Voyant ce post, j’ai mis a jour mon core alpha deb12
J’ai tenté un installdes dependances avec le plugin rfxcom.
Je ne sais pas si c’est relevant mais j’ai des erreurs pipx
+ touch /tmp/jeedom_install_in_progress_rfxcom
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
Launch pre-install of rfxcom dependancy
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.11/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
Reading package lists...
Building dependency tree...
Reading state information...
The following packages will be REMOVED:
python3-serial
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 470 kB disk space will be freed.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 104064 files and directories currently installed.)
Removing python3-serial (3.5-1.1) ...
+ echo 3
+ sudo apt update
Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
Hit:2 http://deb.debian.org/debian bookworm InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 https://deb.nodesource.com/node_16.x bookworm InRelease
All packages are up to date.
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3
python3 is already the newest version (3.11.2-1+b1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
+ echo 5
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pip
python3-pip is already the newest version (23.0.1+dfsg-1).
+ echo 6
+ sudo apt install -o Dpkg::Options::=--force-confdef -y build-essential
+ echo 7
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pyudev
python3-pyudev is already the newest version (0.24.0-1).
+ echo 8
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-dev
python3-dev is already the newest version (3.11.2-1+b1).
+ echo 9
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-requests
python3-requests is already the newest version (2.28.1+dfsg-1).
+ echo 10
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-setuptools
python3-setuptools is already the newest version (66.1.1-1).
+ echo 11
+ sudo apt update
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
+ sudo apt install -y pipx
The following additional packages will be installed:
blt fonts-font-awesome fonts-lato ghp-import libjs-bootstrap4
libjs-highlight.js libjs-lunr libjs-modernizr libjs-popper.js libjs-sizzle
mkdocs node-jquery python-babel-localedata python3-argcomplete python3-attr
python3-babel python3-click python3-colorama python3-dateutil
python3-iniconfig python3-jinja2 python3-joblib python3-livereload
python3-lunr python3-markdown python3-markupsafe python3-mergedeep
python3-more-itertools python3-nltk python3-numpy python3-packaging
python3-pluggy python3-psutil python3-py python3-pytest
python3-pyyaml-env-tag python3-regex python3-simplejson python3-tk
python3-tornado python3-tqdm python3-tz python3-userpath python3-watchdog
sphinx-rtd-theme-common tk8.6-blt2.5
Suggested packages:
blt-demo libjs-es5-shim mkdocs-doc python-attr-doc python-jinja2-doc
coffeescript node-less node-uglify python-livereload-doc python3-django
python3-flask python3-slimmer python-lunr-doc python-markdown-doc gfortran
python-psutil-doc subversion tix python3-tk-dbg python-tornado-doc
python3-twisted
Recommended packages:
prover9
mkdocs node-jquery pipx python-babel-localedata python3-argcomplete
python3-attr python3-babel python3-click python3-colorama python3-dateutil
0 upgraded, 47 newly installed, 0 to remove and 0 not upgraded.
Need to get 23.1 MB of archives.
After this operation, 106 MB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bookworm/main amd64 fonts-lato all 2.0-2.1 [2696 kB]
Get:2 http://deb.debian.org/debian bookworm/main amd64 tk8.6-blt2.5 amd64 2.5.3+dfsg-4.1 [593 kB]
Get:3 http://deb.debian.org/debian bookworm/main amd64 blt amd64 2.5.3+dfsg-4.1 [14.9 kB]
Get:4 http://deb.debian.org/debian bookworm/main amd64 fonts-font-awesome all 5.0.10+really4.7.0~dfsg-4.1 [517 kB]
Get:5 http://deb.debian.org/debian bookworm/main amd64 python3-dateutil all 2.8.2-2 [78.3 kB]
Get:6 http://deb.debian.org/debian bookworm/main amd64 ghp-import all 2.1.0-3 [12.3 kB]
