Je voulais vous répondre sur le poste que vous avez mis mais je dois me dire de vous contacter en privé je crois que le fait que le test est long merci d’avance
[-Topic=zigbee2mqtt/USB Gateway Zigbee, Payload={"device":{"applicationVersion":16,"dateCode":"20240614","friendlyName":"USB Gateway Zigbee","hardwareVersion":16,"ieeeAddr":"0x1cc089fffe70627e","manufacturerID":4742,"manufacturerName":"SONOFF","model":"ZBMicro","networkAddress":17336,"powerSource":"Mains (single phase)","softwareBuildID":"1.0.5","type":"Router","zclVersion":3},"linkquality":255,"state":"ON","update":{"installed_version":4101,"latest_version":4101,"state":"idle"}}
[2025-12-12 13:23:09] DEBUG state = converted:1
[2025-12-12 13:23:09] DEBUG linkquality = 255
[2025-12-12 13:23:10] DEBUG [Aucun][Lixee ZLinky] : MQTT-->Jeedom, Topic=zigbee2mqtt/Lixee ZLinky, Payload={"active_register_tier_delivered":"TH..","apparent_power":262,"available_power":30,"current_summ_delivered":13671.477,"current_tarif":"BASE","device":{"applicationVersion":12,"dateCode":"20250923","friendlyName":"Lixee ZLinky","hardwareVersion":1,"ieeeAddr":"0x00158d0005d29900","manufacturerID":4151,"manufacturerName":"LiXee","model":"ZLinky_TIC","networkAddress":15589,"powerSource":"Mains (single phase)","softwareBuildID":"4000-0017","stackVersion":2,"type":"Router","zclVersion":3},"linkquality":255,"meter_serial_number":"341964595469","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_version":17,"state":"idle"},"warn_d_p_s":0}
[2025-12-12 13:23:10] DEBUG active_register_tier_delivered = TH..
[2025-12-12 13:23:10] DEBUG current_summ_delivered = 13671.477
[2025-12-12 13:23:10] DEBUG meter_serial_number = 341964595469
[2025-12-12 13:23:10] DEBUG available_power = 30
[2025-12-12 13:23:10] DEBUG apparent_power = 262
[2025-12-12 13:23:10] DEBUG current_tarif = BASE
[2025-12-12 13:23:10] DEBUG rms_current = 1
[2025-12-12 13:23:10] DEBUG rms_current_max = 90
[2025-12-12 13:23:10] DEBUG warn_d_p_s = 0
[2025-12-12 13:23:10] DEBUG linkquality = 255
[2025-12-12 13:23:11] DEBUG [Interrupteurs ZigBee][Interrupteur Cuisine] : MQTT-->Jeedom, Topic=zigbee2mqtt/Interrupteur Cuisine, Payload={"backlight_mode":"normal","device":{"applicationVersion":80,"dateCode":"","friendlyName":"Interrupteur Cuisine","hardwareVersion":1,"ieeeAddr":"0xa4c13886275fdeec","manufacturerID":4417,"manufacturerName":"_TZ3000_z7j4thy1","model":"TS0011","networkAddress":39477,"powerSource":"Mains (single phase)","stackVersion":0,"type":"EndDevice","zclVersion":3},"linkquality":255,"state":"OFF"} [2025-12-12 13:23:11] DEBUG state = converted:0
[2025-12-12 13:23:11] DEBUG backlight_mode = normal
[2025-12-12 13:23:11] DEBUG linkquality = 255
[2025-12-12 13:23:11] DEBUG [Interrupteurs ZigBee][Interrupteur Salon] : MQTT-->Jeedom, Topic=zigbee2mqtt/Interrupteur Salon, Payload={"backlight_mode":"normal","device":{"applicationVersion":80,"dateCode":"","friendlyName":"Interrupteur Salon","hardwareVersion":1,"ieeeAddr":"0xa4c13848cfcf8dc5","manufacturerID":4417,"manufacturerName":"_TZ3000_z7j4thy1","model":"TS0011","networkAddress":20152,"powerSource":"Mains (single phase)","stackVersion":0,"type":"EndDevice","zclVersion":3},"linkquality":255,"state":"OFF"} [2025-12-12 13:23:11] DEBUG state = converted:0
[2025-12-12 13:23:12] DEBUG <--- MQTT message, ieeeAddr not found (Dans l'interface Zigbee2MQTT, vérifiez que vous avez activé l'option Settings->MQTT->Include device information)
[2025-12-12 13:23:12] DEBUG Données reçues : { "manufacturerdata": "d200003c", "name": "nut", "id": "5A:90:56:B0:E2:36", "rssi": -81, "servicedatauuid": "180a", "servicedata": "5a9056b0e236", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "track": true, "device": "nut Tracker" }
