Tu peux me guider ?
Ouvres un tickets au support et je te le fait (faut l’accès support). C’est pas simple à expliquer
Ok, je suis en train de downgrader ma clé conbee2 des fois que ça soit ça qui pose problème.
J’ai lu " Warning: Conbee 2 firmware versions newer than 0x26580700 will result in an unstable network with devices dropping randomly, see Issue 9554"
Le daemon ne veut plus démarrer ![]()
[2024-09-23 13:20:08] e[31merrore[39m: z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2024-09-23 13:20:08] e[31merrore[39m: z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2024-09-23 13:20:08] e[34mdebuge[39m: z2m: Loaded state from file /var/www/html/plugins/z2m/data/state.json
[2024-09-23 13:20:08] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 1.40.1 (commit #403d3c0)
[2024-09-23 13:20:08] e[32minfoe[39m: z2m: Starting zigbee-herdsman (0.57.3)
[2024-09-23 13:20:08] e[34mdebuge[39m: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":41781,\"extendedPanID\":[194,227,122,246,18,217,62,143],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/var/www/html/plugins/z2m/data/database.db\",\"databaseBackupPath\":\"/var/www/html/plugins/z2m/data/database.db.backup\",\"backupPath\":\"/var/www/html/plugins/z2m/data/coordinator_backup.json\",\"serialPort\":{\"path\":\"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2151040-if00\",\"adapter\":\"deconz\"},\"adapter\":{\"concurrent\":null,\"delay\":null,\"disableLED\":false}}"'
[2024-09-23 13:20:08] e[34mdebuge[39m: zh:deconz:driver: Set delay to 0
[2024-09-23 13:20:08] e[34mdebuge[39m: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":41781,"extendedPanID":[194,227,122,246,18,217,62,143],"channelList":[11]},"serialPort":{"path":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2151040-if00","adapter":"deconz"},"adapter":{"disableLED":false,"concurrent":null,"delay":null},"databasePath":"/var/www/html/plugins/z2m/data/database.db","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json"}'
[2024-09-23 13:20:08] e[34mdebuge[39m: zh:deconz:driver: Opening with /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2151040-if00
[2024-09-23 13:20:08] e[34mdebuge[39m: zh:deconz:driver: Serialport opened
[2024-09-23 13:20:08] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. seqNr: 1 paramId: 5
[2024-09-23 13:20:11] e[34mdebuge[39m: zh:deconz: checking coordinator simple descriptor
[2024-09-23 13:20:11] e[34mdebuge[39m: zh:deconz:driver: DATA_REQUEST - destAddr: 0x0 EP:0 SeqNr. 2 request id: 1
[2024-09-23 13:20:18] e[34mdebuge[39m: zh:deconz:driver: Timeout for request - CMD: 0xa seqNr: 1
[2024-09-23 13:20:18] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2024-09-23 13:20:18] e[31merrore[39m: z2m: Failed to start zigbee
[2024-09-23 13:20:18] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-09-23 13:20:18] e[31merrore[39m: z2m: Exiting...
[2024-09-23 13:20:18] e[31merrore[39m: z2m: undefined
@Loic
Je ne peux pas faire de demande au support, j’ai des plugins en beta…
EDIT:
J’ai trouvé, j’ai remplacé
homeassistant: []
optimistic: true
par
homeassistant:
optimistic: true
mais le daemon ne démarre toujours pas
> zigbee2mqtt@1.40.1 start
> node index.js
Starting Zigbee2MQTT without watchdog.
