Tout fonctionnait parfaitement depuis plus de 2 ans, et la impossible d’avoir un statut OK au niveau du statut de service. (depuis une coupure de courant)
Auriez vous une piste?
Informations Jeedom Luna
Core : 4.4.5 (V4-stable)
DNS Jeedom Luna : oui
Plugin : VMC (Zehnder/Storkair)
Version : 2024-04-10 01:26:54 (stable)
Informations complémentaires
Log des dépendances:
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_vmczehnder
0003|+ echo 1
0004|+ echo 2
0005|+ php /var/www/html/core/class/../php/jeecli.php plugin install mqtt2
0006|apt: no process found
0007|apt-get: no process found
0008|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0009|Hit:1 https://deb.debian.org/debian bullseye InRelease
0010|Hit:2 https://deb.debian.org/debian-security bullseye-security InRelease
0011|Hit:3 https://deb.debian.org/debian bullseye-updates InRelease
0012|Hit:4 https://deb.debian.org/debian bullseye-backports InRelease
0013|Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
0014|Reading package lists...
0015|Building dependency tree...
0016|Reading state information...
0017|1 package can be upgraded. Run 'apt list --upgradable' to see it.
0018|Hit:1 https://deb.debian.org/debian bullseye InRelease
0019|Hit:2 https://deb.debian.org/debian-security bullseye-security InRelease
0020|Hit:3 https://deb.debian.org/debian bullseye-updates InRelease
0021|Hit:4 https://deb.debian.org/debian bullseye-backports InRelease
0022|Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
0023|Reading package lists...
0024|Reading package lists...
0025|Building dependency tree...
0026|Reading state information...
0027|apt-utils is already the newest version (2.2.4).
0028|build-essential is already the newest version (12.9).
0029|git is already the newest version (1:2.30.2-1+deb11u2).
0030|lsb-release is already the newest version (11.1.0).
0031|0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
0032|[Check Version NodeJS actuelle : v18.19.1 : [ OK ]
0033|[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
0034|Hit:1 https://deb.debian.org/debian bullseye InRelease
0035|Hit:2 https://deb.debian.org/debian-security bullseye-security InRelease
0036|Hit:3 https://deb.debian.org/debian bullseye-updates InRelease
0037|Hit:4 https://deb.debian.org/debian bullseye-backports InRelease
0038|Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
0039|Reading package lists...
0040|Reading package lists...
0041|Building dependency tree...
0042|Reading state information...
0043|apt-utils is already the newest version (2.2.4).
0044|build-essential is already the newest version (12.9).
0045|git is already the newest version (1:2.30.2-1+deb11u2).
0046|lsb-release is already the newest version (11.1.0).
0047|0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
0048|[Check Version NodeJS actuelle : v18.19.1 : [ OK ]
0049|[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
0050|Hit:1 https://deb.debian.org/debian bullseye InRelease
0051|Hit:2 https://deb.debian.org/debian-security bullseye-security InRelease
0052|Hit:3 https://deb.debian.org/debian bullseye-updates InRelease
0053|Hit:4 https://deb.debian.org/debian bullseye-backports InRelease
0054|Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
0055|Reading package lists...
0056|Reading package lists...
0057|Building dependency tree...
0058|Reading state information...
0059|apt-utils is already the newest version (2.2.4).
0060|build-essential is already the newest version (12.9).
0061|git is already the newest version (1:2.30.2-1+deb11u2).
0062|lsb-release is already the newest version (11.1.0).
0063|0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
0064|[Check Version NodeJS actuelle : v18.19.1 : [ OK ]
0065|[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
0066|--2024-04-28 07:53:16-- https://getcomposer.org/installer
0067|Resolving getcomposer.org (getcomposer.org)... 54.36.53.46, 2001:41d0:302:1100::8:104f
0068|Connecting to getcomposer.org (getcomposer.org)|54.36.53.46|:443... connected.
0069|HTTP request sent, awaiting response... 200 OK
0070|Length: 58444 (57K) [application/octet-stream]
0071|Saving to: 'composer-setup.php'
0072|0K .......... .......... .......... .......... .......... 87% 2.50M 0s
0073|50K ....... 100% 32.7M=0.02s
0074|2024-04-28 07:53:16 (2.83 MB/s) - 'composer-setup.php' saved [58444/58444]
0075|Begin installation of composer
0076|All settings correct for using Composer
0077|Downloading...
0078|Composer (version 2.7.4) successfully installed to: /var/www/html/core/ajax/composer.phar
0079|Use it: php composer.phar
0080|End installation of composer
0081|npm notice
0082|npm notice New minor version of npm available! 10.2.4 -> 10.6.0
0083|npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.6.0>
0084|npm notice Run `npm install -g npm@10.6.0` to update!
