J’ai un léger soucis concernant l’installation des dépendances du plugin z-wave voici le log:
Lancement de l'installation/mise à jour des dépendances openzwave
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Err:2 http://ftp.fr.debian.org/debian stretch InRelease
Temporary failure resolving 'ftp.fr.debian.org'
Err:3 http://ftp.fr.debian.org/debian stretch-updates InRelease
Hit:4 https://deb.nodesource.com/node_12.x stretch InRelease
Reading package lists...
W: Failed to fetch http://ftp.fr.debian.org/debian/dists/stretch/InRelease Temporary failure resolving 'ftp.fr.debian.org'
W: Failed to fetch http://ftp.fr.debian.org/debian/dists/stretch-updates/InRelease Temporary failure resolving 'ftp.fr.debian.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Installation des dependances
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.3).
g++ is already the newest version (4:6.3.0-4).
gcc is already the newest version (4:6.3.0-4).
libjpeg-dev is already the newest version (1:1.5.1-2).
python-louie is already the newest version (1.1-2.1).
python-lxml is already the newest version (3.7.1-1).
make is already the newest version (4.1-9.1).
python-serial is already the newest version (3.2.1-1).
python-dev is already the newest version (2.7.13-2).
python-pip is already the newest version (9.0.1-2+deb9u1).
python-setuptools is already the newest version (33.1.1-1).
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.12.4-1).
libudev-dev is already the newest version (232-25+deb9u12).
unzip is already the newest version (6.0-21+deb9u2).
git is already the newest version (1:2.11.0-3+deb9u7).
The following packages were automatically installed and are no longer required:
python-blinker python-jwt python-lockfile python-oauthlib python-paramiko
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Installation des dependances Python
Requirement already satisfied: urwid in /usr/local/lib/python3.5/dist-packages (2.1.0)
WARNING: You are using pip version 20.0.2; however, version 20.1 is available.
You should consider upgrading via the '/usr/bin/python3 -m pip install --upgrade pip' command.
Collecting louie
Using cached Louie-2.0.tar.gz (13 kB)
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-r6eosbk7/louie/setup.py'"'"'; __file__='"'"'/tmp/pip-install-r6eosbk7/louie/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-install-r6eosbk7/louie/pip-egg-info
cwd: /tmp/pip-install-r6eosbk7/louie/
Complete output (10 lines):
File "<string>", line 1, in <module>
File "/tmp/pip-install-r6eosbk7/louie/setup.py", line 3, in <module>
from louie import version
File "/tmp/pip-install-r6eosbk7/louie/louie/__init__.py", line 1, in <module>
from . import dispatcher, error, plugin, robustapply, saferef, sender, signal, version
File "/tmp/pip-install-r6eosbk7/louie/louie/dispatcher.py", line 44
f"Louie connects: {connects}
SyntaxError: invalid syntax
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
could not install - abort
Sachant que j’utilise Debian 10 strech et qu’il est en virtual machine sur un Nas Synology
Si quelqu’un peux m’aider ca serais super, je ne comprend pas le problème.
merci à la communauté
