Une erreur sur les logs généraux
2022-09-26 00:00:05 cron [Erreur] Classe ou fonction non trouvée Freebox_OS::FreeboxAPI()
Et ci dessous les logs depuis
[2022-09-26 18:30:06][DEBUG] : ================= FIN REFRESH TOKEN ==================
[2022-09-26 19:00:04][DEBUG] : ================= REFRESH TOKEN ==================
[2022-09-26 19:00:04][DEBUG] : │──────────> Close Session
[2022-09-26 19:00:04][DEBUG] : [Freebox Close Session] : {"uid":"9386444b14151c55ba836c9494b707cc","success":false,"msg":"Vous devez vous connecter pour accéder à cette fonction","result":{"password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","challenge":"\/TCxIc2PuL6XLAg\/VD1rXgmStX3YZNXp"},"error_code":"invalid_session"}
[2022-09-26 19:00:04][DEBUG] : [Freebox Password] : {"success":true,"result":{"logged_in":false,"challenge":"\/TCxIc2PuL6XLAg\/VD1rXgmStX3YZNXp","password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","password_set":true}}
[2022-09-26 19:00:07][DEBUG] : ================= Etat du Démon nok ==================
[2022-09-26 19:00:09][DEBUG] : │──────────> Close Session
[2022-09-26 19:00:09][DEBUG] : ================= REFRESH TOKEN ==================
[2022-09-26 19:00:09][DEBUG] : [Freebox Password] : {"success":true,"result":{"logged_in":false,"challenge":"\/TCxIc2PuL6XLAg\/VD1rXgmStX3YZNXp","password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","password_set":true}}
[2022-09-26 19:00:09][DEBUG] : [Freebox Open Session] : {"result":{"session_token":"rEVBI4sQOEcuELHFiGe50woI7IVCE0uc4KBY45l59WchFggsYU1gUV26YCv3wA6U","challenge":"\/TCxIc2PuL6XLAg\/VD1rXgmStX3YZNXp","password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","permissions":{"parental":true,"contacts":true,"explorer":true,"tv":true,"wdo":true,"downloader":true,"profile":true,"camera":true,"settings":true,"calls":true,"home":true,"pvr":true,"vm":true,"player":true},"password_set":true},"success":true}
[2022-09-26 19:00:09][DEBUG] : [Freebox Etat Session] : OK / 1
[2022-09-26 19:00:09][DEBUG] : [Freebox Close Session] : {"uid":"9386444b14151c55ba836c9494b707cc","success":false,"msg":"Vous devez vous connecter pour accéder à cette fonction","result":{"password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","challenge":"\/TCxIc2PuL6XLAg\/VD1rXgmStX3YZNXp"},"error_code":"invalid_session"}
[2022-09-26 19:00:09][DEBUG] : [Freebox Open Session] : {"result":{"session_token":"1B\/+mHwMGcIEK1TRLP\/NfCrVNRx\/u6GgbYDei\/wCDwYYQyYWfIf35Yb9eTsLqQek","challenge":"\/TCxIc2PuL6XLAg\/VD1rXgmStX3YZNXp","password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","permissions":{"parental":true,"contacts":true,"explorer":true,"tv":true,"wdo":true,"downloader":true,"profile":true,"camera":true,"settings":true,"calls":true,"home":true,"pvr":true,"vm":true,"player":true},"password_set":true},"success":true}
[2022-09-26 19:00:09][DEBUG] : ================= Redémarrage du démon : ok ==================
[2022-09-26 19:00:09][DEBUG] : ================= CRON pour l'actualisation de : Système ==================
[2022-09-26 19:00:09][DEBUG] : │──────────> Récupération des valeurs du Système
[2022-09-26 19:00:09][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2022-09-26 19:00:09][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"20:66:CF:1B:71:38","sensors":[{"id":"temp_hdd2","name":"Disque dur 3","value":49},{"id":"temp_t2","name":"Température 2","value":54},{"id":"temp_t1","name":"Température 1","value":49},{"id":"temp_t3","name":"Température 3","value":48},{"id":"temp_cpu_cp_slave","name":"Température CPU CP Slave","value":82},{"id":"temp_cpu_ap","name":"Température CPU AP","value":76},{"id":"temp_cpu_cp_master","name":"Température CPU CP Master","value":84}],"model_info":{"customer_hdd_slots":4,"net_operator":"free_fra","supported_languages":["fra"],"has_dsl":true,"has_dect":true,"wifi_country":"FR","has_home_automation":true,"wifi_type":"2d4_5g_5g","pretty_name":"Freebox v7 (r1)","has_lan_sfp":true,"name":"fbxgw7-r1\/full","has_separate_internal_storage":true,"internal_hdd_size":0,"default_language":"fra","has_vm":true,"has_expansions":true},"fans":[{"id":"fan1_speed","name":"Ventilateur 2","value":1572},{"id":"fan0_speed","name":"Ventilateur 1","value":1595}],"expansions":[{"type":"security","present":true,"slot":1,"probe_done":true,"supported":true,"bundle":"985700J191407906"},{"type":"ftth_pon","present":true,"slot":2,"probe_done":true,"supported":true,"bundle":"955810J214001591"}],"board_name":"fbxgw7r","disk_status":"active","uptime":"2 jours 6 heures 38 minutes 43 secondes","uptime_val":196723,"user_main_storage":"Freebox","box_authenticated":true,"serial":"957603J214305723","firmware_version":"4.6.4"}}
