J’ai pris quelques minute se midi pour debugé le code a mettre dans le widget HTML
<table class="table_programation">
<thead>
<tr>
<th>Jour actif</th>
<th>Heure</th>
</tr>
</thead>
<tbody></tbody>
</table>
<script type="text/javascript">
var reveilId=**ID a recuper dans la configuration avancé du reveil**;
$.ajax({
type: "POST",
url: "plugins/reveil/core/ajax/reveil.ajax.php",
data: {
action: "getProgramation",
dataType: 'json',
global: false,
error: function(request, status, error) {
handleAjaxError(request, status, error);
success: function(data) { // si l'appel a bien fonctionné
if (data.state != 'ok') {
$('#div_alert').showAlert({message: data.result, level: 'danger'});
return;
for(var index in data.result) {
if( (typeof data.result[index] === "object") && (data.result[index] !== null) )
addProgramation(data.result[index],$('.eqLogic[data-eqLogic_id=#id#] .table_programation'));
function sendProgramation(_el){
var prog=_el.closest('.ProgramationGroup').attr('data-id');
var day='';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=1]').is(':checked'))
day=day+'1';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=2]').is(':checked'))
day=day+'2';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=3]').is(':checked'))
day=day+'.';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=4]').is(':checked'))
day=day+'4';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=5]').is(':checked'))
day=day+'5';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=6]').is(':checked'))
day=day+'6';
if(_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=0]').is(':checked'))
day=day+'0';
var heure=_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=Heure]').val();
var minute=_el.closest('.ProgramationGroup').find('.expressionAttr[data-l1key=Minute]').val();
$.ajax({// fonction permettant de faire de l'ajax
type: "POST", // methode de transmission des données au fichier php
url: "plugins/reveil/core/ajax/reveil.ajax.php", // url du fichier php
data: {
action: "setProgramation",
prog: prog,
day: day,
heure: heure,
minute: minute
dataType: 'json',
global: false,
return;
function addProgramation(_programation, _el) {
var Heure=$('<select class="expressionAttr form-control" data-l1key="Heure" >');
var Minute=$('<select class="expressionAttr form-control" data-l1key="Minute" >');
var number = 0;
while (number < 24) {
Heure.append($('<option value="'+number+'">')
.text(number));
number++;
number = 0;
while (number < 60) {
Minute.append($('<option value="'+number+'">')
.text(number));
number++;
var tr = $('<tr class="ProgramationGroup" data-id="'+_programation.id+'">')
.append($('<td>')
.append($('<div class="col-sm-5">')
.append($('<label class="checkbox-inline">')
.append($('<input type="checkbox" class="expressionAttr" data-l1key="1">'))
.append('Lundi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="2">'))
.append('Mardi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="3">'))
.append('Mercredi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="4">'))
.append('Jeudi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="5">'))
.append('Vendredi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="6">'))
.append('Samedi'))
.append($('<input type="checkbox" class="expressionAttr" data-l1key="0" />'))
.append('Dimanche'))))
.append($('<td>')
.append(Heure)
.append(Minute));
_el.append(tr);
_el.find('tr:last').setValues(_programation, '.expressionAttr');
_el.find('.expressionAttr[data-l1key=Heure]').off().on('change', function () {
sendProgramation($(this));
_el.find('.expressionAttr[data-l1key=Minute]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=1]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=2]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=3]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=4]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=5]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=6]').off().on('change', function () {
_el.find('.expressionAttr[data-l1key=0]').off().on('change', function () {
</script>
Pour utilisé l’iframe c’est un peux plus complexe et faut que je prenne le temps d’ajouté les librairie qui manque
