Salut, tout ce que j’ai, c’est ce que j’utilise toujours sur une Jeedom v3.
Je te colle les sources, au cas où.
<div style="min-width:90px;min-height:60px;margin-right: 5px;margin-left: 5px;padding:0px !important;" class="cmd #history# container-fluid tooltips cmd cmd-widget circle#id#" data-type="info" data-subtype="numeric" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#">
<center>
<div class="cmdName" style="font-weight: bold;font-size: 12px;#hideCmdName#">#name_display#</div>
<div class="iconCmd#id# c100" style="margin:0; float:none;">
<span id="circlevalue#id#">#state# #unite#</span>
<div class="slice">
<div class="bar"></div>
<div class="fill"></div>
</div>
</div>
<div class="cmdStats #hide_history# history#id# col-xs-12 center-block" style="font-size: 11px;#displayHistory#">
<span title='Min' class='tooltips'>#minHistoryValue##unite#</span>|
<span title='Moyenne' class='tooltips'>#averageHistoryValue##unite#</span>|
<span title='Max' class='tooltips'>#maxHistoryValue##unite# </span><i class="#tendance#"></i>
</div>
</center>
<script>
jeedom.cmd.update['#id#'] = function(_options) {
var param_temp_froid = (is_numeric('#param_temp_froid#')) ? parseFloat('#param_temp_froid#') : '18.0';
var param_temp_chaud = (is_numeric('#param_temp_chaud#')) ? parseFloat('#param_temp_chaud#') : '22.0';
var param_temp_mini = (is_numeric('#param_temp_mini#')) ? parseFloat('#param_temp_mini#') : '00.0';
var param_temp_maxi = (is_numeric('#param_temp_maxi#')) ? parseFloat('#param_temp_maxi#') : '30.0';
var valeur = _options.display_value;
var pourcent = Math.round((valeur - param_temp_mini) / (param_temp_maxi - param_temp_mini) * 100);
if (pourcent < 0) pourcent = 0;
if (pourcent > 100) pourcent = 100;
$('.iconCmd#id#').removeClass (function (index, className) {
return (className.match (/(^|\s)p\d+/g) || []).join(' ');
$('.iconCmd#id#').removeClass('blue green orange');
$('#circlevalue#id#').html(valeur + ' #unite#');
$('.iconCmd#id#').addClass('p'+pourcent);
if (valeur < param_temp_froid) {
$('.iconCmd#id#').addClass('blue');
else if (valeur > param_temp_chaud) {
$('.iconCmd#id#').addClass('orange');
else {
$('.iconCmd#id#').addClass('green');
$("div.iconCmd#id#").attr('title', _options.collectDate);
$.include(['plugins/widget/core/template/dashboard/cmd.info.numeric.Temperature_Circle/circle.css'], function() {
var param_theme = ('#param_theme#' == 'dark') ? '#param_theme#' : '';
var param_taille = ('#param_taille#' == 'small' || '#param_taille#' == 'big') ? '#param_taille#' : '';
$('.iconCmd#id#').addClass(param_theme);
$('.iconCmd#id#').addClass(param_taille);
jeedom.cmd.update['#id#']({display_value:'#state#',valueDate:'#valueDate#',collectDate:'#collectDate#'});
</script>
</div>
.rect-auto,
.c100.p51 .slice,
.c100.p52 .slice,
.c100.p53 .slice,
.c100.p54 .slice,
.c100.p55 .slice,
.c100.p56 .slice,
.c100.p57 .slice,
.c100.p58 .slice,
.c100.p59 .slice,
.c100.p60 .slice,
.c100.p61 .slice,
.c100.p62 .slice,
.c100.p63 .slice,
.c100.p64 .slice,
.c100.p65 .slice,
.c100.p66 .slice,
.c100.p67 .slice,
.c100.p68 .slice,
.c100.p69 .slice,
.c100.p70 .slice,
.c100.p71 .slice,
.c100.p72 .slice,
.c100.p73 .slice,
