Swap disponible
De quoi peut venir cette charge svp ?
as-tu essayé de faire du ménage dans ta BD ?
As-tu isolé un process qui semble poser pb
Que donne la commùande dans reglage >> system >> configuration >> _OS/DB >> _administration systeme >> cpu usage
salut,
menage bd c est a dire ?
oui plus d historique superieur a 30 jours
pas de process semble poser probleme
cpu usage :
    PID    PPID %MEM %CPU CMD
    727       1  1.9  4.9 /usr/sbin/mariadbd
3698544 3698543  2.6  1.0 node index.js
3697491 3697490  0.5  0.4 /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel info --socketport 55035 --mqtt_server mqtts://127.0.0.1:8883 --client_key /var/www/html/plugins/mqtt2/data/ssl/client.key --client_crt /var/www/html/plugins/mqtt2/data/ssl/client.crt --ca /var/www/html/plugins/mqtt2/data/ssl/ca.crt --username jeedom --password UkzjrIhIgbM3NANxmBoME2RKF4hYMB7WpbLvZ7kAiQHVyrsZWRedVSqCbBiqe9qn --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey 1PEaCNRTmVau5W6cVxQhU7lzfCIl8WqnrEFv2aarhJh0N470supXjEXm3YaWoPnH --cycle 0.3 --root_topic jeedom --pid /tmp/jeedom/mqtt2/deamon.pid
     15       2  0.0  0.3 [rcu_preempt]
   6128       1  0.1  0.3 php /var/www/html/core/class/../php/jeeCron.php cron_id=619861
 239371 3696870  0.5  0.3 /usr/sbin/apache2 -k start
 255445 3696870  0.8  0.3 /usr/sbin/apache2 -k start
3941202 3941176  1.1  0.3 /usr/local/bin/node --security-revert=CVE-2023-46809 /usr/src/app/dist/bin/server.js --host 0.0.0.0 --config /dev/shm/eufy-security-ws-config.json
     42       2  0.0  0.2 [kcompactd0]
     55       2  0.0  0.2 [kswapd0]
   5789       1  0.2  0.2 python3 /var/www/html/plugins/tydom/resources/tydomd/tydomd.py --loglevel info --socketport 55200 --mode local --host 192.168.1.19 --mac 001A250549BF --password Bat181s302km230 --pid /tmp/jeedom/tydom/deamon.pid --apikey x8KhgL1FXujP6N6WlvG1gxE0I6dCl2M4TIULBIT35DnJCbVkXPdlJsOyVCiWmm8F --callback http://127.0.0.1:80/plugins/tydom/core/php/jeeTydom.php
   6121       1  0.1  0.2 php /var/www/html/core/class/../php/jeeCron.php cron_id=1028772
 228717 3696870  0.5  0.2 /usr/sbin/apache2 -k start
 239380 3696870  0.5  0.2 /usr/sbin/apache2 -k start
 243155 3696870  0.3  0.2 /usr/sbin/apache2 -k start
 253072 3696870  0.4  0.2 /usr/sbin/apache2 -k start
 253291 3696870  0.5  0.2 /usr/sbin/apache2 -k start
 255450 3696870  0.4  0.2 /usr/sbin/apache2 -k start
 255460 3696870  0.4  0.2 /usr/sbin/apache2 -k start
 256105 3696870  0.5  0.2 /usr/sbin/apache2 -k start
3941626       1  0.3  0.2 /usr/bin/python3 /var/www/html/plugins/eufy/resources/eufyd/eufyd.py --loglevel info --socketport 60600 --callback http://127.0.0.1:80/plugins/eufy/core/php/jeeeufy.php --containerip 192.168.1.91 --containerport 3000 --schemaversion 21 --apikey 6mbitRiJgqhNIjG5QPPx3DJaBx2oCc67fyrPSv7fMTdSRjOumXgYF4pJPE1obPnr --pid /tmp/jeedom/eufy/deamon.pid
    593       1  0.0  0.1 /usr/sbin/mosquitto -c /var/www/html/plugins/mqtt2/core/class/../../data/mosquitto.conf
    991       1  0.6  0.1 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
