Je viens également de recevoir 3 de ces sondes, j’en avais déjà une ancienne qui fonctionnait bien avec la config normale, celles-ci, c’est une vraie galère.
Déjà, la version est encore différente de celles de Dan5, elles sont d’octobre 2022, voici les infos brutes :
"ieee": "3c:6a:2c:ff:fe:d2:f7:7b",
"nwk": 35695,
"status": 2,
"lqi": "75",
"rssi": "0",
"last_seen": "1671209246.367073",
"node_descriptor": "02:40:80:3c:11:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 770,
"profile_id": 260,
"manufacturer": "OWON",
"model": "THS317-ET",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"input_clusters": [
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 32
"id": 33,
"name": "battery_percentage_remaining",
"value": 200
"id": 32,
"name": "Poll Control",
"attributes": [
"id": 0,
"name": "checkin_interval",
"value": 14400
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 4
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "OWON"
"id": 5,
"name": "model",
"value": "THS317-ET"
"id": 6,
"name": "date_code",
"value": "20221019"
"id": 7,
"name": "power_source",
"value": 3
"id": 3,
"name": "Identify",
"attributes": []
"id": 1026,
"name": "Temperature Measurement",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 1980
"signature": {
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4412,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 770,
"input_clusters": [
1,
32,
0,
3,
1026
3
"class": "zigpy.device"
Je galère pour les appairer, sur 3, j’ai pu en appairer une seule, une seconde a été appairée mais ne remontait rien du tout; le timestamp du dernier message n’évoluait pas.
D’ailleurs, je me demande quelle est la procédure d’appairage, la doc fournie dans la boite parle de led rouge clignotant, elle est verte…
Les infos qui sont sensées remonter sont manquantes
Sinon, j’ai pu avoir une température en faisant la modif de l’Id mais il n’en reste pas moins qu’il y a un pb d’appairage. Pour info, je tourne avec 2 clés dans le plugin zigbee, une popp et une zigate v1. Pb idem qq soit la clé. Même en allant mettre la sonde sous le nez de la clé Zigbee.
Si vous avez des solutions à proposer
, sinon je vais devoir les retourner.