[2025-12-12 13:23:18] DEBUG [Prises ZigBee][Prise TV Home Salon] : MQTT-->Jeedom, Topic=zigbee2mqtt/Prise TV Home Salon, Payload={"current":0,"device":{"applicationVersion":192,"dateCode":"","friendlyName":"Prise TV Home Salon","hardwareVersion":1,"ieeeAddr":"0xa4c138b151eee681","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":13553,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":0.79,"linkquality":255,"power":0,"state":"OFF","voltage":231}
[2025-12-12 13:23:18] DEBUG state = converted:0 [2025-12-12 13:23:18] DEBUG power = 0 [2025-12-12 13:23:18] DEBUG current = 0
[2025-12-12 13:23:18] DEBUG voltage = 231
[2025-12-12 13:23:18] DEBUG energy = 0.79
[2025-12-12 13:23:18] DEBUG linkquality = 255 [2025-12-12 13:23:18] DEBUG [Prises ZigBee][Prise TV Home Salon] : MQTT-->Jeedom, Topic=zigbee2mqtt/Prise TV Home Salon, Payload={"current":0,"device":{"applicationVersion":192,"dateCode":"","friendlyName":"Prise TV Home Salon","hardwareVersion":1,"ieeeAddr":"0xa4c138b151eee681","manufacturerID":4417,"manufacturerName":"_TZ3000_w0qqde0g","model":"TS011F_plug_1","networkAddress":13553,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":0.79,"linkquality":255,"power":0,"state":"OFF","voltage":231}
[2025-12-12 13:23:21] DEBUG <--- MQTT message, ieeeAddr not found (Dans l'interface Zigbee2MQTT, vérifiez que vous avez activé l'option Settings->MQTT->Include device information) [2025-12-12 13:23:21] DEBUG Données reçues : { "manufacturerdata": "d200003c", "name": "nut", "id": "5A:90:56:B0:E2:36", "rssi": -79, "servicedatauuid": "180a", "servicedata": "5a9056b0e236", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "track": true, "device": "nut Tracker" }
[2025-12-12 13:23:23] DEBUG <--- MQTT message, ieeeAddr not found (Dans l'interface Zigbee2MQTT, vérifiez que vous avez activé l'option Settings->MQTT->Include device information)
[2025-12-12 13:23:23] DEBUG Données reçues : { "manufacturerdata": "d200003c", "name": "nut", "id": "5A:90:56:B0:E2:36", "rssi": -81, "servicedatauuid": "180a", "servicedata": "5a9056b0e236", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "track": true, "device": "nut Tracker" }
[2025-12-12 13:23:26] DEBUG [Prises ZigBee][LED TV Chambre] : MQTT-->Jeedom, Topic=zigbee2mqtt/LED TV Chambre, Payload={"current":0,"device":{"applicationVersion":192,"dateCode":"","friendlyName":"LED TV Chambre","hardwareVersion":1,"ieeeAddr":"0xa4c1382acdaf1220","manufacturerID":4417,"manufacturerName":"_TZ3000_2putqrmw","model":"A1Z","networkAddress":16829,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":0,"linkquality":255,"power":0,"state":"OFF","voltage":231}
[2025-12-12 13:23:26] DEBUG state = converted:0
[2025-12-12 13:23:26] DEBUG power = 0
[2025-12-12 13:23:26] DEBUG current = 0
[2025-12-12 13:23:26] DEBUG voltage = 231
[2025-12-12 13:23:26] DEBUG energy = 0
[2025-12-12 13:23:26] DEBUG linkquality = 255
[2025-12-12 13:23:28] DEBUG <--- MQTT message, ieeeAddr not found (Dans l'interface Zigbee2MQTT, vérifiez que vous avez activé l'option Settings->MQTT->Include device information)
[2025-12-12 13:23:28] DEBUG Données reçues : { "manufacturerdata": "d200003c", "name": "nut", "id": "5A:90:56:B0:E2:36", "rssi": -79, "servicedatauuid": "180a", "servicedata": "5a9056b0e236", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "track": true, "device": "nut Tracker" }
[2025-12-12 13:23:30] DEBUG [Aucun][Lixee ZLinky] : MQTT-->Jeedom, Topic=zigbee2mqtt/Lixee ZLinky, Payload={"active_register_tier_delivered":"TH..","apparent_power":261,"available_power":30,"current_summ_delivered":13671.477,"current_tarif":"BASE","device":{"applicationVersion":12,"dateCode":"20250923","friendlyName":"Lixee ZLinky","hardwareVersion":1,"ieeeAddr":"0x00158d0005d29900","manufacturerID":4151,"manufacturerName":"LiXee","model":"ZLinky_TIC","networkAddress":15589,"powerSource":"Mains (single phase)","softwareBuildID":"4000-0017","stackVersion":2,"type":"Router","zclVersion":3},"linkquality":255,"meter_serial_number":"341964595469","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_version":17,"state":"idle"},"warn_d_p_s":0}
[2025-12-12 13:23:30] DEBUG active_register_tier_delivered = TH..
