Bonsoir à tous,
j’ai migré du plugin zigbee au jeezigbee depuis quelques jours.
En gros tout se passe bien, mais j’ai un souci : mes prises NOUS TS011F.
Côté remontée d’informations, aucun souci, tout remonte bien.
Si j’en active une manuellement, dans Jeedom ça remonte instantanément (état + conso).
Par contre les actions depuis Jeedom fonctionnent une fois de temps en temps.
Ce qui est vraiment étrange c’est que je n’ai aucun log d’erreur.
Voici les logs que j’ai quand j’execute les actions (toggle, state On, state OFF) :
0004|Zigbee2MQTT:debug 2023-12-21 19:31:52: Received MQTT message on 'zigbee2mqtt/0xa4c1382fcdcfc6ac/set' with data '{"state":"TOGGLE"}'
0005|Zigbee2MQTT:debug 2023-12-21 19:31:52: Publishing 'set' 'state' to '0xa4c1382fcdcfc6ac'
0006|Zigbee2MQTT:debug 2023-12-21 19:31:54: Received MQTT message on 'zigbee2mqtt/0xa4c1382fcdcfc6ac/set' with data '{"state":"ON"}'
0007|Zigbee2MQTT:debug 2023-12-21 19:31:54: Publishing 'set' 'state' to '0xa4c1382fcdcfc6ac'
0008|Zigbee2MQTT:debug 2023-12-21 19:31:55: Received Zigbee message from '0xa4c13807a3c6a239', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":923}' from endpoint 1 with groupID 0
0009|Zigbee2MQTT:info 2023-12-21 19:31:55: MQTT publish: topic 'zigbee2mqtt/0xa4c13807a3c6a239', payload '{"child_lock":"UNLOCK","current":4.15,"device":{"applicationVersion":76,"dateCode":"","friendlyName":"0xa4c13807a3c6a239","hardwareVersion":1,"ieeeAddr":"0xa4c13807a3c6a239","manufacturerID":4417,"manufacturerName":"_TZ3000_ksw8qtmt","model":"A1Z","networkAddress":64044,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":824.53,"indicator_mode":"off/on","last_seen":"2023-12-21T18:31:55.361Z","linkquality":96,"power":923,"power_outage_memory":"restore","state":"ON","voltage":228}'
0010|Zigbee2MQTT:debug 2023-12-21 19:31:55: Received Zigbee message from '0xa4c13807a3c6a239', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":4093}' from endpoint 1 with groupID 0
0011|Zigbee2MQTT:info 2023-12-21 19:31:55: MQTT publish: topic 'zigbee2mqtt/0xa4c13807a3c6a239', payload '{"child_lock":"UNLOCK","current":4.09,"device":{"applicationVersion":76,"dateCode":"","friendlyName":"0xa4c13807a3c6a239","hardwareVersion":1,"ieeeAddr":"0xa4c13807a3c6a239","manufacturerID":4417,"manufacturerName":"_TZ3000_ksw8qtmt","model":"A1Z","networkAddress":64044,"powerSource":"Mains (single phase)","stackVersion":0,"type":"Router","zclVersion":3},"energy":824.53,"indicator_mode":"off/on","last_seen":"2023-12-21T18:31:55.383Z","linkquality":96,"power":923,"power_outage_memory":"restore","state":"ON","voltage":228}'
0012|Zigbee2MQTT:debug 2023-12-21 19:31:55: Received Zigbee message from '0x003c84fffe21eacf', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,210],"type":"Buffer"},"datatype":2,"dp":3}],"seq":652}' from endpoint 1 with groupID 0
0014|Zigbee2MQTT:debug 2023-12-21 19:31:55: Received Zigbee message from '0x003c84fffe21eacf', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,25],"type":"Buffer"},"datatype":2,"dp":104}],"seq":908}' from endpoint 1 with groupID 0
0016|Zigbee2MQTT:debug 2023-12-21 19:31:56: Received MQTT message on 'zigbee2mqtt/0xa4c1382fcdcfc6ac/set' with data '{"state":"OFF"}'
0017|Zigbee2MQTT:debug 2023-12-21 19:31:56: Publishing 'set' 'state' to '0xa4c1382fcdcfc6ac'
Si besoin de ma config pour la réflexion :
- Raspberry Pi
- Debian 10.7
- Jeedom 4.3.17
- Modules tous à jour
- Dongle POPP Stick
Qu’en pensez-vous ? Que devrais je faire ?
Merci pour votre aide.