.c100.p74 .slice,
.c100.p75 .slice,
.c100.p76 .slice,
.c100.p77 .slice,
.c100.p78 .slice,
.c100.p79 .slice,
.c100.p80 .slice,
.c100.p81 .slice,
.c100.p82 .slice,
.c100.p83 .slice,
.c100.p84 .slice,
.c100.p85 .slice,
.c100.p86 .slice,
.c100.p87 .slice,
.c100.p88 .slice,
.c100.p89 .slice,
.c100.p90 .slice,
.c100.p91 .slice,
.c100.p92 .slice,
.c100.p93 .slice,
.c100.p94 .slice,
.c100.p95 .slice,
.c100.p96 .slice,
.c100.p97 .slice,
.c100.p98 .slice,
.c100.p99 .slice,
.c100.p100 .slice {
clip: rect(auto, auto, auto, auto);
.pie,
.c100 .bar,
.c100.p51 .fill,
.c100.p52 .fill,
.c100.p53 .fill,
.c100.p54 .fill,
.c100.p55 .fill,
.c100.p56 .fill,
.c100.p57 .fill,
.c100.p58 .fill,
.c100.p59 .fill,
.c100.p60 .fill,
.c100.p61 .fill,
.c100.p62 .fill,
.c100.p63 .fill,
.c100.p64 .fill,
.c100.p65 .fill,
.c100.p66 .fill,
.c100.p67 .fill,
.c100.p68 .fill,
.c100.p69 .fill,
.c100.p70 .fill,
.c100.p71 .fill,
.c100.p72 .fill,
.c100.p73 .fill,
.c100.p74 .fill,
.c100.p75 .fill,
.c100.p76 .fill,
.c100.p77 .fill,
.c100.p78 .fill,
.c100.p79 .fill,
.c100.p80 .fill,
.c100.p81 .fill,
.c100.p82 .fill,
.c100.p83 .fill,
.c100.p84 .fill,
.c100.p85 .fill,
.c100.p86 .fill,
.c100.p87 .fill,
.c100.p88 .fill,
.c100.p89 .fill,
.c100.p90 .fill,
.c100.p91 .fill,
.c100.p92 .fill,
.c100.p93 .fill,
.c100.p94 .fill,
.c100.p95 .fill,
.c100.p96 .fill,
.c100.p97 .fill,
.c100.p98 .fill,
.c100.p99 .fill,
.c100.p100 .fill {
position: absolute;
border: 0.08em solid #307bbb;
width: 0.84em;
height: 0.84em;
clip: rect(0em, 0.5em, 1em, 0em);
border-radius: 50%;
-webkit-transform: rotate(0deg);
-moz-transform: rotate(0deg);
-ms-transform: rotate(0deg);
-o-transform: rotate(0deg);
.pie-fill,
.c100.p51 .bar:after,
.c100.p51 .fill,
.c100.p52 .bar:after,
.c100.p52 .fill,
.c100.p53 .bar:after,
.c100.p53 .fill,
.c100.p54 .bar:after,
.c100.p54 .fill,
.c100.p55 .bar:after,
.c100.p55 .fill,
.c100.p56 .bar:after,
.c100.p56 .fill,
.c100.p57 .bar:after,
.c100.p57 .fill,
.c100.p58 .bar:after,
.c100.p58 .fill,
.c100.p59 .bar:after,
.c100.p59 .fill,
.c100.p60 .bar:after,
.c100.p60 .fill,
.c100.p61 .bar:after,
.c100.p61 .fill,
.c100.p62 .bar:after,
.c100.p62 .fill,
.c100.p63 .bar:after,
.c100.p63 .fill,
.c100.p64 .bar:after,
.c100.p64 .fill,
.c100.p65 .bar:after,
.c100.p65 .fill,
.c100.p66 .bar:after,
.c100.p66 .fill,
.c100.p67 .bar:after,
.c100.p67 .fill,
.c100.p68 .bar:after,
.c100.p68 .fill,
.c100.p69 .bar:after,
.c100.p69 .fill,
.c100.p70 .bar:after,
.c100.p70 .fill,
.c100.p71 .bar:after,
.c100.p71 .fill,
.c100.p72 .bar:after,
.c100.p72 .fill,
.c100.p73 .bar:after,
.c100.p73 .fill,
.c100.p74 .bar:after,
.c100.p74 .fill,
.c100.p75 .bar:after,
.c100.p75 .fill,
.c100.p76 .bar:after,
.c100.p76 .fill,
.c100.p77 .bar:after,
.c100.p77 .fill,
.c100.p78 .bar:after,
.c100.p78 .fill,
.c100.p79 .bar:after,
.c100.p79 .fill,
.c100.p80 .bar:after,
.c100.p80 .fill,
.c100.p81 .bar:after,
.c100.p81 .fill,
.c100.p82 .bar:after,
.c100.p82 .fill,
.c100.p83 .bar:after,
.c100.p83 .fill,
.c100.p84 .bar:after,
.c100.p84 .fill,
.c100.p85 .bar:after,
.c100.p85 .fill,
.c100.p86 .bar:after,
.c100.p86 .fill,
.c100.p87 .bar:after,
.c100.p87 .fill,
.c100.p88 .bar:after,
.c100.p88 .fill,
.c100.p89 .bar:after,
