Ta console est sur quel périphérique ? UDM ?
Sur VM, debian 11.
Edit : je suis repassé en 7.5.187.
Tu vas rigoler mais après la mise à jour des dépendances
, je n’ai plus les évènements qui remontent
By accessing the wireless network, you acknowledge that you're of legal age, you have read and understood and agree to be bound this agreement.
You agree not to use the wireless network for any purpose that is unlawful and take full responsibility of your acts.
The wireless network is provided \"as is\" without warranties of any kind, either expressed or implied.","key":"guest_access","portal_customized_bg_color":"#233041","portal_customized_logo_position":"center","restricted_subnet_3":"10.0.0.0\/8","expire_unit":1,"restricted_subnet_2":"172.16.0.0\/12","restricted_subnet_1":"192.168.0.0\/16","voucher_enabled":false,"wechat_enabled":false,"portal_customized_box_text_color":"#000000","redirect_to_https":false,"portal_customized_authentication_text":"Select Your authentication method"},"ntp":{"setting_preference":"auto","site_id":"607c57fd0ddad139c8d36b0d","ntp_server_1":"0.ubnt.pool.ntp.org","_id":"607c58010ddad139c8d36b17","ntp_server_2":"1.ubnt.pool.ntp.org","ntp_server_3":"2.ubnt.pool.ntp.org","ntp_server_4":"3.ubnt.pool.ntp.org","key":"ntp"},"mgmt":{"led_enabled":true,"x_ssh_bind_wildcard":false,"wifiman_enabled":true,"direct_connect_enabled":false,"advanced_feature_enabled":true,"x_api_token":"vhOaeT7cgP5WX3XKS5dhgX54SRnIdma0QtAoT6XbnJ8seFmp1GCGroosWpRlxMhu","x_ssh_auth_password_enabled":true,"x_mgmt_key":"9e1e58050e11c4a6b136f9226884a9e6","x_ssh_sha512passwd":"OBFUSCATED","unifi_idp_enabled":true,"x_ssh_username":"zeit54","site_id":"607c57fd0ddad139c8d36b0d","x_ssh_keys":[],"debug_tools_enabled":false,"_id":"607c58010ddad139c8d36b18","auto_upgrade":true,"x_ssh_password":"OBFUSCATED","key":"mgmt","x_ssh_enabled":true,"auto_upgrade_hour":4},"dpi":{"fingerprintingEnabled":true,"site_id":"607c57fd0ddad139c8d36b0d","_id":"607c58010ddad139c8d36b19","key":"dpi","enabled":true},"lcm":{"brightness":80,"touch_event":true,"site_id":"607c57fd0ddad139c8d36b0d","_id":"607c58010ddad139c8d36b1a","idle_timeout":300,"sync":true,"key":"lcm","enabled":true},"usg":{"h323_module":true,"send_redirects":true,"upnp_enabled":false,"broadcast_ping":false,"geo_ip_filtering_traffic_direction":"both","mss_clamp_mss":1452,"tcp_close_timeout":10,"upnp_secure_mode":true,"tcp_fin_wait_timeout":120,"upnp_wan_interface":"WAN","geo_ip_filtering_block":"block","geo_ip_filtering_countries":"","offload_sch":true,"other_timeout":600,"firewall_wan_default_log":true,"arp_cache_timeout":"normal","icmp_timeout":30,"key":"usg","echo_server":"ping.ui.com","geo_ip_filtering_enabled":false,"udp_other_timeout":30,"firewall_lan_default_log":false,"gre_module":true,"arp_cache_base_reachable":30,"timeout_setting_preference":"auto","tcp_time_wait_timeout":120,"ftp_module":true,"firewall_guest_default_log":false,"offload_accounting":true,"mss_clamp":"auto","udp_stream_timeout":180,"receive_redirects":false,"syn_cookies":true,"tcp_last_ack_timeout":30,"upnp_nat_pmp_enabled":true,"site_id":"607c57fd0ddad139c8d36b0d","tftp_module":true,"offload_l2_blocking":true,"tcp_syn_recv_timeout":60,"_id":"607c58010