Tu as le mac adresse du module pour que je puisse m’y retrouver dans les logs ? Mais je pense c’est mort.
Voila : 7c:b0:3e:aa:00:ac:7d:aa
La je sais pas la commande est bien envoyé à l’ampoule c’est tous ce que je peux dire :
[2021-02-01 15:32:29][DEBUG] : [DeviceHandler.prepare] Json arg : {'ieee': '7c:b0:3e:aa:00:ac:7d:aa', 'cmd': [{'endpoint': 3, 'cluster': 'light_color', 'command': 'move_to_color_temp', 'await': 1, 'args': ['6500', '0']}], 'allowQueue': False}
[2021-02-01 15:32:29][DEBUG] : Sending Zigbee request with tsn 86 under 87 request id, data: b'01560a64190000'
[2021-02-01 15:32:29][DEBUG] : Command Command.aps_data_request (22, 87, 0, <DeconzAddressEndpoint address_mode=2 address=0xF11A endpoint=3>, 260, 768, 1, b'\x01V
d\x19\x00\x00', 2, 0)
[2021-02-01 15:32:29][DEBUG] : Send: 0x1230001d0016005700021af1030401000301070001560a641900000200
[2021-02-01 15:32:29][DEBUG] : Frame received: 0x123000090002002257
[2021-02-01 15:32:29][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 87]
[2021-02-01 15:32:29][DEBUG] : Frame received: 0x0e31000700a600
[2021-02-01 15:32:29][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
[2021-02-01 15:32:29][DEBUG] : Command Command.aps_data_confirm (0,)
[2021-02-01 15:32:29][DEBUG] : Send: 0x04310007000000
[2021-02-01 15:32:29][DEBUG] : Frame received: 0x04310013000c002257021af103010000000000
[2021-02-01 15:32:29][DEBUG] : APS data confirm response for request with id 87: 00
[2021-02-01 15:32:29][DEBUG] : Request id: 0x57 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xf11a endpoint=3>, status: 0x00
[2021-02-01 15:32:29][DEBUG] : Frame received: 0x0e32000700aa00
[2021-02-01 15:32:29][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 0]
[2021-02-01 15:32:29][DEBUG] : Command Command.aps_data_indication (1, 1)
[2021-02-01 15:32:29][DEBUG] : Send: 0x1732000800010001
[2021-02-01 15:32:29][DEBUG] : Frame received: 0x17320023001c002202000001021af10304010003050018560b0a0000af6f5e890e00b0
[2021-02-01 15:32:29][DEBUG] : APS data indication response: [28, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xf11a>, 3, 260, 768, b'\x18V\x0b
\x00', 0, 175, 111, 94, 137, 14, 0, -80]
[2021-02-01 15:32:29][DEBUG] : [0xf11a:3:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=86 command_id=Command.Default_Response>
[2021-02-01 15:32:29][DEBUG] : 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xf11a>, ep: 3, profile: 0x0104, cluster_id: 0x0300, data: b'18560b0a00'
[2021-02-01 15:32:29][INFO] : 200 PUT /device/command (127.0.0.1) 63.32ms
Je n’en doute pas
mais l’ampoule ne change pas de température. Dommage. Je testerai avec d’autres marques. Merci d’avoir regardé.
Juste pour info
Suite à la mise a jours de cette nuit,
perte dans la configuration des informations du demon 1.
Bonne journée bon
Oui en wifizigate remplacé par gateway suite a la demande de certains utilisateurs.
Hello @akenad
J’ai vu dans tes copies d’écran que tu utilises 2 dongles différents avec le plugin zigbee : conbee2 et cc2531 … observe tu des différences de comportements entre les 2 dongles ?
Je possède la conbee 2 avec le plugin deconz mais je testerais bien ce nouveau plugin sans pour le moment me passer de deconz (gestion de variation de lumière via association bouton et ampoule dans phoscon) … un clef cc2531 (peu cher) me permettrait de faire ce test sans gros investissement…
Par avance merci
Chris94440
Merci @akenad j etais passé a coté de celui la …tu en produit tellement!!!
