je viens d’acquérir 2 modules AqaracSSM-U01avec neutre.
ils sont dans la liste des modules compatibles avec le pluging Zigbee.
ils remontent bien dans le reseau :
Le hic, j’ai un défaut :
Log Zigbee :
[2022-06-03 18:32:57]ERROR : Erreur exécution de la commande [Jardin][LUMI.lumi.switch.n0agl1 54:ef:44:10:00:26:9e:72][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"54:ef:44:10:00:26:9e:72","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[54:ef:44:10:00:26:9e:72][zdevices.command] Cluster not found : on_off","code":0
Log Zigbeed_1:
[2022-06-03 17:44:08]INFO : [DeviceHandler.prepare] Json arg : {'ieee': '54:ef:44:10:00:25:95:cf', 'cmd': [{'endpoint': 1, 'cluster': 'on_off', 'command': 'on', 'await': 1}], 'allowQueue': False}
[2022-06-03 17:44:08]INFO : Traceback (most recent call last):
File "/var/www/html/plugins/zigbee/resources/zigbeed/restServer.py", line 269, in put
await zdevices.command(self.json_args)
File "/var/www/html/plugins/zigbee/resources/zigbeed/zdevices.py", line 54, in command
"["+str(device._ieee)+"][zdevices.command] Cluster not found : "+str(cmd['cluster']))
Exception: [54:ef:44:10:00:25:95:cf][zdevices.command] Cluster not found : on_off
[2022-06-03 17:44:08]INFO : 200 PUT /device/command (127.0.0.1) 4.08ms
Quand je regarde les informations brutes je ne trouve pas On/\Off :
"ieee": "54:ef:44:10:00:25:95:cf",
"nwk": 21229,
"status": 2,
"lqi": "255",
"rssi": "-45",
"last_seen": "1654276122.058333",
"node_descriptor": "01:40:8e:5f:11:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": "LUMI",
"model": "lumi.switch.n0agl1",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 21
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.switch.n0agl1"
"id": 6,
"name": "date_code",
"value": "Aug 8 2020"
"id": 7,
"name": "power_source",
"value": 0
"id": 16384,
"name": "sw_build_id",
"value": ""
"id": 2,
"name": "Device Temperature",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 9,
"name": "Alarms",
"attributes": []
"id": 10,
"name": "Time",
"attributes": [
"id": 0,
"name": "time",
"value": 707590324
"id": 1,
"name": "time_status",
"value": 1
"id": 2,
"name": "time_zone",
"value": 7200
"id": 64704,
"name": "Manufacturer Specific",
"attributes": []
"id": 41,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 18,
"name": "MultistateInput",
"attributes": [
"id": 85,
"name": "present_value",
"value": 0
"id": 21,
"status": 1,
"device_type": 256,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 12,
"name": "AnalogInput",
"attributes": [
"id": 85,
"value": 0
"id": 31,
"status": 1,
"device_type": 256,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 12,
"attributes": [
"id": 85,
"value": 0
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4447,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
0,
2,
3,
4,
5,
9,
10,
64704
25
"41": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
18
"21": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
12
"31": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
12
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
un petit coup de main SVP?
Doudou