ddad139c8d36b1b","tcp_close_wait_timeout":60,"tcp_syn_sent_timeout":120,"tcp_established_timeout":7440,"pptp_module":true,"sip_module":true},"usw":{"dhcp_snoop":true,"site_id":"607c57fd0ddad139c8d36b0d","_id":"607c58010ddad139c8d36b1c","key":"usw"},"rsyslogd":{"this_controller":true,"debug":false,"netconsole_enabled":false,"this_controller_encrypted_only":true,"port":"514","netconsole_host":"","ip":"","site_id":"607c57fd0ddad139c8d36b0d","netconsole_port":"514","_id":"607c58010ddad139c8d36b1d","key":"rsyslogd","enabled":true},"country":{"code":"250","site_id":"607c57fd0ddad139c8d36b0d","_id":"607c588c0ddad139c8d36b2d","key":"country"},"locale":{"timezone":"Europe\/Paris","site_id":"607c57fd0ddad139c8d36b0d","_id":"607c588c0ddad139c8d36b2e","key":"locale"},"network_optimization":{"site_id":"607c57fd0ddad139c8d36b0d","_id":"607c588c0ddad139c8d36b30","key":"network_optimization","enabled":true},"radio_ai":{"setting_preference":"auto","channels_na":["36","40","44","48"],"auto_adjust_channels_to_country":true,"ht_modes_na":["20","40"],"ht_modes_ng":["20"],"channels_ng":["1","6","11"],"enabled":true,"default":true,"optimize":["channel"],"cron_expr":"0 3 * * *","radios":["ng","na"],"auto_enabled":false,"site_id":"607c57fd0ddad139c8d36b0d","exclude_devices":[],"_id":"607c588caebcc090a5875396","key":"radio_ai"},"ips":{"utm_token":"10e3bd0ac175d54dab816c1408436fd24495e68199e372c9da3b884e6c3345db0","enabled_categories":["botcc","emerging-worm","emerging-malware","emerging-mobile","tor","emerging-exploit","emerging-shellcode","dshield"],"advanced_filtering_preference":"auto","dns_filters":[{"filter":"none","network_id":"607c58010ddad139c8d36b1e","blocked_tld":[],"blocked_sites":[],"allowed_sites":[],"name":"","description":"","version":"v4"},{"filter":"none","network_id":"63e77add38c2d616516b9072","blocked_tld":[],"blocked_sites":[],"allowed_sites":[],"name":"","description":"","version":"v4"}],"dns_filtering":true,"last_alert_id":"1633315-2023-11-22T09:10:25.108262+0100","enabled_networks":["607c58010ddad139c8d36b1e","63e77add38c2d616516b9072"],"restrict_ip_addresses":true,"ips_mode":"ids","ad_blocking_configurations":[],"site_id":"607c57fd0ddad139c8d36b0d","suppression":{"alerts":[],"whitelist":[]},"_id":"6090360ac9e77c0015da30b1","restrict_tor":true,"key":"ips","honeypot_enabled":false},"auto_speedtest":{"cron_expr":"0 5 * * *","site_id":"607c57fd0ddad139c8d36b0d","_id":"613c51d546e0fb0016057a4a","key":"auto_speedtest","enabled":false},"radius":{"acct_port":1813,"interim_update_interval":3600,"site_id":"607c57fd0ddad139c8d36b0d","auth_port":1812,"tunneled_reply":true,"_id":"61bef76946e0fb001b1756d5","key":"radius","enabled":false,"x_secret":"OBFUSCATED","configure_whole_network":true},"teleport":{"site_id":"607c57fd0ddad139c8d36b0d","_id":"626999a846e0fb0018bab70a","key":"teleport","enabled":false},"global_switch":{"stp_version":"rstp","flowctrl_enabled":false,"dot1x_fallback_networkconf_id":"","dot1x_portctrl_enabled":false,"dhcp_snoop":true,"site_id":"607c57fd0ddad139c8d36b0d","jumboframe_enabled":true,"_id":"62f031e5c234228b05050c6e","key":"global_switch","radiusprofile_id":"607c58010ddad139c8d36b27","switch_exclusions":[]},"magic_site_to_site_vpn":{"