Voici les logs avec seulement onduleur.
4511|[2023-09-06 07:22:39]INFO : Send to jeedom : {'eqId': '23', 'values': {'113': 48, '145': 4999}}
4512|[2023-09-06 07:22:39]DEBUG : PyModbusClient: *ONDULEUR* disconnect called
4513|[2023-09-06 07:22:39]DEBUG : Starting new HTTP connection (1): localhost:80
4514|[2023-09-06 07:22:39]INFO : Protocol lost connection.
4515|[2023-09-06 07:22:39]DEBUG : Client disconnected from modbus server: None
4516|[2023-09-06 07:22:39]DEBUG : jeemymodbus.php: $result *{"eqId":"23","values":{"113":48,"145":4999}}* type: array
4517|[2023-09-06 07:22:39]DEBUG : jeemodbus.php: Mise à jour cmd Psortie onduleur -> new value: 48
4518|[2023-09-06 07:22:39]DEBUG : jeemodbus.php: Mise à jour cmd frequence -> new value: 49.99
4519|[2023-09-06 07:22:39]INFO : jeemodbus.php: Mise à jour des commandes info : 'Psortie onduleur' 'frequence'
4520|[2023-09-06 07:22:39]DEBUG : http://localhost:80 "POST /plugins/mymodbus/core/php/jeemymodbus.php?apikey=sD9E4aSXLtWnaalBpq85uKEpiFMIEZvDbG6PADF66lryYEfDQbrGRSMYnmQPaJQp HTTP/1.1" 200 0
4521|[2023-09-06 07:22:44]DEBUG : PyModbusClient: *ONDULEUR* connect called
4522|[2023-09-06 07:22:44]DEBUG : PyModbusClient: *ONDULEUR* connecting...
4523|[2023-09-06 07:22:44]DEBUG : Connecting to 192.168.1.233:8899.
4524|[2023-09-06 07:22:44]DEBUG : Connecting.
4525|[2023-09-06 07:22:44]DEBUG : Client connected to modbus server
4526|[2023-09-06 07:22:44]INFO : Protocol made connection.
4527|[2023-09-06 07:22:44]INFO : Connected to 192.168.1.233:8899.
4528|[2023-09-06 07:22:44]DEBUG : send: 0x1 0x3 0x4 0x85 0x0 0x1 0x94 0xd3
4529|[2023-09-06 07:22:44]DEBUG : Adding transaction 1
4530|[2023-09-06 07:22:44]DEBUG : recv: 0x1 0x3 0x2 0x0 0x37 0xf9 0x92
4531|[2023-09-06 07:22:44]DEBUG : Getting Frame - 0x3 0x2 0x0 0x37
4532|[2023-09-06 07:22:44]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4533|[2023-09-06 07:22:44]DEBUG : Frame advanced, resetting header!!
4534|[2023-09-06 07:22:44]DEBUG : Getting transaction 1
4535|[2023-09-06 07:22:44]DEBUG : Frame - [b'\x01\x03\x02\x007\xf9\x92'] not ready
4536|[2023-09-06 07:22:44]DEBUG : [55]
4537|[2023-09-06 07:22:44]DEBUG : PyModbusClient: *ONDULEUR* read value for Psortie onduleur (command id 113): 55
4538|[2023-09-06 07:22:44]DEBUG : send: 0x1 0x3 0x6 0x8 0x0 0x1 0x5 0x40
4539|[2023-09-06 07:22:44]DEBUG : Adding transaction 1
4540|[2023-09-06 07:22:44]DEBUG : recv: 0x1 0x3 0x2 0x0 0x26 0x39 0x9e
4541|[2023-09-06 07:22:44]DEBUG : Getting Frame - 0x3 0x2 0x0 0x26
4542|[2023-09-06 07:22:44]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4543|[2023-09-06 07:22:44]DEBUG : Frame advanced, resetting header!!
4544|[2023-09-06 07:22:44]DEBUG : Getting transaction 1
4545|[2023-09-06 07:22:44]DEBUG : Frame - [b'\x01\x03\x02\x00&9\x9e'] not ready
4546|[2023-09-06 07:22:44]DEBUG : [38]
4547|[2023-09-06 07:22:44]DEBUG : send: 0x1 0x3 0x5 0xc4 0x0 0x1 0xc5 0x3b
4548|[2023-09-06 07:22:44]DEBUG : Adding transaction 1
4549|[2023-09-06 07:22:44]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4550|[2023-09-06 07:22:44]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4551|[2023-09-06 07:22:44]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4552|[2023-09-06 07:22:44]DEBUG : Frame advanced, resetting header!!
4553|[2023-09-06 07:22:44]DEBUG : Getting transaction 1
4554|[2023-09-06 07:22:44]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4555|[2023-09-06 07:22:44]DEBUG : [0]
4556|[2023-09-06 07:22:44]DEBUG : send: 0x1 0x3 0x4 0x84 0x0 0x1 0xc5 0x13
4557|[2023-09-06 07:22:44]DEBUG : Adding transaction 1
4558|[2023-09-06 07:22:44]DEBUG : recv: 0x1 0x3 0x2 0x13 0x88 0xb5 0x12
4559|[2023-09-06 07:22:44]DEBUG : Getting Frame - 0x3 0x2 0x13 0x88
4560|[2023-09-06 07:22:44]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4561|[2023-09-06 07:22:44]DEBUG : Frame advanced, resetting header!!
