pas bien mieux, meme pire , j’ai plus le dimanche :
Tu a agrandi le widget?
Voici une petite mise a jours de style
<div class="eqLogic eqLogic-widget allowResize" data-eqType="#eqType#" data-translate-category="#translate_category#" data-category="#category#" data-tags="#tags#" data-eqLogic_id="reveilId" data-eqLogic_uid="#uid#" data-version="#version#" style="min-width : 50px;min-height : 80px ;border:#border#;border-radius:#border-radius#;background-color: #background-color#;color: #color#;width: #width#;height: #height#;#style#" >
<center class="widget-name">
<span style="font-size: 1.2em;#hideEqLogicName#"><a href="#eqLink#">#name_display# <span class="object_name">#object_name#</span></a></span>
</center>
<table class="table_programation">
<thead>
<tr>
<th>Jour actif</th>
<th>Heure</th>
</tr>
</thead>
<tbody></tbody>
</table>
<script type="text/javascript">
var reveilId=72;
$.ajax({
type: "POST",
url: "plugins/reveil/core/ajax/reveil.ajax.php",
data: {
action: "getProgramation",
dataType: 'json',
global: false,
error: function(request, status, error) {
handleAjaxError(request, status, error);
success: function(data) { // si l'appel a bien fonctionné
if (data.state != 'ok') {
$('#div_alert').showAlert({message: data.result, level: 'danger'});
return;
for(var index in data.result) {
if( (typeof data.result[index] === "object") && (data.result[index] !== null) )
addProgramation(data.result[index],$('.eqLogic[data-eqLogic_id=#id#] .table_programation'));
function sendProgramation(_el){
var prog=_el.closest('.ProgramationGroup').attr('data-id');
var day='';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=1]').is(':checked'))
day=day+'1';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=2]').is(':checked'))
day=day+'2';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=3]').is(':checked'))
day=day+'.';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=4]').is(':checked'))
day=day+'4';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=5]').is(':checked'))
day=day+'5';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=6]').is(':checked'))
day=day+'6';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=0]').is(':checked'))
day=day+'0';
var heure=_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=Heure]').val();
var minute=_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=Minute]').val();
$.ajax({
type: "POST",
data: {
action: "setProgramation",
prog: prog,
day: day,
heure: heure,
minute: minute
dataType: 'json',
global: false,
return;
function addProgramation(_programation, _el) {
var Heure=$('<select class="expressionAttr form-control" data-l1key="Heure" >');
var Minute=$('<select class="expressionAttr form-control" data-l1key="Minute" >');
var number = 0;
while (number < 24) {
Heure.append($('<option value="'+number+'">')
.text(number));
number++;
number = 0;
while (number < 60) {
Minute.append($('<option value="'+number+'">')
.text(number));
number++;
var tr = $('<tr class="ProgramationGroup" data-id="'+_programation.id+'">')
.append($('<td style="width: 50%;">')
.append($('<div class="col-sm-2">')
.append($('<label class="checkbox-inline">')
.append($('<input type="checkbox" class="expressionAttr" data-l1key="1">'))
.append('Lundi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="2">'))
.append('Mardi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="3">'))
.append('Mercredi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="4">'))
.append('Jeudi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="5">'))
.append('Vendredi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="6">'))
.append('Samedi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="0" />'))
.append('Dimanche'))))
.append(Heure)
.append(Minute));
_el.append(tr);
_el.find('tr:last').setValues(_programation, '.expressionAttr');
_el.find('.expressionAttr[data-l1key=Heure]').off().on('change', function () {
sendProgramation($(this));
_el.find('.expressionAttr[data-l1key=Minute]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=1]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=2]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=3]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=4]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=5]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=6]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=0]').off().on('change', function () {
</script>
</div>
Ah, c’est mieux.
Pour le mercredi, l’affichage fonctionne (si mercredi programmé, le mercredi est coché et inversement)
Par contre, si je coche ou décoche mercredi depuis le widget du dashboard, la programmation ne fonctionne pas.