 261244 3696870  0.3  0.1 /usr/sbin/apache2 -k start
      1       0  0.1  0.0 /sbin/init
      2       0  0.0  0.0 [kthreadd]
      3       2  0.0  0.0 [rcu_gp]
      4       2  0.0  0.0 [rcu_par_gp]
      5       2  0.0  0.0 [slub_flushwq]
      6       2  0.0  0.0 [netns]
      8       2  0.0  0.0 [kworker/0:0H-kblockd]
     10       2  0.0  0.0 [mm_percpu_wq]
     11       2  0.0  0.0 [rcu_tasks_kthread]
     12       2  0.0  0.0 [rcu_tasks_rude_kthread]
     13       2  0.0  0.0 [rcu_tasks_trace_kthread]
     14       2  0.0  0.0 [ksoftirqd/0]
     16       2  0.0  0.0 [migration/0]
     17       2  0.0  0.0 [cpuhp/0]
     18       2  0.0  0.0 [cpuhp/1]
     19       2  0.0  0.0 [migration/1]
     20       2  0.0  0.0 [ksoftirqd/1]
     22       2  0.0  0.0 [kworker/1:0H-events_highpri]
     23       2  0.0  0.0 [cpuhp/2]
     24       2  0.0  0.0 [migration/2]
     25       2  0.0  0.0 [ksoftirqd/2]
     27       2  0.0  0.0 [kworker/2:0H-kblockd]
     28       2  0.0  0.0 [cpuhp/3]
     29       2  0.0  0.0 [migration/3]
     30       2  0.0  0.0 [ksoftirqd/3]
     32       2  0.0  0.0 [kworker/3:0H-kblockd]
     33       2  0.0  0.0 [kdevtmpfs]
     34       2  0.0  0.0 [inet_frag_wq]
     36       2  0.0  0.0 [kauditd]
     38       2  0.0  0.0 [khungtaskd]
     40       2  0.0  0.0 [oom_reaper]
     41       2  0.0  0.0 [writeback]
     43       2  0.0  0.0 [kintegrityd]
     44       2  0.0  0.0 [kblockd]
     45       2  0.0  0.0 [blkcg_punt_bio]
     46       2  0.0  0.0 [watchdogd]
     50       2  0.0  0.0 [kworker/1:1H-kblockd]
     51       2  0.0  0.0 [rpciod]
     52       2  0.0  0.0 [xprtiod]
     56       2  0.0  0.0 [nfsiod]
     57       2  0.0  0.0 [kthrotld]
     65       2  0.0  0.0 [hwrng]
     66       2  0.0  0.0 [iscsi_conn_clea]
     67       2  0.0  0.0 [nvme-wq]
     68       2  0.0  0.0 [nvme-reset-wq]
     69       2  0.0  0.0 [nvme-delete-wq]
     71       2  0.0  0.0 [DWC Notificatio]
     72       2  0.0  0.0 [uas]
     73       2  0.0  0.0 [vchiq-slot/0]
     74       2  0.0  0.0 [vchiq-recy/0]
     75       2  0.0  0.0 [vchiq-sync/0]
     76       2  0.0  0.0 [zswap-shrink]
     77       2  0.0  0.0 [kworker/u9:0-hci0]
     98       2  0.0  0.0 [sdhci]
     99       2  0.0  0.0 [irq/37-mmc0]
    101       2  0.0  0.0 [scsi_eh_0]
    102       2  0.0  0.0 [scsi_tmf_0]
    103       2  0.0  0.0 [kworker/3:1H-kblockd]
    104       2  0.0  0.0 [jbd2/sda2-8]
    105       2  0.0  0.0 [ext4-rsv-conver]
    106       2  0.0  0.0 [mld]
    107       2  0.0  0.0 [ipv6_addrconf]
    110       2  0.0  0.0 [kworker/0:1H-kblockd]
    114       2  0.0  0.0 [kworker/2:1H-kblockd]
    147       1  0.1  0.0 /lib/systemd/systemd-journald
    186       1  0.0  0.0 /lib/systemd/systemd-udevd
    220       2  0.0  0.0 [vchiq-keep/0]
    221       2  0.0  0.0 [SMIO]
    239       2  0.0  0.0 [mmal-vchiq]
    240       2  0.0  0.0 [mmal-vchiq]
    241       2  0.0  0.0 [mmal-vchiq]
    243       2  0.0  0.0 [mmal-vchiq]
    244       2  0.0  0.0 [mmal-vchiq]