4562|[2023-09-06 07:22:44]DEBUG : Getting transaction 1
4563|[2023-09-06 07:22:44]DEBUG : Frame - [b'\x01\x03\x02\x13\x88\xb5\x12'] not ready
4564|[2023-09-06 07:22:44]DEBUG : [5000]
4565|[2023-09-06 07:22:44]DEBUG : PyModbusClient: *ONDULEUR* read value for frequence (command id 145): 5000
4566|[2023-09-06 07:22:44]DEBUG : send: 0x1 0x3 0x4 0x8a 0x0 0x1 0xa4 0xd0
4567|[2023-09-06 07:22:44]DEBUG : Adding transaction 1
4568|[2023-09-06 07:22:44]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4569|[2023-09-06 07:22:44]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4570|[2023-09-06 07:22:44]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4571|[2023-09-06 07:22:44]DEBUG : Frame advanced, resetting header!!
4572|[2023-09-06 07:22:44]DEBUG : Getting transaction 1
4573|[2023-09-06 07:22:44]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4574|[2023-09-06 07:22:44]DEBUG : [0]
4575|[2023-09-06 07:22:44]DEBUG : send: 0x1 0x3 0x4 0x89 0x0 0x1 0x54 0xd0
4576|[2023-09-06 07:22:44]DEBUG : Adding transaction 1
4577|[2023-09-06 07:22:45]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4578|[2023-09-06 07:22:45]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4579|[2023-09-06 07:22:45]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4580|[2023-09-06 07:22:45]DEBUG : Frame advanced, resetting header!!
4581|[2023-09-06 07:22:45]DEBUG : Getting transaction 1
4582|[2023-09-06 07:22:45]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4583|[2023-09-06 07:22:45]DEBUG : [0]
4584|[2023-09-06 07:22:45]INFO : Send to jeedom : {'eqId': '23', 'values': {'113': 55, '145': 5000}}
4585|[2023-09-06 07:22:45]DEBUG : PyModbusClient: *ONDULEUR* disconnect called
4586|[2023-09-06 07:22:45]INFO : Protocol lost connection.
4587|[2023-09-06 07:22:45]DEBUG : Client disconnected from modbus server: None
4588|[2023-09-06 07:22:45]DEBUG : Starting new HTTP connection (1): localhost:80
4589|[2023-09-06 07:22:45]DEBUG : jeemymodbus.php: $result *{"eqId":"23","values":{"113":55,"145":5000}}* type: array
4590|[2023-09-06 07:22:45]DEBUG : jeemodbus.php: Mise à jour cmd Psortie onduleur -> new value: 55
4591|[2023-09-06 07:22:45]DEBUG : jeemodbus.php: Mise à jour cmd frequence -> new value: 50
4592|[2023-09-06 07:22:45]INFO : jeemodbus.php: Mise à jour des commandes info : 'Psortie onduleur' 'frequence'
4593|[2023-09-06 07:22:45]DEBUG : http://localhost:80 "POST /plugins/mymodbus/core/php/jeemymodbus.php?apikey=sD9E4aSXLtWnaalBpq85uKEpiFMIEZvDbG6PADF66lryYEfDQbrGRSMYnmQPaJQp HTTP/1.1" 200 0
4594|[2023-09-06 07:22:49]DEBUG : PyModbusClient: *ONDULEUR* connect called
4595|[2023-09-06 07:22:49]DEBUG : PyModbusClient: *ONDULEUR* connecting...
4596|[2023-09-06 07:22:49]DEBUG : Connecting to 192.168.1.233:8899.
4597|[2023-09-06 07:22:49]DEBUG : Connecting.
4598|[2023-09-06 07:22:49]DEBUG : Client connected to modbus server
4599|[2023-09-06 07:22:49]INFO : Protocol made connection.
4600|[2023-09-06 07:22:49]INFO : Connected to 192.168.1.233:8899.
4601|[2023-09-06 07:22:49]DEBUG : send: 0x1 0x3 0x4 0x85 0x0 0x1 0x94 0xd3
4602|[2023-09-06 07:22:49]DEBUG : Adding transaction 1
4603|[2023-09-06 07:22:49]DEBUG : recv: 0x1 0x3 0x2 0x0 0x3d 0x79 0x95
4604|[2023-09-06 07:22:49]DEBUG : Getting Frame - 0x3 0x2 0x0 0x3d
4605|[2023-09-06 07:22:49]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4606|[2023-09-06 07:22:49]DEBUG : Frame advanced, resetting header!!
