Hello !
Depuis hier, je n’ai plus de remontée des valeurs de l’Ondilo ICO.
Cependant, sur l’application du produit, les dernières valeurs sont bien présentes et les remontées se font.
A tout hasard, je me suis ré-identifié (plusieurs fois), et il semble qu’en effet, il y a bien un soucis.
Les valeurs restent bien bloquées à hier soir.
Du coup, j’imagine un problème sur le plugin.
[2024-03-19 09:21:51][DEBUG] : url: https://interop.ondilo.com/api/customer/v1/pools/52402/lastmeasures
[2024-03-19 09:21:51][DEBUG] : headers: Array ( [0] => Accept: application/json [1] => Accept-Charset: utf-8 [2] => Accept-Encoding: gzip, deflate [3] => Authorization: Bearer b850fab08920e0cdc970c06e673a8d85b3e74c1d )
[2024-03-19 09:21:51][DEBUG] : data: Array ( [bearer] => XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX )
[2024-03-19 09:21:51][DEBUG] : lastMeasures: Array ( [0] => Array ( [data_type] => temperature [value] => 10.7 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) [1] => Array ( [data_type] => orp [value] => 571 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) [2] => Array ( [data_type] => ph [value] => 6.97 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) [3] => Array ( [data_type] => salt [value] => 2885 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) [4] => Array ( [data_type] => battery [value] => 62 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) [5] => Array ( [data_type] => rssi [value] => 100 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) )
[2024-03-19 09:21:51][DEBUG] : mesure: temperature=10.7
[2024-03-19 09:21:51][DEBUG] : mesure: orp=571
[2024-03-19 09:21:51][DEBUG] : mesure: ph=6.97
[2024-03-19 09:21:51][DEBUG] : mesure: salt=2885
[2024-03-19 09:21:51][DEBUG] : mesure: battery=62
[2024-03-19 09:21:51][DEBUG] : mesure: rssi=100
[2024-03-19 09:22:45][DEBUG] : url: https://interop.ondilo.com/oauth2/token
[2024-03-19 09:22:45][DEBUG] : headers: Array ( [0] => Content-Type: application/x-www-form-urlencoded )
[2024-03-19 09:22:45][DEBUG] : data: Array ( [code] => XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX [grant_type] => authorization_code [client_id] => customer_api [redirect_uri] => http://192.168.1.115/plugins/ondilo/core/api/ondilo.php?action=autorize )
[2024-03-19 09:23:44][DEBUG] : return: <div class="eqLogic eqLogic-widget allowResize allowReorderCmd allowLayout " style="position: relative; width:230px; height:110px; " data-eqLogic_id="3034" data-eqLogic_uid="eqLogic3034__923122213__" data-version="dashboard" data-category=""> <span class="statusCmd"></span> <span class="cmd refresh pull-right cursor" data-cmd_id="21064"> <i class="fas fa-sync"></i> </span> <center class="widget-name"> <a href="index.php?v=d&p=ondilo&m=ondilo&id=3034" style="#hideEqLogicName#">ICO <span class="object_name">Piscine</span></a> </center> <div class="center"> </div> <div class="row row-overflow"> <div class="col-xs-4 center">10.7 °</div> <div class="col-xs-4">Signal 100 %</div> <div class="col-xs-4">Batterie 62 %</div> </div> <div class="row row-overflow"> <div class="col-xs-4"></div> <div class="col-xs-4 center"><img src="plugins/ondilo/desktop/images/pool.png" width="100" title ="ICO" class="ui-sortable-handle"/></div> <div class="col-xs-4"></div> </div> <div class="row row-overflow"> <div class="col-xs-4 center">Redox<br/>571 mV</div> <div class="col-xs-4 center">pH<br/>6.97</div> <div class="col-xs-4 center">Sel<br/>2885 mg/l</div> </div> <div class="row row-overflow"> <div class="col-xs-12 left"> <i class="fas fa-sync"></i> 18/03/2024 17:21:07 </div> </div> </div> <script type="text/javascript"> $('.eqLogic[data-eqLogic_uid=eqLogic3034__923122213__] .refresh').on('click', function () { jeedom.cmd.execute({id: '21064'}); }); </script>
[2024-03-19 09:28:04][DEBUG] : url: https://interop.ondilo.com/oauth2/token