Get:7 http://deb.debian.org/debian bookworm/main amd64 libjs-popper.js all 1.16.1+ds-6 [52.4 kB]
Get:8 http://deb.debian.org/debian bookworm/main amd64 libjs-bootstrap4 all 4.6.1+dfsg1-4 [517 kB]
Get:9 http://deb.debian.org/debian bookworm/main amd64 libjs-highlight.js all 9.18.5+dfsg1-2 [397 kB]
Get:10 http://deb.debian.org/debian bookworm/main amd64 libjs-lunr all 2.3.9~dfsg-2 [76.6 kB]
Get:11 http://deb.debian.org/debian bookworm/main amd64 libjs-modernizr all 2.6.2+ds1-5 [47.1 kB]
Get:12 http://deb.debian.org/debian bookworm/main amd64 libjs-sizzle all 2.3.6+ds+~2.3.3-2 [31.6 kB]
Get:13 http://deb.debian.org/debian bookworm/main amd64 python3-tornado amd64 6.2.0-3 [337 kB]
Get:14 http://deb.debian.org/debian bookworm/main amd64 python3-livereload all 2.6.3-2 [26.4 kB]
Get:15 http://deb.debian.org/debian bookworm/main amd64 python3-colorama all 0.4.6-2 [36.8 kB]
Get:16 http://deb.debian.org/debian bookworm/main amd64 python3-click all 8.1.3-2 [92.2 kB]
Get:17 http://deb.debian.org/debian bookworm/main amd64 python3-joblib all 1.2.0-4 [211 kB]
Get:18 http://deb.debian.org/debian bookworm/main amd64 python3-regex amd64 0.1.20221031-1+b1 [266 kB]
Get:19 http://deb.debian.org/debian bookworm/main amd64 python3-tqdm all 4.64.1-1 [97.7 kB]
Get:20 http://deb.debian.org/debian bookworm/main amd64 python3-nltk all 3.8-1 [1004 kB]
Get:21 http://deb.debian.org/debian bookworm/main amd64 python3-lunr all 0.6.2-2 [29.1 kB]
Get:22 http://deb.debian.org/debian bookworm/main amd64 sphinx-rtd-theme-common all 1.2.0+dfsg-1 [997 kB]
Get:23 http://deb.debian.org/debian bookworm/main amd64 python3-markupsafe amd64 2.1.2-1+b1 [13.2 kB]
Get:24 http://deb.debian.org/debian bookworm/main amd64 python3-jinja2 all 3.1.2-1 [119 kB]
Get:25 http://deb.debian.org/debian bookworm/main amd64 python3-markdown all 3.4.1-2 [64.7 kB]
Get:26 http://deb.debian.org/debian bookworm/main amd64 python3-mergedeep all 1.3.4-3 [6556 B]
Get:27 http://deb.debian.org/debian bookworm/main amd64 python3-packaging all 23.0-1 [32.5 kB]
Get:28 http://deb.debian.org/debian bookworm/main amd64 python3-pyyaml-env-tag all 0.1-3 [5252 B]
Get:29 http://deb.debian.org/debian bookworm/main amd64 python3-watchdog all 2.2.1-1 [124 kB]
Get:30 http://deb.debian.org/debian bookworm/main amd64 mkdocs all 1.4.2+dfsg-2 [2252 kB]
Get:31 http://deb.debian.org/debian bookworm/main amd64 node-jquery all 3.6.1+dfsg+~3.5.14-1 [160 kB]
Get:32 http://deb.debian.org/debian bookworm/main amd64 python3-argcomplete all 2.0.0-1 [34.7 kB]
Get:33 http://deb.debian.org/debian bookworm/main amd64 python3-userpath all 1.8.0-1 [10.6 kB]
Get:34 http://deb.debian.org/debian bookworm/main amd64 pipx all 1.1.0-1 [393 kB]
Get:35 http://deb.debian.org/debian bookworm/main amd64 python-babel-localedata all 2.10.3-1 [5615 kB]
Get:36 http://deb.debian.org/debian bookworm/main amd64 python3-attr all 22.2.0-1 [65.4 kB]
Get:37 http://deb.debian.org/debian bookworm/main amd64 python3-tz all 2022.7.1-4 [30.1 kB]
Get:38 http://deb.debian.org/debian bookworm/main amd64 python3-babel all 2.10.3-1 [103 kB]
Get:39 http://deb.debian.org/debian bookworm/main amd64 python3-iniconfig all 1.1.1-2 [6396 B]
Get:40 http://deb.debian.org/debian bookworm/main amd64 python3-more-itertools all 8.10.0-2 [53.0 kB]
Get:41 http://deb.debian.org/debian bookworm/main amd64 python3-numpy amd64 1:1.24.2-1 [5209 kB]
Get:42 http://deb.debian.org/debian bookworm/main amd64 python3-pluggy all 1.0.0+repack-1 [19.7 kB]
Get:43 http://deb.debian.org/debian bookworm/main amd64 python3-psutil amd64 5.9.4-1+b1 [189 kB]
Get:44 http://deb.debian.org/debian bookworm/main amd64 python3-py all 1.11.0-1 [89.2 kB]
Get:45 http://deb.debian.org/debian bookworm/main amd64 python3-pytest all 7.2.1-2 [236 kB]
Get:46 http://deb.debian.org/debian bookworm/main amd64 python3-simplejson amd64 3.18.3-1 [59.8 kB]
Get:47 http://deb.debian.org/debian bookworm/main amd64 python3-tk amd64 3.11.2-3 [98.3 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 23.1 MB in 13s (1737 kB/s)
Selecting previously unselected package fonts-lato.
