Problème sur le Demon
Bonsoir à tous,
Je ne sais pas pourquoi mais j’ai beaucoup d’erreur sur les log mymodbus_demon:
J’ai l’impression peut-être à tor que c’est depuis la dernière MAJ mais pas sûr :disappointed:
0x5 0x0 0x0 0x0 0x6 0x1 0x3 0x0 0x1a 0x0 0x1
0582|>>>>> recv: 0x0 0x5 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x0 0x9d extra data:
0583|>>>>> send: 0x0 0x6 0x0 0x0 0x0 0x6 0x1 0x1 0x0 0xe 0x0 0x1
0584|>>>>> recv: 0x0 0x6 0x0 0x0 0x0 0x4 0x1 0x1 0x1 0x1 extra data:
0585|>>>>> send: 0xbd 0x19 0x0 0x0 0x0 0x6 0xf0 0x3 0x9c 0x84 0x0 0x1
0586|>>>>> recv: 0xbd 0x19 0x0 0x0 0x0 0x5 0xf0 0x3 0x2 0x0 0xf0 extra data:
0587|>>>>> send: 0xbd 0x1a 0x0 0x0 0x0 0x6 0xf0 0x3 0x9c 0x74 0x0 0x2
0588|[2025-09-19 18:16:46] ERROR  : Esera ECO502 Modbus RTU/Temp_Souff_Pallier_OWD6: exception during read request on device id 1, address 1405 -> Modbus Error: [Input/Output] No response received after 3.0 retries, continue with next request
0589|[2025-09-19 18:16:46] ERROR  : chauffage insert PIAZZETTA/Heure marche chauffage: exception during read request on device id 1, address 1000 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0590|[2025-09-19 18:16:46] ERROR  : ESERA TCP ip/OWD02 Temp ext garage: exception during read request on device id 1, address 200 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0591|[2025-09-19 18:16:47] ERROR  : Esera ECO502 Modbus RTU/CAVE_ECS_BASSE_OWD7: exception during read request on device id 1, address 1406 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0592|[2025-09-19 18:16:47] ERROR  : chauffage insert PIAZZETTA/Retour marche chauffage: exception during read request on device id 1, address 18 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0593|[2025-09-19 18:16:47] ERROR  : ESERA TCP ip/OWD04 Temp salon: exception during read request on device id 1, address 400 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0594|[2025-09-19 18:16:48] ERROR  : chauffage insert PIAZZETTA/Nombre de démarrage: exception during read request on device id 1, address 1001 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0595|[2025-09-19 18:16:48] ERROR  : ESERA TCP ip/OWD05 Temp Bureau Ch SO: exception during read request on device id 1, address 500 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0596|[2025-09-19 18:16:49] ERROR  : ESERA TCP ip/OWD06 Temp Salle à manger: exception during read request on device id 1, address 600 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0597|[2025-09-19 18:16:50] ERROR  : ESERA TCP ip/OWD7 Temp int garage: exception during read request on device id 1, address 700 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0598|[2025-09-19 18:16:52] ERROR  : ESERA TCP ip/OWD7 Tension bus 1 wire: exception during read request on device id 1, address 702 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0599|[2025-09-19 18:16:53] ERROR  : ESERA TCP ip/OWD10 Temp souf cuisine: exception during read request on device id 1, address 1000 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0600|[2025-09-19 18:16:54] ERROR  : ESERA TCP ip/OWD8.0 Temp cave: exception during read request on device id 1, address 800 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0601|[2025-09-19 18:16:55] ERROR  : ESERA TCP ip/OWD8.2 Vcc Bus cave: exception during read request on device id 1, address 802 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0602|[2025-09-19 18:16:56] ERROR  : Gestion fuite d’eau maison/Détection fuite eau la nuit: exception during read request on device id 1, address 49 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0603|[2025-09-19 18:16:56] ERROR  : ESERA TCP ip/OWD8.4 Humidité cave: exception during read request on device id 1, address 804 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0604|[2025-09-19 18:16:57] ERROR  : Gestion fuite d’eau maison/Fuite eau sous cumulus: exception during read request on device id 1, address 4 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0605|[2025-09-19 18:16:57] ERROR  : Gestion fuite d’eau maison/Détection fuite eau la nuit: exception during read request on device id 1, address 49 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0606|[2025-09-19 18:16:57] ERROR  : ESERA TCP ip/OWD8.6 Luminiosité cave: exception during read request on device id 1, address 806 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.60:502]