[2025-12-12 13:23:30] DEBUG current_summ_delivered = 13671.477
[2025-12-12 13:23:30] DEBUG meter_serial_number = 341964595469
[2025-12-12 13:23:30] DEBUG available_power = 30
[2025-12-12 13:23:30] DEBUG apparent_power = 261
[2025-12-12 13:23:30] DEBUG current_tarif = BASE
[2025-12-12 13:23:30] DEBUG rms_current = 1
[2025-12-12 13:23:30] DEBUG rms_current_max = 90
[2025-12-12 13:23:30] DEBUG warn_d_p_s = 0
[2025-12-12 13:23:30] DEBUG linkquality = 255
[2025-12-12 13:23:30] DEBUG [Prises ZigBee][Chauffage Enfants] : MQTT-->Jeedom, Topic=zigbee2mqtt/Chauffage Enfants, Payload={"current":0,"device":{"applicationVersion":66,"dateCode":"","friendlyName":"Chauffage Enfants","hardwareVersion":1,"ieeeAddr":"0xcc86ecfffe35c306","manufacturerID":4098,"manufacturerName":"_TZ3000_8nkb7mof","model":"TS0121_plug","networkAddress":24738,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":2.63,"linkquality":255,"power":0,"state":"OFF","voltage":235}
[2025-12-12 13:23:30] DEBUG state = converted:0
[2025-12-12 13:23:30] DEBUG power = 0
[2025-12-12 13:23:30] DEBUG current = 0
[2025-12-12 13:23:30] DEBUG voltage = 235
[2025-12-12 13:23:30] DEBUG energy = 2.63
[2025-12-12 13:23:30] DEBUG [Prises ZigBee][Diffuseur Febreze Prise] : MQTT-->Jeedom, Topic=zigbee2mqtt/Diffuseur Febreze Prise, Payload={"current":0,"device":{"friendlyName":"Diffuseur Febreze Prise","ieeeAddr":"0x84fd27fffe5f01f8","manufacturerID":4098,"manufacturerName":"_TZ3000_8nkb7mof","model":"TS0121_plug","networkAddress":280,"powerSource":"Battery","type":"Router"},"energy":7.26,"linkquality":255,"power":0,"state":"ON","voltage":235}
[2025-12-12 13:23:30] DEBUG state = converted:1
[2025-12-12 13:23:30] DEBUG energy = 7.26
[2025-12-12 13:23:31] DEBUG <--- MQTT message, ieeeAddr not found (Dans l'interface Zigbee2MQTT, vérifiez que vous avez activé l'option Settings->MQTT->Include device information) [2025-12-12 13:23:31] DEBUG Données reçues : { "manufacturerdata": "d200003c", "name": "nut", "id": "5A:90:56:B0:E2:36", "rssi": -82, "servicedatauuid": "180a", "servicedata": "5a9056b0e236", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "track": true, "device": "nut Tracker" }
[2025-12-12 13:23:37] DEBUG [Prises ZigBee][LED TV Chambre] : MQTT-->Jeedom, Topic=zigbee2mqtt/LED TV Chambre, Payload={"current":0,"device":{"applicationVersion":192,"dateCode":"","friendlyName":"LED TV Chambre","hardwareVersion":1,"ieeeAddr":"0xa4c1382acdaf1220","manufacturerID":4417,"manufacturerName":"_TZ3000_2putqrmw","model":"A1Z","networkAddress":16829,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":0,"linkquality":255,"power":0,"state":"OFF","voltage":231}
[2025-12-12 13:23:37] DEBUG state = converted:0
[2025-12-12 13:23:37] DEBUG power = 0
[2025-12-12 13:23:37] DEBUG current = 0
[2025-12-12 13:23:37] DEBUG voltage = 231
[2025-12-12 13:23:37] DEBUG energy = 0
[2025-12-12 13:23:37] DEBUG linkquality = 255
[2025-12-12 13:23:38] DEBUG [Prises ZigBee][Lampe Salon] : MQTT-->Jeedom, Topic=zigbee2mqtt/Lampe Salon, Payload={"current":0,"device":{"applicationVersion":192,"dateCode":"","friendlyName":"Lampe Salon","hardwareVersion":1,"ieeeAddr":"0xa4c138e87a4a7eff","manufacturerID":4417,"manufacturerName":"_TZ3000_typdpbpg","model":"TS011F_plug_1","networkAddress":51909,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":79.81,"linkquality":255,"power":0,"state":"OFF","voltage":233}