Merci encore
OK je regarderai ce problème
Effectivement un petit faute de frappe
</center>
<thead>
<tr>
<th>Jour actif</th>
<th>Heure</th>
</tr>
</thead>
<tbody></tbody>
</table>
var reveilId=72;
$.ajax({
type: "POST",
data: {
dataType: 'json',
global: false,
return;
var day='';
day=day+'1';
day=day+'2';
day=day+'3';
day=day+'4';
day=day+'5';
day=day+'6';
day=day+'0';
$.ajax({
type: "POST",
data: {
prog: prog,
day: day,
heure: heure,
minute: minute
dataType: 'json',
global: false,
return;
var number = 0;
.text(number));
number++;
number = 0;
.text(number));
number++;
.append('Lundi'))
.append('Mardi'))
.append('Jeudi'))
.append('Samedi'))
.append(Heure)
.append(Minute));
_el.append(tr);
</script>
</div>
Super ca marche
Merci pour le support
Un petit bonus que j’ai préparer hier soir
<div class="eqLogic eqLogic-widget allowResize" data-eqType="#eqType#" data-translate-category="#translate_category#" data-category="#category#" data-tags="#tags#" data-eqLogic_id="#id#" data-eqLogic_uid="#uid#" data-version="#version#" style="min-width : 50px;min-height : 80px ;border:#border#;border-radius:#border-radius#;background-color: #background-color#;color: #color#;width: #width#;height: #height#;#style#" >
<span style="font-size: 1[2]em;#hideEqLogicName#"><a href="#eqLink#">#name_display# <span class="object_name">#object_name#</span></a></span>
</center>
<a class="btn btn-success pull-right" id="bt_addProgramation" style="margin-top: 5px;"><i class="fa fa-plus-circle"></i> Ajouter Programation</a><br/><br/>
<div id="reveilProgramation"></div>
var reveilId=72;
$('#bt_addProgramation').off().on('click',function(){
addProgramation({}, $('.eqLogic[ data-eqLogic_id=#id#] #reveilProgramation'));
$.ajax({
type: "POST",
data: {
dataType: 'json',
global: false,
return;
addProgramation(data.result[index], $('.eqLogic[ data-eqLogic_id=#id#] #reveilProgramation'));
var day='';
day=day+'1';
day=day+'2';
day=day+'3';
day=day+'4';
day=day+'5';
day=day+'6';
day=day+'0';
$.ajax({
type: "POST",
data: {
prog: prog,
day: day,
heure: heure,
minute: minute
dataType: 'json',
global: false,
return;
function titleProgramation(_programation){
var title =_programation.Heure+':'+_programation.Minute;
if(_programation[1] == "1" && _programation[2] == "1" && _programation[3] == "1" && _programation[4] && _programation[5] == "1" && _programation[6] == "1" && _programation[0] == "1")
title += ' Tous les jours';
else if(_programation[1] == "1" && _programation[2] == "1" && _programation[3] == "1" && _programation[4] == "1" && _programation[5] == "1" && _programation[6] == "0" && _programation[0] == "0")
title += ' Tous les jours ouvrée';
else if(_programation[1] == "0" && _programation[2] == "0" && _programation[3] == "0" && _programation[4] == "0" && _programation[5] == "0" && _programation[6] == "1" && _programation[0] == "1")
title += ' Tous les weekend';
else{
if(_programation[1] == "1")
title += ' Lundi';
if(_programation[2] == "1")
title += ' Mardi';
if(_programation[3] == "1")
title += ' Mercredi';
if(_programation[4] == "1")
title += ' Jeudi';
if(_programation[5] == "1")
title += ' Vendredi';
if(_programation[6] == "1")
title += ' Samedi';
if(_programation[0] == "1")
title += ' Dimanche';
return title;
var number = 0;
.text(number));
number++;
number = 0;
.text(number));
number++;
var random = Math.floor((Math.random() * 1000000) + 1);
var div = $('<div class="programation panel panel-default">')
.append($('<div class="panel-heading">')
.append($('<h4 class="panel-title">')
.append($('<a data-toggle="collapse" data-parent="#reveilProgramation" href="#collapse' + random + '">')
.append($('<span class="name">')
.append(titleProgramation(_programation))))))
.append($('<div id="collapse' + random + '" class="panel-collapse collapse in">')
.append($('<div class="panel-body">')
.append($('<div class="well">')
.append($('<form class="form-horizontal" role="form">')
.append($('<div class="form-group">')
.append('Lundi'))
.append('Mardi'))
.append('Jeudi'))
.append('Samedi'))
.append(Heure)
.append(Minute))))));
_el.append(div);
_el.find('.programation:last').setValues(_programation, '.expressionAttr');
$('.collapse').collapse();
</script>
</div>
J’ai créé un nouveau Widget HTML (en laissant l’ancien) pour tester.
Un bien le nouveau Widget modifie l’affichage de mon ancien.
C’est normal?
J’ai une vague idée et ça peut-être chiant à corriger
L’id n’est peut-être pas remplacé
pas la peine, j’en n’ai pas besoin.
par contre, il manque la commande pour desactiver le reveil
Je comprend pas
Sur le widget de base y a 2 commande arrêt et snooze
Tu n’a pas ca
oui mais pas sur le Display HTML
le code que j’ai donné precedement n’est que pour la partie programmation
oui mais il aurait été bien d’avoir aussi l’activation/desactivation sur le meme visuel.
Bonjour, aussi, le widget ne marche pas en transparent sur le design. C’est pas la fin du monde , mais bon…
Bonjour, je viens de constater un probleme avec le display HTML.
J’ai rajouté 2 reveils pour gérer l’eclairage de mon aquarium, un reveil ON et un reveil OFF.
Si je mets 2 display HTML sur la meme page, l’un des display configure l’autre reveil.
Je suis obligé de séparer les displays aussi bien sur le dashboard que sur les designs.
Petit déterrage
Merci pour le plugin il est top top @mika-nt28 ! Je suis ravi de mon achat.
Pour la parti widget html deux petites questions :
- Comment on le resize pour afficher tous les jours ? (désolé pas trouvé dans la doc). → j’ai changé comme un cochon dans le code mais doit y avoir mieux
- Quand je l’ajoute à un désign il apparait bien mais dès que je refresh pouf disparu. → Trouvé c’est seulement quand il y a le widget 'activation sur la page aussi.
- Comment valide t’on un changement de programmation avec le widget html ?
voila , il faut juste modifier reveilId par l’id de ton equipement
</center>
<thead>
<tr>
<th>Jour actif</th>
<th>Heure</th>
</tr>
</thead>
<tbody></tbody>
</table>
var reveilId=103;
$.ajax({
type: "POST",
data: {
dataType: 'json',
global: false,
return;
var day='';
day=day+'1';
day=day+'2';
day=day+'3';
day=day+'4';
day=day+'5';
day=day+'6';
day=day+'0';
$.ajax({
type: "POST",
data: {
prog: prog,
day: day,
heure: heure,
minute: minute
dataType: 'json',
global: false,
return;
var number = 0;
.text(number));
number++;
number = 0;
.text(number));
number++;
.append('Lundi'))
.append('Mardi'))
.append('Jeudi'))
.append('Samedi'))
.append(Heure)
.append(Minute));
_el.append(tr);
</script>
</div>
