plus de remontées des consignes dans le plugin quelque soit le programme selectionné !
uniquement remontée de la tempèrature.
pas d’erreur dans dans le log.
essai avec cron 15, idem.
[2023-03-06 13:10:03][DEBUG][%scenarioName%]: [qivivo] <cron5>
[2023-03-06 13:10:03][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> refreshQivivoInfos
[2023-03-06 13:10:04][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> Number of houses: 1
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivoCmd] <execute> action: set_program options: {"select":"Cf Couvert","user_login":"kervelys","user_id":"2"}
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivoCmd] <execute> set_program Piriac - Thermostat Soleil | Cf Couvert
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> isMultizone: 0
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> ProgramsList: [{"id":"17de474c-d8be-4353-8dd1-063575aaf5b9","title":"Absence"},{"id":"9aeda78c-4c80-4aea-8216-4ade98ce6444","title":"Cf Couvert"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca001","title":"Cf Soleil"},{"id":"4cd13a87-a7ea-4210-9d8a-d4cb07fd7363","title":"Eco"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca003","title":"Gite"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca004","title":"Hors Gel"}]
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> devices: {"060d761d00124b00":{"housing_id":"a81ca5cf-4368-43cf-bfb5-0c84293c524e","model":"gateway","last_communication_time":"2023-03-06T11:48:12.923675+00:00","first_communication_time":"2021-01-28T10:08:21.234307+00:00","is_new":false,"firmware_version":2115,"errors":[]},"g143400516":{"housing_id":"a81ca5cf-4368-43cf-bfb5-0c84293c524e","model":"thermostat","last_communication_time":"2023-03-06T12:07:50.027269+00:00","first_communication_time":"2021-01-28T10:08:21.212268+00:00","voltage":6.01,"voltage_percent":100,"is_new":false,"firmware_version":2014,"errors":[],"zone":"Soleil","order":"presence_2","heating_status":"heating"}}
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> type: gateway serial: 060d761d00124b00 zone: Thermostat
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivo] <postSave> Passerelle | 060d761d00124b00
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> type: thermostat serial: g143400516 zone: Soleil
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> zone: {"id":"a81ca5cf-4368-43cf-bfb5-0c84293cc001","title":"Soleil","open_window":false,"area_type":null,"last_transmission":"2023-03-06T13:07:57.051827+01:00","transmission_error":false,"temperature":18.56,"humidity":null,"programming_type":"connected","set_point_type":"defined_temperature","set_point":{"instruction":"presence_2"},"next_timeslot":{"begin_at":"2023-03-06T17:00:00+01:00","set_point":{"instruction":"presence_3"}},"heating_status":"heating","kids_lock":false,"ot_max_water_temperature":null,"ot_wc_slope":null,"ot_wc_curve":null,"events":[],"last_presence_detected":"2023-03-06T12:57:48.871804+01:00","bg_image":"","errors":[]}
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> temperature: 18.56
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> humidity:
[2023-03-06 13:10:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> lastPresence: 06-03-2023 12:57
[2023-03-06 13:10:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> settings: {"global_informations":{"can_be_multizone":false,"installation_type":"monozone","heating_system_types":["temperature"],"heating_priority":null},"used_temperatures":["presence_2","presence_3","night","away","frost_protection","presence_4"],"thermal_housing_settings":{"timezone":"Europe\/Paris","summer_mode":false,"max_temperature":null}}
[2023-03-06 13:10:06][DEBUG][%scenarioName%]: [qivivo] <postSave> Thermostat | g143400516
[2023-03-06 13:10:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> refreshQivivoInfos done
[2023-03-06 13:10:10][DEBUG][%scenarioName%]: [qivivoCmd] <execute> set_program: success
[2023-03-06 13:10:10][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> refreshQivivoInfos
[2023-03-06 13:10:11][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> Number of houses: 1
[2023-03-06 13:10:11][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> isMultizone: 0
