Depuis quelques temps (je crois depuis le passage en V4.2.x mais sans certitude), j’ai des problèmes aléatoires de remontée des status de mes inter volets roulants 67251.
Quelqu’un rencontre-t-il aussi ce problème :
[2022-03-25 08:59:58][DEBUG] : Jeeboxio_Equipement : Array ( [trame] => *2*1*9579362## [format] => BUS_COMMAND [mode] => UNICAST [media] => CPL [type] => automatism [value] => MOVE_UP [dimension] => [param] => [id] => 598710 [unit] => 2 [date] => 2022-03-25 08:59:58 )
[2022-03-25 08:59:58][DEBUG] : Jeeboxio_BUS_COMMAND
[2022-03-25 08:59:58][DEBUG] : Update Status Automatism
[2022-03-25 08:59:58][DEBUG] : unit_status : 2 poss : ACTION,STATUS,MEMORY Sous_device : 00 last : CLOSED duréecmd : 13 id cmd : 157 date : 1648195199
[2022-03-25 08:59:58][DEBUG] : Bouton normal
[2022-03-25 08:59:58][DEBUG] : Action MOVE_UP
[2022-03-25 08:59:58][DEBUG] : Point UP
[2022-03-25 08:59:58][DEBUG] : Move time : 13
[2022-03-25 08:59:58][DEBUG] : mise a jour du status : UP
[2022-03-25 08:59:58][DEBUG] : Jeeboxio_Equipement : Array ( [trame] => *#*1## [format] => ACK [mode] => UNKNOWN [media] => UNKNOWN [type] => UNKNOWN [value] => [dimension] => [param] => [id] => [unit] => [date] => 2022-03-25 08:59:58 )
[2022-03-25 08:59:58][DEBUG] : Jeeboxio_Trame non interprétée
[2022-03-25 08:59:58][DEBUG] : Jeeboxio_Equipement : Array ( [trame] => *1000*72*9579362## [format] => DIMENSION_SET [mode] => UNICAST [media] => CPL [type] => CONFIGURATION [value] => VALID_ACTION [dimension] => [param] => [id] => 598710 [unit] => 2 [date] => 2022-03-25 08:59:58 )
[2022-03-25 08:59:58][DEBUG] : Jeeboxio_DIMENSION_SET, mise a jour des statuts
[2022-03-25 09:00:00][DEBUG] : Jeeboxio_Equipement : Array ( [trame] => *2*1*9726658## [format] => BUS_COMMAND [mode] => UNICAST [media] => CPL [type] => automatism [value] => MOVE_UP [dimension] => [param] => [id] => 607916 [unit] => 2 [date] => 2022-03-25 09:00:00 )
[2022-03-25 09:00:00][DEBUG] : Jeeboxio_BUS_COMMAND
[2022-03-25 09:00:00][DEBUG] : Update Status Automatism
[2022-03-25 09:00:00][DEBUG] : unit_status : 2 poss : ACTION,STATUS,MEMORY Sous_device : 00 last : CLOSED duréecmd : 13 id cmd : 206 date : 1648195201
[2022-03-25 09:00:00][DEBUG] : Bouton normal
[2022-03-25 09:00:00][DEBUG] : Action MOVE_UP
[2022-03-25 09:00:00][DEBUG] : Point UP
[2022-03-25 09:00:00][DEBUG] : Move time : 13
[2022-03-25 09:00:00][DEBUG] : mise a jour du status : UP
[2022-03-25 09:00:00][DEBUG] : Jeeboxio_Equipement : Array ( [trame] => *#*1## [format] => ACK [mode] => UNKNOWN [media] => UNKNOWN [type] => UNKNOWN [value] => [dimension] => [param] => [id] => [unit] => [date] => 2022-03-25 09:00:00 )
[2022-03-25 09:00:00][DEBUG] : Jeeboxio_Trame non interprétée
[2022-03-25 09:00:00][DEBUG] : Jeeboxio_Equipement : Array ( [trame] => *1000*72*9726658## [format] => DIMENSION_SET [mode] => UNICAST [media] => CPL [type] => CONFIGURATION [value] => VALID_ACTION [dimension] => [param] => [id] => 607916 [unit] => 2 [date] => 2022-03-25 09:00:00 )
[2022-03-25 09:00:00][DEBUG] : Jeeboxio_DIMENSION_SET, mise a jour des statuts
[2022-03-25 09:00:12][DEBUG] : Jeeboxio_Equipement : Array ( [trame] => *2*1*9579362## [format] => BUS_COMMAND [mode] => UNICAST [media] => CPL [type] => automatism [value] => MOVE_UP [dimension] => [param] => [id] => 598710 [unit] => 2 [date] => 2022-03-25 09:00:12 )
[2022-03-25 09:00:12][DEBUG] : Jeeboxio_BUS_COMMAND
[2022-03-25 09:00:12][DEBUG] : Update Status Automatism
[2022-03-25 09:00:12][DEBUG] : Jeeboxio_Equipement : Array ( [trame] => *#*1## [format] => ACK [mode] => UNKNOWN [media] => UNKNOWN [type] => UNKNOWN [value] => [dimension] => [param] => [id] => [unit] => [date] => 2022-03-25 09:00:12 )
[2022-03-25 09:00:12][DEBUG] : Jeeboxio_Trame non interprétée
[2022-03-25 09:00:12][DEBUG] : unit_status : 2 poss : ACTION,STATUS,MEMORY Sous_device : 00 last : UP duréecmd : 13 id cmd : 157 date : 1648195213
[2022-03-25 09:00:12][DEBUG] : Bouton normal
[2022-03-25 09:00:12][DEBUG] : Action MOVE_UP
[2022-03-25 09:00:12][DEBUG] : mise a jour du status : OPEN
[2022-03-25 09:00:12][DEBUG] : Jeeboxio_Equipement : Array ( [trame] => *1000*72*9579362## [format] => DIMENSION_SET [mode] => UNICAST [media] => CPL [type] => CONFIGURATION [value] => VALID_ACTION [dimension] => [param] => [id] => 598710 [unit] => 2 [date] => 2022-03-25 09:00:12 )
[2022-03-25 09:00:12][DEBUG] : Jeeboxio_DIMENSION_SET, mise a jour des statuts
