Problème lors de l'installation de jeedom sur RPI5 Debian 12
Bonjour, je tente d’installer Jeedom sur un Pi5 sous Debian 12.
J’ai suivi la procédure de DanielJ mais ca bloque à la fin sur le step 10.
https://community.jeedom.com/t/tuto-installation-jeedom-sur-un-rpi5-avec-un-ssd-nvme/124018
Je vous joins la fin du log d’install.
Si quelqu’un a une idée.
Merci à vous
Starting step 6 - download Jeedom
--2026-01-09 20:37:40--  https://codeload.github.com/jeedom/core/zip/refs/heads/master
Resolving codeload.github.com (codeload.github.com)... 140.82.121.10
Connecting to codeload.github.com (codeload.github.com)|140.82.121.10|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 83995609 (80M) [application/zip]
Saving to: ‘/tmp/jeedom.zip’
/tmp/jeedom.zip                                             100%[========================================================================================================================================>]  80.10M  39.1MB/s    in 2.0s
2026-01-09 20:37:43 (39.1 MB/s) - ‘/tmp/jeedom.zip’ saved [83995609/83995609]
cp: cannot stat '/root/core/.htaccess': No such file or directory
Step 6 - download Jeedom done
Starting step 7 - mariadb customization
Step 7 - mariadb customization done
Starting step 8 - Jeedom customization
ln: failed to create symbolic link '/etc/apache2/conf-enabled/remoteip.conf': File exists
mkdir: cannot create directory ‘/etc/systemd/system/apache2.service.d’: File exists
Update php file /etc/php/8.2/cli/php.ini
Update php file /etc/php/8.2/apache2/php.ini
Module status already disabled
Module headers already enabled
Module remoteip already enabled
vm.swappiness = 10
Step 8 - Jeedom customization done
Starting step 9 - Jeedom configuration
Step 9 - Jeedom configuration done
Starting step 10 - Jeedom install
Begin installation of composer
--2026-01-09 20:37:46--  https://getcomposer.org/installer
Resolving getcomposer.org (getcomposer.org)... 2001:41d0:304:300::18ef, 57.128.19.244
Connecting to getcomposer.org (getcomposer.org)|2001:41d0:304:300::18ef|:443...
Je ne peux pas t’aider mais j’ai posé la question à tchat gpt:
Peux tu me dire pourquoi j’ai une erreur a l’installation de jeedom sur un raspberry pi5 avec debian 12: dans le log:
Puis copier/coller ton log
Les réponses pourront peut être t’aider, copie fichier depuis github erroné etc…
Avoir si cela peut t’aider.
C’est vrai je n’ai jamais le réflexe de faire ça …
merci pour ta réponse.
Quand tu dis ça bloque c’est à dire ?
Parce que dans le log il n’y a pas d’erreur la …
Il est resté bloqué longtemps sur cette étape ? Ou il y autre chose ?
Il reste bloqué à cette étape …
Tu as essayé plusieurs fois ou une seule ?
Car la il essaye de télécharger des sources sur un site externe. Donc ça pourrait très bien être un problème passager sur leur site, un problème sur ta connexion internet … pas forcément une « vraie » erreur du script d’install.
Sinon on voit que visiblement :
  • il cherche à résoudre le nom de domaine getcomposer.org et obtient une ipv4 et une ipv6
  • il essaye de télécharger le fichier en ipv6
Ca vaudrait le coup de désactiver l’ipv6 pour le forcer à télécharger en ipv4 voir si c’est mieux.
Tu peux essayer de lancer avant le script d’install :
sudo sysctl -w net.ipv6.conf.eth0.disable_ipv6=1
Si ton interface réseau est bien eth0 (ce qui devrait être le cas sur un pi).
J’ai relancé et laissé toute la nuit et ce matin c’est bon jeedom est bien installé.