Hello @Loic
Sur la LIDL E14 RGB j’ai l’erreur suivante quand je modifie l’intensité et que ça tombe sur un float :
Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"84:2e:14:ff:fe:00:d3:07","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":["44.5","0"]}],"allowQueue":false} erreur : {"state":"error","result":"invalid literal for int() with base 10: '44.5'","code":0}
L’intensité n’est du coup pas prise en compte.
Aucun souci si c’est un int.
Du coup j’ai palier avec ça sur la commande action/slider
Bravo pour le taf sur ce plugin, au top ![]()
Merci pour le retour, j’ai fait une correction au niveau du code directement car il n’y a jamais de nombre a virgule en zigbee (enfin jamais vu encore). A voir si ya pas trop d’effet de bord
Bonjour @Loic
J’ai regardé la documentation sur les modules qui sont pris en charge mais il me semble que les dernières version de schneider electric sur la gamme WISER en zigbee 3.0 ne sont pas sur celles ci
Est ce que c’est la doc qui n’est pas encore à jour ou les devices WISER sont reconnus tels que par le plugin :
- SCHNEIDER ELECTRIC - ACTIONNEUR POUR RADIATEUR ÉLECTRIQUE FIL PILOTE ZIGBEE 3.0 WISER CCTFR6700
- SCHNEIDER ELECTRIC - THERMOSTAT D’AMBIANCE CONNECTÉ ZIGBEE 3.0 WISER CCTFR6400
- SCHNEIDER ELECTRIC - PRISE CONNECTÉE ET RÉPÉTEUR ZIGBEE 3.0 WISER CCTFR6500
La doc c’est quoi pour toi ? Le site compatibilité ? Si oui il est mis a jour toute les nuits donc il est forcement a jour. Si le module est pas dedans il est pas compatible tout simplement
Bonjour, une documentation sur un plugin en BETA est par définition par forcément complète normalement. Je n’avais pas vu qu’elle était mise à jour chaque nuit, d’où ma demande.
Je suppose que comme ils sont en version zigbee 3.0 il n’y a pas de raison qu’à terme ses modules devront être compatibles avec le plugin ?
Surement je ne pourrais jamais garantir qu’un module marche avant de l’avoir tester et surtout je ne peux pas non plus garantir qu’il marche (ou meme marche bien) sur toute les clef zigbee.
oui je me doute, merci de ton retour.
Hello all
Utilisateur du plugin deconz avec une conbee 2 et voulant tester ce nouveau plugin fort prometteur j’ai commandé une clef cc2531 … après 3 semaines d’attente je l’ai enfin reçue … flashée dans la foulée (merci @akenad) … inclusion pour tester d’une ampoule LIDL.
Jusque là aucun soucis … tout est fonctionnel mise à part la portée … mais je pense que c’est liée à l’antenne que j’ai prise qui est pas terrible …
Je vais partir sur ce type je pense …
Par contre lorsque je regarde l’état de mon réseau zigbee le status du contrôleur est indiqué ‹ Non initialisé › … est-ce normal ?
Le LQI correspond bien à la qualité de la connexion ? quelles sont les valeurs max et min ?
La portée est elle différente d’un channel à un autre ?
Ma clef conbee est pas loin de cette nouvelle clef … et elle est déportée du switch usb par un long câble… dois-je également déportée la clef du hub ?
@chris94440
update :
fabrication d’un pti banc de test pour vérifier la portée …
La clef cc2531 est au centre de ma maison dans mon dressins (ou pico datacenter …
) donc enfermée entre 4 murs…
Chose étrange est que les actions fonctionnent toutes aux 4 coins de la maison… même dans le garage et aux étages … mais pas le retour d’informations, ex statut de l’ampoule, ne fonctionne que sur un cercle d’environs 8/10m …
Prq le comportement est il différent en émission que en réception ?
Le comportement est il lié principalement à l’antenne ou est-ce un ensemble ?
