Oui du coup
Oui je n’y vois pas le programme. Donc deCONZ n’est pas complètement installé.
Depuis le plug in Jeedom il faut arrêter le démon et relancer l’installation en local. Visiblement ta dernière instal n’a rien installé
OK, je fait ça. En tout cas merci pour l’aide.
Et si ça ne marche pas il faudra aller faire un tour ici :
* Installation deconz *
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Hit:2 http://phoscon.de/apt/deconz stretch InRelease
Ign:3 http://ftp.fr.debian.org/debian stretch InRelease
Hit:4 http://ftp.fr.debian.org/debian stretch-updates InRelease
Hit:5 http://ftp.fr.debian.org/debian stretch Release
Hit:6 https://deb.nodesource.com/node_12.x stretch InRelease
Reading package lists...
Building dependency tree...
Reading state information...
libqt5serialport5 is already the newest version (5.7.1~20161021-2).
libqt5websockets5 is already the newest version (5.7.1~20161021-4).
0 upgraded, 0 newly installed, 0 to remove and 223 not upgraded.
sqlite3 is already the newest version (3.16.2-5+deb9u3).
It's x86_64 arch
--2021-01-15 21:27:39-- http://phoscon.de/apt/deconz.pub.key
Resolving phoscon.de (phoscon.de)... 144.76.96.194
Connecting to phoscon.de (phoscon.de)|144.76.96.194|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1692 (1.7K) [application/octet-stream]
Saving to: 'STDOUT'
0K . 100% 122M=0s
2021-01-15 21:27:39 (122 MB/s) - written to stdout [1692/1692]
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
Ign:1 http://ftp.fr.debian.org/debian stretch InRelease
Hit:2 http://security.debian.org/debian-security stretch/updates InRelease
Hit:3 http://ftp.fr.debian.org/debian stretch-updates InRelease
Hit:4 http://phoscon.de/apt/deconz stretch InRelease
E: Unable to locate package deconz
Failed to disable unit: No such file or directory
Failed to stop deconz-gui.service: Unit deconz-gui.service not loaded.
Failed to stop deconz.service: Unit deconz.service not loaded.
* Installation terminée *
Et je re-test :
jeedom@JeedomBT3:~$ GCFFlasher_internal -l
-bash: GCFFlasher_internal : commande introuvable
Pas mieux…
Je vais voir ton tuto
Il y a du monde à mettre à jour visiblement
Tu es sous Debian 10 ?
Non Debian 9, fort possible qu’il y est des mises à jour à faire.
Je peux effectivement faire cela avant de poursuivre
sudo apt-get update donc en premier
Oui je fait cela
jeedom n'apparaît pas dans le fichier sudoers. Cet événement sera signalé.
Ca se gâte !
quel est l’utilisateur qui a les droits admin sur ta box ?
Parce qu’il va être indispensable pour remettre l’utilisateur Jeedom dans le groupe sudo
Moi, c’est bon c’est corrigé, les mises à jour sont en cours
Avant de faire upgrade il faut voir ce qui va être mis à jour
jeedom@JeedomBT3:~$ sudo apt-get update
[sudo] Mot de passe de jeedom :
Atteint:1 http://phoscon.de/apt/deconz stretch InRelease
Ign:2 http://ftp.fr.debian.org/debian stretch InRelease
Atteint:3 http://security.debian.org/debian-security stretch/updates InRelease
Atteint:4 http://ftp.fr.debian.org/debian stretch-updates InRelease
Atteint:5 http://ftp.fr.debian.org/debian stretch Release
Atteint:6 https://deb.nodesource.com/node_12.x stretch InRelease
Lecture des listes de paquets... Fait
sudo apt show deconz
puis
sudo apt-get upgrade deconz
C’est pas simple …
jeedom@JeedomBT3 : /etc/apt/sources.list.d $ sudo apt show deconz
N: Impossible de trouver le paquet deconz
E: Aucun paquet n’a été trouvé
donc deconz n’est pas installé
Il faut l’installer à la main
jeedom@JeedomBT3:/etc/apt/sources.list.d$ sudo apt-get install deconz
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
E: Impossible de trouver le paquet deconz
Mais le fichier deconz.list donne bien le lien vers le dépot :
deb [arch=amd64] http://phoscon.de/apt/deconz stretch main
copie du résultat de
uname -a
