Prise TS0121 ZIGBEE toujours sans remonté de puissance
je rédéterre ce sujet car un an après le problème n’est pas résolu sous Zigbee
https://community.jeedom.com/t/prise-ts0121-zigbee-sans-remonte-de-puissance/62472
j’ai du suivre les instructions et créé un scénario pour rafraichir les données Puissance toute les minutes
C’est un peu du bricolage et cela fonctionne sans problème (automatiquement) sous deconZ (j’ai du passer à Zigbee pour d’autres capteurs)
Ce n’est pas corrigeable sous Zigbee ?
merci
Sans le json brute il est impossible de vous aider
le json brut
    "ieee": "60:a4:23:ff:fe:ff:3f:68",
    "nwk": 41526,
    "status": 2,
    "lqi": "224",
    "rssi": "-44",
    "last_seen": "1654623242.805077",
    "node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 81,
            "profile_id": 260,
            "manufacturer": "_TZ3000_rdtixbnu",
            "model": "TS0121",
            "output_clusters": [
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 65
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_rdtixbnu"
                            "id": 5,
                            "name": "model",
                            "value": "TS0121"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "name": "off_wait_time",
                            "value": 0
                            "id": 32769,
                            "name": "backlight_mode",
                            "value": 1
                            "id": 32770,
                            "name": "power_on_state",
                            "value": 0
                    "id": 1794,
                    "name": "TuyaZBMeteringCluster",
                    "attributes": [
                            "id": 0,
                            "name": "current_summ_delivered",
                            "value": 47151
                    "id": 2820,
                    "name": "Electrical Measurement",
                    "attributes": [
                            "id": 1291,
                            "name": "active_power",
                            "value": 97
    "signature": {
        "model": "TS0121",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 81,
                "input_clusters": [
                    0,
                    4,
                    5,
                    6,
                    1794,
                    2820
                    10,
                    25
    "class": "zhaquirks.tuya.ts0121_plug"
Ok c’est le module qui ne remonte pas de lui meme les informations, j’ai rajouté dans la conf un refresh à 5min, moins peut etre dangereux pour la stabilité du réseaux zigbee.
merci pour la réponse
étrange car sous deconZ j’avais bien les mises à jour sans rien faire de particulier avec le même équipement
Oui car il font un auto refresh en interne, comme je viens de rajouter dans le plugin sauf que dans le plugin zigbee on le montre alors que deconz le montre pas c’est la seule difference.
c’est clair merci
j’avais fait un scénario pour ce refresh , du coup ça sera d’office dans une MAJ du Pluggin Zigbee à venir ?
oui comme je l’ai dit
