Récupération json impossible
J’utilise MQTT manager pour récupérer/controler un dimmer distant.
Cet appareil publi des infos sous un topic homeassistant que je n’arrive pas à lire.
Pourtant mosquitto (via MQTT2) reçoit bien les trames:
[2023-10-23 16:14:26][DEBUG] : Received message on topic : homeassistant/sensor/dimmer-2052/power/state =>   { "power" : "32"  }
[2023-10-23 16:14:26][DEBUG] : Send data to jeedom : {"dimmer":{"201":32},"homeassistant":{"sensor":{"dimmer-2052":{"power":{"state":{"power":"32"}}}}},"zigbee2mqtt":{"bridge":{"logging":{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x0004740000c92765', payload '{\"device\":{\"applicationVersion\":0,\"dateCode\":\" \u000020211213\u0000\u0000\u0000\u0000\u0000\",\"friendlyName\":\"0x0004740000c92765\",\"hardwareVersion\":4,\"ieeeAddr\":\"0x0004740000c92765\",\"manufacturerID\":4129,\"manufacturerName\":\" Legrand\",\"model\":\"412015\",\"networkAddress\":20814,\"powerSource\":\"Mains (single phase)\",\"softwareBuildID\":\"004a\",\"stackVersion\":67,\"type\":\"Router\",\"zclVersion\":2},\"last_seen\":\"2023-10-23T16:14:26.805Z\",\"linkquality\":255,\"power\":17,\"power_alarm_active\":false,\"power_alarm_active_value\":0,\"power_alarm_enabled\":0,\"power_alarm_wh_threshold\":0,\"power_apparent\":109,\"update\":{\"installed_version\":4867071,\"latest_version\":5128707,\"state\":\"available\"},\"update_available\":true}'"}},"0x000474000083c763":{"auto_mode":"off","device":{"applicationVersion":0,"dateCode":" \u000020201128\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000083c763","hardwareVersion":2,"ieeeAddr":"0x000474000083c763","manufacturerID":4129,"manufacturerName":" Legrand","model":"412171","networkAddress":55556,"powerSource":"Mains (single phase)","softwareBuildID":"004a","stackVersion":67,"type":"Router","zclVersion":2},"device_mode":"switch","last_seen":"2023-10-23T16:14:26.744Z","linkquality":220,"power":171,"power_apparent":430,"state":"ON","update":{"installed_version":4867071,"latest_version":5325315,"state":"available"},"update_available":true},"0x0004740000c92765":{"device":{"applicationVersion":0,"dateCode":" \u000020211213\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x0004740000c92765","hardwareVersion":4,"ieeeAddr":"0x0004740000c92765","manufacturerID":4129,"manufacturerName":" Legrand","model":"412015","networkAddress":20814,"powerSource":"Mains (single phase)","softwareBuildID":"004a","stackVersion":67,"type":"Router","zclVersion":2},"last_seen":"2023-10-23T16:14:26.805Z","linkquality":255,"power":17,"power_alarm_active":false,"power_alarm_active_value":0,"power_alarm_enabled":0,"power_alarm_wh_threshold":0,"power_apparent":109,"update":{"installed_version":4867071,"latest_version":5128707,"state":"available"},"update_available":true}}}
J’ai créé un equipement dans MQTT manager abonné au topic homeassistant:
et ensuite un equipement info:
Mais rien ne remonte.
Il y a qqchose de mal configuré?
Peux tu essayer avec topic homeassistant/#
Je ne vois pas l’intérêt pour vous d’aller lire ce topic.
Il n’y a aucune donnée ni aucun contrôle possible sur ce topic.
pas mieux sur ce topic, rien ne remonte
sur ce topic, il y a plein d’info d’état, et en théorie du control possible (d’apres le developpeur).
sur le topic homeassistant il n’y a pas de « données » mais juste des « meta-données » => des infos sur la config qui décrit où on peut trouver les données
sans vouloir faire de pub, je crois que le plugin-mqttdiscovery pourrait vous aider voir ce sujet et documentation