.c100.p89 .fill,
.c100.p90 .bar:after,
.c100.p90 .fill,
.c100.p91 .bar:after,
.c100.p91 .fill,
.c100.p92 .bar:after,
.c100.p92 .fill,
.c100.p93 .bar:after,
.c100.p93 .fill,
.c100.p94 .bar:after,
.c100.p94 .fill,
.c100.p95 .bar:after,
.c100.p95 .fill,
.c100.p96 .bar:after,
.c100.p96 .fill,
.c100.p97 .bar:after,
.c100.p97 .fill,
.c100.p98 .bar:after,
.c100.p98 .fill,
.c100.p99 .bar:after,
.c100.p99 .fill,
.c100.p100 .bar:after,
.c100.p100 .fill {
-webkit-transform: rotate(180deg);
-moz-transform: rotate(180deg);
-ms-transform: rotate(180deg);
-o-transform: rotate(180deg);
.c100 {
position: relative;
font-size: 120px;
width: 1em;
height: 1em;
border-radius: 50%;
float: left;
margin: 0 0.1em 0.1em 0;
background-color: #cccccc;
.c100 *,
.c100 *:before,
.c100 *:after {
-webkit-box-sizing: content-box;
-moz-box-sizing: content-box;
.c100.center {
float: none;
margin: 0 auto;
.c100.big {
font-size: 240px;
.c100.small {
font-size: 80px;
.c100 > span {
position: absolute;
width: 100%;
z-index: 1;
left: 0;
top: 0;
width: 5em;
line-height: 5em;
font-size: 0.2em;
color: #cccccc;
display: block;
text-align: center;
white-space: nowrap;
-webkit-transition-property: all;
-moz-transition-property: all;
-o-transition-property: all;
-webkit-transition-duration: 0.2s;
-moz-transition-duration: 0.2s;
-o-transition-duration: 0.2s;
-webkit-transition-timing-function: ease-out;
-moz-transition-timing-function: ease-out;
-o-transition-timing-function: ease-out;
.c100:after {
position: absolute;
top: 0.08em;
left: 0.08em;
display: block;
content: " ";
border-radius: 50%;
background-color: #f5f5f5;
width: 0.84em;
height: 0.84em;
-webkit-transition-timing-function: ease-in;
-moz-transition-timing-function: ease-in;
-o-transition-timing-function: ease-in;
.c100 .slice {
position: absolute;
width: 1em;
height: 1em;
clip: rect(0em, 1em, 1em, 0.5em);
.c100.p1 .bar {
-webkit-transform: rotate(3.6deg);
-moz-transform: rotate(3.6deg);
-ms-transform: rotate(3.6deg);
-o-transform: rotate(3.6deg);
.c100.p2 .bar {
-webkit-transform: rotate(7.2deg);
-moz-transform: rotate(7.2deg);
-ms-transform: rotate(7.2deg);
-o-transform: rotate(7.2deg);
.c100.p3 .bar {
-webkit-transform: rotate(10.8deg);
-moz-transform: rotate(10.8deg);
-ms-transform: rotate(10.8deg);
-o-transform: rotate(10.8deg);
.c100.p4 .bar {
-webkit-transform: rotate(14.4deg);
-moz-transform: rotate(14.4deg);
-ms-transform: rotate(14.4deg);
-o-transform: rotate(14.4deg);
.c100.p5 .bar {
-webkit-transform: rotate(18deg);
-moz-transform: rotate(18deg);
-ms-transform: rotate(18deg);
-o-transform: rotate(18deg);
.c100.p6 .bar {
-webkit-transform: rotate(21.6deg);
-moz-transform: rotate(21.6deg);
-ms-transform: rotate(21.6deg);
-o-transform: rotate(21.6deg);
.c100.p7 .bar {
-webkit-transform: rotate(25.2deg);
-moz-transform: rotate(25.2deg);
-ms-transform: rotate(25.2deg);
-o-transform: rotate(25.2deg);
.c100.p8 .bar {
-webkit-transform: rotate(28.8deg);
-moz-transform: rotate(28.8deg);
-ms-transform: rotate(28.8deg);
-o-transform: rotate(28.8deg);
.c100.p9 .bar {
-webkit-transform: rotate(32.4deg);
-moz-transform: rotate(32.4deg);
-ms-transform: rotate(32.4deg);
-o-transform: rotate(32.4deg);