(Reading database ... 104006 files and directories currently installed.)
Preparing to unpack .../00-fonts-lato_2.0-2.1_all.deb ...
Unpacking fonts-lato (2.0-2.1) ...
Selecting previously unselected package tk8.6-blt2.5.
Preparing to unpack .../01-tk8.6-blt2.5_2.5.3+dfsg-4.1_amd64.deb ...
Unpacking tk8.6-blt2.5 (2.5.3+dfsg-4.1) ...
Selecting previously unselected package blt.
Preparing to unpack .../02-blt_2.5.3+dfsg-4.1_amd64.deb ...
Unpacking blt (2.5.3+dfsg-4.1) ...
Selecting previously unselected package fonts-font-awesome.
Preparing to unpack .../03-fonts-font-awesome_5.0.10+really4.7.0~dfsg-4.1_all.deb ...
Unpacking fonts-font-awesome (5.0.10+really4.7.0~dfsg-4.1) ...
Selecting previously unselected package python3-dateutil.
Preparing to unpack .../04-python3-dateutil_2.8.2-2_all.deb ...
Unpacking python3-dateutil (2.8.2-2) ...
Selecting previously unselected package ghp-import.
Preparing to unpack .../05-ghp-import_2.1.0-3_all.deb ...
Unpacking ghp-import (2.1.0-3) ...
Selecting previously unselected package libjs-popper.js.
Preparing to unpack .../06-libjs-popper.js_1.16.1+ds-6_all.deb ...
Unpacking libjs-popper.js (1.16.1+ds-6) ...
Selecting previously unselected package libjs-bootstrap4.
Preparing to unpack .../07-libjs-bootstrap4_4.6.1+dfsg1-4_all.deb ...
Unpacking libjs-bootstrap4 (4.6.1+dfsg1-4) ...
Selecting previously unselected package libjs-highlight.js.
Preparing to unpack .../08-libjs-highlight.js_9.18.5+dfsg1-2_all.deb ...
Unpacking libjs-highlight.js (9.18.5+dfsg1-2) ...
Selecting previously unselected package libjs-lunr.
Preparing to unpack .../09-libjs-lunr_2.3.9~dfsg-2_all.deb ...
Unpacking libjs-lunr (2.3.9~dfsg-2) ...
Selecting previously unselected package libjs-modernizr.
Preparing to unpack .../10-libjs-modernizr_2.6.2+ds1-5_all.deb ...
Unpacking libjs-modernizr (2.6.2+ds1-5) ...
Selecting previously unselected package libjs-sizzle.
Preparing to unpack .../11-libjs-sizzle_2.3.6+ds+~2.3.3-2_all.deb ...
Unpacking libjs-sizzle (2.3.6+ds+~2.3.3-2) ...
Selecting previously unselected package python3-tornado.
Preparing to unpack .../12-python3-tornado_6.2.0-3_amd64.deb ...
Unpacking python3-tornado (6.2.0-3) ...
Selecting previously unselected package python3-livereload.
Preparing to unpack .../13-python3-livereload_2.6.3-2_all.deb ...
Unpacking python3-livereload (2.6.3-2) ...
Selecting previously unselected package python3-colorama.
Preparing to unpack .../14-python3-colorama_0.4.6-2_all.deb ...
Unpacking python3-colorama (0.4.6-2) ...
Selecting previously unselected package python3-click.
Preparing to unpack .../15-python3-click_8.1.3-2_all.deb ...
Unpacking python3-click (8.1.3-2) ...
Selecting previously unselected package python3-joblib.
Preparing to unpack .../16-python3-joblib_1.2.0-4_all.deb ...
Unpacking python3-joblib (1.2.0-4) ...
Selecting previously unselected package python3-regex.
Preparing to unpack .../17-python3-regex_0.1.20221031-1+b1_amd64.deb ...
Unpacking python3-regex (0.1.20221031-1+b1) ...
Selecting previously unselected package python3-tqdm.
Preparing to unpack .../18-python3-tqdm_4.64.1-1_all.deb ...
Unpacking python3-tqdm (4.64.1-1) ...
Selecting previously unselected package python3-nltk.
Preparing to unpack .../19-python3-nltk_3.8-1_all.deb ...
Unpacking python3-nltk (3.8-1) ...
Selecting previously unselected package python3-lunr.
Preparing to unpack .../20-python3-lunr_0.6.2-2_all.deb ...
