bonjour,
j’ai un soucis d’installation des dépendances de blea en béta:
je pensais que c’était lié a la nouvelle béta de ce matin mais j’ai pareil avec un restore de mon backup, et comme le restore relance les dépendance j’ai la meme erreur sur xiaomihome:
je met les logs complets en piece jointe car le message est trop long…
xiaomihome_packages.txt (35,3 Ko)
blea_update.txt (45,1 Ko)
la partie interessante me semble etre ça:
+ sudo pip3 install --upgrade pip
File "/usr/bin/pip3", line 33, in <module>
sys.exit(load_entry_point('pip==20.3.4', 'console_scripts', 'pip3')())
File "/usr/bin/pip3", line 25, in importlib_load_entry_point
return next(matches).load()
File "/usr/lib/python3.9/importlib/metadata.py", line 77, in load
module = import_module(match.group('module'))
File "/usr/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 790, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/usr/lib/python3/dist-packages/pip/_internal/cli/main.py", line 10, in <module>
from pip._internal.cli.autocompletion import autocomplete
File "/usr/lib/python3/dist-packages/pip/_internal/cli/autocompletion.py", line 9, in <module>
from pip._internal.cli.main_parser import create_main_parser
File "/usr/lib/python3/dist-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
from pip._internal.cli import cmdoptions
File "/usr/lib/python3/dist-packages/pip/_internal/cli/cmdoptions.py", line 23, in <module>
from pip._vendor.packaging.utils import canonicalize_name
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 94, in <module>
vendored("requests.packages.urllib3.contrib.pyopenssl")
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
__import__(modulename, globals(), locals(), level=0)
File "<frozen importlib._bootstrap>", line 664, in _load_unlocked
File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible
File "<frozen zipimport>", line 259, in load_module
File "/usr/share/python-wheels/urllib3-1.26.5-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 50, in <module>
File "/usr/local/lib/python3.9/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import SSL, crypto
File "/usr/local/lib/python3.9/dist-packages/OpenSSL/SSL.py", line 34, in <module>
from OpenSSL.crypto import (
File "/usr/local/lib/python3.9/dist-packages/OpenSSL/crypto.py", line 942, in <module>
utils.deprecated(
TypeError: deprecated() got an unexpected keyword argument 'name'
du coup je pense que c’est une incompatibilité avec une version d’un autre package mais je sais pas lequel…
version de jeedom:
si quelqu’un a une idée d’où chercher, je suis preneur ![]()
