brd-o
Mars 16, 2022, 9:15
1
Good morning everyone,
I have a problem with a jeedom Smart box, I can no longer access the jeedom interface for a few days. When I go to the ip address of the smart box, I have this error : « Composer detected issues in your platform: Your Composer dependencies require a PHP version « >= 7.1.0 ». »
So for that I tried to update every packages with apt update and I have this error :
This came from this packet : deb-src Index of /odroid stable main
in the file /etc/apt/sources.list
Have you ever had this kind of error and find a solution ?
Thanks for your help,
A first way to help yourself would have been to look for the error in the forum.
sudo apt-get --allow-releaseinfo-change update
brd-o
Mars 16, 2022, 10:18
3
Thanks for the insight but the reason i’m posting is precisely because I couldn’t find anything on the forum
Did you tried the solution I gave you?
Do not truncate the command line if it is not working. Haw can we check if you did a mistake or not?
Please read this topic.
J’ai voulu faire une mise à jour du plugin SmartLife/Tuya et depuis j’ai l’erreur suivante quand je vais au centre de mise à jour:
« Composer detected issues in your platform: Your Composer dependencies require a PHP version « >= 7.1.0 ». You are running 7.0.27-0+deb9u1. »’
Comment faire pour installer la version 7.1.0 de PHP ?
Merci d’avance pour vos réponses.
You have to consider to update your Smart.
brd-o
Mars 16, 2022, 1:16
8
I tried sudo apt-get update :
Your command line is not the one I suggested.
brd-o
Mars 16, 2022, 1:44
10
Yes but I don’t understand what you suggest because the command gives only informations on subcommands
Could you just copy paste all the line? And not only a part of it.
brd-o
Mars 16, 2022, 1:51
12
I also tried all the line but I have this error :