[2022-09-26 19:00:09][DEBUG] : │──────────> Allumée depuis : 2 jours 6h 38min 43s
[2022-09-26 19:00:09][DEBUG] : [Freebox Open Session] : {"result":{"session_token":"RYxy5wRjmTEbDBJTEAyvNvt9RiMuEtUSKGDp+h\/cQJmi95lA6zqrQmzKapXskiLR","challenge":"\/TCxIc2PuL6XLAg\/VD1rXgmStX3YZNXp","password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","permissions":{"parental":true,"contacts":true,"explorer":true,"tv":true,"wdo":true,"downloader":true,"profile":true,"camera":true,"settings":true,"calls":true,"home":true,"pvr":true,"vm":true,"player":true},"password_set":true},"success":true}
[2022-09-26 19:00:11][DEBUG] : ================= FIN REFRESH TOKEN ==================
[2022-09-26 19:30:05][DEBUG] : ================= REFRESH TOKEN ==================
[2022-09-26 19:30:05][DEBUG] : │──────────> Close Session
[2022-09-26 19:30:05][DEBUG] : [Freebox Close Session] : {"uid":"9386444b14151c55ba836c9494b707cc","success":false,"msg":"Vous devez vous connecter pour accéder à cette fonction","result":{"password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","challenge":"KOf8cA0vgOxUmU0F5zqeUDAwXjAygTpP"},"error_code":"invalid_session"}
[2022-09-26 19:30:05][DEBUG] : [Freebox Password] : {"success":true,"result":{"logged_in":false,"challenge":"KOf8cA0vgOxUmU0F5zqeUDAwXjAygTpP","password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","password_set":true}}
[2022-09-26 19:30:05][DEBUG] : [Freebox Open Session] : {"result":{"session_token":"iKXNV1PjSpMgs9Ph7nsv194FlFD7CIwLHv+qUVKU+Zz50Rc+1DTBEDheKew03MY7","challenge":"KOf8cA0vgOxUmU0F5zqeUDAwXjAygTpP","password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","permissions":{"parental":true,"contacts":true,"explorer":true,"tv":true,"wdo":true,"downloader":true,"profile":true,"camera":true,"settings":true,"calls":true,"home":true,"pvr":true,"vm":true,"player":true},"password_set":true},"success":true}
[2022-09-26 19:30:05][DEBUG] : [Freebox Etat Session] : OK / 1
[2022-09-26 19:30:05][DEBUG] : ================= CRON pour l'actualisation de : Système ==================
[2022-09-26 19:30:05][DEBUG] : │──────────> Récupération des valeurs du Système
[2022-09-26 19:30:05][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2022-09-26 19:30:05][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"20:66:CF:1B:71:38","sensors":[{"id":"temp_hdd2","name":"Disque dur 3","value":49},{"id":"temp_t2","name":"Température 2","value":54},{"id":"temp_t1","name":"Température 1","value":49},{"id":"temp_t3","name":"Température 3","value":48},{"id":"temp_cpu_cp_slave","name":"Température CPU CP Slave","value":83},{"id":"temp_cpu_ap","name":"Température CPU AP","value":75},{"id":"temp_cpu_cp_master","name":"Température CPU CP Master","value":84}],"model_info":{"customer_hdd_slots":4,"net_operator":"free_fra","supported_languages":["fra"],"has_dsl":true,"has_dect":true,"wifi_country":"FR","has_home_automation":true,"wifi_type":"2d4_5g_5g","pretty_name":"Freebox v7 (r1)","has_lan_sfp":true,"name":"fbxgw7-r1\/full","has_separate_internal_storage":true,"internal_hdd_size":0,"default_language":"fra","has_vm":true,"has_expansions":true},"fans":[{"id":"fan1_speed","name":"Ventilateur 2","value":1518},{"id":"fan0_speed","name":"Ventilateur 1","value":1541}],"expansions":[{"type":"security","present":true,"slot":1,"probe_done":true,"supported":true,"bundle":"985700J191407906"},{"type":"ftth_pon","present":true,"slot":2,"probe_done":true,"supported":true,"bundle":"955810J214001591"}],"board_name":"fbxgw7r","disk_status":"active","uptime":"2 jours 7 heures 8 minutes 39 secondes","uptime_val":198519,"user_main_storage":"Freebox","box_authenticated":true,"serial":"957603J214305723","firmware_version":"4.6.4"}}
[2022-09-26 19:30:05][DEBUG] : │──────────> Allumée depuis : 2 jours 7h 8min 39s
[2022-09-26 19:30:06][DEBUG] : ================= FIN REFRESH TOKEN ==================