Update: peut etre un pb de firmware … je vais en tester d autres
Bon j’avance un peu mais peu …
… j’ai l’impression que le soucis se trouve sur la commande info statut qui ne remonte pas …
Lorsque je coupe le courant et le rallume j’ai les logs suivantes :
[2021-03-05 21:18:03][DEBUG] : {"devices":{"84:2e:14:ff:fe:40:5c:a9":{"1":{"8":[{"value":"255","cluster_name":"Level control"}],"0":{"1":{"value":"80","cluster_name":"Basic"}}}}}}
[2021-03-05 21:18:03][DEBUG] : Search attribut for 84:2e:14:ff:fe:40:5c:a9 logicalId : 1::8::0 => 255
[2021-03-05 21:18:03][DEBUG] : Search attribut for 84:2e:14:ff:fe:40:5c:a9 logicalId : 1::0::1 => 80
[2021-03-05 21:18:26][DEBUG] : {"devices":{"84:2e:14:ff:fe:40:5c:a9":{"1":{"768":{"color":{"value":"#ff004b","cluster_name":"Color Control"},"7":{"value":"153","cluster_name":"Color Control"}}}}}}
[2021-03-05 21:18:26][DEBUG] : Search attribut for 84:2e:14:ff:fe:40:5c:a9 logicalId : 1::768::color => #ff004b
[2021-03-05 21:18:26][DEBUG] : Search attribut for 84:2e:14:ff:fe:40:5c:a9 logicalId : 1::768::7 => 153
et dans la log zigbeed
[2021-03-05 21:29:07][DEBUG] : Frame received: <UnpiFrame command_type=CommandType.AREQ subsystem=Subsystem.AF command_id=129 data=b"\x00\x00\x08\x00\x90 \x01\x01\x00'\x00\xe4[_\x00\x00\x07\x18\x01
\x00\x00 \xff\x90 \x1d" length=27 fcs=199>
[2021-03-05 21:29:07][DEBUG] : <-- AREQ AF incomingMsg tsn: None {'groupid': 0, 'clusterid': 8, 'srcaddr': 0x0990, 'srcendpoint': 1, 'dstendpoint': 1, 'wasbroadcast': 0, 'linkquality': 39, 'securityuse': 0, 'timestamp': 6249444, 'transseqnumber': 0, 'len': 7, 'data': b'\x18\x01
\x00\x00 \xff'}
[2021-03-05 21:29:07][INFO] : handle_message incomingMsg
[2021-03-05 21:29:07][DEBUG] : [0x0990:1:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=1 command_id=Command.Report_Attributes>
[2021-03-05 21:29:07][DEBUG] : [0x0990:1:0x0008] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=uint8_t, value=255>)]]
[2021-03-05 21:29:07][INFO] : [84:2e:14:ff:fe:40:5c:a9][listener.general_command] Cluster: <zigpy.zcl.clusters.general.LevelControl object at 0xb49c1590> ClusterId: 0x0008 command_id: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=False disable_default_response=True> manufacturer=None tsn=1 command_id=Command.Report_Attributes> args: ([[Attribute(attrid=0, value=<TypeValue type=uint8_t, value=255>)]],)
[2021-03-05 21:29:07][DEBUG] : [0x0990:1:0x0008] Attribute report received: current_level=255
[2021-03-05 21:29:07][INFO] : [84:2e:14:ff:fe:40:5c:a9][listener.attribute_updated] Received an attribute update 0=255 on cluster 8
[2021-03-05 21:29:07][DEBUG] : Frame received: <UnpiFrame command_type=CommandType.AREQ subsystem=Subsystem.AF command_id=129 data=b'\x00\x00\x00\x00\x90 \x01\x01\x00$\x00\xf4[_\x00\x00\x07\x18\x02
\x01\x00 P\x90 \x1d' length=27 fcs=113>
[2021-03-05 21:29:07][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xb52b8120>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (84:2e:14:ff:fe:40:5c:a9, 1, 8, 0, 255))
[2021-03-05 21:29:07][DEBUG] : <-- AREQ AF incomingMsg tsn: None {'groupid': 0, 'clusterid': 0, 'srcaddr': 0x0990, 'srcendpoint': 1, 'dstendpoint': 1, 'wasbroadcast': 0, 'linkquality': 36, 'securityuse': 0, 'timestamp': 6249460, 'transseqnumber': 0, 'len': 7, 'data': b'\x18\x02
\x01\x00 P'}
[2021-03-05 21:29:07][DEBUG] : [0x0990:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=2 command_id=Command.Report_Attributes>
