Depuis une réinstallation de ma box domotique je n’arrive pas à relancer le démon
Avez vous une idée ?
Voici le log démon et la conf
J’ai relancé les dépendance.
Cordialement
On peut voir le journal d’installation des dépendances, pas en copie d’écran, mais en copier coller entre les balises code.
Il semble manquer un module.
- Élément
je pense que c’est cela.
Error: importing module from jeedom folder
No module named requests
- Élément
J’ai aussi cela dans Téléinfo packages;
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_teleinfo
0003|+ echo 1
0004|+ echo 2
0005|+ sudo apt update
0006|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0007|Hit:1 http://deb.debian.org/debian buster InRelease
0008|Hit:2 http://deb.debian.org/debian-security buster/updates InRelease
0009|Hit:3 http://deb.debian.org/debian buster-updates InRelease
0010|Hit:4 http://archive.raspberrypi.org/debian buster InRelease
0011|Reading package lists...
0012|Building dependency tree...
0013|Reading state information...
0014|All packages are up to date.
0015|+ echo 3
0016|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-ftdi1
0017|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0018|Reading package lists...
0019|Building dependency tree...
0020|Reading state information...
0021|The following package was automatically installed and is no longer required:
0022|raspi-gpio
0023|Use 'sudo apt autoremove' to remove it.
0024|The following NEW packages will be installed:
0025|python3-ftdi1
0026|0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
0027|Need to get 46.9 kB of archives.
0028|After this operation, 526 kB of additional disk space will be used.
0029|Get:1 http://deb.debian.org/debian buster/main arm64 python3-ftdi1 arm64 1.4-1+b2 [46.9 kB]
0030|debconf: unable to initialize frontend: Dialog
0031|debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
0032|debconf: falling back to frontend: Readline
0033|debconf: unable to initialize frontend: Readline
0034|debconf: (This frontend requires a controlling tty.)
0035|debconf: falling back to frontend: Teletype
0036|dpkg-preconfigure: unable to re-open stdin:
0037|Fetched 46.9 kB in 0s (724 kB/s)
0038|Selecting previously unselected package python3-ftdi1.
0039|(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 58616 files and directories currently installed.)
0040|Preparing to unpack .../python3-ftdi1_1.4-1+b2_arm64.deb ...
0041|Unpacking python3-ftdi1 (1.4-1+b2) ...
0042|Setting up python3-ftdi1 (1.4-1+b2) ...
0043|+ echo 4
0044|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end teleinfo
0045|+ rm /tmp/jeedom_install_in_progress_teleinfo
0046|+ echo '*******************End of package installation******************'
0047|*******************End of package installation******************
En ssh, tentes cela :
pip3 install requests
j’ai cette erreur
pi@garagejeedom:~ $ pip3 install requests
Defaulting to user installation because normal site-packages is not writeable
Looking in indexes: Simple index, piwheels - Simple index
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)
Tu est sur quelle version de debian?
Debian 10 Buster 64 bits
Non cela ne fonctionne pas j’ai cette erreur:
pi@garagejeedom:~ $ sudo pip3 install requests
WARNING: Running pip as the ‹ root › user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: 12. Virtual Environments and Packages — Python 3.10.5 documentation
En fait, sur les sujets de ce plugin, pas mal de personne on un problème avec, une personne à trouvé une solution en remplaçant des fichiers d’origine.
Lire tout ici :
Modifications Plugin Téléinfo: checksum en mode standard + traduction du champ STGE + traduction du champs RELAIS - Plugins - Communauté Jeedom
Salut Fabrice,
j’étais justement en train de lire ce poste!
Il faut modifier des fichiers sources dans le plugin ! pas simple.
je ne sais pas si le développeur de ce plugin maintient toujours celui-ci ? je lui ai envoyé un message.
A+
je me réponds à moi même pour clôturer ce poste.
j’ai suivi le conseil de Fabrice voir plus Haut.
Et finalement je suis repassé en Bêta.
Mon plugin est reparti.
Bonne journée
