J’ouvre un nouveau sujet a propos d’une Sonde de Luminosité, Température et d’Humidité avec écran qui s’appaire correctement dans le plugin mais qui n’est pas reconnu automatiquement,
les données brutes sont
"ieee": "5c:02:72:ff:fe:03:a1:31",
"nwk": 985,
"status": 2,
"lqi": "244",
"rssi": "-39",
"last_seen": "1620869866.2345526",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 262,
"profile_id": 260,
"manufacturer": "_TYZB01_kvwjujy9",
"model": "TS0222",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 72
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TYZB01_kvwjujy9"
"id": 5,
"name": "model",
"value": "TS0222"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 33,
"name": "battery_percentage_remaining",
"value": 200
"id": 1024,
"name": "Illuminance Measurement",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 0
"id": 2,
"status": 1,
"device_type": 770,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 1026,
"name": "Temperature Measurement",
"attributes": [
"id": 0,
"value": 0
"id": 1029,
"name": "Relative Humidity Measurement",
"attributes": [
"id": 0,
"value": 4801
"signature": {
"model": "TS0222",
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 262,
"input_clusters": [
0,
1,
1024
25,
10
"2": {
"profile_id": 260,
"device_type": 770,
"input_clusters": [
1026,
1029
"class": "zigpy.device"
Les logs sont :
[2021-05-13 03:35:11][DEBUG] : {"devices":{"5c:02:72:ff:fe:03:a1:31":{"1":{"1":{"33":{"value":"200","cluster_name":"Power Configuration"}}}}}}
[2021-05-13 03:35:16][DEBUG] : {"devices":{"5c:02:72:ff:fe:03:a1:31":{"2":{"1026":[{"value":"0","cluster_name":"Temperature Measurement"}]}}}}
[2021-05-13 03:35:16][DEBUG] : Search attribut for 5c:02:72:ff:fe:03:a1:31 logicalId : 2::1026::0 => 0
[2021-05-13 03:35:16][DEBUG] : {"devices":{"5c:02:72:ff:fe:03:a1:31":{"2":{"1029":[{"value":"0","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-05-13 03:35:16][DEBUG] : Search attribut for 5c:02:72:ff:fe:03:a1:31 logicalId : 2::1029::0 => 0
[2021-05-13 03:35:16][DEBUG] : {"devices":{"5c:02:72:ff:fe:03:a1:31":{"1":{"1024":[{"value":"0","cluster_name":"Illuminance Measurement"}]}}}}
[2021-05-13 03:35:16][DEBUG] : Search attribut for 5c:02:72:ff:fe:03:a1:31 logicalId : 1::1024::0 => 0
[2021-05-13 03:35:16][DEBUG] : {"devices":{"5c:02:72:ff:fe:03:a1:31":{"2":{"1029":[{"value":"4841","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-05-13 03:35:16][DEBUG] : Search attribut for 5c:02:72:ff:fe:03:a1:31 logicalId : 2::1029::0 => 4841
[2021-05-13 03:35:16][DEBUG] : {"devices":{"5c:02:72:ff:fe:03:a1:31":{"1":{"1024":[{"value":"23839","cluster_name":"Illuminance Measurement"}]}}}}
[2021-05-13 03:35:16][DEBUG] : Search attribut for 5c:02:72:ff:fe:03:a1:31 logicalId : 1::1024::0 => 23839
le capteur est un MOES