4607|[2023-09-06 07:22:49]DEBUG : Getting transaction 1
4608|[2023-09-06 07:22:49]DEBUG : Frame - [b'\x01\x03\x02\x00=y\x95'] not ready
4609|[2023-09-06 07:22:49]DEBUG : [61]
4610|[2023-09-06 07:22:49]DEBUG : PyModbusClient: *ONDULEUR* read value for Psortie onduleur (command id 113): 61
4611|[2023-09-06 07:22:49]DEBUG : send: 0x1 0x3 0x6 0x8 0x0 0x1 0x5 0x40
4612|[2023-09-06 07:22:49]DEBUG : Adding transaction 1
4613|[2023-09-06 07:22:49]DEBUG : recv: 0x1 0x3 0x2 0x0 0x26 0x39 0x9e
4614|[2023-09-06 07:22:49]DEBUG : Getting Frame - 0x3 0x2 0x0 0x26
4615|[2023-09-06 07:22:49]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4616|[2023-09-06 07:22:49]DEBUG : Frame advanced, resetting header!!
4617|[2023-09-06 07:22:49]DEBUG : Getting transaction 1
4618|[2023-09-06 07:22:49]DEBUG : Frame - [b'\x01\x03\x02\x00&9\x9e'] not ready
4619|[2023-09-06 07:22:49]DEBUG : [38]
4620|[2023-09-06 07:22:49]DEBUG : send: 0x1 0x3 0x5 0xc4 0x0 0x1 0xc5 0x3b
4621|[2023-09-06 07:22:49]DEBUG : Adding transaction 1
4622|[2023-09-06 07:22:49]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4623|[2023-09-06 07:22:49]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4624|[2023-09-06 07:22:49]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4625|[2023-09-06 07:22:49]DEBUG : Frame advanced, resetting header!!
4626|[2023-09-06 07:22:49]DEBUG : Getting transaction 1
4627|[2023-09-06 07:22:49]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4628|[2023-09-06 07:22:49]DEBUG : [0]
4629|[2023-09-06 07:22:49]DEBUG : send: 0x1 0x3 0x4 0x84 0x0 0x1 0xc5 0x13
4630|[2023-09-06 07:22:49]DEBUG : Adding transaction 1
4631|[2023-09-06 07:22:49]DEBUG : recv: 0x1 0x3 0x2 0x13 0x89 0x74 0xd2
4632|[2023-09-06 07:22:49]DEBUG : Getting Frame - 0x3 0x2 0x13 0x89
4633|[2023-09-06 07:22:49]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4634|[2023-09-06 07:22:49]DEBUG : Frame advanced, resetting header!!
4635|[2023-09-06 07:22:49]DEBUG : Getting transaction 1
4636|[2023-09-06 07:22:49]DEBUG : Frame - [b'\x01\x03\x02\x13\x89t\xd2'] not ready
4637|[2023-09-06 07:22:49]DEBUG : [5001]
4638|[2023-09-06 07:22:49]DEBUG : PyModbusClient: *ONDULEUR* read value for frequence (command id 145): 5001
4639|[2023-09-06 07:22:49]DEBUG : send: 0x1 0x3 0x4 0x8a 0x0 0x1 0xa4 0xd0
4640|[2023-09-06 07:22:49]DEBUG : Adding transaction 1
4641|[2023-09-06 07:22:49]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4642|[2023-09-06 07:22:49]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4643|[2023-09-06 07:22:49]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4644|[2023-09-06 07:22:49]DEBUG : Frame advanced, resetting header!!
4645|[2023-09-06 07:22:49]DEBUG : Getting transaction 1
4646|[2023-09-06 07:22:49]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4647|[2023-09-06 07:22:49]DEBUG : [0]
4648|[2023-09-06 07:22:49]DEBUG : send: 0x1 0x3 0x4 0x89 0x0 0x1 0x54 0xd0
4649|[2023-09-06 07:22:49]DEBUG : Adding transaction 1
4650|[2023-09-06 07:22:50]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4651|[2023-09-06 07:22:50]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4652|[2023-09-06 07:22:50]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4653|[2023-09-06 07:22:50]DEBUG : Frame advanced, resetting header!!
4654|[2023-09-06 07:22:50]DEBUG : Getting transaction 1
4655|[2023-09-06 07:22:50]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4656|[2023-09-06 07:22:50]DEBUG : [0]
4657|[2023-09-06 07:22:50]INFO : Send to jeedom : {'eqId': '23', 'values': {'113': 61, '145': 5001, 'cycle_time': 5.034879207611084}}
4658|[2023-09-06 07:22:50]DEBUG : PyModbusClient: *ONDULEUR* disconnect called
4659|[2023-09-06 07:22:50]DEBUG : Starting new HTTP connection (1): localhost:80
4660|[2023-09-06 07:22:50]INFO : Protocol lost connection.