    249       2  0.0  0.0 [mmal-vchiq]
    253       2  0.0  0.0 [irq/38-feb10000.codec]
    254       2  0.0  0.0 [mmal-vchiq]
    261       2  0.0  0.0 [v3d_bin]
    268       2  0.0  0.0 [v3d_render]
    272       2  0.0  0.0 [v3d_tfu]
    273       2  0.0  0.0 [v3d_csd]
    274       2  0.0  0.0 [v3d_cache_clean]
    296       2  0.0  0.0 [cfg80211]
    312       2  0.0  0.0 [brcmf_wq/mmc1:0]
    318       2  0.0  0.0 [brcmf_wdog/mmc1:0001:1]
    336       2  0.0  0.0 [irq/41-vc4 hdmi hpd connected]
    337       2  0.0  0.0 [irq/42-vc4 hdmi hpd disconnected]
    339       2  0.0  0.0 [cec-vc4-hdmi-0]
    340       2  0.0  0.0 [irq/43-vc4 hdmi cec rx]
    341       2  0.0  0.0 [irq/44-vc4 hdmi cec tx]
    348       2  0.0  0.0 [irq/45-vc4 hdmi hpd connected]
    349       2  0.0  0.0 [irq/46-vc4 hdmi hpd disconnected]
    351       2  0.0  0.0 [cec-vc4-hdmi-1]
    352       2  0.0  0.0 [irq/47-vc4 hdmi cec rx]
    353       2  0.0  0.0 [irq/48-vc4 hdmi cec tx]
    361       2  0.0  0.0 [card1-crtc0]
    365       2  0.0  0.0 [card1-crtc1]
    368       2  0.0  0.0 [card1-crtc2]
    369       2  0.0  0.0 [card1-crtc3]
    371       2  0.0  0.0 [card1-crtc4]
    374       2  0.0  0.0 [card1-crtc5]
    447       1  0.0  0.0 avahi-daemon: running [Jeedom.local]
    448       1  0.0  0.0 /usr/sbin/cron -f
    449       1  0.0  0.0 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
    464       1  0.0  0.0 /usr/sbin/rsyslogd -n -iNONE
    469     447  0.0  0.0 avahi-daemon: chroot helper
    470       1  0.2  0.0 /usr/lib/snapd/snapd
    475       1  0.0  0.0 /lib/systemd/systemd-logind
    481       1  0.0  0.0 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
    483       1  0.0  0.0 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
    488       1  0.0  0.0 /usr/sbin/atd -f
    522       1  0.0  0.0 /usr/sbin/rngd -r /dev/hwrng
    586       1  0.2  0.0 /usr/bin/python3 /usr/bin/fail2ban-server -xf start
    594       1  0.3  0.0 /usr/bin/containerd
    604       1  0.0  0.0 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
    631       1  0.0  0.0 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 110:114
    685       1  0.0  0.0 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
    858       2  0.0  0.0 [kworker/u9:2-hci0]
    859       1  0.0  0.0 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow -
    874       1  0.0  0.0 /usr/libexec/bluetooth/bluetoothd
    990       1  0.0  0.0 /usr/sbin/dhcpcd -w -q
    997       1  0.0  0.0 /sbin/agetty -o -p -- \u --noclear tty1 linux
   1347       1  0.0  0.0 /usr/sbin/exim4 -bd -q30m
   4130       1  0.1  0.0 php /var/www/html/core/class/../php/jeeCron.php cron_id=23
   5709       1  0.1  0.0 php /var/www/html/core/class/../php/jeeCron.php cron_id=871484
   5761       1  0.0  0.0 /usr/libexec/packagekitd
   5769       1  0.0  0.0 /usr/libexec/polkitd --no-debug
 220112       2  0.0  0.0 [kworker/1:2-mm_percpu_wq]
 242561       2  0.0  0.0 [kworker/1:1-mm_percpu_wq]
 250104       2  0.0  0.0 [kworker/2:0-events]