[2023-03-06 13:10:11][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> ProgramsList: [{"id":"17de474c-d8be-4353-8dd1-063575aaf5b9","title":"Absence"},{"id":"9aeda78c-4c80-4aea-8216-4ade98ce6444","title":"Cf Couvert"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca001","title":"Cf Soleil"},{"id":"4cd13a87-a7ea-4210-9d8a-d4cb07fd7363","title":"Eco"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca003","title":"Gite"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca004","title":"Hors Gel"}]
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> devices: {"060d761d00124b00":{"housing_id":"a81ca5cf-4368-43cf-bfb5-0c84293c524e","model":"gateway","last_communication_time":"2023-03-06T11:48:12.923675+00:00","first_communication_time":"2021-01-28T10:08:21.234307+00:00","is_new":false,"firmware_version":2115,"errors":[]},"g143400516":{"housing_id":"a81ca5cf-4368-43cf-bfb5-0c84293c524e","model":"thermostat","last_communication_time":"2023-03-06T12:07:50.027269+00:00","first_communication_time":"2021-01-28T10:08:21.212268+00:00","voltage":6.01,"voltage_percent":100,"is_new":false,"firmware_version":2014,"errors":[],"zone":"Soleil","order":"presence_2","heating_status":"heating"}}
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> type: gateway serial: 060d761d00124b00 zone: Thermostat
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <postSave> Passerelle | 060d761d00124b00
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> type: thermostat serial: g143400516 zone: Soleil
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> zone: {"id":"a81ca5cf-4368-43cf-bfb5-0c84293cc001","title":"Soleil","open_window":false,"area_type":null,"last_transmission":"2023-03-06T13:07:57.051827+01:00","transmission_error":false,"temperature":18.56,"humidity":null,"programming_type":"connected","set_point_type":"defined_temperature","set_point":{"instruction":"presence_2"},"next_timeslot":{"begin_at":"2023-03-06T18:00:00+01:00","set_point":{"instruction":"presence_4"}},"heating_status":"heating","kids_lock":false,"ot_max_water_temperature":null,"ot_wc_slope":null,"ot_wc_curve":null,"events":[],"last_presence_detected":"2023-03-06T12:57:48.871804+01:00","bg_image":"","errors":[]}
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> temperature: 18.56
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> humidity:
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> lastPresence: 06-03-2023 12:57
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> settings: {"global_informations":{"can_be_multizone":false,"installation_type":"monozone","heating_system_types":["temperature"],"heating_priority":null},"used_temperatures":["presence_2","presence_3","night","away","frost_protection","presence_4"],"thermal_housing_settings":{"timezone":"Europe\/Paris","summer_mode":false,"max_temperature":null}}
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <postSave> Thermostat | g143400516
[2023-03-06 13:10:12][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> refreshQivivoInfos done
[2023-03-06 13:15:04][DEBUG][%scenarioName%]: [qivivo] <cron5>
[2023-03-06 13:15:04][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> refreshQivivoInfos
[2023-03-06 13:15:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> Number of houses: 1
[2023-03-06 13:15:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> isMultizone: 0
[2023-03-06 13:15:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> ProgramsList: [{"id":"17de474c-d8be-4353-8dd1-063575aaf5b9","title":"Absence"},{"id":"9aeda78c-4c80-4aea-8216-4ade98ce6444","title":"Cf Couvert"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca001","title":"Cf Soleil"},{"id":"4cd13a87-a7ea-4210-9d8a-d4cb07fd7363","title":"Eco"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca003","title":"Gite"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca004","title":"Hors Gel"}]
[2023-03-06 13:15:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> devices: {"060d761d00124b00":{"housing_id":"a81ca5cf-4368-43cf-bfb5-0c84293c524e","model":"gateway","last_communication_time":"2023-03-06T11:48:12.923675+00:00","first_communication_time":"2021-01-28T10:08:21.234307+00:00","is_new":false,"firmware_version":2115,"errors":[]},"g143400516":{"housing_id":"a81ca5cf-4368-43cf-bfb5-0c84293c524e","model":"thermostat","last_communication_time":"2023-03-06T12:12:53.340330+00:00","first_communication_time":"2021-01-28T10:08:21.212268+00:00","voltage":6,"voltage_percent":100,"is_new":false,"firmware_version":2014,"errors":[],"zone":"Soleil","order":"presence_2","heating_status":"heating"}}
[2023-03-06 13:15:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> type: gateway serial: 060d761d00124b00 zone: Thermostat