Unpacking python3-lunr (0.6.2-2) ...
Selecting previously unselected package sphinx-rtd-theme-common.
Preparing to unpack .../21-sphinx-rtd-theme-common_1.2.0+dfsg-1_all.deb ...
Unpacking sphinx-rtd-theme-common (1.2.0+dfsg-1) ...
Selecting previously unselected package python3-markupsafe.
Preparing to unpack .../22-python3-markupsafe_2.1.2-1+b1_amd64.deb ...
Unpacking python3-markupsafe (2.1.2-1+b1) ...
Selecting previously unselected package python3-jinja2.
Preparing to unpack .../23-python3-jinja2_3.1.2-1_all.deb ...
Unpacking python3-jinja2 (3.1.2-1) ...
Selecting previously unselected package python3-markdown.
Preparing to unpack .../24-python3-markdown_3.4.1-2_all.deb ...
Unpacking python3-markdown (3.4.1-2) ...
Selecting previously unselected package python3-mergedeep.
Preparing to unpack .../25-python3-mergedeep_1.3.4-3_all.deb ...
Unpacking python3-mergedeep (1.3.4-3) ...
Selecting previously unselected package python3-packaging.
Preparing to unpack .../26-python3-packaging_23.0-1_all.deb ...
Unpacking python3-packaging (23.0-1) ...
Selecting previously unselected package python3-pyyaml-env-tag.
Preparing to unpack .../27-python3-pyyaml-env-tag_0.1-3_all.deb ...
Unpacking python3-pyyaml-env-tag (0.1-3) ...
Selecting previously unselected package python3-watchdog.
Preparing to unpack .../28-python3-watchdog_2.2.1-1_all.deb ...
Unpacking python3-watchdog (2.2.1-1) ...
Selecting previously unselected package mkdocs.
Preparing to unpack .../29-mkdocs_1.4.2+dfsg-2_all.deb ...
Unpacking mkdocs (1.4.2+dfsg-2) ...
Selecting previously unselected package node-jquery.
Preparing to unpack .../30-node-jquery_3.6.1+dfsg+~3.5.14-1_all.deb ...
Unpacking node-jquery (3.6.1+dfsg+~3.5.14-1) ...
Selecting previously unselected package python3-argcomplete.
Preparing to unpack .../31-python3-argcomplete_2.0.0-1_all.deb ...
Unpacking python3-argcomplete (2.0.0-1) ...
Selecting previously unselected package python3-userpath.
Preparing to unpack .../32-python3-userpath_1.8.0-1_all.deb ...
Unpacking python3-userpath (1.8.0-1) ...
Selecting previously unselected package pipx.
Preparing to unpack .../33-pipx_1.1.0-1_all.deb ...
Unpacking pipx (1.1.0-1) ...
Selecting previously unselected package python-babel-localedata.
Preparing to unpack .../34-python-babel-localedata_2.10.3-1_all.deb ...
Unpacking python-babel-localedata (2.10.3-1) ...
Selecting previously unselected package python3-attr.
Preparing to unpack .../35-python3-attr_22.2.0-1_all.deb ...
Unpacking python3-attr (22.2.0-1) ...
Selecting previously unselected package python3-tz.
Preparing to unpack .../36-python3-tz_2022.7.1-4_all.deb ...
Unpacking python3-tz (2022.7.1-4) ...
Selecting previously unselected package python3-babel.
Preparing to unpack .../37-python3-babel_2.10.3-1_all.deb ...
Unpacking python3-babel (2.10.3-1) ...
Selecting previously unselected package python3-iniconfig.
Preparing to unpack .../38-python3-iniconfig_1.1.1-2_all.deb ...
Unpacking python3-iniconfig (1.1.1-2) ...
Selecting previously unselected package python3-more-itertools.
Preparing to unpack .../39-python3-more-itertools_8.10.0-2_all.deb ...
Unpacking python3-more-itertools (8.10.0-2) ...
Selecting previously unselected package python3-numpy.
Preparing to unpack .../40-python3-numpy_1%3a1.24.2-1_amd64.deb ...
Unpacking python3-numpy (1:1.24.2-1) ...
Selecting previously unselected package python3-pluggy.
Preparing to unpack .../41-python3-pluggy_1.0.0+repack-1_all.deb ...
Unpacking python3-pluggy (1.0.0+repack-1) ...
Selecting previously unselected package python3-psutil.
Preparing to unpack .../42-python3-psutil_5.9.4-1+b1_amd64.deb ...
Unpacking python3-psutil (5.9.4-1+b1) ...
Selecting previously unselected package python3-py.
Preparing to unpack .../43-python3-py_1.11.0-1_all.deb ...
