J’ai remis ma carte sd débrancé le reste, avec Putty j’ai rentré mon login et mot de passe et j’ai fais un dmesg :
pi@raspberrypi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 6.1.28-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #16 49 SMP PREEMPT Fri May 12 14:25:37 BST 2023
[ 0.000000] random: crng init done
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, s ize 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id share d-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0, zone DMA: 19456 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
[ 0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 996608
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835 .enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 v ideo=HDMI-A-1:1920x1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_ bottom=48 smsc95xx.macaddr=E4:5F:01:5C:DB:4A vc_mem.mem_base=0x3ec00000 vc_mem.m em_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=ca5a60f9-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes , linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 3423248K/4050944K available (11776K kernel code, 2106K rw data, 3688K rodata, 4160K init, 1077K bss, 103408K reserved, 524288K cma-reserve d)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 39763 entries in 156 pages
[ 0.000000] ftrace: allocated 156 pages with 4 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif fies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 43980 46511102ns
[ 0.000344] Console: colour dummy device 80x25
[ 0.000951] printk: console [tty1] enabled
[ 0.001015] Calibrating delay loop (skipped), value calculated using timer fr equency.. 108.00 BogoMIPS (lpj=216000)
[ 0.001060] pid_max: default: 32768 minimum: 301
[ 0.001212] LSM: Security Framework initializing
[ 0.001455] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, line ar)
[ 0.001547] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002938] cgroup: Disabling memory control group subsystem
[ 0.005359] cblist_init_generic: Setting adjustable number of callback queues .
[ 0.005397] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005600] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005794] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.006260] rcu: Hierarchical SRCU implementation.
[ 0.006284] rcu: Max phase no-delay instances is 1000.
[ 0.007643] EFI services will not be available.
[ 0.008294] smp: Bringing up secondary CPUs ...
[ 0.009450] Detected PIPT I-cache on CPU1
[ 0.009627] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.010846] Detected PIPT I-cache on CPU2
[ 0.010970] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.012196] Detected PIPT I-cache on CPU3
[ 0.012328] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.012477] smp: Brought up 1 node, 4 CPUs
[ 0.012569] SMP: Total of 4 processors activated.
[ 0.012592] CPU features: detected: 32-bit EL0 Support
[ 0.012611] CPU features: detected: 32-bit EL1 Support
[ 0.012635] CPU features: detected: CRC32 instructions
[ 0.012786] CPU: All CPU(s) started at EL2
[ 0.012824] alternatives: applying system-wide alternatives
[ 0.014915] devtmpfs: initialized
[ 0.027423] Enabled cp15_barrier support
[ 0.027498] Enabled setend support
[ 0.027732] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns
[ 0.027784] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.043096] pinctrl core: initialized pinctrl subsystem
[ 0.044175] DMI not present or invalid.
[ 0.044925] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.048803] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.049159] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic all ocations
[ 0.050175] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic a llocations
[ 0.050295] audit: initializing netlink subsys (disabled)
[ 0.050585] audit: type=2000 audit(0.048:1): state=initialized audit_enabled= 0 res=1
[ 0.051230] thermal_sys: Registered thermal governor 'step_wise'
[ 0.051323] cpuidle: using governor menu
[ 0.051751] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.051969] ASID allocator initialised with 32768 entries
[ 0.052189] Serial: AMBA PL011 UART driver
[ 0.064593] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.080307] raspberrypi-firmware soc:firmware: Attached to firmware from 2023 -04-25T18:26:03, variant start
[ 0.084319] raspberrypi-firmware soc:firmware: Firmware hash is d7f9c2b4ef7e4 a8c0b04374a879ce89d7a948453
[ 0.100449] KASLR enabled
[ 0.131457] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.137514] SCSI subsystem initialized
[ 0.137798] usbcore: registered new interface driver usbfs
[ 0.137872] usbcore: registered new interface driver hub
[ 0.137956] usbcore: registered new device driver usb
[ 0.138324] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.138582] usb_phy_generic phy: dummy supplies not allowed for exclusive req uests
[ 0.138976] pps_core: LinuxPPS API ver. 1 registered
[ 0.139000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.139042] PTP clock support registered
[ 0.140212] vgaarb: loaded
[ 0.141058] clocksource: Switched to clocksource arch_sys_counter
[ 0.141807] VFS: Disk quotas dquot_6.6.0
[ 0.141910] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.142287] FS-Cache: Loaded
[ 0.142504] CacheFiles: Loaded
[ 0.153841] NET: Registered PF_INET protocol family
[ 0.154806] IP idents hash table entries: 65536 (order: 7, 524288 bytes, line ar)
[ 0.159917] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 3276 8 bytes, linear)
[ 0.160008] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.160051] TCP established hash table entries: 32768 (order: 6, 262144 bytes , linear)
[ 0.160346] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, line ar)
[ 0.161613] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.161963] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.162082] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.162484] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.163464] RPC: Registered named UNIX socket transport module.