0085|npm notice
0086|added 115 packages, and audited 116 packages in 10s
0087|18 packages are looking for funding
0088|run `npm fund` for details
0089|2 moderate severity vulnerabilities
0090|To address all issues, run:
0091|npm audit fix
0092|Run `npm audit` for details.
0093|Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
0094|Executing: /lib/systemd/systemd-sysv-install enable mosquitto
0095|+ echo 3
0096|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end vmczehnder
0097|+ echo 4
0098|+ rm /tmp/jeedom_install_in_progress_vmczehnder
0099|+ echo '*******************End of package installation******************'
0100|*******************End of package installation******************
Log du plugin:
0000|[2024-04-28 08:17:45] INFO : Successfully connected to MQTT server with code 0
0001|[2024-04-28 08:17:45] INFO : Successfully subscribed to the MQTT topics
0002|[2024-04-28 08:17:46] INFO : Refresh hrv config
0003|[2024-04-28 08:17:48]WARNING : Checksum doesn't match (121 vs 252). Message ignored
0004|[2024-04-28 08:17:49]WARNING : get_bootloader_data function could not get serial data
0005|[2024-04-28 08:17:57] INFO : Successfully connected to MQTT server with code 0
0006|[2024-04-28 08:17:57] INFO : Successfully subscribed to the MQTT topics
0007|[2024-04-28 08:17:58] INFO : Refresh hrv config
0008|[2024-04-28 08:18:00]WARNING : Checksum doesn't match (253 vs 143). Message ignored
0009|[2024-04-28 08:18:00]WARNING : get_bootloader_data function could not get serial data
0010|[2024-04-28 08:51:44]WARNING : Checksum doesn't match (139 vs 108). Message ignored
0011|[2024-04-28 08:51:44]WARNING : get_firmware_info function could not get serial data
0012|[2024-04-28 08:51:47]WARNING : Checksum doesn't match (250 vs 252). Message ignored
0013|[2024-04-28 08:51:47]WARNING : get_connector_board_info function could not get serial data
0014|[2024-04-28 08:51:49]WARNING : Checksum doesn't match (11 vs 152). Message ignored
0015|[2024-04-28 08:51:49]WARNING : get_status function could not get serial data
0016|[2024-04-28 08:51:51]WARNING : Checksum doesn't match (151 vs 143). Message ignored
0017|[2024-04-28 08:51:51]WARNING : get_delay_timers function could not get serial data
0018|[2024-04-28 08:51:55]WARNING : Checksum doesn't match (131 vs 252). Message ignored
0019|[2024-04-28 08:51:55]WARNING : get_temp function could not get serial data
0020|[2024-04-28 08:51:57]WARNING : Checksum doesn't match (123 vs 152). Message ignored
0021|[2024-04-28 08:51:57]WARNING : get_ventilation_status function could not get serial data
0022|[2024-04-28 08:52:00]WARNING : Checksum doesn't match (110 vs 224). Message ignored
0023|[2024-04-28 08:52:00]WARNING : get_filter_status function could not get serial data
0024|[2024-04-28 08:52:02]WARNING : Checksum doesn't match (37 vs 252). Message ignored
0025|[2024-04-28 08:52:02]WARNING : get_fan_status function could not get serial data
0026|[2024-04-28 08:52:04]WARNING : Checksum doesn't match (156 vs 152). Message ignored
0027|[2024-04-28 08:52:04]WARNING : get_bypass_control function could not get serial data
0028|[2024-04-28 08:52:07]WARNING : Checksum doesn't match (208 vs 143). Message ignored
0029|[2024-04-28 08:52:07]WARNING : get_valve_status function could not get serial data
0030|[2024-04-28 08:52:09]WARNING : Checksum doesn't match (228 vs 224). Message ignored
0031|[2024-04-28 08:52:09]WARNING : get_operating_hours function could not get serial data
0032|[2024-04-28 08:52:22] INFO : Successfully connected to MQTT server with code 0
0033|[2024-04-28 08:52:22] INFO : Successfully subscribed to the MQTT topics
0034|[2024-04-28 08:52:23] INFO : Refresh hrv config
0035|[2024-04-28 08:52:25]WARNING : Checksum doesn't match (14 vs 108). Message ignored
0036|[2024-04-28 08:52:25]WARNING : get_bootloader_data function could not get serial data
0037|[2024-04-28 08:52:27]WARNING : Checksum doesn't match (203 vs 152). Message ignored
0038|[2024-04-28 08:52:27]WARNING : get_firmware_info function could not get serial data