0607|[2025-09-19 18:16:58] ERROR  : Gestion fuite d’eau maison/Volume fuite: exception during read request on device id 1, address 25 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0608|[2025-09-19 18:16:58] ERROR  : Gestion fuite d’eau maison/Fuite eau sous cumulus: exception during read request on device id 1, address 4 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0609|[2025-09-19 18:16:59] ERROR  : Gestion fuite d’eau maison/Volume fuite: exception during read request on device id 1, address 25 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0610|[2025-09-19 18:17:03] ERROR  : EV eau ECL terrasse M221/Pré réglage tempo spot: 'command_write' modbus exception during write request on device id 1, address 125 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0611|[2025-09-19 18:17:03] ERROR  : Solcast vers M221/Prévision Prod J+1: 'command_write' modbus exception during write request on device id 1, address 53 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0612|[2025-09-19 18:17:07] ERROR  : chauffage insert PIAZZETTA/Heure marche chauffage: exception during read request on device id 1, address 1000 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
0613|[2025-09-19 18:17:08] ERROR  : chauffage insert PIAZZETTA/Retour marche chauffage: exception during read request on device id 1, address 18 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.50:502]
Je suis désolé je ne suis plus comment coller les log plus proprement.
Merci à vous
Du plugin? De Jeedom? De Debian?
As-tu vérifié que tes 2 équipements sont toujours joignables sur le réseau 192.168.1.50 et 192.168.1.60 ?
Désolé dernière mise à voir du plugin Mymodbus
Bonsoir Tonio16
désolé
MERCI POUR LE TUTO SUR COMMENT COPIER LES LOG
Bonsoir Bison,
OUI ces deux adresses répondent très bien.
Petite précision. J’ai constaté une lenteur du plugin lorsque j’ai voulu hier commander mes volets roulant depuis ma tablette.
Je pilote mes volets depuis un automate en modbus TCP.
J’ai vérifié mes log et j’ai vu ces erreurs dans les lod demon mymodbus.
Bonne soirée
Finalement j’ai arrêté le démon et relancé les dépendances et tout est rentré dans l’ordre.
Désolé de vous avoir dérangé.
Belle journée ensoleillée à tous.
Non finalement j’ai toujours des erreurs dans le démon. Beaucoup moins toutefois.
0000|[2025-09-20 08:52:08] ERROR  : Cancel send, because not connected!
0001|>>>>> extra:  unexpected data: 0x0
0002|>>>>> recv: 0xf1 extra data: 0x0
0003|>>>>> extra:  unexpected data: 0x0 0xf1
0004|>>>>> recv: 0x0 extra data: 0x0 0xf1
0005|>>>>> extra:  unexpected data: 0x0 0xf1 0x0
0006|>>>>> recv: 0x0 extra data: 0x0 0xf1 0x0
0007|>>>>> extra:  unexpected data: 0x0 0xf1 0x0 0x0
0008|>>>>> recv: 0x0 extra data: 0x0 0xf1 0x0 0x0
0009|>>>>> extra:  unexpected data: 0x0 0xf1 0x0 0x0 0x0
0010|>>>>> recv: 0x5 extra data: 0x0 0xf1 0x0 0x0 0x0
0011|>>>>> extra:  unexpected data: 0x0 0xf1 0x0 0x0 0x0 0x5
0012|>>>>> recv: 0x1 extra data: 0x0 0xf1 0x0 0x0 0x0 0x5
0013|>>>>> extra:  unexpected data: 0x0 0xf1 0x0 0x0 0x0 0x5 0x1
0014|>>>>> recv: 0x3 extra data: 0x0 0xf1 0x0 0x0 0x0 0x5 0x1
0015|>>>>> extra:  unexpected data: 0x0 0xf1 0x0 0x0 0x0 0x5 0x1 0x3
0016|>>>>> recv: 0x2 extra data: 0x0 0xf1 0x0 0x0 0x0 0x5 0x1 0x3
0017|>>>>> extra:  unexpected data: 0x0 0xf1 0x0 0x0 0x0 0x5 0x1 0x3 0x2
0018|>>>>> recv: 0x0 extra data: 0x0 0xf1 0x0 0x0 0x0 0x5 0x1 0x3 0x2
0019|>>>>> extra:  unexpected data: 0x0 0xf1 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x0
0020|>>>>> recv: 0x1e extra data: 0x0 0xf1 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x0
0021|[2025-09-20 08:52:37] ERROR  : Cancel send, because not connected!
