j’ai une alarme HEIMAN sous protocole ZIGBEE que je n’arrive pas à faire marcher avec le plugin-in officiel ZIGBEE.
L’équipement est bien détecté et des commandes sont crées.
Par contre quand je les test j’ai un message d’erreur comme quoi le endPoint n’est pas trouvé.
J’ai tenté de remplacer le endPoint apr la valeur « 1 » → plus de message d’erreur mais impossible de faire sonner la sirène.
Voici les informations brut du plug-in
"ieee": "00:0d:6f:00:14:f6:c9:a5",
"nwk": 50936,
"status": 2,
"lqi": "None",
"rssi": "None",
"last_seen": "None",
"node_descriptor": "01:40:8e:0b:12:52:52:00:00:00:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1027,
"profile_id": 260,
"manufacturer": "Heiman",
"model": "WarningDevice",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 18
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 16
"id": 4,
"name": "manufacturer",
"value": "Heiman"
"id": 5,
"name": "model",
"value": "WarningDevice"
"id": 6,
"name": "date_code",
"value": "2018.03.21"
"id": 7,
"name": "power_source",
"value": 129
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 26
"id": 33,
"name": "battery_percentage_remaining",
"value": 0
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 9,
"name": "Alarms",
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": []
"id": 1282,
"name": "IAS Warning Device",
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4619,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 0,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
1,
3,
4,
9,
1280,
1282
3,
25
"class": "zigpy.device"
Du coup, j’ai testé avec le plug-in « abeille » dont je ne me sert plus car j’ai plein d’autre équipements qu’il ne detecte pas. Par contre pour la sirène cela fonctionne.
Voici les commandes qui sont crées :
j’arrive bien a faire signer la SIRENE mais je ne comprend pas comment je pourrai recréer ce type de commande sous plug-in ZIGBEE
merci pour votre aide
