Voici une preuve de concept fonctionnelle.
Seul le fichier plugins/gsh/core/php/jeeGshOauth.php
est à remplacer par :
<?php
require_once __DIR__ . '/../../../../core/php/core.inc.php';
if (init('response_type') == 'code') {
// Allow access from local network only
if (network::getUserLocation() != 'internal')
die();
include_file('core', 'authentification', 'php');
// Check for a logged in user
if (!isConnect()) {
// If login and password supplied, try to login the user
if (init('username', '') != '' || init('password', '') != '') {
$user = user::connect(init('username'), init('password'));
if (is_object($user)
&& network::getUserLocation() != 'internal'
&& $user->getOptions('twoFactorAuthentification', 0) == 1
&& $user->getOptions('twoFactorAuthentificationSecret') != ''
&& init('twoFactorCode') == '') {
$error = __("Merci de fournir un Token 2FA", __FILE__);
$mfa = true;
} elseif (!login(init('username'), init('password'), init('twoFactorCode'))) {
$error = __("Mot de passe ou nom d'utilisateur incorrect", __FILE__);
} else {
$error = '';
// Check if user is an Admin
if (!isConnect('admin') && !isset($error)) {
$error = __('Merci de vous connecter avec un compte Admin', __FILE__);
// If something failed prompt a login page
if (isset($error)) {
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=yes">
<title>Jeedom</title>
<link rel="icon" href="/core/img/logo-jeedom-petit-nom-couleur-128x128.png">
<meta name="theme-color" content="#3f51b5">
<link rel="stylesheet" href="https://stackpath.bootstrapcdn.com/bootstrap/4.1.3/css/bootstrap.min.css" integrity="sha384-MCw98/SFnGE8fJT3GXwEOngsV7Zt27NXFoaoApmYm81iuXoPkFOJwJ8ERdknLPMO" crossorigin="anonymous">
</head>
<body>
<br/>
<center>
<img src='/core/img/logo-jeedom-petit-nom-couleur-128x128.png' /><br/><br/>
<?php
if ($error != '')
echo ' <div class="alert alert-danger" role="alert" style="margin:10px">' . $error . '</div>';
<h2 id="welcome_message">{{Merci de vous connecter à votre Jeedom pour configurer la connexion avec Google}}</h2>
<form method='post' action='<?php echo $_SERVER["PHP_SELF"]; ?>' style="margin:10px">
<div class="form-group row"><div class="col-sm-4 col-md-4 col-lg-2 offset-md-4 offset-lg-5">
<input class="form-control" name="username" placeholder="{{Nom d'utilisateur}}">
</div></div>
<input type="password" class="form-control" name="password" placeholder="{{Mot de passe}}">
</div></div>
<?php
if ($mfa) {
<input class="form-control" name="twoFactorCode" placeholder="{{Authentification à 2 facteurs}}">
</div></div>
<?php
foreach(array('response_type', 'client_id', 'redirect_uri', 'state') as $param) {
$value = init($param);
if($value != '')
echo ' <input type="hidden" name="'. htmlspecialchars($param) .'" value="'. htmlspecialchars($value) .'" />';
<button type="submit" class="btn btn-primary mb-2">{{Valider}}</button>
</form>
</center>
<pre><?php print_r($_REQUEST); ?></pre>
</body>
</html>
<?php
die();
if (init('client_id') == config::byKey('gshs::clientId', 'gsh')) {
$authorization_code = config::genKey();
config::save('OAuthAuthorizationCode', $authorization_code, 'gsh');
header('Location: ' . init('redirect_uri') . '?code=' . $authorization_code . '&state=' . init('state'));
} else if ($_POST['client_id'] == config::byKey('gshs::clientId', 'gsh') && $_POST['client_secret'] == config::byKey('gshs::clientSecret', 'gsh')) {
if (!in_array(init('type', 'sh'), array('df', 'sh'))) {
echo 'Le type ne peut etre que sh ou df';
die();
header('Content-type: application/json');
header('HTTP/1.1 200 OK');
header('\'Access-Control-Allow-Origin\': *');
header('\'Access-Control-Allow-Headers\': \'Content-Type, Authorization\'');
if ($_POST['grant_type'] == 'authorization_code' && $_POST['code'] == config::byKey('OAuthAuthorizationCode', 'gsh') && config::byKey('OAuthAuthorizationCode', 'gsh') != '') {
config::save('OAuthAuthorizationCode', '', 'gsh');
$access_token = config::genKey();
config::save('OAuthAccessToken' . init('type', 'sh'), $access_token, 'gsh');
$refresh_token = config::genKey();
config::save('OAuthRefreshToken' . init('type', 'sh'), $refresh_token, 'gsh');
$response = array(
'token_type' => 'bearer',
'access_token' => $access_token,
'refresh_token' => $refresh_token,
'expires_in' => 3600 * 24,
echo json_encode($response);
} elseif ($_POST['grant_type'] == 'refresh_token' && $_POST['refresh_token'] == config::byKey('OAuthRefreshToken' . init('type', 'sh'), 'gsh') && config::byKey('OAuthRefreshToken' . init('type', 'sh'), 'gsh') != '') {
$response = array(
Bad