0022|>>>>> extra:  unexpected data: 0x0 0xfe 0x0
0023|>>>>> recv: 0x0 extra data: 0x0 0xfe 0x0
0024|>>>>> extra:  unexpected data: 0x0 0xfe 0x0 0x0
0025|>>>>> recv: 0x0 extra data: 0x0 0xfe 0x0 0x0
0026|>>>>> extra:  unexpected data: 0x0 0xfe 0x0 0x0 0x0
0027|>>>>> recv: 0x5 extra data: 0x0 0xfe 0x0 0x0 0x0
0028|>>>>> extra:  unexpected data: 0x0 0xfe 0x0 0x0 0x0 0x5
0029|>>>>> recv: 0x1 extra data: 0x0 0xfe 0x0 0x0 0x0 0x5
0030|>>>>> extra:  unexpected data: 0x0 0xfe 0x0 0x0 0x0 0x5 0x1
0031|>>>>> recv: 0x3 extra data: 0x0 0xfe 0x0 0x0 0x0 0x5 0x1
0032|>>>>> extra:  unexpected data: 0x0 0xfe 0x0 0x0 0x0 0x5 0x1 0x3
0033|>>>>> recv: 0x2 extra data: 0x0 0xfe 0x0 0x0 0x0 0x5 0x1 0x3
0034|>>>>> extra:  unexpected data: 0x0 0xfe 0x0 0x0 0x0 0x5 0x1 0x3 0x2
0035|>>>>> recv: 0x7 extra data: 0x0 0xfe 0x0 0x0 0x0 0x5 0x1 0x3 0x2
0036|>>>>> extra:  unexpected data: 0x0 0xfe 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x7
0037|>>>>> recv: 0xd0 extra data: 0x0 0xfe 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x7
0038|>>>>> recv: 0x1 0x26 0x0 0x0 0x0 0x7 0xf0 0x3 0x4 0x3f 0xd4 0x39 0x58 extra data:
0039|>>>>> send: 0x1 0x27 0x0 0x0 0x0 0x6 0xf0 0x3 0x9c 0xc1 0x0 0x2
0040|>>>>> recv: 0x1 0x27 0x0 0x0 0x0 0x7 0xf0 0x3 0x4 0x4b 0x24 0x46 0x48 extra data:
0041|>>>>> send: 0x1 0x28 0x0 0x0 0x0 0x6 0xf0 0x3 0x9c 0x9f 0x0 0x2
0042|[2025-09-20 08:53:08] ERROR  : Cancel send, because not connected!
0043|>>>>> extra:  unexpected data: 0x1
0044|>>>>> recv: 0xd extra data: 0x1
0045|>>>>> extra:  unexpected data: 0x1 0xd
0046|>>>>> recv: 0x0 extra data: 0x1 0xd
0047|>>>>> extra:  unexpected data: 0x1 0xd 0x0
0048|>>>>> recv: 0x0 extra data: 0x1 0xd 0x0
0049|>>>>> extra:  unexpected data: 0x1 0xd 0x0 0x0
0050|>>>>> recv: 0x0 extra data: 0x1 0xd 0x0 0x0
0051|>>>>> extra:  unexpected data: 0x1 0xd 0x0 0x0 0x0
0052|>>>>> recv: 0x5 extra data: 0x1 0xd 0x0 0x0 0x0
0053|>>>>> extra:  unexpected data: 0x1 0xd 0x0 0x0 0x0 0x5
0054|>>>>> recv: 0x1 extra data: 0x1 0xd 0x0 0x0 0x0 0x5
0055|>>>>> extra:  unexpected data: 0x1 0xd 0x0 0x0 0x0 0x5 0x1
0056|>>>>> recv: 0x3 extra data: 0x1 0xd 0x0 0x0 0x0 0x5 0x1
0057|>>>>> extra:  unexpected data: 0x1 0xd 0x0 0x0 0x0 0x5 0x1 0x3
0058|>>>>> recv: 0x2 extra data: 0x1 0xd 0x0 0x0 0x0 0x5 0x1 0x3
0059|>>>>> extra:  unexpected data: 0x1 0xd 0x0 0x0 0x0 0x5 0x1 0x3 0x2
Vous n’avez toujours pas donné de page santé jeedom, page de configuration…
Désolé
Je suis sur jeedom en 4.4.20 Distribution Bullseye sur RPI4 avec disque SSD de 120G
Voici la page santé et le conf du plugin MyModbus
Je me réponds à moi même car j’ai ce souci sur les Log Du demon MyModbus qui traine depuis septembre
0650|>>>>> send: 0x91 0x77 0x0 0x0 0x0 0x6 0x1 0x3 0x9c 0x85 0x0 0x1
0651|[2025-11-30 03:22:28] ERROR  : Cancel send, because not connected!
