Nouveau test en activant le mode Debug puis Lancement du LAN
Voici les logs ewejee et ewejee_lan (j’ai filtré la partie utile car nb de caractères limités)
A la fin du log ewejee_lan, on voit les 4 commandes que j’ai lancées depuis jeedom. Dans l’ordre :
- Commande envoyée : Ch1 ON > Réaction 4CH PRO = Ch1 ON
- Commande envoyée : Ch2 ON > Réaction 4CH PRO = Ch1 ON + Ch2 ON
- Commande envoyée : Ch3 ON > Réaction 4CH PRO = Ch1 ON + Ch2 ON + Ch3 ON
- Commande envoyée : Ch1 ON > Réaction 4CH PRO = Ch1 ON + Ch2 ON + Ch3 ON
Log ewejee_lan :
[2020-11-01 08:39:25][DEBUG] : - ON en on
[2020-11-01 08:39:25][DEBUG] : ---------- Switch device 1000b1a5f1 channel : 101 Action : on
[2020-11-01 08:39:25][DEBUG] : Démarrage switch ...
[2020-11-01 08:39:25][DEBUG] : -- Channel 101 Modifié par : 1
[2020-11-01 08:39:25][DEBUG] : ** Envoi de la commande au serveur : Device : 1000b1a5f1 Channel : 1 Action : on
[2020-11-01 08:39:25][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"on","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:25][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:25][DEBUG] : Commande pour 1000b1a5f1 correctement Envoyé
[2020-11-01 08:39:26][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"on","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:26][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:28][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:28][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:29][DEBUG] : - ON en on
[2020-11-01 08:39:29][DEBUG] : ---------- Switch device 1000b1a5f1 channel : 102 Action : on
[2020-11-01 08:39:29][DEBUG] : Démarrage switch ...
[2020-11-01 08:39:29][DEBUG] : -- Channel 102 Modifié par : 2
[2020-11-01 08:39:29][DEBUG] : ** Envoi de la commande au serveur : Device : 1000b1a5f1 Channel : 2 Action : on
[2020-11-01 08:39:29][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:29][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:29][DEBUG] : Commande pour 1000b1a5f1 correctement Envoyé
[2020-11-01 08:39:29][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"on","outlet":0},{"switch":"on","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:30][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"on","outlet":0},{"switch":"on","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:30][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:32][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:32][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:33][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:33][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:33][DEBUG] : - ON en on
[2020-11-01 08:39:33][DEBUG] : ---------- Switch device 1000b1a5f1 channel : 103 Action : on
[2020-11-01 08:39:33][DEBUG] : Démarrage switch ...
[2020-11-01 08:39:33][DEBUG] : -- Channel 103 Modifié par : 3
[2020-11-01 08:39:33][DEBUG] : ** Envoi de la commande au serveur : Device : 1000b1a5f1 Channel : 3 Action : on
[2020-11-01 08:39:34][DEBUG] : Commande pour 1000b1a5f1 correctement Envoyé
[2020-11-01 08:39:34][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:34][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"on","outlet":0},{"switch":"on","outlet":1},{"switch":"on","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:35][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"on","outlet":0},{"switch":"on","outlet":1},{"switch":"on","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:35][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:37][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:37][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:38][DEBUG] : - ON en on
[2020-11-01 08:39:38][DEBUG] : ---------- Switch device 1000b1a5f1 channel : 101 Action : on
[2020-11-01 08:39:38][DEBUG] : Démarrage switch ...
[2020-11-01 08:39:38][DEBUG] : -- Channel 101 Modifié par : 1
[2020-11-01 08:39:38][DEBUG] : ** Envoi de la commande au serveur : Device : 1000b1a5f1 Channel : 1 Action : on
[2020-11-01 08:39:38][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:38][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:38][DEBUG] : Commande pour 1000b1a5f1 correctement Envoyé
[2020-11-01 08:39:38][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"on","outlet":0},{"switch":"on","outlet":1},{"switch":"on","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:39][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"on","outlet":0},{"switch":"on","outlet":1},{"switch":"on","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:39][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:41][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:41][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:42][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:42][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
[2020-11-01 08:39:43][DEBUG] : [MDNS][Update] {"params":{"configure":[{"startup":"off","outlet":0},{"startup":"off","outlet":1},{"startup":"off","outlet":2},{"startup":"off","outlet":3}],"pulses":[{"pulse":"off","width":1000,"outlet":0},{"pulse":"off","width":1000,"outlet":1},{"pulse":"off","width":1000,"outlet":2},{"pulse":"off","width":1000,"outlet":3}],"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1},{"switch":"off","outlet":2},{"switch":"off","outlet":3}]}}
[2020-11-01 08:39:43][DEBUG] : [attribute_update]Device ID = 1000b1a5f1 Nom = SW Volets Deprat 3
Log ewejee_lan
Serveur LAN correctement lancé sur http://localhost:6006 Le Sun Nov 01 2020 08:37:45 GMT+0100 (Central European Standard Time)
{ status: 'ok', state: 'on' }
{"action":"update","userAgent":"lan","deviceid":"1000b1a5f1","params":{"switches":[{"switch":"on","outlet":0}]}}
{"action":"update","userAgent":"lan","deviceid":"1000b1a5f1","params":{"switches":[{"switch":"on","outlet":1}]}}
{"action":"update","userAgent":"lan","deviceid":"1000b1a5f1","params":{"switches":[{"switch":"on","outlet":2}]}}
