su - me demande un mot de passe que je n’arrive pas à trouver.
essaye Mjeedom96
C’est le mot de passe que j’utilise pour me connecter en SSH. Mais il ne fonctionne pas pour - su
essaies
sudo su -
avec le mdp de Jeedom
Sinon je viens de pousser une maj qui sera dispo demain
J’ai réussi, mais ci-dessous le résultat :
root@jeedom:/var/www/html/plugins/eufy/resources# ./eufy upgrade
stopping container 6c236a6cae7b
6c236a6cae7b
deleting image bropat/eufy-security-ws
Untagged: bropat/eufy-security-ws:latest
Untagged: bropat/eufy-security-ws@sha256:1a98601c02ac9e506b8528e5d17a0f9ea7fb0eb72436296a16f9aaa55b782f45
Deleted: sha256:5bd4522dabbdafe942a78b97910045e5a539ec0c02e2dadc0d5c8a503f0e0c1d
Deleted: sha256:6d57cbb8d1872b304311def6609e7b2075440c5aa15b1a61ad68f806e69d4eb2
Deleted: sha256:0aae1965d1a70f1382c429b5efcb63a84c41e210e363e7a7921e2e38d8cd094d
Deleted: sha256:aad1a7db8a9ba7dcec8d6ea26faa168290700ff12c9072da2584ba4365f150f9
Deleted: sha256:363f3479fc66bb3670ed3136e426d6365f06589348836cc2b2f740edf888fddf
Deleted: sha256:9bccbb5112a94093579797f66ee8bd20ad420e6c08e883450aa352f3272c373d
Deleted: sha256:2d0da0e9e1dcb37afa14e633e44951feb22886c7cd15f0f7dce9a691de89116b
Deleted: sha256:833027390b02509e906c5c182cf3192908b2d7f214b7e35d679a928fd150454a
Deleted: sha256:012e3dc69a8fba84e51a46396c2cce2bc7cd406847a2efa390f4e1963d11ef21
Deleted: sha256:3ac3b1e1f6c4dfc8107e8760294c57216cc850664b8a7414639a8bd5843fc92f
Deleted: sha256:c36a5912bdbd231e14744c252908f25b18900481672863cb67688d645b2a99ed
Deleted: sha256:315bd5088587f904ce90b0801a0c8db45648746faf106758d6946f4ef96ae5d0
starting image bropat/eufy-security-ws
parsing /var/www/html/plugins/eufy/data/docker-compose.yml: yaml: line 4: mapping values are not allowed in this context
Maintenant, quand je veux installer le container :
v2024-09-07 10:19:38] INFO : >>> Début de l’opération start du service Eufy
[2024-09-07 10:19:39] DEBUG : images installées:
[2024-09-07 10:19:39] DEBUG : container actif:
[2024-09-07 10:19:39]WARNING : >>> start du service Eufy: L’image n’est pas installée
[2024-09-07 10:20:07] DEBUG : debian OS version: 10
[2024-09-07 10:20:07] DEBUG : Py executable: /usr/bin/python3
[2024-09-07 10:20:07] DEBUG : >>> Checking container 127.0.0.1:4000
[2024-09-07 10:20:07] DEBUG : Container 127.0.0.1:4000 is not responding ![]()
[2024-09-07 10:20:07] ERROR : Container Eufy non démarré
Maintenant, c’est le port 4000 qui ne semble plus pouvoir être utilisé :
2024-09-07 10:29:26] DEBUG : >>> Checking container 127.0.0.1:4000
[2024-09-07 10:29:26] DEBUG : Container 127.0.0.1:4000 is not responding ![]()
[2024-09-07 10:29:26] DEBUG : debian OS version: 10
[2024-09-07 10:29:26] DEBUG : Py executable: /usr/bin/python3
[2024-09-07 10:29:26] DEBUG : eufy-security-ws image version:
[2024-09-07 10:29:27] DEBUG : eufy-security-ws service online:
A mon avis, c’est que vu que j’utilise v2.10 maintenant, il faut que je refasse la manipulation que tu m’avais faite faite ici (https://community.jeedom.com/t/eufy-demande-aide/120801/77) pour basculer le port utilisé de 3000 vers 4000.
Mais j’ai refais la manipulation, et elle ne fonctionne plus.