4661|[2023-09-06 07:22:50]DEBUG : Client disconnected from modbus server: None
4662|[2023-09-06 07:22:50]DEBUG : jeemymodbus.php: $result *{"eqId":"23","values":{"113":61,"145":5001,"cycle_time":5.034879207611084}}* type: array
4663|[2023-09-06 07:22:50]DEBUG : jeemodbus.php: Mise à jour cmd Psortie onduleur -> new value: 61
4664|[2023-09-06 07:22:50]DEBUG : jeemodbus.php: Mise à jour cmd frequence -> new value: 50.01
4665|[2023-09-06 07:22:50]DEBUG : jeemodbus.php: Mise à jour cmd Temps de rafraîchissement -> new value: 5.035
4666|[2023-09-06 07:22:50]INFO : jeemodbus.php: Mise à jour des commandes info : 'Psortie onduleur' 'frequence' 'Temps de rafraîchissement'
4667|[2023-09-06 07:22:50]DEBUG : http://localhost:80 "POST /plugins/mymodbus/core/php/jeemymodbus.php?apikey=sD9E4aSXLtWnaalBpq85uKEpiFMIEZvDbG6PADF66lryYEfDQbrGRSMYnmQPaJQp HTTP/1.1" 200 0
4668|[2023-09-06 07:22:51]INFO : Send to jeedom : {'heartbeat_request': 1693977771}
4669|[2023-09-06 07:22:51]DEBUG : Starting new HTTP connection (1): localhost:80
4670|[2023-09-06 07:22:51]DEBUG : jeemymodbus.php: $result *{"heartbeat_request":1693977771}* type: array
4671|[2023-09-06 07:22:51]DEBUG : mymodbusd: Received message: {'CMD': 'heartbeat_answer', 'answer': 1693977771, 'apikey': 'sD9E4aSXLtWnaalBpq85uKEpiFMIEZvDbG6PADF66lryYEfDQbrGRSMYnmQPaJQp', 'dt': '2023-09-06T07:22:51+02:00'}
4672|[2023-09-06 07:22:51]DEBUG : http://localhost:80 "POST /plugins/mymodbus/core/php/jeemymodbus.php?apikey=sD9E4aSXLtWnaalBpq85uKEpiFMIEZvDbG6PADF66lryYEfDQbrGRSMYnmQPaJQp HTTP/1.1" 200 0
4673|[2023-09-06 07:22:54]DEBUG : PyModbusClient: *ONDULEUR* connect called
4674|[2023-09-06 07:22:54]DEBUG : PyModbusClient: *ONDULEUR* connecting...
4675|[2023-09-06 07:22:54]DEBUG : Connecting to 192.168.1.233:8899.
4676|[2023-09-06 07:22:54]DEBUG : Connecting.
4677|[2023-09-06 07:22:54]DEBUG : Client connected to modbus server
4678|[2023-09-06 07:22:54]INFO : Protocol made connection.
4679|[2023-09-06 07:22:54]INFO : Connected to 192.168.1.233:8899.
4680|[2023-09-06 07:22:54]DEBUG : send: 0x1 0x3 0x4 0x85 0x0 0x1 0x94 0xd3
4681|[2023-09-06 07:22:54]DEBUG : Adding transaction 1
4682|[2023-09-06 07:22:54]DEBUG : recv: 0x1 0x3 0x2 0x0 0x3c 0xb8 0x55
4683|[2023-09-06 07:22:54]DEBUG : Getting Frame - 0x3 0x2 0x0 0x3c
4684|[2023-09-06 07:22:54]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4685|[2023-09-06 07:22:54]DEBUG : Frame advanced, resetting header!!
4686|[2023-09-06 07:22:54]DEBUG : Getting transaction 1
4687|[2023-09-06 07:22:54]DEBUG : Frame - [b'\x01\x03\x02\x00<\xb8U'] not ready
4688|[2023-09-06 07:22:54]DEBUG : [60]
4689|[2023-09-06 07:22:54]DEBUG : PyModbusClient: *ONDULEUR* read value for Psortie onduleur (command id 113): 60
4690|[2023-09-06 07:22:54]DEBUG : send: 0x1 0x3 0x6 0x8 0x0 0x1 0x5 0x40
4691|[2023-09-06 07:22:54]DEBUG : Adding transaction 1
4692|[2023-09-06 07:22:54]DEBUG : recv: 0x1 0x3 0x2 0x0 0x26 0x39 0x9e
4693|[2023-09-06 07:22:54]DEBUG : Getting Frame - 0x3 0x2 0x0 0x26
4694|[2023-09-06 07:22:54]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4695|[2023-09-06 07:22:54]DEBUG : Frame advanced, resetting header!!
4696|[2023-09-06 07:22:54]DEBUG : Getting transaction 1
4697|[2023-09-06 07:22:54]DEBUG : Frame - [b'\x01\x03\x02\x00&9\x9e'] not ready
4698|[2023-09-06 07:22:54]DEBUG : [38]
4699|[2023-09-06 07:22:54]DEBUG : send: 0x1 0x3 0x5 0xc4 0x0 0x1 0xc5 0x3b
4700|[2023-09-06 07:22:54]DEBUG : Adding transaction 1
4701|[2023-09-06 07:22:54]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4702|[2023-09-06 07:22:54]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4703|[2023-09-06 07:22:54]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4704|[2023-09-06 07:22:54]DEBUG : Frame advanced, resetting header!!