0039|[2024-04-28 08:52:29]WARNING : Checksum doesn't match (15 vs 230). Message ignored
0040|[2024-04-28 08:52:29]WARNING : get_connector_board_info function could not get serial data
0041|[2024-04-28 08:52:33] INFO : Successfully connected to MQTT server with code 0
0042|[2024-04-28 08:52:33] INFO : Successfully subscribed to the MQTT topics
0043|[2024-04-28 08:52:34] INFO : Refresh hrv config
0044|[2024-04-28 08:52:36]WARNING : Checksum doesn't match (22 vs 252). Message ignored
0045|[2024-04-28 08:52:36]WARNING : get_bootloader_data function could not get serial data
0046|[2024-04-28 08:52:38]WARNING : Checksum doesn't match (51 vs 143). Message ignored
0047|[2024-04-28 08:52:38]WARNING : get_firmware_info function could not get serial data
0048|[2024-04-28 08:52:40]WARNING : Checksum doesn't match (114 vs 108). Message ignored
0049|[2024-04-28 08:52:40]WARNING : get_connector_board_info function could not get serial data
0050|[2024-04-28 08:52:42]WARNING : Checksum doesn't match (139 vs 143). Message ignored
0051|[2024-04-28 08:52:42]WARNING : get_status function could not get serial data
0052|[2024-04-28 08:52:45]WARNING : Checksum doesn't match (195 vs 108). Message ignored
0053|[2024-04-28 08:52:45]WARNING : get_delay_timers function could not get serial data
0054|[2024-04-28 08:52:48]WARNING : Checksum doesn't match (170 vs 80). Message ignored
0055|[2024-04-28 08:52:48]WARNING : get_temp function could not get serial data
0056|[2024-04-28 08:52:53] INFO : Successfully connected to MQTT server with code 0
0057|[2024-04-28 08:52:53] INFO : Successfully subscribed to the MQTT topics
0058|[2024-04-28 08:52:54] INFO : Refresh hrv config
0059|[2024-04-28 08:52:56]WARNING : Checksum doesn't match (3 vs 142). Message ignored
0060|[2024-04-28 08:52:56]WARNING : get_bootloader_data function could not get serial data
0061|[2024-04-28 08:52:58]WARNING : Checksum doesn't match (19 vs 252). Message ignored
0062|[2024-04-28 08:52:58]WARNING : get_firmware_info function could not get serial data
0063|[2024-04-28 08:53:01]WARNING : Checksum doesn't match (198 vs 143). Message ignored
0064|[2024-04-28 08:53:01]WARNING : get_connector_board_info function could not get serial data
0065|[2024-04-28 08:53:03]WARNING : Checksum doesn't match (227 vs 108). Message ignored
0066|[2024-04-28 08:53:03]WARNING : get_status function could not get serial data
0067|[2024-04-28 08:53:05]WARNING : Checksum doesn't match (123 vs 152). Message ignored
0068|[2024-04-28 08:53:05]WARNING : get_delay_timers function could not get serial data
0069|[2024-04-28 08:54:15] INFO : Successfully connected to MQTT server with code 0
0070|[2024-04-28 08:54:15] INFO : Successfully subscribed to the MQTT topics
0071|[2024-04-28 08:54:16] INFO : Refresh hrv config
0072|[2024-04-28 08:54:18]WARNING : Checksum doesn't match (120 vs 108). Message ignored
0073|[2024-04-28 08:54:18]WARNING : get_bootloader_data function could not get serial data
0074|[2024-04-28 08:54:20]WARNING : Checksum doesn't match (164 vs 205). Message ignored
0075|[2024-04-28 08:54:20]WARNING : get_firmware_info function could not get serial data
0076|[2024-04-28 08:54:23]WARNING : Checksum doesn't match (28 vs 179). Message ignored
0077|[2024-04-28 08:54:23]WARNING : get_connector_board_info function could not get serial data
0078|[2024-04-28 08:54:25]WARNING : Checksum doesn't match (179 vs 95). Message ignored
0079|[2024-04-28 08:54:25]WARNING : get_status function could not get serial data
0080|[2024-04-28 08:54:27]WARNING : Checksum doesn't match (33 vs 252). Message ignored
0081|[2024-04-28 08:54:27]WARNING : get_delay_timers function could not get serial data
0082|[2024-04-28 08:54:30]WARNING : Checksum doesn't match (156 vs 150). Message ignored
0083|[2024-04-28 08:54:30]WARNING : get_temp function could not get serial data
0084|[2024-04-28 08:54:32]WARNING : Checksum doesn't match (18 vs 179). Message ignored
0085|[2024-04-28 08:54:32]WARNING : get_ventilation_status function could not get serial data
