J’avais deja checké tous les logs qui apparaissaient en erreur, mais celui la n’apparaissait pas en erreur.
Mais effectivement il y a pas mal d’éléments dedans… mais je suis pas capable d’interpreter…
Je mets le log au complet, des fois que ca inspire…
(L’IP en 88.15 est celle de mon PC et 88.81 celle de Jeedom…)
[Sun Jan 31 11:36:38.508515 2021] [php7:error] [pid 551] [client 192.168.88.15:50930] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 2097160 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
[Sun Jan 31 11:37:15.418799 2021] [php7:error] [pid 640] [client 192.168.88.15:50944] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
[Sun Jan 31 11:37:55.251103 2021] [php7:notice] [pid 24853] [client 192.168.88.15:50971] PHP Notice: Only variables should be passed by reference in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 446, referer: http://192.168.88.81/index.php?v=d&m=vigilancemeteo&p=vigilancemeteo&id=vigilancemeteo
[Sun Jan 31 11:37:55.251444 2021] [php7:notice] [pid 24853] [client 192.168.88.15:50971] PHP Notice: Only variables should be passed by reference in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 444, referer: http://192.168.88.81/index.php?v=d&m=vigilancemeteo&p=vigilancemeteo&id=vigilancemeteo
[Sun Jan 31 11:38:05.486230 2021] [php7:error] [pid 758] [client 192.168.88.15:50942] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 2097160 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
[Sun Jan 31 11:39:47.304742 2021] [php7:error] [pid 31480] [client 192.168.88.15:50969] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 2097160 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
[Sun Jan 31 11:40:53.492748 2021] [php7:error] [pid 623] [client 192.168.88.15:51002] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 2097160 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
[Sun Jan 31 11:42:25.543088 2021] [php7:error] [pid 640] [client 192.168.88.15:51028] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 2097160 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
kill: (9825): No such process
[Sun Jan 31 11:42:58.692217 2021] [php7:error] [pid 16975] [client 192.168.88.15:51025] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 2097160 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
[Sun Jan 31 11:44:42.399904 2021] [php7:error] [pid 640] [client 192.168.88.15:51069] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 2097160 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
[Sun Jan 31 11:45:15.677115 2021] [php7:error] [pid 16975] [client 192.168.88.15:51084] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
[Sun Jan 31 11:45:40.197341 2021] [php7:notice] [pid 11256] [client 192.168.88.15:51113] PHP Notice: Undefined offset: 1 in /var/www/html/core/class/cmd.class.php on line 1310, referer: http://192.168.88.81/index.php?v=d&p=dashboard
[Sun Jan 31 11:46:48.353355 2021] [mpm_prefork:notice] [pid 469] AH00163: Apache/2.4.38 (Debian) OpenSSL/1.1.1d configured -- resuming normal operations
[Sun Jan 31 11:46:48.359953 2021] [core:notice] [pid 469] AH00094: Command line: '/usr/sbin/apache2'
[Sun Jan 31 11:46:48.813799 2021] [php7:error] [pid 568] [client 192.168.88.15:51187] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
thrown in /var/www/html/core/ajax/event.ajax.php on line 36, referer: http://192.168.88.81/index.php?v=d&p=log
[Sun Jan 31 11:46:48.824197 2021] [php7:error] [pid 569] [client 192.168.88.15:51188] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
thrown in /var/www/html/core/ajax/event.ajax.php on line 36, referer: http://192.168.88.81/index.php?v=d&p=dashboard
[Sun Jan 31 11:46:48.831275 2021] [php7:error] [pid 567] [client 192.168.88.15:51192] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
thrown in /var/www/html/core/ajax/event.ajax.php on line 36, referer: http://192.168.88.81/index.php?v=d&p=reboot
[Sun Jan 31 11:46:48.862879 2021] [php7:error] [pid 570] [client 192.168.88.15:51193] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:48.903633 2021] [php7:error] [pid 571] [client 192.168.88.15:51194] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:48.937412 2021] [php7:error] [pid 568] [client 192.168.88.15:51195] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:48.974744 2021] [php7:error] [pid 569] [client 192.168.88.15:51196] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.007524 2021] [php7:error] [pid 567] [client 192.168.88.15:51197] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.029726 2021] [php7:error] [pid 570] [client 192.168.88.15:51198] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.044237 2021] [php7:error] [pid 571] [client 192.168.88.15:51199] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.067890 2021] [php7:error] [pid 568] [client 192.168.88.15:51200] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.082919 2021] [php7:error] [pid 567] [client 192.168.88.15:51202] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.082906 2021] [php7:error] [pid 569] [client 192.168.88.15:51201] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.117621 2021] [php7:error] [pid 570] [client 192.168.88.15:51203] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.143848 2021] [php7:error] [pid 571] [client 