.c100.p10 .bar {
-webkit-transform: rotate(36deg);
-moz-transform: rotate(36deg);
-ms-transform: rotate(36deg);
-o-transform: rotate(36deg);
.c100.p11 .bar {
-webkit-transform: rotate(39.6deg);
-moz-transform: rotate(39.6deg);
-ms-transform: rotate(39.6deg);
-o-transform: rotate(39.6deg);
.c100.p12 .bar {
-webkit-transform: rotate(43.2deg);
-moz-transform: rotate(43.2deg);
-ms-transform: rotate(43.2deg);
-o-transform: rotate(43.2deg);
.c100.p13 .bar {
-webkit-transform: rotate(46.800000000000004deg);
-moz-transform: rotate(46.800000000000004deg);
-ms-transform: rotate(46.800000000000004deg);
-o-transform: rotate(46.800000000000004deg);
.c100.p14 .bar {
-webkit-transform: rotate(50.4deg);
-moz-transform: rotate(50.4deg);
-ms-transform: rotate(50.4deg);
-o-transform: rotate(50.4deg);
.c100.p15 .bar {
-webkit-transform: rotate(54deg);
-moz-transform: rotate(54deg);
-ms-transform: rotate(54deg);
-o-transform: rotate(54deg);
.c100.p16 .bar {
-webkit-transform: rotate(57.6deg);
-moz-transform: rotate(57.6deg);
-ms-transform: rotate(57.6deg);
-o-transform: rotate(57.6deg);
.c100.p17 .bar {
-webkit-transform: rotate(61.2deg);
-moz-transform: rotate(61.2deg);
-ms-transform: rotate(61.2deg);
-o-transform: rotate(61.2deg);
.c100.p18 .bar {
-webkit-transform: rotate(64.8deg);
-moz-transform: rotate(64.8deg);
-ms-transform: rotate(64.8deg);
-o-transform: rotate(64.8deg);
.c100.p19 .bar {
-webkit-transform: rotate(68.4deg);
-moz-transform: rotate(68.4deg);
-ms-transform: rotate(68.4deg);
-o-transform: rotate(68.4deg);
.c100.p20 .bar {
-webkit-transform: rotate(72deg);
-moz-transform: rotate(72deg);
-ms-transform: rotate(72deg);
-o-transform: rotate(72deg);
.c100.p21 .bar {
-webkit-transform: rotate(75.60000000000001deg);
-moz-transform: rotate(75.60000000000001deg);
-ms-transform: rotate(75.60000000000001deg);
-o-transform: rotate(75.60000000000001deg);
.c100.p22 .bar {
-webkit-transform: rotate(79.2deg);
-moz-transform: rotate(79.2deg);
-ms-transform: rotate(79.2deg);
-o-transform: rotate(79.2deg);
.c100.p23 .bar {
-webkit-transform: rotate(82.8deg);
-moz-transform: rotate(82.8deg);
-ms-transform: rotate(82.8deg);
-o-transform: rotate(82.8deg);
.c100.p24 .bar {
-webkit-transform: rotate(86.4deg);
-moz-transform: rotate(86.4deg);
-ms-transform: rotate(86.4deg);
-o-transform: rotate(86.4deg);
.c100.p25 .bar {
-webkit-transform: rotate(90deg);
-moz-transform: rotate(90deg);
-ms-transform: rotate(90deg);
-o-transform: rotate(90deg);
.c100.p26 .bar {
-webkit-transform: rotate(93.60000000000001deg);
-moz-transform: rotate(93.60000000000001deg);
-ms-transform: rotate(93.60000000000001deg);
-o-transform: rotate(93.60000000000001deg);
.c100.p27 .bar {
-webkit-transform: rotate(97.2deg);
-moz-transform: rotate(97.2deg);
-ms-transform: rotate(97.2deg);
-o-transform: rotate(97.2deg);
.c100.p28 .bar {
-webkit-transform: rotate(100.8deg);
-moz-transform: rotate(100.8deg);
-ms-transform: rotate(100.8deg);
-o-transform: rotate(100.8deg);
.c100.p29 .bar {
-webkit-transform: rotate(104.4deg);
-moz-transform: rotate(104.4deg);
-ms-transform: rotate(104.4deg);
-o-transform: rotate(104.4deg);
.c100.p30 .bar {