0086|[2024-04-28 08:54:35]WARNING : Checksum doesn't match (195 vs 224). Message ignored
0087|[2024-04-28 08:54:35]WARNING : get_filter_status function could not get serial data
0088|[2024-04-28 08:54:37]WARNING : Checksum doesn't match (215 vs 252). Message ignored
0089|[2024-04-28 08:54:37]WARNING : get_fan_status function could not get serial data
0090|[2024-04-28 08:54:39]WARNING : Checksum doesn't match (205 vs 142). Message ignored
0091|[2024-04-28 08:54:39]WARNING : get_bypass_control function could not get serial data
0092|[2024-04-28 08:54:41]WARNING : Checksum doesn't match (108 vs 142). Message ignored
0093|[2024-04-28 08:54:41]WARNING : get_valve_status function could not get serial data
0094|[2024-04-28 08:54:43]WARNING : Checksum doesn't match (151 vs 108). Message ignored
0095|[2024-04-28 08:54:43]WARNING : get_operating_hours function could not get serial data
0096|[2024-04-28 08:54:51]WARNING : Checksum doesn't match (12 vs 224). Message ignored
0097|[2024-04-28 08:54:51]WARNING : get_temp function could not get serial data
0098|[2024-04-28 08:54:54]WARNING : Checksum doesn't match (5 vs 108). Message ignored
0099|[2024-04-28 08:54:54]WARNING : get_ventilation_status function could not get serial data
0100|[2024-04-28 08:54:56]WARNING : Checksum doesn't match (228 vs 152). Message ignored
0101|[2024-04-28 08:54:56]WARNING : get_filter_status function could not get serial data
0102|[2024-04-28 08:54:58]WARNING : Checksum doesn't match (99 vs 224). Message ignored
0103|[2024-04-28 08:54:58]WARNING : get_fan_status function could not get serial data
0104|[2024-04-28 08:55:00]WARNING : Checksum doesn't match (251 vs 230). Message ignored
0105|[2024-04-28 08:55:00]WARNING : get_bypass_control function could not get serial data
0106|[2024-04-28 08:55:02]WARNING : Checksum doesn't match (123 vs 252). Message ignored
0107|[2024-04-28 08:55:02]WARNING : get_valve_status function could not get serial data
Log vmc update
0000|[2024-04-28 10:33:23] *********************************
0001|[2024-04-28 10:33:23] * update all packages on the pi *
0002|[2024-04-28 10:33:23] *********************************
0003|[2024-04-28 10:33:24] Atteint :1 http://raspbian.raspberrypi.org/raspbian buster InRelease
0004|[2024-04-28 10:33:24] Atteint :2 http://archive.raspberrypi.org/debian buster InRelease
0005|[2024-04-28 10:33:50] Lecture des listes de paquets…
0006|[2024-04-28 10:33:51] ***********************************
0007|[2024-04-28 10:33:51] * install dependencies if needed *
0008|[2024-04-28 10:33:51] ***********************************
0009|[2024-04-28 10:33:51] Lecture des listes de paquets…
0010|[2024-04-28 10:33:53] Construction de l'arbre des dépendances…
0011|[2024-04-28 10:33:53] Lecture des informations d'état…
0012|[2024-04-28 10:33:58] python3-serial est déjà la version la plus récente (3.4-4).
0013|[2024-04-28 10:33:58] python3-yaml est déjà la version la plus récente (3.13-2).
0014|[2024-04-28 10:33:58] python3-pip est déjà la version la plus récente (18.1-5+rpt1).
0015|[2024-04-28 10:33:58] Le paquet suivant a été installé automatiquement et n'est plus nécessaire :
0016|[2024-04-28 10:33:58] python-colorzero
0017|[2024-04-28 10:33:58] Veuillez utiliser « sudo apt autoremove » pour le supprimer.
0018|[2024-04-28 10:33:59] 0 mis à jour, 0 nouvellement installés, 0 à enlever et 336 non mis à jour.
0019|[2024-04-28 10:34:27] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0020|[2024-04-28 10:34:27] Requirement already satisfied: paho-mqtt>=2.0.0 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 1)) (2.0.0)
0021|[2024-04-28 10:34:27] Requirement already satisfied: pyserial==3.5 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 2)) (3.5)
0022|[2024-04-28 10:34:27] Requirement already satisfied: pyyaml==6.0.1 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 3)) (6.0.1)
0023|[2024-04-28 10:34:31] ********************
0024|[2024-04-28 10:34:31] * install finished *
0025|[2024-04-28 10:34:31] ********************