[2023-03-06 13:15:06][DEBUG][%scenarioName%]: [qivivo] <postSave> Passerelle | 060d761d00124b00
[2023-03-06 13:15:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> type: thermostat serial: g143400516 zone: Soleil
[2023-03-06 13:15:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> zone: {"id":"a81ca5cf-4368-43cf-bfb5-0c84293cc001","title":"Soleil","open_window":false,"area_type":null,"last_transmission":"2023-03-06T13:12:50.083429+01:00","transmission_error":false,"temperature":18.62,"humidity":null,"programming_type":"connected","set_point_type":"defined_temperature","set_point":{"instruction":"presence_2"},"next_timeslot":{"begin_at":"2023-03-06T18:00:00+01:00","set_point":{"instruction":"presence_4"}},"heating_status":"heating","kids_lock":false,"ot_max_water_temperature":null,"ot_wc_slope":null,"ot_wc_curve":null,"events":[],"last_presence_detected":"2023-03-06T13:12:50.083418+01:00","bg_image":"","errors":[]}
[2023-03-06 13:15:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> temperature: 18.62
[2023-03-06 13:15:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> humidity:
[2023-03-06 13:15:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> lastPresence: 06-03-2023 13:12
[2023-03-06 13:15:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> settings: {"global_informations":{"can_be_multizone":false,"installation_type":"monozone","heating_system_types":["temperature"],"heating_priority":null},"used_temperatures":["presence_2","presence_3","night","away","frost_protection","presence_4"],"thermal_housing_settings":{"timezone":"Europe\/Paris","summer_mode":false,"max_temperature":null}}
[2023-03-06 13:15:07][DEBUG][%scenarioName%]: [qivivo] <postSave> Thermostat | g143400516
[2023-03-06 13:15:07][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> refreshQivivoInfos done
[2023-03-06 13:20:03][DEBUG][%scenarioName%]: [qivivo] <cron5>
[2023-03-06 13:20:03][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> refreshQivivoInfos
[2023-03-06 13:20:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> Number of houses: 1
[2023-03-06 13:20:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> isMultizone: 0
[2023-03-06 13:20:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> ProgramsList: [{"id":"17de474c-d8be-4353-8dd1-063575aaf5b9","title":"Absence"},{"id":"9aeda78c-4c80-4aea-8216-4ade98ce6444","title":"Cf Couvert"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca001","title":"Cf Soleil"},{"id":"4cd13a87-a7ea-4210-9d8a-d4cb07fd7363","title":"Eco"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca003","title":"Gite"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca004","title":"Hors Gel"}]
[2023-03-06 13:20:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> devices: {"060d761d00124b00":{"housing_id":"a81ca5cf-4368-43cf-bfb5-0c84293c524e","model":"gateway","last_communication_time":"2023-03-06T12:18:15.268185+00:00","first_communication_time":"2021-01-28T10:08:21.234307+00:00","is_new":false,"firmware_version":2115,"errors":[]},"g143400516":{"housing_id":"a81ca5cf-4368-43cf-bfb5-0c84293c524e","model":"thermostat","last_communication_time":"2023-03-06T12:17:52.365697+00:00","first_communication_time":"2021-01-28T10:08:21.212268+00:00","voltage":6.01,"voltage_percent":100,"is_new":false,"firmware_version":2014,"errors":[],"zone":"Soleil","order":"presence_2","heating_status":"heating"}}
[2023-03-06 13:20:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> type: gateway serial: 060d761d00124b00 zone: Thermostat
[2023-03-06 13:20:05][DEBUG][%scenarioName%]: [qivivo] <postSave> Passerelle | 060d761d00124b00
[2023-03-06 13:20:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> type: thermostat serial: g143400516 zone: Soleil
[2023-03-06 13:20:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> zone: {"id":"a81ca5cf-4368-43cf-bfb5-0c84293cc001","title":"Soleil","open_window":false,"area_type":null,"last_transmission":"2023-03-06T13:17:49.602266+01:00","transmission_error":false,"temperature":18.56,"humidity":null,"programming_type":"connected","set_point_type":"defined_temperature","set_point":{"instruction":"presence_2"},"next_timeslot":{"begin_at":"2023-03-06T17:00:00+01:00","set_point":{"instruction":"presence_3"}},"heating_status":"heating","kids_lock":false,"ot_max_water_temperature":null,"ot_wc_slope":null,"ot_wc_curve":null,"events":[],"last_presence_detected":"2023-03-06T13:17:49.602256+01:00","bg_image":"","errors":[]}