[2024-09-23 13:53:56] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2024-09-23 13:53:56] e[31merrore[39m: z2m: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/utils.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/settings.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js)
[2024-09-23 13:53:56] e[31merrore[39m: z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2024-09-23 13:53:56] e[31merrore[39m: z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2024-09-23 13:53:56] e[34mdebuge[39m: z2m: Loaded state from file /var/www/html/plugins/z2m/data/state.json
[2024-09-23 13:53:56] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 1.40.1 (commit #403d3c0)
[2024-09-23 13:53:56] e[32minfoe[39m: z2m: Starting zigbee-herdsman (0.57.3)
[2024-09-23 13:53:56] e[34mdebuge[39m: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":6754,\"extendedPanID\":[221,221,221,221,221,221,221,221],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/var/www/html/plugins/z2m/data/database.db\",\"databaseBackupPath\":\"/var/www/html/plugins/z2m/data/database.db.backup\",\"backupPath\":\"/var/www/html/plugins/z2m/data/coordinator_backup.json\",\"serialPort\":{\"path\":\"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2151040-if00\",\"adapter\":\"deconz\"},\"adapter\":{\"concurrent\":null,\"delay\":null,\"disableLED\":false}}"'
[2024-09-23 13:53:56] e[34mdebuge[39m: zh:deconz:driver: Set delay to 0
[2024-09-23 13:53:56] e[34mdebuge[39m: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"path":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2151040-if00","adapter":"deconz"},"adapter":{"disableLED":false,"concurrent":null,"delay":null},"databasePath":"/var/www/html/plugins/z2m/data/database.db","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json"}'
[2024-09-23 13:53:56] e[34mdebuge[39m: zh:deconz:driver: Opening with /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2151040-if00
[2024-09-23 13:53:56] e[34mdebuge[39m: zh:deconz:driver: Serialport opened
[2024-09-23 13:53:56] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. seqNr: 1 paramId: 5
[2024-09-23 13:53:59] e[34mdebuge[39m: zh:deconz: checking coordinator simple descriptor
[2024-09-23 13:53:59] e[34mdebuge[39m: zh:deconz:driver: DATA_REQUEST - destAddr: 0x0 EP:0 SeqNr. 2 request id: 1
[2024-09-23 13:54:06] e[34mdebuge[39m: zh:deconz:driver: Timeout for request - CMD: 0xa seqNr: 1
[2024-09-23 13:54:06] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2024-09-23 13:54:06] e[31merrore[39m: z2m: Failed to start zigbee
[2024-09-23 13:54:06] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-09-23 13:54:06] e[31merrore[39m: z2m: Exiting...
[2024-09-23 13:54:06] e[31merrore[39m: z2m: undefined
/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264
var er = new ERR_STREAM_WRITE_AFTER_END();
Error: write after end
at writeAfterEnd (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264:12)
at DerivedLogger.Writable.write (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:300:21)
at DerivedLogger.log (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/winston/lib/winston/logger.js:231:12)
at Logger.log (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/util/logger.ts:189:25)
at Logger.debug (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/util/logger.ts:210:14)
at Driver.processQueue (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:483:28)
at Timeout._onTimeout (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:163:22)
at listOnTimeout (node:internal/timers:581:17)
at processTimers (node:internal/timers:519:7)
Bon, comment puis-je faire une réinstallation de z2m sans perdre les équipements présents ?
C’est pas possible en faisant une reinstallation tu perds le fichier des modules et en zigbee a l’inverse du zwave rien n’est dans le controleur. La il semble avoir des soucis de communication avec la clef deconz je dirais.
Pourtant elle est bien détectée.
Relis mon message j’ai pas dit : pas detecté mais soucis de communication c’est different ca communique mais ne repond pas ce que z2m attend.
Oui, oui, j’avais bien compris dans ce sens.
Peut etre en retirant la clef et la remettant après 10min.
Je vais tenter. Merci
Je pense que la clé à un problème.
J’ai installé Z2M sur mon pc et j’ai des erreurs lors du lancement de Z2M.
> node index.js
[2024-09-23 20:00:41] info: z2m: Logging to console, file (filename: log.log)
[2024-09-23 20:00:41] info: z2m: Starting Zigbee2MQTT version 1.40.1 (commit #unknown)
[2024-09-23 20:00:41] info: z2m: Starting zigbee-herdsman (0.57.3)
[2024-09-23 20:00:41] error: zh:zstack:znp: Failed to determine if path is valid: 'Error: ENOENT: no such file or directory, lstat 'C:\Users\mathi\Downloads\zigbee2mqtt-master\COM4''
[2024-09-23 20:00:41] info: zh:zstack:znp: Opening SerialPort with {"path":"COM4","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-09-23 20:00:41] info: zh:zstack:znp: Serialport opened
[2024-09-23 20:00:42] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-09-23 20:00:43] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-09-23 20:01:01] error: z2m: Error while starting zigbee-herdsman
[2024-09-23 20:01:01] error: z2m: Failed to start zigbee
[2024-09-23 20:01:01] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-09-23 20:01:01] error: z2m: Exiting...
[2024-09-23 20:01:02] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (C:\Users\mathi\Downloads\zigbee2mqtt-master\node_modules\zigbee-herdsman\src\adapter\z-stack\adapter\zStackAdapter.ts:123:27)
at Controller.start (C:\Users\mathi\Downloads\zigbee2mqtt-master\node_modules\zigbee-herdsman\src\controller\controller.ts:138:29)
at Zigbee.start (C:\Users\mathi\Downloads\zigbee2mqtt-master\lib\zigbee.ts:64:27)
at Controller.start (C:\Users\mathi\Downloads\zigbee2mqtt-master\lib\controller.ts:140:27)
at start (C:\Users\mathi\Downloads\zigbee2mqtt-master\index.js:154:5)
Effectivement essaye peut être de reflasher le firmware
J’ai volontairement mis un ancien firmware, version réputée pour ne pas avoir de perte d’équipement.