-webkit-transform: rotate(108deg);
-moz-transform: rotate(108deg);
-ms-transform: rotate(108deg);
-o-transform: rotate(108deg);
.c100.p31 .bar {
-webkit-transform: rotate(111.60000000000001deg);
-moz-transform: rotate(111.60000000000001deg);
-ms-transform: rotate(111.60000000000001deg);
-o-transform: rotate(111.60000000000001deg);
.c100.p32 .bar {
-webkit-transform: rotate(115.2deg);
-moz-transform: rotate(115.2deg);
-ms-transform: rotate(115.2deg);
-o-transform: rotate(115.2deg);
.c100.p33 .bar {
-webkit-transform: rotate(118.8deg);
-moz-transform: rotate(118.8deg);
-ms-transform: rotate(118.8deg);
-o-transform: rotate(118.8deg);
.c100.p34 .bar {
-webkit-transform: rotate(122.4deg);
-moz-transform: rotate(122.4deg);
-ms-transform: rotate(122.4deg);
-o-transform: rotate(122.4deg);
.c100.p35 .bar {
-webkit-transform: rotate(126deg);
-moz-transform: rotate(126deg);
-ms-transform: rotate(126deg);
-o-transform: rotate(126deg);
.c100.p36 .bar {
-webkit-transform: rotate(129.6deg);
-moz-transform: rotate(129.6deg);
-ms-transform: rotate(129.6deg);
-o-transform: rotate(129.6deg);
.c100.p37 .bar {
-webkit-transform: rotate(133.20000000000002deg);
-moz-transform: rotate(133.20000000000002deg);
-ms-transform: rotate(133.20000000000002deg);
-o-transform: rotate(133.20000000000002deg);
.c100.p38 .bar {
-webkit-transform: rotate(136.8deg);
-moz-transform: rotate(136.8deg);
-ms-transform: rotate(136.8deg);
-o-transform: rotate(136.8deg);
.c100.p39 .bar {
-webkit-transform: rotate(140.4deg);
-moz-transform: rotate(140.4deg);
-ms-transform: rotate(140.4deg);
-o-transform: rotate(140.4deg);
.c100.p40 .bar {
-webkit-transform: rotate(144deg);
-moz-transform: rotate(144deg);
-ms-transform: rotate(144deg);
-o-transform: rotate(144deg);
.c100.p41 .bar {
-webkit-transform: rotate(147.6deg);
-moz-transform: rotate(147.6deg);
-ms-transform: rotate(147.6deg);
-o-transform: rotate(147.6deg);
.c100.p42 .bar {
-webkit-transform: rotate(151.20000000000002deg);
-moz-transform: rotate(151.20000000000002deg);
-ms-transform: rotate(151.20000000000002deg);
-o-transform: rotate(151.20000000000002deg);
.c100.p43 .bar {
-webkit-transform: rotate(154.8deg);
-moz-transform: rotate(154.8deg);
-ms-transform: rotate(154.8deg);
-o-transform: rotate(154.8deg);
.c100.p44 .bar {
-webkit-transform: rotate(158.4deg);
-moz-transform: rotate(158.4deg);
-ms-transform: rotate(158.4deg);
-o-transform: rotate(158.4deg);
.c100.p45 .bar {
-webkit-transform: rotate(162deg);
-moz-transform: rotate(162deg);
-ms-transform: rotate(162deg);
-o-transform: rotate(162deg);
.c100.p46 .bar {
-webkit-transform: rotate(165.6deg);
-moz-transform: rotate(165.6deg);
-ms-transform: rotate(165.6deg);
-o-transform: rotate(165.6deg);
.c100.p47 .bar {
-webkit-transform: rotate(169.20000000000002deg);
-moz-transform: rotate(169.20000000000002deg);
-ms-transform: rotate(169.20000000000002deg);
-o-transform: rotate(169.20000000000002deg);
.c100.p48 .bar {
-webkit-transform: rotate(172.8deg);
-moz-transform: rotate(172.8deg);
-ms-transform: rotate(172.8deg);
-o-transform: rotate(172.8deg);
.c100.p49 .bar {
-webkit-transform: rotate(176.4deg);
-moz-transform: rotate(176.4deg);