[2021-03-05 21:29:07][DEBUG] : [0x0990:1:0x0000] ZCL request 0x000a: [[Attribute(attrid=1, value=<TypeValue type=uint8_t, value=80>)]]
[2021-03-05 21:29:07][INFO] : [84:2e:14:ff:fe:40:5c:a9][listener.general_command] Cluster: <zigpy.zcl.clusters.general.Basic object at 0xb51efa70> ClusterId: 0x0000 command_id: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=False disable_default_response=True> manufacturer=None tsn=2 command_id=Command.Report_Attributes> args: ([[Attribute(attrid=1, value=<TypeValue type=uint8_t, value=80>)]],)
[2021-03-05 21:29:07][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xb52b8120>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (84:2e:14:ff:fe:40:5c:a9, 1, 8, 0, 255)) completed
[2021-03-05 21:29:07][DEBUG] : [0x0990:1:0x0000] Attribute report received: app_version=80
[2021-03-05 21:29:07][INFO] : [84:2e:14:ff:fe:40:5c:a9][listener.attribute_updated] Received an attribute update 1=80 on cluster 0
[2021-03-05 21:29:07][DEBUG] : executing functools.partial(<built-in method commit of sqlite3.Connection object at 0xb52b8120>)
[2021-03-05 21:29:07][DEBUG] : operation functools.partial(<built-in method commit of sqlite3.Connection object at 0xb52b8120>) completed
[2021-03-05 21:29:07][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xb52b8120>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (84:2e:14:ff:fe:40:5c:a9, 1, 0, 1, 80))
[2021-03-05 21:29:07][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xb52b8120>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (84:2e:14:ff:fe:40:5c:a9, 1, 0, 1, 80)) completed
[2021-03-05 21:29:07][DEBUG] : Send to jeedom : {'devices': {'84:2e:14:ff:fe:40:5c:a9': {'1': {'8': {'0': {'value': '255', 'cluster_name': 'Level control'}}, '0': {'1': {'value': '80', 'cluster_name': 'Basic'}}}}}}
[2021-03-05 21:29:07][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2021-03-05 21:29:07][DEBUG] : http://127.0.0.1:80 "POST /plugins/zigbee/core/php/jeeZigbee.php?apikey=U671pvxsACdgsHCqx4PaeSkTyvTrRWnD HTTP/1.1" 200 0
[2021-03-05 21:29:30][DEBUG] : Frame received: <UnpiFrame command_type=CommandType.AREQ subsystem=Subsystem.AF command_id=129 data=b'\x00\x00\x00\x03\x90 \x01\x01\x00"\x00
s`\x00\x00\x12\x18\x03
\x03\x00!~(\x04\x00!6\x0e\x07\x00!\x99\x00\x90 \x1d' length=38 fcs=19>
[2021-03-05 21:29:30][DEBUG] : <-- AREQ AF incomingMsg tsn: None {'groupid': 0, 'clusterid': 768, 'srcaddr': 0x0990, 'srcendpoint': 1, 'dstendpoint': 1, 'wasbroadcast': 0, 'linkquality': 34, 'securityuse': 0, 'timestamp': 6320906, 'transseqnumber': 0, 'len': 18, 'data': b'\x18\x03
\x03\x00!~(\x04\x00!6\x0e\x07\x00!\x99\x00'}
[2021-03-05 21:29:30][INFO] : handle_message incomingMsg
[2021-03-05 21:29:30][DEBUG] : [0x0990:1:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=3 command_id=Command.Report_Attributes>
[2021-03-05 21:29:30][DEBUG] : [0x0990:1:0x0300] ZCL request 0x000a: [[Attribute(attrid=3, value=<TypeValue type=uint16_t, value=10366>), Attribute(attrid=4, value=<TypeValue type=uint16_t, value=3638>), Attribute(attrid=7, value=<TypeValue type=uint16_t, value=153>)]]
[2021-03-05 21:29:30][INFO] : [84:2e:14:ff:fe:40:5c:a9][listener.general_command] Cluster: <zigpy.zcl.clusters.lighting.Color object at 0xb49c18d0> ClusterId: 0x0300 command_id: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=False disable_default_response=True> manufacturer=None tsn=3 command_id=Command.Report_Attributes> args: ([[Attribute(attrid=3, value=<TypeValue type=uint16_t, value=10366>), Attribute(attrid=4, value=<TypeValue type=uint16_t, value=3638>), Attribute(attrid=7, value=<TypeValue type=uint16_t, value=153>)]],)
