pPh82pe0pxjqXXXXXXXXXXXXXXXXXXXX --cycle 0.05 --pid /tmp/jeedom/xiaomihome/deamon.pid
[2020-04-09 22:31:17][INFO] : Start xiaomihomed
[2020-04-09 22:31:17][INFO] : Log level : debug
[2020-04-09 22:31:17][INFO] : Socket port : 55019
[2020-04-09 22:31:17][INFO] : Socket host : 127.0.0.1
[2020-04-09 22:31:17][INFO] : PID file : /tmp/jeedom/xiaomihome/deamon.pid
[2020-04-09 22:31:17][INFO] : Apikey : pPh82pe0pxjqXXXXXXXXXXXXXXXXXXXX
[2020-04-09 22:31:17][INFO] : Callback : http://192.168.1.200:80/plugins/xiaomihome/core/php/jeeXiaomiHome.php
[2020-04-09 22:31:17][INFO] : Cycle : 0.05
[2020-04-09 22:31:17][DEBUG] : Writing PID 2416 to /tmp/jeedom/xiaomihome/deamon.pid
[2020-04-09 22:31:17][DEBUG] : Init request module v2.23.0
[2020-04-09 22:31:17][DEBUG] : Starting new HTTP connection (1): 192.168.1.200:80
[2020-04-10 00:31:17][DEBUG] : Format Invalide
[2020-04-09 22:31:17][DEBUG] : http://192.168.1.200:80 "GET /plugins/xiaomihome/core/php/jeeXiaomiHome.php?apikey=pPh82pe0pxjqXXXXXXXXXXXXXXXXXXXX HTTP/1.1" 200 0
[2020-04-09 22:31:17][DEBUG] : Socket interface started
[2020-04-09 22:31:17][DEBUG] : LoopNetServer Thread started
[2020-04-09 22:31:17][DEBUG] : Listening on: [127.0.0.1:55019]
[2020-04-09 22:31:17][INFO] : Start listening...
[2020-04-09 22:31:17][DEBUG] : Read Socket Thread Launched
[2020-04-09 22:31:17][DEBUG] : Aquara Thread Launched