[2023-03-06 13:20:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> temperature: 18.56
[2023-03-06 13:20:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> humidity:
[2023-03-06 13:20:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> lastPresence: 06-03-2023 13:17
[2023-03-06 13:20:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> settings: {"global_informations":{"can_be_multizone":false,"installation_type":"monozone","heating_system_types":["temperature"],"heating_priority":null},"used_temperatures":["presence_2","presence_3","night","away","frost_protection","presence_4"],"thermal_housing_settings":{"timezone":"Europe\/Paris","summer_mode":false,"max_temperature":null}}
[2023-03-06 13:20:06][DEBUG][%scenarioName%]: [qivivo] <postSave> Thermostat | g143400516
[2023-03-06 13:20:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> refreshQivivoInfos done
[2023-03-06 13:25:03][DEBUG][%scenarioName%]: [qivivo] <cron5>
[2023-03-06 13:25:03][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> refreshQivivoInfos
[2023-03-06 13:25:04][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> Number of houses: 1
[2023-03-06 13:25:04][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> isMultizone: 0
[2023-03-06 13:25:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> ProgramsList: [{"id":"17de474c-d8be-4353-8dd1-063575aaf5b9","title":"Absence"},{"id":"9aeda78c-4c80-4aea-8216-4ade98ce6444","title":"Cf Couvert"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca001","title":"Cf Soleil"},{"id":"4cd13a87-a7ea-4210-9d8a-d4cb07fd7363","title":"Eco"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca003","title":"Gite"},{"id":"a81ca5cf-4368-43cf-bfb5-0c84293ca004","title":"Hors Gel"}]
[2023-03-06 13:25:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> devices: {"060d761d00124b00":{"housing_id":"a81ca5cf-4368-43cf-bfb5-0c84293c524e","model":"gateway","last_communication_time":"2023-03-06T12:18:15.268185+00:00","first_communication_time":"2021-01-28T10:08:21.234307+00:00","is_new":false,"firmware_version":2115,"errors":[]},"g143400516":{"housing_id":"a81ca5cf-4368-43cf-bfb5-0c84293c524e","model":"thermostat","last_communication_time":"2023-03-06T12:22:52.475438+00:00","first_communication_time":"2021-01-28T10:08:21.212268+00:00","voltage":6,"voltage_percent":100,"is_new":false,"firmware_version":2014,"errors":[],"zone":"Soleil","order":"presence_2","heating_status":"heating"}}
[2023-03-06 13:25:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> type: gateway serial: 060d761d00124b00 zone: Thermostat
[2023-03-06 13:25:05][DEBUG][%scenarioName%]: [qivivo] <postSave> Passerelle | 060d761d00124b00
[2023-03-06 13:25:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> type: thermostat serial: g143400516 zone: Soleil
[2023-03-06 13:25:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> zone: {"id":"a81ca5cf-4368-43cf-bfb5-0c84293cc001","title":"Soleil","open_window":false,"area_type":null,"last_transmission":"2023-03-06T13:22:51.984439+01:00","transmission_error":false,"temperature":18.72,"humidity":null,"programming_type":"connected","set_point_type":"defined_temperature","set_point":{"instruction":"presence_2"},"next_timeslot":{"begin_at":"2023-03-06T17:00:00+01:00","set_point":{"instruction":"presence_3"}},"heating_status":"heating","kids_lock":false,"ot_max_water_temperature":null,"ot_wc_slope":null,"ot_wc_curve":null,"events":[],"last_presence_detected":"2023-03-06T13:22:51.984428+01:00","bg_image":"","errors":[]}
[2023-03-06 13:25:05][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> temperature: 18.72
[2023-03-06 13:25:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> humidity:
[2023-03-06 13:25:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> lastPresence: 06-03-2023 13:22
[2023-03-06 13:25:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> settings: {"global_informations":{"can_be_multizone":false,"installation_type":"monozone","heating_system_types":["temperature"],"heating_priority":null},"used_temperatures":["presence_2","presence_3","night","away","frost_protection","presence_4"],"thermal_housing_settings":{"timezone":"Europe\/Paris","summer_mode":false,"max_temperature":null}}
[2023-03-06 13:25:06][DEBUG][%scenarioName%]: [qivivo] <postSave> Thermostat | g143400516
[2023-03-06 13:25:06][DEBUG][%scenarioName%]: [qivivo] <refreshQivivoInfos> refreshQivivoInfos done
[2023-03-06 13:27:26][DEBUG][%scenarioName%]: [qivivo] <postSave> Thermostat | g143400516
ok sur le cloud.
