Après plusieurs plantées de mon Jeedom sur Raspberry ces derniers jours (peut-être lié à la taille énorme de la table timeline, autre topic, résolu) , le plugin Zwave fait la grève.
Dommage, on est en vacances et nos pièces sont à 10° maintenant, plus moyen d’enclencher les radiateurs
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=35
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
Raspberry Pi 3 Detected. If you use a Razberry board you must Disabling Bluetooth
Please add ‹ dtoverlay=pi3-miniuart-bt › to the end of the file /boot/config.txt
And reboot your Raspberry Pi
d’après ton log, c’est nécessaire.
Quand javais un rpi c’est vrai que jétais obligé d’avoir dtoverlay ajouté manuellement moi aussi
( javais mis dtoverlay=disable-bt si mes souvenirs sont bons mais suit les recommendations qu’il te met au dessus)