192.168.88.15:51204] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.166484 2021] [php7:error] [pid 568] [client 192.168.88.15:51205] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.182601 2021] [php7:error] [pid 567] [client 192.168.88.15:51206] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.200401 2021] [php7:error] [pid 569] [client 192.168.88.15:51207] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.219326 2021] [php7:error] [pid 570] [client 192.168.88.15:51208] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.245999 2021] [php7:error] [pid 571] [client 192.168.88.15:51209] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.267241 2021] [php7:error] [pid 568] [client 192.168.88.15:51210] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:46:49.287223 2021] [php7:error] [pid 567] [client 192.168.88.15:51211] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 11:54:12.039076 2021] [php7:error] [pid 683] [client 192.168.88.15:51283] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 2097160 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
[Sun Jan 31 11:55:37.532394 2021] [mpm_prefork:notice] [pid 460] AH00163: Apache/2.4.38 (Debian) OpenSSL/1.1.1d configured -- resuming normal operations
[Sun Jan 31 11:55:37.533437 2021] [core:notice] [pid 460] AH00094: Command line: '/usr/sbin/apache2'
[Sun Jan 31 11:55:48.144448 2021] [php7:warn] [pid 552] [client 192.168.88.15:51390] PHP Warning: A non-numeric value encountered in /var/www/html/plugins/heliotrope/core/class/heliotrope.class.php on line 518, referer: http://192.168.88.81/index.php?v=d&p=dashboard
[Sun Jan 31 11:55:48.144638 2021] [php7:warn] [pid 552] [client 192.168.88.15:51390] PHP Warning: A non-numeric value encountered in /var/www/html/plugins/heliotrope/core/class/heliotrope.class.php on line 518, referer: http://192.168.88.81/index.php?v=d&p=dashboard
[Sun Jan 31 11:55:48.708072 2021] [php7:notice] [pid 552] [client 192.168.88.15:51390] PHP Notice: Undefined offset: 1 in /var/www/html/core/class/cmd.class.php on line 1310, referer: http://192.168.88.81/index.php?v=d&p=dashboard
[Sun Jan 31 12:02:50.619296 2021] [php7:error] [pid 551] [client 192.168.88.15:51470] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 524288 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
[Sun Jan 31 12:03:34.641853 2021] [php7:error] [pid 689] [client 192.168.88.15:51489] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 524288 bytes) in /var/www/html/core/class/DB.class.php on line 95, referer: http://192.168.88.81/index.php?v=d&p=timeline
kill: (1573): No such process
[Sun Jan 31 12:04:44.857824 2021] [mpm_prefork:notice] [pid 476] AH00163: Apache/2.4.38 (Debian) OpenSSL/1.1.1d configured -- resuming normal operations
[Sun Jan 31 12:04:44.859452 2021] [core:notice] [pid 476] AH00094: Command line: '/usr/sbin/apache2'
[Sun Jan 31 12:04:45.231778 2021] [php7:error] [pid 554] [client 192.168.88.15:51561] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/core/class/DB.class.php:40
Stack trace:
#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', '8007f680c36b1d8', Array)
#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
#3 /var/www/html/core/class/config.class.php(187): DB::Prepare('SELECT `key`,`v...', Array, 1)
#4 /var/www/html/core/class/translate.class.php(34): config::byKeys(Array)
#5 /var/www/html/core/class/translate.class.php(151): translate::getConfig('language', 'fr_FR')
#6 /var/www/html/core/class/translate.class.php(75): translate::getLanguage()
#7 /var/www/html/core/class/translate.class.php(54): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
#8 /var/www/html/core/class/translate.class.php(165): translate::sentence('Chauffage', '/var/www/html/c...', false)
#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage' in /var/www/html/core/class/DB.class.php on line 40, referer: http://192.168.88.81/index.php?v=d&p=reboot
[Sun Jan 31 12:04:45.233198 2021] [php7:error] [pid 553] [client 192.168.88.15:51560] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.235417 2021] [php7:error] [pid 552] [client 192.168.88.15:51558] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/log.ajax.php:58
Stack trace:
#0 {main}
thrown in /var/www/html/core/ajax/log.ajax.php on line 58, referer: http://192.168.88.81/index.php?v=d&p=log
[Sun Jan 31 12:04:45.240153 2021] [php7:error] [pid 554] [client 192.168.88.15:51563] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Sun Jan 31 12:04:45.245410 2021] [php7:error] [pid 551] [client 192.168.88.15:51562] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.250853 2021] [php7:error] [pid 550] [client 192.168.88.15:51559] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
thrown in /var/www/html/core/ajax/event.ajax.php on line 36, referer: http://192.168.88.81/index.php?v=d&m=doorbird&p=doorbird&id=doorbird