[2021-03-05 21:29:30][DEBUG] : [0x0990:1:0x0300] Attribute report received: current_x=10366, current_y=3638, color_temperature=153
[2021-03-05 21:29:30][INFO] : [84:2e:14:ff:fe:40:5c:a9][listener.attribute_updated] Received an attribute update 3=10366 on cluster 768
[2021-03-05 21:29:30][INFO] : [84:2e:14:ff:fe:40:5c:a9][listener.attribute_updated] Received an attribute update 4=3638 on cluster 768
[2021-03-05 21:29:30][INFO] : [84:2e:14:ff:fe:40:5c:a9][listener.attribute_updated] Received an attribute update 7=153 on cluster 768
[2021-03-05 21:29:30][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xb52b8120>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (84:2e:14:ff:fe:40:5c:a9, 1, 768, 3, 10366))
[2021-03-05 21:29:30][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xb52b8120>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (84:2e:14:ff:fe:40:5c:a9, 1, 768, 3, 10366)) completed
[2021-03-05 21:29:30][DEBUG] : executing functools.partial(<built-in method commit of sqlite3.Connection object at 0xb52b8120>)
[2021-03-05 21:29:30][DEBUG] : operation functools.partial(<built-in method commit of sqlite3.Connection object at 0xb52b8120>) completed
[2021-03-05 21:29:30][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xb52b8120>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (84:2e:14:ff:fe:40:5c:a9, 1, 768, 4, 3638))
[2021-03-05 21:29:30][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xb52b8120>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (84:2e:14:ff:fe:40:5c:a9, 1, 768, 4, 3638)) completed
[2021-03-05 21:29:30][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xb52b8120>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (84:2e:14:ff:fe:40:5c:a9, 1, 768, 7, 153))
[2021-03-05 21:29:30][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xb52b8120>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (84:2e:14:ff:fe:40:5c:a9, 1, 768, 7, 153)) completed
[2021-03-05 21:29:30][DEBUG] : Send to jeedom : {'devices': {'84:2e:14:ff:fe:40:5c:a9': {'1': {'768': {'color': {'value': '#4a26ff', 'cluster_name': 'Color Control'}, '7': {'value': '153', 'cluster_name': 'Color Control'}}}}}}
[2021-03-05 21:29:30][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2021-03-05 21:29:30][DEBUG] : http://127.0.0.1:80 "POST /plugins/zigbee/core/php/jeeZigbee.php?apikey=U671pvxsACdgsHCqx4PaeSkTyvTrRWnD HTTP/1.1" 200 0
On voit des infos sur la couleur et la luminosité mais pas sur le statut de la lampe … celui n’a l’air de fonctionner que si interaction depuis jeedom … sauf si la lampe est tres proche de la clef
pour info j’ai essayé avec le firmware CC2531_SOURCE_ROUTING_20201128
Demain j essai de l inclure dans deconz pour verifier que le soucis vient pas de l ampoule
Petit bug :
lorsque les #plugin-zigbee et #plugin-zigbee2mqtt (alias plugin zigbeelinker) sont installés, si on regarde les boutons logs dans la configuration des plugins, les boutons logs zigbee2mqtt apparaissent comme bouton logs dans le plugin-zigbee.
Cela est du au fait que le plugin-zigbee affiche probablement des boutons pour toutes les logs commençant par « Zigbee ».
akenad
Oui ça malheureusement je peux rien y faire… Il cherche tous les logs commençant par zigbee pour avoir ceux des dépendances, des deamon et autres…