public_key":"s\/I7Ta9jhYjszmPQILHDMgY1ISlOTekYpddYu2SXElY=","site_id":"607c57fd0ddad139c8d36b0d","_id":"641a626507fa2a4c5fe446fe","x_private_key":"0KiDYnJs3H7QyUXowCCkw0K+tWcpJT\/aLLSid8JxJW4=","enabled":true,"key":"magic_site_to_site_vpn"},"doh":{"server_names":["cloudflare","google"],"site_id":"607c57fd0ddad139c8d36b0d","_id":"64b5eaefd100c74415a989d8","state":"off","key":"doh"},"openvpn":{"x_pregenerated_dh_key":"LS0tLS1CRUdJTiBESCBQQVJBTUVURVJTLS0tLS0KTUlJQ0NnS0NBUUVBcDg3aGZDNWdURURzbTBxYXoybmNtRVozOGcyMTZZM1hlVGhKMmo2NEh2ZG5aMHExTWRyRgpRUENDeGVuQk84ci9BRnlqamJMaUpEeStwbHlNOUdRc25GS3VTL2tWdkNxa3BBQStablhGWFZMVzIrNXhtQitwCklTd0VkNDNBS2o4NzVIa2pGSmdjU1FyR3ZaSkZhMkNnMVJ2OVArMHFpYWEzbnlSZFJ3bTB5MUJiS1JhU2V5elAKN0ZKcmorVENWVjNwVG1YVW9vdHFOOHp5cHRYTzV3eXhWRC9qWDBnNDhkSHg1TG1CUXpuT3QrRlpnWHE0TURiOQo3bW1UVkl2b05FUTVjYUM3WWZ3SzFNT2d1MzBUVGJSREQzTXBBUlptelpyRUxqbmNNa3ZqR2RRYU05aEd0Qk4zClZGcFhSTWxWaUFPL09nZlFxWW1RbEFHNUE0dThJYXBTOVFLQ0FRRUFpQXhQNHVXb0VTbGNUWHZ6ZmZmMTJDaFEKOTBQT21sN3FLUGd4cnYwM1BzUVhjTUV5Qm51Ykcva0lLT0hsRVhlakxqcGdFZ0FNejZsNXh5TEpiNFhXN0tZWQpMdy90V2dqS29BdENrYWpES2xSeE1iM1FyTkxhQWRnOE5QcGo4aUxwTjExL2pKa2tzT2JoTENFZE1RZ3IzVFBECmpPQkZ0MTRWekxNaG1VN3hjb1NyZDloRGlEdzBlYUdQalFHdm0rbm5ocWg4cmhPNHp1OHRLbUdwNkdsUlFMVzgKYkZsMzlFSk0zKzdvU0dXVkp3QTBDWnJOVjhIUUNoR2pKM1ZmVVJmS0N0QTdGT2FJVGZQbHJqSUl4Z2dDU1JBRgoxWVJtUVBQTERyRWtmbkZSWWlSUmNJc1N3Znpqa1JPeThzajZybWNFUGRmYjJzcVpKeWEyVFRoWXNzemdaZz09Ci0tLS0tRU5EIERIIFBBUkFNRVRFUlMtLS0tLQo=","site_id":"607c57fd0ddad139c8d36b0d","_id":"655d33f7ddddc74f9543ca93","key":"openvpn"}}
[2023-11-22 10:01:22][INFO] : Évènement getWLanSettings
[2023-11-22 10:01:22][DEBUG] : Évènement getWLanSettings : [{"setting_preference":"auto","dtim_6e":3,"wpa3_support":false,"minrate_na_advertising_rates":false,"wpa_mode":"wpa2","minrate_setting_preference":"auto","minrate_ng_advertising_rates":false,"radius_das_enabled":false,"group_rekey":0,"radius_macacl_format":"none_lower","pmf_mode":"disabled","wpa3_transition":false,"mcastenhance_enabled":false,"usergroup_id":"607c58010ddad139c8d36b1f","proxy_arp":false,"uapsd_enabled":false,"iapp_enabled":true,"name":"LeCroule","site_id":"607c57fd0ddad139c8d36b0d","hide_ssid":false,"_id":"607c588c0ddad139c8d36b2f","no2ghz_oui":true,"x_iapp_key":"ba4b08449073c1f37e57af129eb785aa","networkconf_id":"607c58010ddad139c8d36b1e","dtim_na":3,"is_guest":false,"minrate_na_enabled":false,"enabled":true,"wlan_bands":[],"mac_filter_policy":"allow","security":"wpapsk","ap_group_ids":["607c58010ddad139c8d36b28"],"l2_isolation":false,"minrate_ng_enabled":true,"bss_transition":true,"minrate_ng_data_rate_kbps":1000,"radius_mac_auth_enabled":false,"wpa3_fast_roaming":false,"ap_group_mode":"all","wpa3_enhanced_192":false,"fast_roaming_enabled":false,"wpa_enc":"ccmp","x_passphrase":"1ACDE745C34EEE6A2131DDEA25","mac_filter_list":[],"dtim_mode":"default","element_adopt":false,"minrate_na_data_rate_kbps":6000,"mac_filter_enabled":false,"dtim_ng":1},{"setting_preference":"manual","wpa3_support":false,"dtim_6e":3,"minrate_na_advertising_rates":false,"wpa_mode":"wpa2","minrate_setting_preference":"auto","minrate_ng_advertising_rates":false,"hotspot2conf_enabled":false,"optimize_iot_wifi_connectivity":true,"b_supported