4705|[2023-09-06 07:22:54]DEBUG : Getting transaction 1
4706|[2023-09-06 07:22:54]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4707|[2023-09-06 07:22:54]DEBUG : [0]
4708|[2023-09-06 07:22:54]DEBUG : send: 0x1 0x3 0x4 0x84 0x0 0x1 0xc5 0x13
4709|[2023-09-06 07:22:54]DEBUG : Adding transaction 1
4710|[2023-09-06 07:22:54]DEBUG : recv: 0x1 0x3 0x2 0x13 0x86 0x34 0xd6
4711|[2023-09-06 07:22:54]DEBUG : Getting Frame - 0x3 0x2 0x13 0x86
4712|[2023-09-06 07:22:54]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4713|[2023-09-06 07:22:54]DEBUG : Frame advanced, resetting header!!
4714|[2023-09-06 07:22:54]DEBUG : Getting transaction 1
4715|[2023-09-06 07:22:54]DEBUG : Frame - [b'\x01\x03\x02\x13\x864\xd6'] not ready
4716|[2023-09-06 07:22:54]DEBUG : [4998]
4717|[2023-09-06 07:22:54]DEBUG : PyModbusClient: *ONDULEUR* read value for frequence (command id 145): 4998
4718|[2023-09-06 07:22:54]DEBUG : send: 0x1 0x3 0x4 0x8a 0x0 0x1 0xa4 0xd0
4719|[2023-09-06 07:22:54]DEBUG : Adding transaction 1
4720|[2023-09-06 07:22:54]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4721|[2023-09-06 07:22:54]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4722|[2023-09-06 07:22:54]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4723|[2023-09-06 07:22:54]DEBUG : Frame advanced, resetting header!!
4724|[2023-09-06 07:22:54]DEBUG : Getting transaction 1
4725|[2023-09-06 07:22:54]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4726|[2023-09-06 07:22:54]DEBUG : [0]
4727|[2023-09-06 07:22:54]DEBUG : send: 0x1 0x3 0x4 0x89 0x0 0x1 0x54 0xd0
4728|[2023-09-06 07:22:54]DEBUG : Adding transaction 1
4729|[2023-09-06 07:22:55]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4730|[2023-09-06 07:22:55]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4731|[2023-09-06 07:22:55]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4732|[2023-09-06 07:22:55]DEBUG : Frame advanced, resetting header!!
4733|[2023-09-06 07:22:55]DEBUG : Getting transaction 1
4734|[2023-09-06 07:22:55]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4735|[2023-09-06 07:22:55]DEBUG : [0]
4736|[2023-09-06 07:22:55]INFO : Send to jeedom : {'eqId': '23', 'values': {'113': 60, '145': 4998}}
4737|[2023-09-06 07:22:55]DEBUG : PyModbusClient: *ONDULEUR* disconnect called
4738|[2023-09-06 07:22:55]DEBUG : Starting new HTTP connection (1): localhost:80
4739|[2023-09-06 07:22:55]INFO : Protocol lost connection.
4740|[2023-09-06 07:22:55]DEBUG : Client disconnected from modbus server: None
4741|[2023-09-06 07:22:55]DEBUG : jeemymodbus.php: $result *{"eqId":"23","values":{"113":60,"145":4998}}* type: array
4742|[2023-09-06 07:22:55]DEBUG : jeemodbus.php: Mise à jour cmd Psortie onduleur -> new value: 60
4743|[2023-09-06 07:22:55]DEBUG : jeemodbus.php: Mise à jour cmd frequence -> new value: 49.98
4744|[2023-09-06 07:22:55]INFO : jeemodbus.php: Mise à jour des commandes info : 'Psortie onduleur' 'frequence'
4745|[2023-09-06 07:22:55]DEBUG : http://localhost:80 "POST /plugins/mymodbus/core/php/jeemymodbus.php?apikey=sD9E4aSXLtWnaalBpq85uKEpiFMIEZvDbG6PADF66lryYEfDQbrGRSMYnmQPaJQp HTTP/1.1" 200 0
4746|[2023-09-06 07:22:59]DEBUG : PyModbusClient: *ONDULEUR* connect called
4747|[2023-09-06 07:22:59]DEBUG : PyModbusClient: *ONDULEUR* connecting...
4748|[2023-09-06 07:22:59]DEBUG : Connecting to 192.168.1.233:8899.
4749|[2023-09-06 07:22:59]DEBUG : Connecting.
4750|[2023-09-06 07:22:59]DEBUG : Client connected to modbus server
4751|[2023-09-06 07:22:59]INFO : Protocol made connection.
4752|[2023-09-06 07:22:59]INFO : Connected to 192.168.1.233:8899.
4753|[2023-09-06 07:22:59]DEBUG : send: 0x1 0x3 0x4 0x85 0x0 0x1 0x94 0xd3
4754|[2023-09-06 07:22:59]DEBUG : Adding transaction 1
4755|[2023-09-06 07:22:59]DEBUG : recv: 0x1 0x3 0x2 0x0 0x2d 0x78 0x59
4756|[2023-09-06 07:22:59]DEBUG : Getting Frame - 0x3 0x2 0x0 0x2d
4757|[2023-09-06 07:22:59]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4758|[2023-09-06 07:22:59]DEBUG : Frame advanced, resetting header!!