[Sun Jan 31 12:04:45.273052 2021] [php7:error] [pid 553] [client 192.168.88.15:51564] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.298536 2021] [php7:error] [pid 552] [client 192.168.88.15:51565] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.314597 2021] [php7:error] [pid 554] [client 192.168.88.15:51566] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.330041 2021] [php7:error] [pid 551] [client 192.168.88.15:51567] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.360999 2021] [php7:error] [pid 550] [client 192.168.88.15:51568] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.376274 2021] [php7:error] [pid 553] [client 192.168.88.15:51569] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.392014 2021] [php7:error] [pid 552] [client 192.168.88.15:51570] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.410188 2021] [php7:error] [pid 554] [client 192.168.88.15:51571] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.424833 2021] [php7:error] [pid 551] [client 192.168.88.15:51572] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.441542 2021] [php7:error] [pid 550] [client 192.168.88.15:51573] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.458502 2021] [php7:error] [pid 553] [client 192.168.88.15:51574] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.475486 2021] [php7:error] [pid 552] [client 192.168.88.15:51575] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.492300 2021] [php7:error] [pid 554] [client 192.168.88.15:51576] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.508639 2021] [php7:error] [pid 551] [client 192.168.88.15:51577] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.527046 2021] [php7:error] [pid 550] [client 192.168.88.15:51578] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.541941 2021] [php7:error] [pid 553] [client 192.168.88.15:51579] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.563306 2021] [php7:error] [pid 552] [client 192.168.88.15:51580] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.568706 2021] [php7:error] [pid 554] [client 192.168.88.15:51557] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Sun Jan 31 12:04:45.588962 2021] [php7:error] [pid 551] [client 192.168.88.15:51556] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.608066 2021] [php7:error] [pid 550] [client 192.168.88.15:51581] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.623652 2021] [php7:error] [pid 553] [client 192.168.88.15:51582] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.639685 2021] [php7:error] [pid 552] [client 192.168.88.15:51583] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.658915 2021] [php7:error] [pid 554] [client 192.168.88.15:51584] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.685119 2021] [php7:error] [pid 551] [client 192.168.88.15:51585] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.702114 2021] [php7:error] [pid 550] [client 192.168.88.15:51586] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.735851 2021] [php7:error] [pid 553] [client 192.168.88.15:51587] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.763727 2021] [php7:error] [pid 552] [client 192.168.88.15:51588] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.779530 2021] [php7:error] [pid 554] [client 192.168.88.15:51589] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:45.810922 2021] [php7:error] [pid 551] [client 192.168.88.15:51590] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Sun Jan 31 12:04:55.443357 2021] [php7:warn] [pid 551] [client 192.168.88.15:51597] PHP Warning: A non-numeric value encountered in /var/www/html/plugins/heliotrope/core/class/heliotrope.class.php on line 518, referer: http://192.168.88.81/index.php?v=d&p=dashboard
[Sun Jan 31 12:04:55.443534 2021] [php7:warn] [pid 551] [client 192.168.88.15:51597] PHP Warning: A non-numeric value encountered in /var/www/html/plugins/heliotrope/core/class/heliotrope.class.php on line 518, referer: http://192.168.88.81/index.php?v=d&p=dashboard
[Sun Jan 31 12:04:56.005503 2021] [php7:notice] [pid 551] [client 192.168.88.15:51597] PHP Notice: Undefined offset: 1 in /var/www/html/core/class/cmd.class.php on line 1310, referer: http://192.168.88.81/index.php?v=d&p=dashboard
[Sun Jan 31 13:02:04.651040 2021] [php7:notice] [pid 703] [client 192.168.88.15:52240] PHP Notice: Undefined offset: 1 in /var/www/html/core/class/cmd.class.php on line 1310, referer: http://192.168.88.81/index.php?v=d&p=dashboard
[Sun Jan 31 13:03:14.958183 2021] [mpm_prefork:notice] [pid 522] AH00163: Apache/2.4.38 (Debian) OpenSSL/1.1.1d configured -- resuming normal operations
[Sun Jan 31 13:03:14.960325 2021] [core:notice] [pid 522] AH00094: Command line: '/usr/sbin/apache2'
[Sun Jan 31 13:03:15.254404 2021] [php7:error] [pid 571] [client 192.168.88.15:52300] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
thrown in /var/www/html/core/ajax/event.ajax.php on line 36, referer: http://192.168.88.81/index.php?v=d&p=administration
[Sun Jan 31 13:03:15.254581 2021] [php7:error] [pid 573] [client 192.168.88.15:52299] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/log.ajax.php:58
Stack trace:
#0 {main}
[Sun Jan 31 13:03:15.254601 2021] [php7:error] [pid 572] [client 192.168.88.15:52301] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/core/class/DB.class.php:40
Stack trace:
#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage' in /var/www/html/core/class/DB.class.php on line 40, referer: http://192.168.88.81/index.php?v=d&p=log
[Sun Jan 31 13:03:15.982237 2021] [php7:error] [pid 574] [client 192.168.88.15:52302] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
En tout cas, merci pour ton aide :D