[ 0.163496] RPC: Registered udp transport module.
[ 0.163517] RPC: Registered tcp transport module.
[ 0.163537] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.163574] PCI: CLS 0 bytes, default 64
[ 0.166576] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counte rs available
[ 0.167037] kvm [1]: IPA Size Limit: 44 bits
[ 0.168428] kvm [1]: vgic interrupt IRQ9
[ 0.168682] kvm [1]: Hyp mode initialized successfully
[ 1.296592] Initialise system trusted keyrings
[ 1.297212] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.305239] zbud: loaded
[ 1.308247] NFS: Registering the id_resolver key type
[ 1.308314] Key type id_resolver registered
[ 1.308336] Key type id_legacy registered
[ 1.308479] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.308510] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering ...
[ 1.310079] Key type asymmetric registered
[ 1.310116] Asymmetric key parser 'x509' registered
[ 1.310211] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 47)
[ 1.310532] io scheduler mq-deadline registered
[ 1.310561] io scheduler kyber registered
[ 1.321428] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.321507] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500 000, using [bus 00-ff]
[ 1.321617] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0 x00c0000000
[ 1.321721] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00ffffffff -> 0 x0400000000
[ 1.322792] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.322826] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.322854] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.322947] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.323225] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.327244] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), rec onfiguring
[ 1.327540] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.327755] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regula tor
[ 1.327895] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.395156] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.395339] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.395480] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.395982] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.396780] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.396840] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.396876] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64 bit]
[ 1.396934] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.396965] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.398274] simple-framebuffer 3e513000.framebuffer: framebuffer at 0x3e51300 0, 0x6e7000 bytes
[ 1.398313] simple-framebuffer 3e513000.framebuffer: format=a8r8g8b8, mode=18 24x984x32, linelength=7296
[ 1.406529] Console: switching to colour frame buffer device 228x61
[ 1.413700] simple-framebuffer 3e513000.framebuffer: fb0: simplefb registered !
[ 1.426312] iproc-rng200 fe104000.rng: hwrng registered
[ 1.426881] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000 000(1024 MiB)
[ 1.428589] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe2 00000
[ 1.442239] brd: module loaded
[ 1.451432] loop: module loaded
[ 1.452314] Loading iSCSI transport class v2.0-870.
[ 1.458083] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.517230] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.518559] usbcore: registered new interface driver r8152
[ 1.518693] usbcore: registered new interface driver lan78xx
[ 1.518825] usbcore: registered new interface driver smsc95xx
[ 1.567831] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.568075] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.568157] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe r 1
[ 1.569011] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 qu irks 0x0000e40000000890
[ 1.570180] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.570253] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe r 2
[ 1.570339] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.570793] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 6.01
[ 1.570884] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.570961] usb usb1: Product: xHCI Host Controller
[ 1.571017] usb usb1: Manufacturer: Linux 6.1.28-v8+ xhci-hcd
[ 1.571079] usb usb1: SerialNumber: 0000:01:00.0
[ 1.571905] hub 1-0:1.0: USB hub found
[ 1.572019] hub 1-0:1.0: 1 port detected
[ 1.573025] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc dDevice= 6.01
[ 1.573153] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.573225] usb usb2: Product: xHCI Host Controller
[ 1.573278] usb usb2: Manufacturer: Linux 6.1.28-v8+ xhci-hcd
[ 1.573338] usb usb2: SerialNumber: 0000:01:00.0
[ 1.576085] hub 2-0:1.0: USB hub found
[ 1.578282] hub 2-0:1.0: 4 ports detected
[ 1.582160] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.584553] dwc_otg: FIQ enabled
[ 1.584565] dwc_otg: NAK holdoff enabled
[ 1.584575] dwc_otg: FIQ split-transaction FSM enabled
[ 1.584603] Module dwc_common_port init
[ 1.585292] usbcore: registered new interface driver uas
[ 1.587503] usbcore: registered new interface driver usb-storage
[ 1.589741] mousedev: PS/2 mouse device common for all mice
[ 1.598150] sdhci: Secure Digital Host Controller Interface driver
[ 1.600241] sdhci: Copyright(c) Pierre Ossman
[ 1.602977] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.608542] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.610978] hid: raw HID events driver (C) Jiri Kosina
[ 1.613252] usbcore: registered new interface driver usbhid
[ 1.615281] usbhid: USB HID core driver
[ 1.627477] NET: Registered PF_PACKET protocol family
[ 1.629813] Key type dns_resolver registered
[ 1.633389] registered taskstats version 1
[ 1.635544] Loading compiled-in X.509 certificates
[ 1.638524] Key type .fscrypt registered
[ 1.640405] Key type fscrypt-provisioning registered
[ 1.658614] uart-pl011 fe201000.serial: there is not valid maps for state def ault
[ 1.661643] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.663812] fe201000.serial: ttyAMA1 at MMIO 0xfe201000 (irq = 35, base_baud = 0) is a PL011 rev2