4759|[2023-09-06 07:22:59]DEBUG : Getting transaction 1
4760|[2023-09-06 07:22:59]DEBUG : Frame - [b'\x01\x03\x02\x00-xY'] not ready
4761|[2023-09-06 07:22:59]DEBUG : [45]
4762|[2023-09-06 07:22:59]DEBUG : PyModbusClient: *ONDULEUR* read value for Psortie onduleur (command id 113): 45
4763|[2023-09-06 07:22:59]DEBUG : send: 0x1 0x3 0x6 0x8 0x0 0x1 0x5 0x40
4764|[2023-09-06 07:22:59]DEBUG : Adding transaction 1
4765|[2023-09-06 07:22:59]DEBUG : recv: 0x1 0x3 0x2 0x0 0x26 0x39 0x9e
4766|[2023-09-06 07:22:59]DEBUG : Getting Frame - 0x3 0x2 0x0 0x26
4767|[2023-09-06 07:22:59]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4768|[2023-09-06 07:22:59]DEBUG : Frame advanced, resetting header!!
4769|[2023-09-06 07:22:59]DEBUG : Getting transaction 1
4770|[2023-09-06 07:22:59]DEBUG : Frame - [b'\x01\x03\x02\x00&9\x9e'] not ready
4771|[2023-09-06 07:22:59]DEBUG : [38]
4772|[2023-09-06 07:22:59]DEBUG : send: 0x1 0x3 0x5 0xc4 0x0 0x1 0xc5 0x3b
4773|[2023-09-06 07:22:59]DEBUG : Adding transaction 1
4774|[2023-09-06 07:22:59]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4775|[2023-09-06 07:22:59]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4776|[2023-09-06 07:22:59]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4777|[2023-09-06 07:22:59]DEBUG : Frame advanced, resetting header!!
4778|[2023-09-06 07:22:59]DEBUG : Getting transaction 1
4779|[2023-09-06 07:22:59]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4780|[2023-09-06 07:22:59]DEBUG : [0]
4781|[2023-09-06 07:22:59]DEBUG : send: 0x1 0x3 0x4 0x84 0x0 0x1 0xc5 0x13
4782|[2023-09-06 07:22:59]DEBUG : Adding transaction 1
4783|[2023-09-06 07:23:00]DEBUG : recv: 0x1 0x3 0x2 0x13 0x86 0x34 0xd6
4784|[2023-09-06 07:23:00]DEBUG : Getting Frame - 0x3 0x2 0x13 0x86
4785|[2023-09-06 07:23:00]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4786|[2023-09-06 07:23:00]DEBUG : Frame advanced, resetting header!!
4787|[2023-09-06 07:23:00]DEBUG : Getting transaction 1
4788|[2023-09-06 07:23:00]DEBUG : Frame - [b'\x01\x03\x02\x13\x864\xd6'] not ready
4789|[2023-09-06 07:23:00]DEBUG : [4998]
4790|[2023-09-06 07:23:00]DEBUG : send: 0x1 0x3 0x4 0x8a 0x0 0x1 0xa4 0xd0
4791|[2023-09-06 07:23:00]DEBUG : Adding transaction 1
4792|[2023-09-06 07:23:00]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4793|[2023-09-06 07:23:00]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4794|[2023-09-06 07:23:00]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4795|[2023-09-06 07:23:00]DEBUG : Frame advanced, resetting header!!
4796|[2023-09-06 07:23:00]DEBUG : Getting transaction 1
4797|[2023-09-06 07:23:00]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4798|[2023-09-06 07:23:00]DEBUG : [0]
4799|[2023-09-06 07:23:00]DEBUG : send: 0x1 0x3 0x4 0x89 0x0 0x1 0x54 0xd0
4800|[2023-09-06 07:23:00]DEBUG : Adding transaction 1
4801|[2023-09-06 07:23:00]DEBUG : recv: 0x1 0x3 0x2 0x0 0x0 0xb8 0x44
4802|[2023-09-06 07:23:00]DEBUG : Getting Frame - 0x3 0x2 0x0 0x0
4803|[2023-09-06 07:23:00]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4804|[2023-09-06 07:23:00]DEBUG : Frame advanced, resetting header!!
4805|[2023-09-06 07:23:00]DEBUG : Getting transaction 1
4806|[2023-09-06 07:23:00]DEBUG : Frame - [b'\x01\x03\x02\x00\x00\xb8D'] not ready
4807|[2023-09-06 07:23:00]DEBUG : [0]
4808|[2023-09-06 07:23:00]INFO : Send to jeedom : {'eqId': '23', 'values': {'113': 45}}
4809|[2023-09-06 07:23:00]DEBUG : PyModbusClient: *ONDULEUR* disconnect called
4810|[2023-09-06 07:23:00]DEBUG : Starting new HTTP connection (1): localhost:80
4811|[2023-09-06 07:23:00]INFO : Protocol lost connection.