":true,"radius_das_enabled":false,"group_rekey":0,"radius_macacl_format":"none_lower","pmf_mode":"disabled","sae_psk_vlan_required":false,"wpa3_transition":false,"bc_filter_enabled":false,"tdls_prohibit":false,"usergroup_id":"607c58010ddad139c8d36b1f","mcastenhance_enabled":false,"schedule_enabled":false,"proxy_arp":false,"country_beacon":false,"uapsd_enabled":false,"iapp_enabled":true,"name":"LeCroule2.4","site_id":"607c57fd0ddad139c8d36b0d","hide_ssid":false,"wlan_band":"2g","schedule_reversed":false,"_id":"607c5a770ddad139c8d36b3b","no2ghz_oui":false,"x_iapp_key":"1148660a17dd0e39c5397c28556903e8","auth_cache":true,"networkconf_id":"607c58010ddad139c8d36b1e","dtim_na":3,"is_guest":false,"minrate_na_enabled":false,"sae_groups":[],"enabled":true,"sae_psk":[],"wlan_bands":["2g"],"mac_filter_policy":"allow","p2p_cross_connect":false,"security":"wpapsk","wep_idx":1,"ap_group_ids":["607c58010ddad139c8d36b28"],"l2_isolation":false,"minrate_ng_enabled":true,"wpa3_fast_roaming":false,"bss_transition":true,"minrate_ng_data_rate_kbps":1000,"radius_mac_auth_enabled":false,"schedule_with_duration":[],"pmf_cipher":"auto","ap_group_mode":"all","wpa3_enhanced_192":false,"vlan_enabled":false,"fast_roaming_enabled":false,"rrm_enabled":false,"wpa_enc":"ccmp","x_passphrase":"1ACDE745C34EEE6A2131DDEA25","radius_macacl_empty_password":false,"mac_filter_list":[],"dtim_mode":"default","p2p":false,"schedule":[],"element_adopt":false,"bc_filter_list":[],"dpi_enabled":false,"minrate_na_data_rate_kbps":6000,"mac_filter_enabled":false,"dtim_ng":1},{"setting_preference":"manual","dtim_6e":3,"wpa3_support":false,"minrate_na_advertising_rates":false,"wpa_mode":"wpa2","minrate_setting_preference":"auto","minrate_ng_advertising_rates":false,"optimize_iot_wifi_connectivity":false,"b_supported":false,"radius_das_enabled":false,"group_rekey":0,"radius_macacl_format":"none_lower","pmf_mode":"disabled","wpa3_transition":false,"mcastenhance_enabled":false,"usergroup_id":"607c58010ddad139c8d36b1f","proxy_arp":false,"uapsd_enabled":false,"iapp_enabled":true,"name":"Invite","site_id":"607c57fd0ddad139c8d36b0d","hide_ssid":false,"wlan_band":"both","_id":"63e2846838c2d616516868bd","no2ghz_oui":true,"x_iapp_key":"66ebd4ab76225bb2f8bddb5b081e129e","networkconf_id":"63e77add38c2d616516b9072","dtim_na":3,"is_guest":false,"minrate_na_enabled":false,"sae_groups":[],"enabled":true,"sae_psk":[],"wlan_bands":["5g","2g"],"mac_filter_policy":"allow","security":"wpapsk","ap_group_ids":["607c58010ddad139c8d36b28"],"l2_isolation":true,"minrate_ng_enabled":true,"bss_transition":true,"minrate_ng_data_rate_kbps":1000,"radius_mac_auth_enabled":false,"wpa3_fast_roaming":false,"schedule_with_duration":[],"ap_group_mode":"all","wpa3_enhanced_192":false,"fast_roaming_enabled":false,"wpa_enc":"ccmp","x_passphrase":"2d2746532762215e532f2e6f41496a7a7e5a57316e7e305a567b6c3b76","mac_filter_list":[],"dtim_mode":"default","schedule":[],"bc_filter_list":[],"minrate_na_data_rate_kbps":6000,"mac_filter_enabled":false,"dtim_ng":1}]
[2023-11-22 10:01:23][INFO] : Évènement checkControllerUpdate
[2023-11-22 10:01:23][DEBUG] : Évènement checkControllerUpdate : {"latest":"7.2.97","download_link":"https:\/\/fw-download.ubnt.com\/data\/unifi-controller\/e1f2-debian-7.2.97-c3d73be1d6e14b35ae804ac666ceeade.deb","has_upgradable_controller":false}
