Problème après reboot ou de configuration antenne
salut et bonne année également.
Effectivement si ca marchera pas si le LWT n’est pas sous le meme topic que BTtoMQTT.
Je n’ai pas testé le plugin-theengs depuis longtemps donc si pas moyen de changer ca va être un probleme…
je te suggère 3 autres solutions que j’utilise selon le contexte:
  1. installer l’image docker theengs
    voici mon docker-compose.yml (sur mon Pi3B+):
# docker-compose.yml
services:
  theengs:
    container_name: theengs
    image: theengs/gateway
    network_mode: host
    privileged: true
    restart: unless-stopped
    environment:
      MQTT_HOST: localhost
      MQTT_USERNAME: xxxx
      MQTT_PASSWORD: yyyy
      MQTT_PUB_TOPIC: theengs/tgw_local/BTtoMQTT
      MQTT_SUB_TOPIC: theengs/tgw_local/commands
      LWT_TOPIC: theengs/tgw_local/LWT
      BLE_TIME_BETWEEN_SCANS: 60
      SCAN_TIME: 4
      LOG_LEVEL: WARNING
      DISCOVERY_DEVICE_NAME: tgw_local
      DISCOVERY_FILTER: "[IBEACON,GAEN,MS-CDP]"
      ADAPTER: hci0
    volumes:
      - /var/run/dbus:/var/run/dbus
    healthcheck:
      test: 'hciconfig|awk "/hci0/{ print $0 }" || exit 1'
      interval: 1m
      timeout: 1s
      start_period: 5s
      retries: 3
  1. directement en python (ex sur mon PiZero). voici mon fichier theengs.conf:
    "adapter": "",
    "bindkeys": {},
    "blacklist": [],
    "ble": 1,
    "ble_scan_time": 5,
    "ble_time_between_scans": 60,
    "discovery": 1,
    "discovery_device_name": "tgw_remote",
    "discovery_filter": [
        "IBEACON"
    "discovery_name": "tgw_remote",
    "discovery_topic": "homeassistant",
    "enable_tls": 0,
    "enable_websocket": 0,
    "general_presence": 0,
    "hass_discovery": 1,
    "host": "192.168.1.94",
    "identities": {},
    "log_level": "WARNING",
    "lwt_topic": "theengs/tgw_remote/LWT",
    "pass": "yyyy",
    "port": 1883,
    "presence": 0,
    "presence_topic": "home/TheengsGateway/presence",
    "publish_advdata": 0,
    "publish_all": 1,
    "publish_topic": "theengs/tgw_remote/BTtoMQTT",
    "scan_duration": 60,
    "scanning_mode": "active",
    "subscribe_topic": "theengs/tgw_remote/commands",
    "time_between": 60,
    "time_format": 0,
    "time_sync": [],
    "tls_insecure": 0,
    "tracker_timeout": 120,
    "user": "jeedom",
    "whitelist": []
tu peux aussi regarder ce tuto qui explique tout
  1. un ESP32