-ms-transform: rotate(176.4deg);
-o-transform: rotate(176.4deg);
.c100.p50 .bar {
.c100.p51 .bar {
-webkit-transform: rotate(183.6deg);
-moz-transform: rotate(183.6deg);
-ms-transform: rotate(183.6deg);
-o-transform: rotate(183.6deg);
.c100.p52 .bar {
-webkit-transform: rotate(187.20000000000002deg);
-moz-transform: rotate(187.20000000000002deg);
-ms-transform: rotate(187.20000000000002deg);
-o-transform: rotate(187.20000000000002deg);
.c100.p53 .bar {
-webkit-transform: rotate(190.8deg);
-moz-transform: rotate(190.8deg);
-ms-transform: rotate(190.8deg);
-o-transform: rotate(190.8deg);
.c100.p54 .bar {
-webkit-transform: rotate(194.4deg);
-moz-transform: rotate(194.4deg);
-ms-transform: rotate(194.4deg);
-o-transform: rotate(194.4deg);
.c100.p55 .bar {
-webkit-transform: rotate(198deg);
-moz-transform: rotate(198deg);
-ms-transform: rotate(198deg);
-o-transform: rotate(198deg);
.c100.p56 .bar {
-webkit-transform: rotate(201.6deg);
-moz-transform: rotate(201.6deg);
-ms-transform: rotate(201.6deg);
-o-transform: rotate(201.6deg);
.c100.p57 .bar {
-webkit-transform: rotate(205.20000000000002deg);
-moz-transform: rotate(205.20000000000002deg);
-ms-transform: rotate(205.20000000000002deg);
-o-transform: rotate(205.20000000000002deg);
.c100.p58 .bar {
-webkit-transform: rotate(208.8deg);
-moz-transform: rotate(208.8deg);
-ms-transform: rotate(208.8deg);
-o-transform: rotate(208.8deg);
.c100.p59 .bar {
-webkit-transform: rotate(212.4deg);
-moz-transform: rotate(212.4deg);
-ms-transform: rotate(212.4deg);
-o-transform: rotate(212.4deg);
.c100.p60 .bar {
-webkit-transform: rotate(216deg);
-moz-transform: rotate(216deg);
-ms-transform: rotate(216deg);
-o-transform: rotate(216deg);
.c100.p61 .bar {
-webkit-transform: rotate(219.6deg);
-moz-transform: rotate(219.6deg);
-ms-transform: rotate(219.6deg);
-o-transform: rotate(219.6deg);
.c100.p62 .bar {
-webkit-transform: rotate(223.20000000000002deg);
-moz-transform: rotate(223.20000000000002deg);
-ms-transform: rotate(223.20000000000002deg);
-o-transform: rotate(223.20000000000002deg);
.c100.p63 .bar {
-webkit-transform: rotate(226.8deg);
-moz-transform: rotate(226.8deg);
-ms-transform: rotate(226.8deg);
-o-transform: rotate(226.8deg);
.c100.p64 .bar {
-webkit-transform: rotate(230.4deg);
-moz-transform: rotate(230.4deg);
-ms-transform: rotate(230.4deg);
-o-transform: rotate(230.4deg);
.c100.p65 .bar {
-webkit-transform: rotate(234deg);
-moz-transform: rotate(234deg);
-ms-transform: rotate(234deg);
-o-transform: rotate(234deg);
.c100.p66 .bar {
-webkit-transform: rotate(237.6deg);
-moz-transform: rotate(237.6deg);
-ms-transform: rotate(237.6deg);
-o-transform: rotate(237.6deg);
.c100.p67 .bar {
-webkit-transform: rotate(241.20000000000002deg);
-moz-transform: rotate(241.20000000000002deg);
-ms-transform: rotate(241.20000000000002deg);
-o-transform: rotate(241.20000000000002deg);
.c100.p68 .bar {
-webkit-transform: rotate(244.8deg);
-moz-transform: rotate(244.8deg);
-ms-transform: rotate(244.8deg);
-o-transform: rotate(244.8deg);
.c100.p69 .bar {
-webkit-transform: rotate(248.4deg);
-moz-transform: rotate(248.4deg);
-ms-transform: rotate(248.4deg);
-o-transform: rotate(248.4deg);