0652|>>>>> send: 0x0 0x1 0x0 0x0 0x0 0x6 0x1 0x1 0x0 0xf 0x0 0x1
0653|>>>>> recv: 0x0 0x1 0x0 0x0 0x0 0x4 0x1 0x1 0x1 0x0 extra data:
0654|>>>>> send: 0x0 0x2 0x0 0x0 0x0 0x6 0x1 0x3 0x0 0x64 0x0 0x1
0655|>>>>> recv: 0x0 0x2 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x40 0x1 extra data:
0656|>>>>> send: 0x0 0x3 0x0 0x0 0x0 0x6 0x1 0x3 0x0 0x65 0x0 0x1
0657|>>>>> recv: 0x0 0x3 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x0 0x0 extra data:
0658|>>>>> send: 0x0 0x4 0x0 0x0 0x0 0x6 0x1 0x3 0x0 0x16 0x0 0x1
0659|>>>>> recv: 0x0 0x4 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x3 0xda extra data:
0660|>>>>> send: 0x0 0x5 0x0 0x0 0x0 0x6 0x1 0x3 0x0 0x18 0x0 0x1
0661|>>>>> recv: 0x0 0x5 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x0 0x38 extra data:
0662|>>>>> send: 0x0 0x6 0x0 0x0 0x0 0x6 0x1 0x3 0x0 0x1a 0x0 0x1
0663|>>>>> recv: 0x0 0x6 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x0 0xa3 extra data:
0664|>>>>> send: 0x0 0x7 0x0 0x0 0x0 0x6 0x1 0x1 0x0 0xe 0x0 0x1
0665|>>>>> recv: 0x0 0x7 0x0 0x0 0x0 0x4 0x1 0x1 0x1 0x1 extra data:
0666|>>>>> send: 0x0 0x1 0x0 0x0 0x0 0x6 0x1 0x3 0x3 0xe8 0x0 0x1
0667|>>>>> recv: 0x0 0x1 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x1 0xd5 extra data:
0668|>>>>> send: 0x0 0x2 0x0 0x0 0x0 0x6 0x1 0x2 0x0 0x12 0x0 0x1
0669|>>>>> recv: 0x0 0x2 0x0 0x0 0x0 0x4 0x1 0x2 0x1 0x0 extra data:
0670|>>>>> send: 0x0 0x3 0x0 0x0 0x0 0x6 0x1 0x3 0x3 0xe9 0x0 0x1
0671|>>>>> recv: 0x0 0x3 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x0 0xc6 extra data:
0672|[2025-11-30 05:32:07] ERROR  : Cancel send, because not connected!