PS C:\Users\mathi\Downloads\GCFFlasher_Win_V4_04_00\GCFFlasher_Win_V4_04_00> .\GCFFlasher.exe -d COM4 -f .\deCONZ_ConBeeII_0x26580700.bin.GCF -t 20
read file success: .\deCONZ_ConBeeII_0x26580700.bin.GCF (160944 bytes)
flash firmware
connect \\.\COM4, baudrate 115200
command UART reset done
query bootloader id V1
bootloader detected
bootloader synced: unlock! READY
100% uploading #############################################################
done, wait validation...
firmware successful written
Cela refonctionne. Pour combien de temps, je ne sais pas…
Un grand merci Loic pour ton accompagnement.
Cela n’a duré que 2h.
J’ai de nouveau plein de TIMEOUT lorsque je demande des actions sur mes équipements.
Pourtant, quand je coupe l’alimentation et la remets d’une lampe par exemple, je vois bien qu’il communique avec z2m.
J’ai commandé une conbee3 des fois que…
Je continue mes recherches…
Il semblerait que mon wifi 2,4Ghz soit très perturbé alors que les canaux 11 côté Zigbee et 11 côté wifi sont à l’opposé.
J’ai regardé aussi le comportement de ma clé Zwave et Bluetooth qui sont sur le même hub (Hub allimenté).
Et je constate cela sur le plugin BLE :
[2024-09-25 08:40:04] INFO : GLOBAL------Start blead
[2024-09-25 08:40:04] INFO : GLOBAL------Log level : info
[2024-09-25 08:40:04] INFO : GLOBAL------Socket port : 55008
[2024-09-25 08:40:04] INFO : GLOBAL------Socket host : 127.0.0.1
[2024-09-25 08:40:04] INFO : GLOBAL------Device : hci0
[2024-09-25 08:40:04] INFO : GLOBAL------PID file : /tmp/jeedom/blea/deamon.pid
[2024-09-25 08:40:04] INFO : GLOBAL------Apikey : s9u6bcuB1R5xlLS8NUnbJrs5XmW6QDuq
[2024-09-25 08:40:04] INFO : GLOBAL------Callback : http://127.0.0.1:80/plugins/blea/core/php/jeeBlea.php
[2024-09-25 08:40:04] INFO : GLOBAL------Cycle : 0.3
[2024-09-25 08:40:04] INFO : GLOBAL------Scan interval : 29
[2024-09-25 08:40:04] INFO : GLOBAL------Number for no seen : 4
[2024-09-25 08:40:04] INFO : GLOBAL------Scan Mode : passive
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.amazfitgtr
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.aqualin
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.awoxmesh
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.beagle
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.beewismartdoor
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.beewismartlite
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.blpnr
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.divoompixoo
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.divoomtimeboxmini
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.dotti
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.dreamscreen
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.fitbit
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.gigaset
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.hector
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.ibbq4
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.ibbq6
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.itag
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.jinlin
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.kst1
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.logiswitch
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.lywsd02
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.lywsd03
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.meyerdom2analog
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.meyerdom4contacts
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.meyerdomcontactvocal
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.miband
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.miband2
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.miband3
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.miband4
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.miflora
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.miscale
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.miscale2
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.myfox
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.niu
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.noke
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.nut
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.parrotplant
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.pixoo
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.pixoo.divoom_image
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.pixoo.messages
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.pixoo.timebox
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.pixoo.timeboximage
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.playbulb
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.ropot
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.ruuvi
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.smartplug
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.tb05
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.ticatag
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.tile
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.timebox
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.timebox.divoom_image
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.timebox.messages
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.timebox.timebox
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.timebox.timeboximage
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.wistiki
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.xiaomiht
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.yeelight
[2024-09-25 08:40:04] INFO : LOADER------Import de la configuration devices.yeelightcandela
Can't get device info: No such device
[2024-09-25 08:40:04] INFO : Writing PID 1780239 to /tmp/jeedom/blea/deamon.pid
[2024-09-25 08:40:04] INFO : Init request module v2.32.3
[2024-09-25 08:40:04] INFO : Socket interface started
[2024-09-25 08:40:04] INFO : LoopNetServer Thread started
[2024-09-25 08:40:04] INFO : GLOBAL------Start listening...
[2024-09-25 08:40:04] INFO : GLOBAL------Preparing Scanner...