.c100.p70 .bar {
-webkit-transform: rotate(252deg);
-moz-transform: rotate(252deg);
-ms-transform: rotate(252deg);
-o-transform: rotate(252deg);
.c100.p71 .bar {
-webkit-transform: rotate(255.6deg);
-moz-transform: rotate(255.6deg);
-ms-transform: rotate(255.6deg);
-o-transform: rotate(255.6deg);
.c100.p72 .bar {
-webkit-transform: rotate(259.2deg);
-moz-transform: rotate(259.2deg);
-ms-transform: rotate(259.2deg);
-o-transform: rotate(259.2deg);
.c100.p73 .bar {
-webkit-transform: rotate(262.8deg);
-moz-transform: rotate(262.8deg);
-ms-transform: rotate(262.8deg);
-o-transform: rotate(262.8deg);
.c100.p74 .bar {
-webkit-transform: rotate(266.40000000000003deg);
-moz-transform: rotate(266.40000000000003deg);
-ms-transform: rotate(266.40000000000003deg);
-o-transform: rotate(266.40000000000003deg);
.c100.p75 .bar {
-webkit-transform: rotate(270deg);
-moz-transform: rotate(270deg);
-ms-transform: rotate(270deg);
-o-transform: rotate(270deg);
.c100.p76 .bar {
-webkit-transform: rotate(273.6deg);
-moz-transform: rotate(273.6deg);
-ms-transform: rotate(273.6deg);
-o-transform: rotate(273.6deg);
.c100.p77 .bar {
-webkit-transform: rotate(277.2deg);
-moz-transform: rotate(277.2deg);
-ms-transform: rotate(277.2deg);
-o-transform: rotate(277.2deg);
.c100.p78 .bar {
-webkit-transform: rotate(280.8deg);
-moz-transform: rotate(280.8deg);
-ms-transform: rotate(280.8deg);
-o-transform: rotate(280.8deg);
.c100.p79 .bar {
-webkit-transform: rotate(284.40000000000003deg);
-moz-transform: rotate(284.40000000000003deg);
-ms-transform: rotate(284.40000000000003deg);
-o-transform: rotate(284.40000000000003deg);
.c100.p80 .bar {
-webkit-transform: rotate(288deg);
-moz-transform: rotate(288deg);
-ms-transform: rotate(288deg);
-o-transform: rotate(288deg);
.c100.p81 .bar {
-webkit-transform: rotate(291.6deg);
-moz-transform: rotate(291.6deg);
-ms-transform: rotate(291.6deg);
-o-transform: rotate(291.6deg);
.c100.p82 .bar {
-webkit-transform: rotate(295.2deg);
-moz-transform: rotate(295.2deg);
-ms-transform: rotate(295.2deg);
-o-transform: rotate(295.2deg);
.c100.p83 .bar {
-webkit-transform: rotate(298.8deg);
-moz-transform: rotate(298.8deg);
-ms-transform: rotate(298.8deg);
-o-transform: rotate(298.8deg);
.c100.p84 .bar {
-webkit-transform: rotate(302.40000000000003deg);
-moz-transform: rotate(302.40000000000003deg);
-ms-transform: rotate(302.40000000000003deg);
-o-transform: rotate(302.40000000000003deg);
.c100.p85 .bar {
-webkit-transform: rotate(306deg);
-moz-transform: rotate(306deg);
-ms-transform: rotate(306deg);
-o-transform: rotate(306deg);
.c100.p86 .bar {
-webkit-transform: rotate(309.6deg);
-moz-transform: rotate(309.6deg);
-ms-transform: rotate(309.6deg);
-o-transform: rotate(309.6deg);
.c100.p87 .bar {
-webkit-transform: rotate(313.2deg);
-moz-transform: rotate(313.2deg);
-ms-transform: rotate(313.2deg);
-o-transform: rotate(313.2deg);
.c100.p88 .bar {
-webkit-transform: rotate(316.8deg);
-moz-transform: rotate(316.8deg);
-ms-transform: rotate(316.8deg);
-o-transform: rotate(316.8deg);
.c100.p89 .bar {
-webkit-transform: rotate(320.40000000000003deg);
-moz-transform: rotate(320.40000000000003deg);
