SLZB-06 - Jeezigbee & Ember
Dear Folks,
Sur un debian 11 à jour, core en beta 4.5 et plugin stable.
Un contrôleur zigbee SLZB-06 dernier firmware, bref tout mis à jour.
Il est en mode contrôleur, LAN Poe
Dans Zigbee, en type controleur znp/ti, tout est OK
Je choisis ember et là impossible d’avoir le démon OK
Je dois surement passer à coté d’une subtilité mais je ne vois pas laquelle.
C’est pour cela que je me tourne vers vous.
Voici le log quand je choisis ember
Starting Zigbee2MQTT without watchdog.
[2024-11-08 15:58:00] e[31merrore[39m: 	z2m: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/utils.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/settings.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js)
[2024-11-08 15:58:00] e[31merrore[39m: 	z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2024-11-08 15:58:00] e[31merrore[39m: 	z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2024-11-08 15:58:13] e[31merrore[39m: 	z2m: Error while starting zigbee-herdsman
[2024-11-08 15:58:13] e[31merrore[39m: 	z2m: Failed to start zigbee
[2024-11-08 15:58:13] e[31merrore[39m: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-11-08 15:58:13] e[31merrore[39m: 	z2m: Exiting...
[2024-11-08 15:58:13] e[31merrore[39m: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
at EmberAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1598:24)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:69:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:161:27)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:154:5)
Je comprends pas. Si c’est un chip ti pourquoi mettre ember? Ember, c’est silicon labs. Ou alors tu voulais écrire EZSP et non ZNP?
Je ne suis pas fou, certains ont ce contrôleur et sont sur ember
ZNP = texas instrument
EZSP ou Ember = silicon labs
Donc si cela fonctionne avec ZNP, cela ne peut pas avec Ember.
Un firmware ne change pas une puce.
OK
Donc eux ont fumés la moquette ?
Et donc leur changelog ils ont fumés aussi ?
Attention, y a deux références: « SLZB-06 » <> « SLZB-06M »
Donc cela veut dire que même si j’ai le firmware v2.5.8 si mon controleur est un 06 au lieu d’un 06m je ne peux avoir ember ?
Donc je suis bloqué pour une quelconque évolution vu que a part ember plus rien ne va évoluer ?
ce n’est pas ma compréhension
mais que veux-tu dire par « évoluer »?