[2024-09-25 08:40:04] INFO : Listening on: [127.0.0.1:55008]
[2024-09-25 08:40:04] INFO : Send to jeedom : {'learn_mode': 0, 'source': 'local'}
[2024-09-25 08:40:04] INFO : Send to jeedom : {'started': 1, 'source': 'local', 'version': '2.9'}
[2024-09-25 08:40:04] INFO : Client connected to [127.0.0.1:46442]
[2024-09-25 08:40:04] INFO : Message read from socket: b'{"apikey":"s9u6bcuB1R5xlLS8NUnbJrs5XmW6QDuq","cmd":"add","device":{"id":"5C:CA:D3:F0:12:4E","delay":0,"needsrefresh":0,"name":"miscale2","refreshlist":[],"islocked":0,"emitterallowed":"local","refresherallowed":"local","specificconfiguration":{"Mathieu":{"name":"Mathieu","height":"166","weight":77.4,"sex":"male","age":"02-01-1986"},"C\\u00e9dric":{"name":"C\\u00e9dric","height":"185","weight":90.4,"sex":"male","age":"16-12-1979"},"Lucas":{"name":"Lucas","height":"80","weight":19.15,"sex":"male","age":"17-12-2018"}},"absent":"","type":"","model":"miscale2\\/miscale2"}}'
[2024-09-25 08:40:04] INFO : Client disconnected from [127.0.0.1:46442]
[2024-09-25 08:40:04] INFO : Client connected to [127.0.0.1:46452]
[2024-09-25 08:40:04] INFO : Message read from socket: b'{"apikey":"s9u6bcuB1R5xlLS8NUnbJrs5XmW6QDuq","cmd":"add","device":{"id":"C4:7C:8D:6A:4C:B2","delay":1800,"needsrefresh":0,"name":"miflora","refreshlist":[],"islocked":0,"emitterallowed":"local","refresherallowed":"local","specificconfiguration":[],"absent":"","type":"","model":"miflora\\/miflora"}}'
[2024-09-25 08:40:04] INFO : Client disconnected from [127.0.0.1:46452]
[2024-09-25 08:40:04] INFO : Client connected to [127.0.0.1:46454]
[2024-09-25 08:40:04] INFO : Message read from socket: b'{"apikey":"s9u6bcuB1R5xlLS8NUnbJrs5XmW6QDuq","cmd":"add","device":{"id":"C4:7C:8D:6A:6D:7E","delay":18000,"needsrefresh":0,"name":"miflora","refreshlist":[],"islocked":0,"emitterallowed":"local","refresherallowed":"local","specificconfiguration":[],"absent":"","type":"","model":"miflora\\/miflora"}}'
[2024-09-25 08:40:04] INFO : Client disconnected from [127.0.0.1:46454]
[2024-09-25 08:40:04] INFO : Client connected to [127.0.0.1:46466]
[2024-09-25 08:40:04] INFO : Message read from socket: b'{"apikey":"s9u6bcuB1R5xlLS8NUnbJrs5XmW6QDuq","cmd":"add","device":{"id":"90:03:B7:E7:82:41","delay":18000,"needsrefresh":0,"name":"flowerpower","refreshlist":[],"islocked":0,"emitterallowed":"local","refresherallowed":"local","specificconfiguration":[],"absent":"","type":"","model":"flowerpower\\/flowerpower"}}'
[2024-09-25 08:40:04] INFO : Client disconnected from [127.0.0.1:46466]
[2024-09-25 08:40:04] INFO : Client connected to [127.0.0.1:46472]
[2024-09-25 08:40:04] INFO : Message read from socket: b'{"apikey":"s9u6bcuB1R5xlLS8NUnbJrs5XmW6QDuq","cmd":"ready"}'
[2024-09-25 08:40:04] INFO : Client disconnected from [127.0.0.1:46472]
[2024-09-25 08:40:06]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 11): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 12): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 13): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 14): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 15): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 16): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 17): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 18): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 19): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 20): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06] ERROR : GLOBAL------Exception on scanner (didn't resolve there is an issue with bluetooth) : Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2024-09-25 08:40:06] INFO : GLOBAL------Shutting down due to errors
[2024-09-25 08:40:06] INFO : Send to jeedom : {'learn_mode': 0, 'source': 'local'}
[2024-09-25 08:40:09] INFO : LoopNetServer Thread stopped
Il n’y aurait pas là aussi un problème ?
Je connais pas du tout ce plugin je pourrais pas t’aider sur celui-ci
C’est le plugin Jeedom BLEA ![]()
Oui oui je sais que c’est un plugin officiel jeedom mais ca veut pas dire que je le connais pour autant. En l’occurence celui la (comme le plugin zwavejs par exemple) je ne les connais absolument pas et je ne serais pas capable de vous dire quoique ce soit dessus.