[2022-09-26 20:00:05][DEBUG] : ================= REFRESH TOKEN ==================
[2022-09-26 20:00:05][DEBUG] : │──────────> Close Session
[2022-09-26 20:00:05][DEBUG] : [Freebox Close Session] : {"uid":"9386444b14151c55ba836c9494b707cc","success":false,"msg":"Vous devez vous connecter pour accéder à cette fonction","result":{"password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","challenge":"+cbIngZmO9nyn3+bCKBKzGyZNdeo98pL"},"error_code":"invalid_session"}
[2022-09-26 20:00:05][DEBUG] : [Freebox Password] : {"success":true,"result":{"logged_in":false,"challenge":"+cbIngZmO9nyn3+bCKBKzGyZNdeo98pL","password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","password_set":true}}
[2022-09-26 20:00:07][DEBUG] : │──────────> Close Session
[2022-09-26 20:00:08][DEBUG] : ================= REFRESH TOKEN ==================
[2022-09-26 20:00:08][DEBUG] : │──────────> Close Session
[2022-09-26 20:00:08][DEBUG] : [Freebox Password] : {"success":true,"result":{"logged_in":false,"challenge":"+cbIngZmO9nyn3+bCKBKzGyZNdeo98pL","password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","password_set":true}}
[2022-09-26 20:00:08][DEBUG] : [Freebox Open Session] : {"result":{"session_token":"wcjdYL7xXS+b39924yZ2tbdcziD26Jd7yNwbal01uSDEGNh+5LDzIObcOXTaHQ+j","challenge":"+cbIngZmO9nyn3+bCKBKzGyZNdeo98pL","password_salt":"GtSL8gYUsvCma7GY2ji8r2Hmp4MluzaY","permissions":{"parental":true,"contacts":true,"explorer":true,"tv":true,"wdo":true,"downloader":true,"profile":true,"camera":true,"settings":true,"calls":true,"home":true,"pvr":true,"vm":true,"player":true},"password_set":true},"success":true}
[2022-09-26 20:00:08][DEBUG] : [Freebox Etat Session] : OK / 1
[2022-09-26 20:00:08][DEBUG] : ================= CRON pour l'actualisation de : Système ==================
[2022-09-26 20:00:08][DEBUG] : │──────────> Récupération des valeurs du Système
[2022-09-26 20:00:08][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2022-09-26 20:00:08][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"20:66:CF:1B:71:38","sensors":[{"id":"temp_hdd2","name":"Disque dur 3","value":49},{"id":"temp_t2","name":"Température 2","value":54},{"id":"temp_t1","name":"Température 1","value":49},{"id":"temp_t3","name":"Température 3","value":48},{"id":"temp_cpu_cp_slave","name":"Température CPU CP Slave","value":83},{"id":"temp_cpu_ap","name":"Température CPU AP","value":75},{"id":"temp_cpu_cp_master","name":"Température CPU CP Master","value":85}],"model_info":{"customer_hdd_slots":4,"net_operator":"free_fra","supported_languages":["fra"],"has_dsl":true,"has_dect":true,"wifi_country":"FR","has_home_automation":true,"wifi_type":"2d4_5g_5g","pretty_name":"Freebox v7 (r1)","has_lan_sfp":true,"name":"fbxgw7-r1\/full","has_separate_internal_storage":true,"internal_hdd_size":0,"default_language":"fra","has_vm":true,"has_expansions":true},"fans":[{"id":"fan1_speed","name":"Ventilateur 2","value":1517},{"id":"fan0_speed","name":"Ventilateur 1","value":1540}],"expansions":[{"type":"security","present":true,"slot":1,"probe_done":true,"supported":true,"bundle":"985700J191407906"},{"type":"ftth_pon","present":true,"slot":2,"probe_done":true,"supported":true,"bundle":"955810J214001591"}],"board_name":"fbxgw7r","disk_status":"active","uptime":"2 jours 7 heures 38 minutes 42 secondes","uptime_val":200322,"user_main_storage":"Freebox","box_authenticated":true,"serial":"957603J214305723","firmware_version":"4.6.4"}}
[2022-09-26 20:00:08][DEBUG] : │──────────> Allumée depuis : 2 jours 7h 38min 42s
[2022-09-26 20:00:08][DEBUG] : ================= FIN REFRESH TOKEN ==================
Pour info, j’ai étudier l’historique des evenements sur l’application FREE, et il n’y avait plus aucune interaction apres 16h16, 1 minutes apres avoir activé l’alarme.
J’ai recuperer les evenement apres le bug:
A 17h02, on a desactivé l’alarme. Elle s’est effectivement desactivé mais gros bug sur l’application
D’ailleurs, l’historique de deux detecteur sont incoherent. Il y a le detecteur de prte du garage qui n’a pas detecté son ouverture à 17h02, alors que la porte suivante a elle detecté son ouverture. Mais la porte du detecteur de presence n’a pas detecté de presence !!!
Bon, gros bug donc …