-ms-transform: rotate(320.40000000000003deg);
-o-transform: rotate(320.40000000000003deg);
.c100.p90 .bar {
-webkit-transform: rotate(324deg);
-moz-transform: rotate(324deg);
-ms-transform: rotate(324deg);
-o-transform: rotate(324deg);
.c100.p91 .bar {
-webkit-transform: rotate(327.6deg);
-moz-transform: rotate(327.6deg);
-ms-transform: rotate(327.6deg);
-o-transform: rotate(327.6deg);
.c100.p92 .bar {
-webkit-transform: rotate(331.2deg);
-moz-transform: rotate(331.2deg);
-ms-transform: rotate(331.2deg);
-o-transform: rotate(331.2deg);
.c100.p93 .bar {
-webkit-transform: rotate(334.8deg);
-moz-transform: rotate(334.8deg);
-ms-transform: rotate(334.8deg);
-o-transform: rotate(334.8deg);
.c100.p94 .bar {
-webkit-transform: rotate(338.40000000000003deg);
-moz-transform: rotate(338.40000000000003deg);
-ms-transform: rotate(338.40000000000003deg);
-o-transform: rotate(338.40000000000003deg);
.c100.p95 .bar {
-webkit-transform: rotate(342deg);
-moz-transform: rotate(342deg);
-ms-transform: rotate(342deg);
-o-transform: rotate(342deg);
.c100.p96 .bar {
-webkit-transform: rotate(345.6deg);
-moz-transform: rotate(345.6deg);
-ms-transform: rotate(345.6deg);
-o-transform: rotate(345.6deg);
.c100.p97 .bar {
-webkit-transform: rotate(349.2deg);
-moz-transform: rotate(349.2deg);
-ms-transform: rotate(349.2deg);
-o-transform: rotate(349.2deg);
.c100.p98 .bar {
-webkit-transform: rotate(352.8deg);
-moz-transform: rotate(352.8deg);
-ms-transform: rotate(352.8deg);
-o-transform: rotate(352.8deg);
.c100.p99 .bar {
-webkit-transform: rotate(356.40000000000003deg);
-moz-transform: rotate(356.40000000000003deg);
-ms-transform: rotate(356.40000000000003deg);
-o-transform: rotate(356.40000000000003deg);
.c100.p100 .bar {
-webkit-transform: rotate(360deg);
-moz-transform: rotate(360deg);
-ms-transform: rotate(360deg);
-o-transform: rotate(360deg);
.c100:hover {
cursor: default;
/* effet zoom du texte au passage de la souris */
/*.c100:hover > span {
width: 3.33em;
line-height: 3.33em;
font-size: 0.28em;
color: #307bbb;
/* effet zoom du cercle au passage de la souris */
.c100:hover:after {
top: 0.04em;
left: 0.04em;
width: 0.92em;
height: 0.92em;
/* couleur du cercle restant non coloré en vert/orange/bleu*/
.c100.dark {
background-color: #777777;
.c100.dark .bar,
.c100.dark .fill {
border-color: #c6ff00 !important;
/* Couleur du texte de la température */
.c100.dark > span {
color: #CBE2E2;
/* Couleur de l'intérieur du cercle */
.c100.dark:after {
background-color: #586363;
.c100.dark:hover > span {
color: #c6ff00;
.c100.green .bar,
.c100.green .fill {
border-color: #4db53c !important;
.c100.green:hover > span {
color: #4db53c;
.c100.green.dark .bar,
.c100.green.dark .fill {
border-color: #5fd400 !important;
.c100.green.dark:hover > span {
color: #5fd400;
.c100.orange .bar,
.c100.orange .fill {
border-color: #dd9d22 !important;
.c100.orange:hover > span {
color: #dd9d22;
.c100.orange.dark .bar,
.c100.orange.dark .fill {
border-color: #e08833 !important;
.c100.orange.dark:hover > span {
color: #e08833;
.c100.blue.dark .bar,
.c100.blue.dark .fill {
border-color: #69b5f4 !important;
.c100.blue.dark:hover > span {
color: #69b5f4;