Unpacking python3-py (1.11.0-1) ...
Selecting previously unselected package python3-pytest.
Preparing to unpack .../44-python3-pytest_7.2.1-2_all.deb ...
Unpacking python3-pytest (7.2.1-2) ...
Selecting previously unselected package python3-simplejson.
Preparing to unpack .../45-python3-simplejson_3.18.3-1_amd64.deb ...
Unpacking python3-simplejson (3.18.3-1) ...
Selecting previously unselected package python3-tk:amd64.
Preparing to unpack .../46-python3-tk_3.11.2-3_amd64.deb ...
Unpacking python3-tk:amd64 (3.11.2-3) ...
Setting up python3-more-itertools (8.10.0-2) ...
Setting up python3-iniconfig (1.1.1-2) ...
Setting up python3-attr (22.2.0-1) ...
Setting up python3-tornado (6.2.0-3) ...
Setting up tk8.6-blt2.5 (2.5.3+dfsg-4.1) ...
Setting up fonts-lato (2.0-2.1) ...
Setting up python3-py (1.11.0-1) ...
Setting up python3-joblib (1.2.0-4) ...
Setting up libjs-popper.js (1.16.1+ds-6) ...
Setting up python3-colorama (0.4.6-2) ...
Setting up python3-watchdog (2.2.1-1) ...
Setting up libjs-lunr (2.3.9~dfsg-2) ...
Setting up blt (2.5.3+dfsg-4.1) ...
Setting up python3-tqdm (4.64.1-1) ...
Setting up python3-tk:amd64 (3.11.2-3) ...
Setting up python3-click (8.1.3-2) ...
Setting up libjs-sizzle (2.3.6+ds+~2.3.3-2) ...
Setting up python3-markupsafe (2.1.2-1+b1) ...
Setting up libjs-modernizr (2.6.2+ds1-5) ...
Setting up python3-psutil (5.9.4-1+b1) ...
Setting up python3-tz (2022.7.1-4) ...
Setting up python-babel-localedata (2.10.3-1) ...
Setting up python3-pyyaml-env-tag (0.1-3) ...
Setting up python3-simplejson (3.18.3-1) ...
Setting up python3-jinja2 (3.1.2-1) ...
Setting up python3-packaging (23.0-1) ...
Setting up python3-markdown (3.4.1-2) ...
Setting up python3-mergedeep (1.3.4-3) ...
Setting up python3-regex (0.1.20221031-1+b1) ...
Setting up python3-numpy (1:1.24.2-1) ...
Setting up python3-pluggy (1.0.0+repack-1) ...
Setting up libjs-highlight.js (9.18.5+dfsg1-2) ...
Setting up python3-livereload (2.6.3-2) ...
Setting up python3-dateutil (2.8.2-2) ...
Setting up libjs-bootstrap4 (4.6.1+dfsg1-4) ...
Setting up python3-argcomplete (2.0.0-1) ...
Setting up python3-nltk (3.8-1) ...
Setting up fonts-font-awesome (5.0.10+really4.7.0~dfsg-4.1) ...
Setting up sphinx-rtd-theme-common (1.2.0+dfsg-1) ...
Setting up node-jquery (3.6.1+dfsg+~3.5.14-1) ...
Setting up python3-userpath (1.8.0-1) ...
Setting up python3-lunr (0.6.2-2) ...
Setting up python3-babel (2.10.3-1) ...
update-alternatives: using /usr/bin/pybabel-python3 to provide /usr/bin/pybabel (pybabel) in auto mode
Setting up python3-pytest (7.2.1-2) ...
Setting up pipx (1.1.0-1) ...
Setting up ghp-import (2.1.0-3) ...
Setting up mkdocs (1.4.2+dfsg-2) ...
Processing triggers for libc-bin (2.36-9+deb12u3) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for fontconfig (2.14.1-4) ...
+ echo 12
+ sudo pipx install --force-reinstall --upgrade six
usage: pipx [-h] [--version]
{install,inject,upgrade,upgrade-all,uninstall,uninstall-all,reinstall,reinstall-all,list,run,runpip,ensurepath,environment,completions}
pipx: error: unrecognized arguments: --force-reinstall --upgrade
+ echo 13
+ sudo pipx install --force-reinstall --upgrade requests
+ echo 14
+ sudo pipx install --force-reinstall --upgrade setuptools
+ echo 15
+ sudo pipx install --force-reinstall --upgrade pyudev
+ echo 16
+ sudo pipx install --force-reinstall --upgrade pyserial
+ echo 17
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end rfxcom
+ rm /tmp/jeedom_install_in_progress_rfxcom
