Je suis entrain de faire un fresh install sur un raspberry pi 3 sous raspbian 9.
L’installation se termine avec une erreur SQL à l’étape 9. *
Merci par avance pour votre aide.
\033[1;33mCommence l'étape 9 installation de jeedom\033[0;39m
[START INSTALL]
PHP Fatal error: Uncaught Exception: [MySQL] Error code : 42S02 (1146). Table 'jeedom.config' doesn't exist : SELECT `key`,`value`
FROM config
WHERE `key` IN ('language')
AND plugin=:plugin in /var/www/html/core/class/DB.class.php:101
Stack trace:
#0 /var/www/html/core/class/config.class.php(173): DB::Prepare('SELECT `key`,`v...', Array, 1)
#1 /var/www/html/core/class/translate.class.php(34): config::byKeys(Array)
#2 /var/www/html/core/class/translate.class.php(149): translate::getConfig('language', 'fr_FR')
#3 /var/www/html/core/class/translate.class.php(75): translate::getLanguage()
#4 /var/www/html/core/class/translate.class.php(54): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
#5 /var/www/html/core/class/translate.class.php(163): translate::sentence('Chauffage', '/var/www/html/c...', false)
#6 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/var/www/html/c...')
#7 /var/www/html/core/php/utils.inc.php(70): require_once('/var/www/html/c...')
#8 /var/www/html/core/php/core.inc.php(27 in /var/www/html/core/class/DB.class.php on line 101
Erreur durant l'installation : [MySQL] Error code : 42S02 (1146). Table 'jeedom.config' doesn't exist : SELECT `key`,`value`
FROM config
AND plugin=:pluginDétails : Array
[0] => Array
[file] => /var/www/html/core/class/config.class.php
[line] => 173
[function] => Prepare
[class] => DB
[type] => ::
[args] => Array
[0] => SELECT `key`,`value`
FROM config
AND plugin=:plugin
[1] => Array
[plugin] => core
[2] => 1
[1] => Array
[file] => /var/www/html/core/class/translate.class.php
[line] => 34
[function] => byKeys
[class] => config
[type] => ::
[args] => Array
[0] => Array
[0] => language
[2] => Array
[line] => 149
[function] => getConfig
[class] => translate
[type] => ::
[args] => Array
[0] => language
[1] => fr_FR
[3] => Array
[line] => 75
[function] => getLanguage
[type] => ::
[args] => Array
[4] => Array
[line] => 54
[function] => exec
[type] => ::
[args] => Array
[0] => {{Chauffage}}
[1] => /var/www/html/core/config/jeedom.config.php
[2] =>
[5] => Array
[line] => 163
[function] => sentence
[type] => ::
[args] => Array
[0] => Chauffage
[2] =>
[6] => Array
[file] => /var/www/html/core/config/jeedom.config.php
[line] => 23
[function] => __
[args] => Array
[0] => Chauffage
[7] => Array
[file] => /var/www/html/core/php/utils.inc.php
[line] => 70
[args] => Array
[0] => /var/www/html/core/config/jeedom.config.php
[function] => require_once
[8] => Array
[file] => /var/www/html/core/php/core.inc.php
[line] => 27
[function] => include_file
[args] => Array
[0] => core/config
[1] => jeedom.config.php
[2] => config
[9] => Array
[file] => /var/www/html/install/install.php
[line] => 40
[args] => Array
[0] => /var/www/html/core/php/core.inc.php
[END INSTALL ERROR]
\033[1;31mNe peut installer jeedom - Annulation\033[0;39m