4812|[2023-09-06 07:23:00]DEBUG : Client disconnected from modbus server: None
4813|[2023-09-06 07:23:00]DEBUG : jeemymodbus.php: $result *{"eqId":"23","values":{"113":45}}* type: array
4814|[2023-09-06 07:23:00]DEBUG : jeemodbus.php: Mise à jour cmd Psortie onduleur -> new value: 45
4815|[2023-09-06 07:23:00]INFO : jeemodbus.php: Mise à jour des commandes info : 'Psortie onduleur'
4816|[2023-09-06 07:23:00]DEBUG : http://localhost:80 "POST /plugins/mymodbus/core/php/jeemymodbus.php?apikey=sD9E4aSXLtWnaalBpq85uKEpiFMIEZvDbG6PADF66lryYEfDQbrGRSMYnmQPaJQp HTTP/1.1" 200 0
4817|[2023-09-06 07:23:04]DEBUG : PyModbusClient: *ONDULEUR* connect called
4818|[2023-09-06 07:23:04]DEBUG : PyModbusClient: *ONDULEUR* connecting...
4819|[2023-09-06 07:23:04]DEBUG : Connecting to 192.168.1.233:8899.
4820|[2023-09-06 07:23:04]DEBUG : Connecting.
4821|[2023-09-06 07:23:04]DEBUG : Client connected to modbus server
4822|[2023-09-06 07:23:04]INFO : Protocol made connection.
4823|[2023-09-06 07:23:04]INFO : Connected to 192.168.1.233:8899.
4824|[2023-09-06 07:23:04]DEBUG : send: 0x1 0x3 0x4 0x85 0x0 0x1 0x94 0xd3
4825|[2023-09-06 07:23:04]DEBUG : Adding transaction 1
4826|[2023-09-06 07:23:04]DEBUG : recv: 0x1 0x3 0x2 0x0 0x2d 0x78 0x59
4827|[2023-09-06 07:23:04]DEBUG : Getting Frame - 0x3 0x2 0x0 0x2d
4828|[2023-09-06 07:23:04]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4829|[2023-09-06 07:23:04]DEBUG : Frame advanced, resetting header!!
4830|[2023-09-06 07:23:04]DEBUG : Getting transaction 1
4831|[2023-09-06 07:23:04]DEBUG : Frame - [b'\x01\x03\x02\x00-xY'] not ready
4832|[2023-09-06 07:23:04]DEBUG : [45]
4833|[2023-09-06 07:23:04]DEBUG : send: 0x1 0x3 0x6 0x8 0x0 0x1 0x5 0x40
4834|[2023-09-06 07:23:04]DEBUG : Adding transaction 1
4835|[2023-09-06 07:23:07]INFO : Protocol lost connection.
4836|[2023-09-06 07:23:07]DEBUG : Client disconnected from modbus server: trying to send
4837|[2023-09-06 07:23:07]DEBUG : Getting transaction 1
4838|[2023-09-06 07:23:07]ERROR : PyModbusClient: *ONDULEUR* Something went wrong while reading Batterie (command id 114): <class 'asyncio.exceptions.TimeoutError'> = . Traceback: <traceback object at 0x7ff4569dc980>
4839|[2023-09-06 07:23:07]ERROR : PyModbusClient: *ONDULEUR* Something went wrong while reading Ppanneauxx (command id 135): <class 'pymodbus.exceptions.ConnectionException'> = Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.233:8899]. Traceback: <traceback object at 0x7ff456a37b80>
4840|[2023-09-06 07:23:07]ERROR : PyModbusClient: *ONDULEUR* Something went wrong while reading frequence (command id 145): <class 'pymodbus.exceptions.ConnectionException'> = Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.233:8899]. Traceback: <traceback object at 0x7ff456a37b80>
4841|[2023-09-06 07:23:07]ERROR : PyModbusClient: *ONDULEUR* Something went wrong while reading test (command id 146): <class 'pymodbus.exceptions.ConnectionException'> = Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.233:8899]. Traceback: <traceback object at 0x7ff456a37b80>
4842|[2023-09-06 07:23:07]ERROR : PyModbusClient: *ONDULEUR* Something went wrong while reading test1 (command id 147): <class 'pymodbus.exceptions.ConnectionException'> = Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.233:8899]. Traceback: <traceback object at 0x7ff456a37b80>
4843|[2023-09-06 07:23:07]DEBUG : PyModbusClient: *ONDULEUR* disconnect called
4844|[2023-09-06 07:23:09]DEBUG : PyModbusClient: *ONDULEUR* connect called
4845|[2023-09-06 07:23:09]DEBUG : PyModbusClient: *ONDULEUR* connecting...
4846|[2023-09-06 07:23:09]DEBUG : Connecting to 192.168.1.233:8899.
4847|[2023-09-06 07:23:09]DEBUG : Connecting.
4848|[2023-09-06 07:23:09]INFO : Protocol lost connection.
4849|[2023-09-06 07:23:09]DEBUG : Client disconnected from modbus server: None
4850|[2023-09-06 07:23:09]DEBUG : Client connected to modbus server
4851|[2023-09-06 07:23:09]INFO : Protocol made connection.
4852|[2023-09-06 07:23:09]INFO : Connected to 192.168.1.233:8899.
