J’ai voulu faire ce jour un upgrade de la 4.4.6 à la 4.4.12. Celle-ci ne s’est pas bien déroulée et je n’ai maintenant plus accès à ma jeedom (sauf en ftp). Je suis sous PHP 8.3.11 sous raspberry pi en Debian 11.11.
Le log de l’update :
> [START UPDATE]
[PROGRESS][1]
****Update from 4.4.6 (2024-09-05 16:07:01)****
Parameters : {"preUpdate":"0","backup::before":"1","core":"1","force":"0","plugins":"0","update::reapply":""}
Send begin of update event...OK
[PROGRESS][5]
Check rights...
OK
[START BACKUP]
***************Start of Jeedom backup at 2024-09-05 16:07:22***************
Send begin backup event...OK
Checking files rights...
OK
Checking database...
OK
Backing up database...
OK
Cache persistence:
OK
Creating archive...
OK
Cleaning old backup...OK
Limiting backup size to 5000 Mb...
Delete: /var/www/html/core/php/../../backup/backup-Jeedom_Brunet-4.4.6-2024-08-31-03h24.tar.gz
OK
Backup name: /var/www/html/core/php/../../backup/backup-Jeedom_Brunet-4.4.6-2024-09-05-16h07.tar.gz
OK
Send end backup event...OK
Backup operation duration: 253s
***************Jeedom backup end***************
[END BACKUP SUCCESS]
[PROGRESS][10]
[PROGRESS][15]
Download url : https://github.com/jeedom/core/archive/V4-stable.zip
Download in progress...--2024-09-05 16:11:35-- https://github.com/jeedom/core/archive/V4-stable.zip
Resolving github.com (github.com)... 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable [following]
--2024-09-05 16:11:36-- https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable
Resolving codeload.github.com (codeload.github.com)... 140.82.121.10
Connecting to codeload.github.com (codeload.github.com)|140.82.121.10|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K ........ ........ ........ ........ ........ .....
... 5.99M
3072K ........ ........ ........ ........ ........ ........ 6.93M
6144K ........ ........ ........ ........ ........ ........ 6.18M
9216K ........ ........ ........ ........ ........ ........ 7.66M
12288K ........ ........ ........ ........ ........ ........ 5.57M
15360K ........ ....
.... ........ ........ ........ ........ 7.32M
18432K ........ ........ ........ ........ ........ ........ 7.45M
21504K ........ ........ ........ ........ ........ ........ 8.46M
24576K ........ ........ ........ ........ ........ ........ 8.40M
27648K ........ ........ ........ ........ ........ ........ 7.51M
30720K ........ ........ ........ ....
.... ........ ........ 8.28M
33792K ........ ........ ........ ........ ........ ........ 7.68M
36864K ........ ........ ........ ........ ........ ........ 8.55M
39936K ........ ........ ........ ........ ........ ........ 8.52M
43008K ........ ........ ........ ........ ........ ........ 7.42M
46080K ........ ........ ........ ........ ........ ..
...... 8.53M
49152K ........ ........ ........ ........ ........ ........ 8.62M
52224K ........ ........ ........ ........ ........ ........ 7.52M
55296K ........ ........ ........ ........ ........ ........ 8.33M
58368K ........ ........ ........ ........ ........ ........ 8.74M
61440K ........ ........ ........ ........ ........ ........ 7.51M
64512K ........ ........ ..
67584K ........ ........ ........ ........ ........ ........ 8.48M
70656K ........ ........ ........ ........ ........ ........ 7.66M
73728K ........ ........ ........ ........ ........ ........ 8.64M
76800K ........ ........ ........ ........ ........ ........ 8.59M
79872K ........ ........ ........ ........ ........ .....
... 8.65M
82944K ........ ........ ........ ........ ........ ........ 9.11M
86016K . 17.0M=11s
2024-09-05 16:11:47 (7.78 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [88193019]
[PROGRESS][25]
OK
Cleaning folders...OK
[PROGRESS][30]
Create temporary folder...OK
[PROGRESS][35]
Unzip in progress...
OK
[PROGRESS][40]
Clean temporary files (tmp)...OK
Disable all task
kill: (96686): No such process
. OK
Disable all scenario....................
.........kill: (108940): No such process
.... OK
[PROGRESS][45]
Moving files...
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/de_DE/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/en_US/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/es_ES/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/fr_FR/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/pt_PT/noteVersion.md because size is 0
OK
[PROGRESS][50]
Remove temporary files...OK
[PROGRESS][52]
Remove useless files...
Cleaning 3rdparty
Cleaning desktop
Cleaning mobile
Cleaning core
Cleaning docs
Cleaning install
Cleaning script
find: '/var/www/html/install/../script/*': No such file or directory
OK
[PROGRESS][53]
Update composer file...
OK
[PROGRESS][58]
Update jeedom information date...
PHP Fatal error: Uncaught Error: Class "update" not found in /var/www/html/install/update.php:254
Stack trace:
#0 {main}
thrown in /var/www/html/install/update.php on line 254
Je précise que j’ai vu cette erreur dans ce poste mais j’avoue ne pas avoir identifié comment m’en sortir.