 250798       2  0.0  0.0 [kworker/3:2-mm_percpu_wq]
 252535       2  0.0  0.0 [kworker/u8:1-events_unbound]
 253046       2  0.0  0.0 [kworker/0:0-mm_percpu_wq]
 256309       2  0.0  0.0 [kworker/3:0]
 256378       2  0.0  0.0 [kworker/0:2-events]
 257996       2  0.0  0.0 [kworker/u8:0-ext4-rsv-conversion]
 258094       2  0.0  0.0 [kworker/2:1-mm_percpu_wq]
 260365       2  0.0  0.0 [kworker/0:1-mm_percpu_wq]
 260551       2  0.0  0.0 [kworker/2:2-events_power_efficient]
 261221       2  0.0  0.0 [kworker/u8:2-events_unbound]
 261274       2  0.0  0.0 [kworker/1:0]
 261329  253072  0.0  0.0 sh -c ps -eo pid,ppid,%mem,%cpu,cmd --sort=-%cpu 2>&1
 261330  261329  0.0  0.0 ps -eo pid,ppid,%mem,%cpu,cmd --sort=-%cpu
 380177       2  0.0  0.0 [dio/sda2]
3696870       1  0.2  0.0 /usr/sbin/apache2 -k start
3697233       1  0.5  0.0 /tmp/jeedom/.venvs/merosssync/bin/python3 /var/www/html/plugins/MerosSync/resources/MerossIOTd/MerossIOTd.py --muser florentdaval71@orange.fr --mpswd Bat181s302km230 --callback http://127.0.0.1:80/plugins/MerosSync/core/php/jeeMerosSync.php --apikey Vs0Fk7QJiXcFZohtDkqVQLsv2Pdi3ylicGkq425iF17QqSQ8Ex5VR8iqV64xAfLU --loglevel info --pid /tmp/jeedom/MerosSync/daemon.pid --errorfile /tmp/jeedom/MerosSync/errordaemon.pid --socket /tmp/jeedom/MerosSync/daemon.sock --logfile /var/www/html/core/class/../../log/MerosSync --versionFile /var/www/html/plugins/MerosSync/resources/meross-iot_version.txt
3697490       1  0.0  0.0 sudo /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel info --socketport 55035 --mqtt_server mqtts://127.0.0.1:8883 --client_key /var/www/html/plugins/mqtt2/data/ssl/client.key --client_crt /var/www/html/plugins/mqtt2/data/ssl/client.crt --ca /var/www/html/plugins/mqtt2/data/ssl/ca.crt --username jeedom --password UkzjrIhIgbM3NANxmBoME2RKF4hYMB7WpbLvZ7kAiQHVyrsZWRedVSqCbBiqe9qn --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey 1PEaCNRTmVau5W6cVxQhU7lzfCIl8WqnrEFv2aarhJh0N470supXjEXm3YaWoPnH --cycle 0.3 --root_topic jeedom --pid /tmp/jeedom/mqtt2/deamon.pid
3698523       1  0.0  0.0 sudo ZIGBEE2MQTT_DATA=/var/www/html/plugins/z2m/core/class/../../data npm start --prefix /var/www/html/plugins/z2m/resources/zigbee2mqtt
3698531 3698523  0.2  0.0 npm start
3698543 3698531  0.0  0.0 sh -c node index.js
3941124     991  0.0  0.0 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 3000 -container-ip 172.18.0.2 -container-port 3000
3941130     991  0.0  0.0 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 3000 -container-ip 172.18.0.2 -container-port 3000
3941176       1  0.1  0.0 /usr/bin/containerd-shim-runc-v2 -namespace moby -id 967476f7ffc40976cb5ae28087b4124d4904f61d0d4755a583b217990d9a3e4e -address /run/containerd/containerd.sock
solutionner par @ngrataloup
1 - versi le fait que tu as pluguer ton disque sur l’USB2 et non l’USB3 (passage d’un tx d’ecriture sur disque de 25Mb/s à 75Mb/s
2 - pb de config du journalctl connu et dejà traité sur le community : Taille du répertoire /var/log énorme. Debian 11 et 12