Quand j’exécute le script suivant pour modifier le port 3000 vers le port 4000 :
Connect 2 eufy-security-client:
$ docker exec -it <container_id> /bin/sh
$ node /usr/src/app/dist/bin/client.js
#set -x
#-e DEBUG=true \
docker run --privileged
-it --name Eufy-WS
-e TRUSTED_DEVICE_NAME=""
-e USERNAME=
-e PASSWORD=***
-e COUNTRY=FR -e LANGUAGE=fr -p 4000:3000
–restart=unless-stopped bropat/eufy-security-ws
J’ai ce résultat :
root@jeedom:~# cd /tmp
root@jeedom:/tmp# chown root:root teststart3_eufy.sh
root@jeedom:/tmp# chmod 755 start_eufy.sh
root@jeedom:/tmp# chmod 755 teststart3_eufy.sh
root@jeedom:/tmp# ./teststart3_eufy.sh
Unable to find image ‹ bropat/eufy-security-ws:latest › locally
latest: Pulling from bropat/eufy-security-ws
docker: no matching manifest for linux/arm/v7 in the manifest list entries.
See ‹ docker run --help ›.
root@jeedom:/tmp#
Si tu as un moment dans l’aprem fais moi signe en MP
la ligne 4:
image: bropat/eufy-security-ws:#version#
as tu indiqué la version cible ? latest ou 1.9.0 et saugegardé AVANT d’appuyer sur le bouton?
Tu n’as plus d’image donc le bon bouton c’est Installer
Pour le port tu peux mettre 4000 s’il est libre
Oui, j’ai bien, Lasted dans la version cible :
[2024-09-07 15:03:06] INFO : >>> Début de l’opération install du service Eufy
[2024-09-07 15:03:06] DEBUG : images installées:
[2024-09-07 15:03:06] DEBUG : container actif:
[2024-09-07 15:03:06] DEBUG : docker pull bropat/eufy-security-ws:latest
[2024-09-07 15:03:08] INFO : >>> Fin de l’opération install du service Eufy
[2024-09-07 15:03:08] INFO : >>> Début de l’opération start du service Eufy
[2024-09-07 15:03:08] DEBUG : images installées:
[2024-09-07 15:03:08] DEBUG : container actif:
[2024-09-07 15:03:08]WARNING : >>> start du service Eufy: L’image n’est pas installée
Ca c’est autre chose: il n’y a plus de version arm v7 donc prends la dernière: 1.7.1
https://hub.docker.com/r/bropat/eufy-security-ws/tags
Comment faire pour installer la dernière version de docker ?
Tu la mets dans le champ version cible cf copie d’ecran plus haut.
Tu sauves et tu cliques installer Eufy
Toujours 1 NOK, mais je sais pourquoi. Mon port 3000 est utilisé par ADGUARDHOME. Mais Je ne sais pas comment le modifier en 4000.
Rien a voir tout est ok maintenant
Ce qui bloque c’est ton authentification cloud…
Tu as bien désactivé le 2FA?
Si tu es sur de ton login/passwd et du nom de ton device vérifies si tu n’as pas une demande de code OTC dans ton email
Si c’est le cas vas dans paramètres > acces portail web et generes un PIN CODE.
Une fois renseigné relances installer eufy ca devrait rentrer dans l’ordre
Sinon pour modifier le port il te suffit de le changer de sauver et de refaire un install eufy
J’ai tout fait, rien n’a fonctionné.
Quand je réinstalle sur le port 4000, voici la réponse :
docker.io/bropat/eufy-security-ws:1.7.1
[2024-09-07 23:15:25] INFO : >>> Fin de l’opération install du service Eufy
[2024-09-07 23:15:25] INFO : >>> Début de l’opération start du service Eufy
[2024-09-07 23:15:25] DEBUG : images installées: 5356b8ab18ef
[2024-09-07 23:15:25] DEBUG : container actif:
[2024-09-07 23:15:25] DEBUG : Mise à jour du fichier yaml /var/www/html/plugins/eufy/data/docker-compose.yml
[2024-09-07 23:15:25] DEBUG : docker compose -f /var/www/html/plugins/eufy/data/docker-compose.yml up -d
eufy-security-ws Pulling
[2024-09-07 23:15:27] DEBUG : container id:
[2024-09-07 23:15:30] DEBUG : >>> Checking container 127.0.0.1:4000
[2024-09-07 23:15:30] DEBUG : Container 127.0.0.1:4000 is not responding ![]()
[2024-09-07 23:15:30] DEBUG : debian OS version: 10
[2024-09-07 23:15:30] DEBUG : Py executable: /usr/bin/python3
[2024-09-07 23:15:30] DEBUG : eufy-security-ws image version:
[2024-09-07 23:15:30] DEBUG : eufy-security-ws service online:
[2024-09-07 23:15:30] INFO : >>> Fin de l’opération start du service Euf
