Bonjour à tous
je viens de voir que le plugin FORDCAR a une date de dernière synchro au 09/10
l’application FORDPASS fonctionne bien, mes identifiants sont OK
log :
[2023-11-04 19:17:19]DEBUG : commande python3 /var/www/html/plugins/fordcar/core/class/../../resources/fordcar.py yyyyy zzzzz XXXX refresh
File "/var/www/.local/lib/python3.7/site-packages/urllib3/connection.py", line 175, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/var/www/.local/lib/python3.7/site-packages/urllib3/util/connection.py", line 72, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name or service not known
During handling of the above exception, another exception occurred:
File "/var/www/.local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 710, in urlopen
chunked=chunked,
File "/var/www/.local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 386, in _make_request
self._validate_conn(conn)
File "/var/www/.local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 1040, in _validate_conn
conn.connect()
File "/var/www/.local/lib/python3.7/site-packages/urllib3/connection.py", line 358, in connect
self.sock = conn = self._new_conn()
File "/var/www/.local/lib/python3.7/site-packages/urllib3/connection.py", line 187, in _new_conn
self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno -2] Name or service not known
File "/var/www/.local/lib/python3.7/site-packages/requests/adapters.py", line 499, in send
timeout=timeout,
File "/var/www/.local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 786, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/var/www/.local/lib/python3.7/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='usapi.cv.ford.com', port=443): Max retries exceeded with url: /api/vehicles/v2/XXXX/status (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
File "/var/www/html/plugins/fordcar/core/class/../../resources/fordcar.py", line 289, in
r.refresh();
File "/var/www/html/plugins/fordcar/core/class/../../resources/fordcar.py", line 210, in refresh
"PUT", f"{API_URI}/api/vehicles/v2/{self.vin}/status", None, None
File "/var/www/html/plugins/fordcar/core/class/../../resources/fordcar.py", line 248, in __makeRequest
url, headers=headers, data=data, params=params
File "/var/www/.local/lib/python3.7/site-packages/requests/api.py", line 130, in put
return request("put", url, data=data, **kwargs)
File "/var/www/.local/lib/python3.7/site-packages/requests/api.py", line 59, in request
return session.request(method=method, url=url, **kwargs)
File "/var/www/.local/lib/python3.7/site-packages/requests/sessions.py", line 587, in request
resp = self.send(prep, **send_kwargs)
File "/var/www/.local/lib/python3.7/site-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/var/www/.local/lib/python3.7/site-packages/requests/adapters.py", line 565, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='usapi.cv.ford.com', port=443): Max retries exceeded with url: /api/vehicles/v2/XXXX/status (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
une idée du problème ?
merci