[2025-12-12 13:23:38] DEBUG state = converted:0
[2025-12-12 13:23:38] DEBUG power = 0
[2025-12-12 13:23:38] DEBUG current = 0
[2025-12-12 13:23:38] DEBUG voltage = 233
[2025-12-12 13:23:38] DEBUG energy = 79.81
[2025-12-12 13:23:38] DEBUG linkquality = 255
[2025-12-12 13:23:39] DEBUG <--- MQTT message, ieeeAddr not found (Dans l'interface Zigbee2MQTT, vérifiez que vous avez activé l'option Settings->MQTT->Include device information) [2025-12-12 13:23:39] DEBUG Données reçues : { "manufacturerdata": "d200003c", "name": "nut", "id": "5A:90:56:B0:E2:36", "rssi": -82, "servicedatauuid": "180a", "servicedata": "5a9056b0e236", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "track": true, "device": "nut Tracker" }
[2025-12-12 13:23:44] DEBUG [Prises ZigBee][Projecteur Alarme] : MQTT-->Jeedom, Topic=zigbee2mqtt/Projecteur Alarme, Payload={"current":0,"device":{"applicationVersion":192,"dateCode":"","friendlyName":"Projecteur Alarme","hardwareVersion":1,"ieeeAddr":"0xa4c138c0a1fff637","manufacturerID":4417,"manufacturerName":"_TZ3000_gjnozsaz","model":"NAS-WR01B","networkAddress":33430,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":0.05,"linkquality":255,"power":0,"voltage":235}
[2025-12-12 13:23:44] DEBUG power = 0
[2025-12-12 13:23:44] DEBUG current = 0
[2025-12-12 13:23:44] DEBUG voltage = 235
[2025-12-12 13:23:44] DEBUG energy = 0.05
[2025-12-12 13:23:44] DEBUG linkquality = 255
[2025-12-12 13:23:49] DEBUG [Prises ZigBee][Lampe Salon] : MQTT-->Jeedom, Topic=zigbee2mqtt/Lampe Salon, Payload={"current":0,"device":{"applicationVersion":192,"dateCode":"","friendlyName":"Lampe Salon","hardwareVersion":1,"ieeeAddr":"0xa4c138e87a4a7eff","manufacturerID":4417,"manufacturerName":"_TZ3000_typdpbpg","model":"TS011F_plug_1","networkAddress":51909,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":79.81,"linkquality":255,"power":0,"state":"OFF","voltage":233}
[2025-12-12 13:23:49] DEBUG state = converted:0
[2025-12-12 13:23:49] DEBUG power = 0
[2025-12-12 13:23:49] DEBUG current = 0
[2025-12-12 13:23:49] DEBUG voltage = 233
[2025-12-12 13:23:49] DEBUG energy = 79.81
[2025-12-12 13:23:49] DEBUG linkquality = 255
[2025-12-12 13:23:49] DEBUG [Prises ZigBee][Prise Diffuseur] : MQTT-->Jeedom, Topic=zigbee2mqtt/Prise Diffuseur, Payload={"current":0,"device":{"applicationVersion":192,"dateCode":"","friendlyName":"Prise Diffuseur","hardwareVersion":1,"ieeeAddr":"0xa4c138a7ef812e02","manufacturerID":4417,"manufacturerName":"_TZ3000_typdpbpg","model":"TS011F_plug_1","networkAddress":44236,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":2.1,"linkquality":255,"power":0,"state":"OFF","voltage":232}
[2025-12-12 13:23:49] DEBUG voltage = 232
[2025-12-12 13:23:49] DEBUG energy = 2.1
[2025-12-12 13:23:49] DEBUG [Prises ZigBee][Prise Diffuseur] : MQTT-->Jeedom, Topic=zigbee2mqtt/Prise Diffuseur, Payload={"current":0,"device":{"applicationVersion":192,"dateCode":"","friendlyName":"Prise Diffuseur","hardwareVersion":1,"ieeeAddr":"0xa4c138a7ef812e02","manufacturerID":4417,"manufacturerName":"_TZ3000_typdpbpg","model":"TS011F_plug_1","networkAddress":44236,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":2.1,"linkquality":255,"power":0,"state":"OFF","voltage":234}
[2025-12-12 13:23:49] DEBUG voltage = 234