[2023-11-22 10:01:23][INFO] : ÉvènementgetSiteSettings
[2023-11-22 10:01:23][DEBUG] : ÉvènementgetSiteSettings : {"super_identity":{"hostname":"UDM","name":"Dream Machine","_id":"607c58010ddad139c8d36b11","key":"super_identity"},"super_mgmt":{"data_retention_time_in_hours_for_5minutes_scale":24,"analytics_disapproved_for":"7.5.187","autobackup_post_actions":["copy_cloud"],"enable_analytics":false,"data_retention_time_in_hours_for_hourly_scale":168,"data_retention_time_in_hours_for_daily_scale":2160,"multiple_sites_enabled":false,"minimum_usable_hd_space":500,"autobackup_max_files":10,"data_retention_setting_preference":"auto","live_chat":"disabled","live_updates":"auto","override_inform_host":false,"auto_upgrade":false,"autobackup_cron_expr":"0 4 * * 1","key":"super_mgmt","data_retention_time_in_hours_for_monthly_scale":8760,"autobackup_enabled":true,"time_series_per_client_stats_enabled":true,"autobackup_timezone":"Europe\/Paris","data_retention_time_in_hours_for_others":2160,"discoverable":true,"google_maps_api_key":"OBFUSCATED","autobackup_days":60,"backup_to_cloud_enabled":true,"_id":"607c58010ddad139c8d36b12"},"super_cloudaccess":{"device_auth":"OBFUSCATED","device_id":"8737f9e5-3556-41a7-993b-44671b874496","ubic_uuid":"f0062f24-57ea-48d9-9251-5404e8a8fa5e","x_certificate_arn":"OBFUSCATED","_id":"607c58020ddad139c8d36b29","x_private_key":"OBFUSCATED","x_certificate_pem":"OBFUSCATED","key":"super_cloudaccess","enabled":true},"super_fingerbank":{"fingerbank_key":"1398f353e68c95832f02fd3faf7ee792d91ebc29","_id":"607c58040ddad139c8d36b2a","key":"super_fingerbank"},"super_sdn":{"sso_login_enabled":true,"ubic_uuid":"f0062f24-57ea-48d9-9251-5404e8a8fa5e","_id":"607c588c0ddad139c8d36b34","key":"super_sdn"},"super_mail":{"provider":"cloud","_id":"607c58990ddad139c8d36b35","key":"super_mail"},"super_fwupdate":{"sso_enabled":false,"available_controller_channels":["release"],"controller_channel":"release","firmware_channel":"release","_id":"607c589c0ddad139c8d36b36","available_firmware_channels":["release"],"key":"super_fwupdate"},"connectivity":{"uplink_type":"gateway","x_mesh_psk":"2929968a58c202544468ff7a5f3ef3fc","site_id":"607c57fd0ddad139c8d36b0d","_id":"607c58010ddad139c8d36b13","x_mesh_essid":"vwire-03c87da5bf48d63a","key":"connectivity","enabled":true},"element_adopt":{"x_element_essid":"element-06e399c01f3472fd","site_id":"607c57fd0ddad139c8d36b0d","x_element_psk":"6d448a17bd242b9af893bdd81d99c64e","_id":"607c58010ddad139c8d36b14","key":"element_adopt","enabled":true},"guest_access":{"portal_customized_title":"UniFi Guest WiFi","auth":"hotspot","redirect_https":true,"portal_enabled":true,"portal_customized_button_color":"#1379b7","payment_enabled":false,"portal_customized_bg_image_tile":false,"portal_customized_button_text_color":"#ffffff","portal_hostname":"","portal_customized_box_link_color":"#1379b7","portal_use_hostname":false,"portal_customized_link_color":"#00db9e","portal_customized_box_radius":25,"redirect_enabled":false,"radius_enabled":false,"password_enabled":true,"portal_customized_welcome_text_position":"under_logo","radius_disconnect_enabled":false,"portal_customized_box_opacity":90,"ec_enabled":true,"radiusprofile_id":"607c58010ddad139c8d36b27","portal_customized_bg_type":"color","portal_customized_tos_enabled":false,"expire":1440,"site_id":"607c57fd0ddad139c8d36b0d","template_engine":"angular","portal_customized_box_color":"#ffffff","_id":"607c58010ddad139c8d36b16","custom_ip":"","facebook_enabled":false,"redirect_url":"","radius_auth_type":"mschapv2","portal_customized_logo_enabled":true,"portal_customized_text_color":"#ffffff","portal_customized_welcome_text_enabled":false,"radius_disconnect_port":3799,"portal_customized":false,"portal_customized_languages":["fr"],"portal_customized_button_text":"Login","portal_customized_welcome_text":"","portal_customized_bg_image_enabled":true,"portal_customized_success_text":"Welcome to UniFi Guest WiFi Hotspot","expire_number":1,"x_password":"esvres","x_stripe_api_key":"","portal_customized_logo_size":128,"portal_customized_tos":"Terms of Use
On dirait qu’ils ont retiré les évenements de type « Alert » sur la v8.
je vais contourner en utilisant un autre évènement que je n’utilisais pas jusqu’ici car beaucoup plus lent que les alertes… mais bon voilà pas le choix
C’est poussé en beta ! (plus lent qu’avant… dans mes tests l’évenement arrivait parfois plusieurs minutes après l’alerte)
Ceux qui utilisent le hotspot peuvent tester aussi et fournir le log démon svp ?
Chez eux ? j’ai déjà fait un ticket quand on avait eu le problème l’autre fois, ils veullent pas donner du support pour la partie websocket et evenement… donc ça m’étonnerait qu’ils l’annoncent officiellement, en fait ça utilise les evenements de l’interface web… donc s’ils ont décidé de passer par event plutot que alerte, et qu’ils ont adapté leur page web, ils écrivent rien car au final, il n’y a pas de problème pour eux…
J’ai fait la mise à jour et ça a l’air de fonctionner
@nebz
j’ai poussé en stable.
Je ne sais pas si c’est exactement le même problème au pire je créé un autre topic.
Je suis avec:
- la dernière version du plugin (2023-11-27 07:37:01)
- jeedom en 4.3.20
- jeedom sur une debian 11.8
- l’unifi Network est en version 8.0.7
Les dépendances ont été ré-installées.
Le jeedom rebooté (dans un cas de miracle
A noter que le daemon ne se démarrer pas avant la maj du plugin et de l’unifi Network
J’ai mis en PJ le log du daemon en debug
Unifi_daemon_debug.txt (11,3 Ko)
Cordialement
Bon…
Quelque chose d’incompréhensible, j’ai remis le même mot de passe (dans le plugin) puis re sauvegardé et relancé le daemon et la nickel.
Désolé pour le bruit.
Par contre, je n’ai aucune remontée :
Mais je les vois bien dans le log du daemon
Tu as vérifié ces paramètres
Regarde s’il y a pas une nouvelle version, j’ai encore fait quelques correctifs apres
Oui, je n’avais que le UP down de coché.
Mais par acquis de conscience, je les ai coché puis decoché mais pareil
Il ne me propose que celle là en stable…
il a probablement changé de mac adresse ou il est désactivé, sinon Supprime ton redmi et re scan (en ayant retiré ceux de la poubelle )
Ah je viens de voir que ton démon démarre pas, vérifie ton ip, le port, le site et ton login et pass locaux.
Et tu es hors sujet.