[2024-03-19 09:28:04][DEBUG] : headers: Array ( [0] => Content-Type: application/x-www-form-urlencoded )
[2024-03-19 09:28:04][DEBUG] : data: Array ( [code] => [grant_type] => authorization_code [client_id] => customer_api [redirect_uri] => /plugins/ondilo/core/api/ondilo.php?action=autorize )
[2024-03-19 09:30:08][DEBUG] : url: https://interop.ondilo.com/api/customer/v1/pools/52402/lastmeasures
[2024-03-19 09:30:08][DEBUG] : headers: Array ( [0] => Accept: application/json [1] => Accept-Charset: utf-8 [2] => Accept-Encoding: gzip, deflate [3] => Authorization: Bearer )
[2024-03-19 09:30:08][DEBUG] : data: Array ( [bearer] => )
[2024-03-19 09:30:08][DEBUG] : lastMeasures: Array ( [error] => invalid_request [error_description] => Malformed auth header )
[2024-03-19 09:30:21][DEBUG] : url: https://interop.ondilo.com/oauth2/token
[2024-03-19 09:30:21][DEBUG] : headers: Array ( [0] => Content-Type: application/x-www-form-urlencoded )
[2024-03-19 09:30:21][DEBUG] : data: Array ( [refresh_token] => [grant_type] => refresh_token [client_id] => customer_api )
[2024-03-19 09:35:09][DEBUG] : url: https://interop.ondilo.com/oauth2/token
[2024-03-19 09:35:09][DEBUG] : headers: Array ( [0] => Content-Type: application/x-www-form-urlencoded )
[2024-03-19 09:35:09][DEBUG] : data: Array ( [refresh_token] => [grant_type] => refresh_token [client_id] => customer_api )
[2024-03-19 09:35:23][DEBUG] : url: https://interop.ondilo.com/oauth2/token
[2024-03-19 09:35:23][DEBUG] : headers: Array ( [0] => Content-Type: application/x-www-form-urlencoded )
[2024-03-19 09:35:23][DEBUG] : data: Array ( [code] => XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX [grant_type] => authorization_code [client_id] => customer_api [redirect_uri] => http://192.168.1.115/plugins/ondilo/core/api/ondilo.php?action=autorize )
[2024-03-19 09:37:03][DEBUG] : url: https://interop.ondilo.com/oauth2/token
[2024-03-19 09:37:03][DEBUG] : headers: Array ( [0] => Content-Type: application/x-www-form-urlencoded )
[2024-03-19 09:37:03][DEBUG] : data: Array ( [code] => XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX [grant_type] => authorization_code [client_id] => customer_api [redirect_uri] => http://192.168.1.115/plugins/ondilo/core/api/ondilo.php?action=autorize )
[2024-03-19 09:37:39][DEBUG] : url: https://interop.ondilo.com/api/customer/v1/pools/52402/lastmeasures
[2024-03-19 09:37:39][DEBUG] : headers: Array ( [0] => Accept: application/json [1] => Accept-Charset: utf-8 [2] => Accept-Encoding: gzip, deflate [3] => Authorization: Bearer 4bbb5ce950fb9ea4b1ff80c9d445abf6d23ab3b8 )
[2024-03-19 09:37:39][DEBUG] : data: Array ( [bearer] => XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX )
[2024-03-19 09:37:39][DEBUG] : lastMeasures: Array ( [0] => Array ( [data_type] => temperature [value] => 10.7 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) [1] => Array ( [data_type] => orp [value] => 571 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) [2] => Array ( [data_type] => ph [value] => 6.97 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) [3] => Array ( [data_type] => salt [value] => 2885 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) [4] => Array ( [data_type] => battery [value] => 62 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) [5] => Array ( [data_type] => rssi [value] => 100 [value_time] => 2024-03-18T16:21:07+0000 [is_valid] => 1 [exclusion_reason] => ) )
[2024-03-19 09:37:39][DEBUG] : mesure: temperature=10.7
[2024-03-19 09:37:39][DEBUG] : mesure: orp=571
[2024-03-19 09:37:39][DEBUG] : mesure: ph=6.97
[2024-03-19 09:37:39][DEBUG] : mesure: salt=2885
[2024-03-19 09:37:39][DEBUG] : mesure: battery=62
[2024-03-19 09:37:39][DEBUG] : mesure: rssi=100
Merci de votre aide.
Bonne journée,
Fabrice