4853|[2023-09-06 07:23:09]DEBUG : send: 0x1 0x3 0x4 0x85 0x0 0x1 0x94 0xd3
4854|[2023-09-06 07:23:09]DEBUG : Adding transaction 1
4855|[2023-09-06 07:23:09]DEBUG : recv: 0x1 0x3 0x2 0x0 0x26 0x39 0x9e
4856|[2023-09-06 07:23:09]DEBUG : Getting Frame - 0x3 0x2 0x0 0x26
4857|[2023-09-06 07:23:09]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4858|[2023-09-06 07:23:09]DEBUG : Frame advanced, resetting header!!
4859|[2023-09-06 07:23:09]DEBUG : Getting transaction 1
4860|[2023-09-06 07:23:09]DEBUG : Frame - [b'\x01\x03\x02\x00&9\x9e'] not ready
4861|[2023-09-06 07:23:09]DEBUG : [38]
4862|[2023-09-06 07:23:09]DEBUG : PyModbusClient: *ONDULEUR* read value for Psortie onduleur (command id 113): 38
4863|[2023-09-06 07:23:09]DEBUG : send: 0x1 0x3 0x6 0x8 0x0 0x1 0x5 0x40
4864|[2023-09-06 07:23:09]DEBUG : Adding transaction 1
4865|[2023-09-06 07:23:09]DEBUG : recv: 0x1 0x3 0x2 0x0 0x2c 0xb9 0x99
4866|[2023-09-06 07:23:09]DEBUG : Getting Frame - 0x3 0x2 0x0 0x2c
4867|[2023-09-06 07:23:09]DEBUG : Factory Response[ReadHoldingRegistersResponse': 3]
4868|[2023-09-06 07:23:09]DEBUG : Frame advanced, resetting header!!
4869|[2023-09-06 07:23:09]DEBUG : Getting transaction 1
4870|[2023-09-06 07:23:09]DEBUG : Frame - [b'\x01\x03\x02\x00,\xb9\x99'] not ready
4871|[2023-09-06 07:23:09]DEBUG : [44]
4872|[2023-09-06 07:23:09]DEBUG : PyModbusClient: *ONDULEUR* read value for Batterie (command id 114): 44
4873|[2023-09-06 07:23:09]DEBUG : send: 0x1 0x3 0x5 0xc4 0x0 0x1 0xc5 0x3b
4874|[2023-09-06 07:23:09]DEBUG : Adding transaction 1
4875|[2023-09-06 07:23:09]DEBUG : recv: 0x1 0x3 0x2 0x0 0x26 0xf9
4876|[2023-09-06 07:23:09]DEBUG : Frame - [b'\x01\x03\x02\x00&\xf9'] not ready
4877|[2023-09-06 07:23:12]INFO : Protocol lost connection.
4878|[2023-09-06 07:23:12]DEBUG : Client disconnected from modbus server: trying to send
4879|[2023-09-06 07:23:12]DEBUG : Getting transaction 1
4880|[2023-09-06 07:23:12]ERROR : PyModbusClient: *ONDULEUR* Something went wrong while reading Ppanneauxx (command id 135): <class 'asyncio.exceptions.TimeoutError'> = . Traceback: <traceback object at 0x7ff456170100>
4881|[2023-09-06 07:23:12]ERROR : PyModbusClient: *ONDULEUR* Something went wrong while reading frequence (command id 145): <class 'pymodbus.exceptions.ConnectionException'> = Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.233:8899]. Traceback: <traceback object at 0x7ff4561676c0>
4882|[2023-09-06 07:23:12]ERROR : PyModbusClient: *ONDULEUR* Something went wrong while reading test (command id 146): <class 'pymodbus.exceptions.ConnectionException'> = Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.233:8899]. Traceback: <traceback object at 0x7ff4561676c0>
4883|[2023-09-06 07:23:12]ERROR : PyModbusClient: *ONDULEUR* Something went wrong while reading test1 (command id 147): <class 'pymodbus.exceptions.ConnectionException'> = Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.233:8899]. Traceback: <traceback object at 0x7ff4561676c0>
4884|[2023-09-06 07:23:12]INFO : Send to jeedom : {'eqId': '23', 'values': {'113': 38, '114': 44}}
4885|[2023-09-06 07:23:12]DEBUG : PyModbusClient: *ONDULEUR* disconnect called
4886|[2023-09-06 07:23:12]DEBUG : Starting new HTTP connection (1): localhost:80
4887|[2023-09-06 07:23:12]DEBUG : jeemymodbus.php: $result *{"eqId":"23","values":{"113":38,"114":44}}* type: array
4888|[2023-09-06 07:23:12]DEBUG : jeemodbus.php: Mise à jour cmd Psortie onduleur -> new value: 38
4889|[2023-09-06 07:23:12]DEBUG : jeemodbus.php: Mise à jour cmd Batterie -> new value: 44
4890|[2023-09-06 07:23:12]INFO : jeemodbus.php: Mise à jour des commandes info : 'Psortie onduleur' 'Batterie'
4891|[2023-09-06 07:23:12]DEBUG : http://localhost:80 "POST /plugins/mymodbus/core/php
Pour ce qui est de la différence entre les adresses la 487 c’est la puissance apparente sortie d’onduleur
la 48A c’est la puissance du réseau (consomation-production)
enfin je pense j’aurais voulu avoir des données pour pouvoir les interpreter
Merci a tous pour votre aide.