0673|>>>>> recv: 0xc3 extra data: 0x93
0674|>>>>> extra:  unexpected data: 0x93 0xc3
0675|>>>>> recv: 0x0 extra data: 0x93 0xc3
0676|>>>>> extra:  unexpected data: 0x93 0xc3 0x0
0677|>>>>> recv: 0x0 extra data: 0x93 0xc3 0x0
0678|>>>>> extra:  unexpected data: 0x93 0xc3 0x0 0x0
0679|>>>>> recv: 0x0 extra data: 0x93 0xc3 0x0 0x0
0680|>>>>> extra:  unexpected data: 0x93 0xc3 0x0 0x0 0x0
0681|>>>>> recv: 0x5 extra data: 0x93 0xc3 0x0 0x0 0x0
0682|>>>>> extra:  unexpected data: 0x93 0xc3 0x0 0x0 0x0 0x5
0683|>>>>> recv: 0x1 extra data: 0x93 0xc3 0x0 0x0 0x0 0x5
0684|>>>>> extra:  unexpected data: 0x93 0xc3 0x0 0x0 0x0 0x5 0x1
0685|>>>>> recv: 0x3 extra data: 0x93 0xc3 0x0 0x0 0x0 0x5 0x1
0686|>>>>> extra:  unexpected data: 0x93 0xc3 0x0 0x0 0x0 0x5 0x1 0x3
0687|>>>>> recv: 0x2 extra data: 0x93 0xc3 0x0 0x0 0x0 0x5 0x1 0x3
0688|>>>>> extra:  unexpected data: 0x93 0xc3 0x0 0x0 0x0 0x5 0x1 0x3 0x2
0689|>>>>> recv: 0x1 extra data: 0x93 0xc3 0x0 0x0 0x0 0x5 0x1 0x3 0x2
0690|>>>>> extra:  unexpected data: 0x93 0xc3 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x1
0691|>>>>> recv: 0x60 extra data: 0x93 0xc3 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x1
0692|>>>>> send: 0xec 0xad 0x0 0x0 0x0 0x6 0x1 0x3 0x9c 0x9b 0x0 0x2
0693|[2025-11-30 09:06:07] ERROR  : Cancel send, because not connected!
Je suis sur jeedom 4.5 RPI 4B Debian 11 Bullseye
Merci beaucoup
Une capture de la configuration de l’équipement et des commandes STP.
Toutes les erreurs que j’ai vue chez toi c’est systématiquement des erreurs de connexion. Il faudrait s’assurer que les automates « aillent bien », qu’ils n’aient pas trop de requêtes réseau (Modbus et autre) et que leur charge système ou leur temps de cycle soit dans les clous.
A+
Michel
Bonsoir Michel,
tu veux quel équipement exactement, dans les log il n’y a pas d’adresse IP !
Si tu veux tout les équipement et commande ! ça fait beaucoup de screenshot.
Tu n’as que 2 automates ? Les équipements qui s’y connectent ont chacun leur connexion ?
Je n’ai qu’un seul Automate M221 Schneider dont voici la configuration et quelques commandes:
Tous les équipements dont le nom contient M221 communiquent avec le même automate ? Tous ces équipements ont la même configuration de rafraichissement (polling, avec temps identique) ?
Tu as d’autres appareils qui communiquent en Modbus avec cet automate ? Jeedom de test ?
Tu utilises les plages de registres pour optimiser le nombre de requêtes ?
Tu as fait une modification de quoi que ce soit juste avant le 19 septembre (date de ton 1er post ici) ? Tu as peut-être ajouté une commande ou un équipement ?
Je pense qu’il serait intéressant de ne configurer qu’un seul équipement avec la configuration de connexion comme ton équipement M221 et les autres en protocole « Interface d’in autre équipement » en pointant vers cet équipement M221. Ca ne fera qu’une seule connexion et ton automate le supportera peut-être mieux.
L’essai est vite fait et si ça n’améliore rien, tu peux revenir en arrière facilement.
Pense juste à sauvegarder les configurations.
Pour moi, ça vient de la connexion, pas du plugin. On va vérifier ça.
Pour info : ce genre de log
ne sont pas générés par le plugin ni par le démon mais par le module pymodbus que le démon du plugin utilise.
Il y a des déconnexions d’au moins un équipement. Il faudrait déjà trouver lequel. Si tu as plusieurs équipements qui communiquent avec le M221, c’est peut-être ça le problème…
Bonsoir Michel,
et un grand merci pour avoir pris le temps de me répondre de façon détallée.
Il est vrai que sur la période de septembre j’ai rajouté un nouvel équipement dans mon réseau Modbus.
J’ai rajouté un onduleur hybride Photovoltaique.
Comme celui-ci est actuellement en panne je viens de mettre sur non actif l’équipement dans le plugin. Je vais voir si les logs que je viens d’effacés changent.
Je vais y allez par déduction étape par étape, suivant tes recommandations.
Par contre il est vrai que je n’utilise toujours pas les plages de registre certainement faute de temps pour le faire mais aussi par méconnaissance sur le sujet.
Encore merci
Je t’invite à lire la documentation et à me dire si tu as compris. J’ajusterai
