voici les log du demon ZIGBEE, après réinstallation des dépendances et un rafraichissement du reseau
zigbeed_1.txt (58,8 Ko)
[2021-04-18 08:10:07][DEBUG] : Read parameter nwk_update_id response: [3]
[2021-04-18 08:10:07][DEBUG] : device: 0x8dfb - _TZ3000_wamqdr3f TS011F, FFD=True, Rx_on_when_idle=True
[2021-04-18 08:10:07][DEBUG] : device: 0x8ebf - _TYZB01_qezuin6k TS110F, FFD=True, Rx_on_when_idle=True
[2021-04-18 08:10:07][INFO] : [00:21:2e:ff:ff:06:bc:5a][listener.device_initialized] new=False
[2021-04-18 08:10:07][INFO] : [bc:33:ac:ff:fe:a8:60:7c][listener.device_initialized] new=False
[2021-04-18 08:10:07][INFO] : [5c:02:72:ff:fe:2c:44:d4][listener.device_initialized] new=False
[2021-04-18 08:10:07][INFO] : [04:cf:8c:df:3c:78:c0:b6][listener.device_initialized] new=False
[2021-04-18 08:10:07][INFO] : [00:12:4b:00:22:34:46:64][listener.device_initialized] new=False
[2021-04-18 08:10:07][INFO] : [5c:02:72:ff:fe:83:c4:c0][listener.device_initialized] new=False
[2021-04-18 08:10:08][INFO] : [00:12:4b:00:22:31:2b:02][listener.device_initialized] new=False
[2021-04-18 08:10:08][INFO] : [00:12:4b:00:22:ec:59:00][listener.device_initialized] new=False
[2021-04-18 08:10:08][INFO] : [84:71:27:ff:fe:19:cf:89][listener.device_initialized] new=False
[2021-04-18 08:10:08][DEBUG] : [start_zigbee] Init and start http server : {'database_path': '/var/www/html/plugins/zigbee/data/1/network_deconz.db', 'device': {'path': '/dev/ttyACM0'}, 'network': {'channel': 11}}
[2021-04-18 08:10:08][DEBUG] : [start_zigbee] Start zigbee network
[2021-04-18 08:10:24][DEBUG] : Frame received: 0x0e16000700aa00
[2021-04-18 08:10:24][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 0]
[2021-04-18 08:10:24][DEBUG] : Command Command.aps_data_indication (1, 1)
[2021-04-18 08:10:24][DEBUG] : Send: 0x1716000800010001
[2021-04-18 08:10:24][DEBUG] : Frame received: 0x17160025001e002202000001029b130104010100070018bc0a2000201f00afff7c622200df
[2021-04-18 08:10:24][DEBUG] : APS data indication response: [30, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x139b>, 1, 260, 1, b'\x18\xbc
\x00 \x1f', 0, 175, 255, 124, 98, 34, 0, -33]
[2021-04-18 08:10:24][DEBUG] : [0x139b:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=188 command_id=Command.Report_Attributes>
[2021-04-18 08:10:24][DEBUG] : [0x139b:1:0x0001] ZCL request 0x000a: [[Attribute(attrid=32, value=<TypeValue type=uint8_t, value=31>)]]
[2021-04-18 08:10:24][INFO] : [04:cf:8c:df:3c:78:c0:b6][listener.general_command] Cluster: <zhaquirks.PowerConfigurationCluster object at 0x7fac4c2940> ClusterId: 0x0001 command_id: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=False disable_default_response=True> manufacturer=None tsn=188 command_id=Command.Report_Attributes> args: ([[Attribute(attrid=32, value=<TypeValue type=uint8_t, value=31>)]],)
[2021-04-18 08:10:24][DEBUG] : [0x139b:1:0x0001] Attribute report received: battery_voltage=31
[2021-04-18 08:10:24][INFO] : [04:cf:8c:df:3c:78:c0:b6][listener.attribute_updated] Received an attribute update 32=31 on cluster 1
[2021-04-18 08:10:24][DEBUG] : [0x139b:1:0x0001] Voltage [RAW]:31 [Max]:2.8 [Min]:1.5, Battery Percent: 100.0
[2021-04-18 08:10:24][INFO] : [04:cf:8c:df:3c:78:c0:b6][listener.attribute_updated] Received an attribute update 33=200 on cluster 1
[2021-04-18 08:10:24][DEBUG] : 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x139b>, ep: 1, profile: 0x0104, cluster_id: 0x0001, data: b'18bc0a2000201f'
[2021-04-18 08:10:24][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7facd67e30>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (04:cf:8c:df:3c:78:c0:b6, 1, 1, 32, 31))
[2021-04-18 08:10:24][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0x7facd67e30>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (04:cf:8c:df:3c:78:c0:b6, 1, 1, 32, 31)) completed
[2021-04-18 08:10:24][DEBUG] : executing functools.partial(<built-in method commit of sqlite3.Connection object at 0x7facd67e30>)
[2021-04-18 08:10:24][DEBUG] : operation functools.partial(<built-in method commit of sqlite3.Connection object at 0x7facd67e30>) completed
[2021-04-18 08:10:24][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7facd67e30>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (04:cf:8c:df:3c:78:c0:b6, 1, 1, 33, 200))
[2021-04-18 08:10:24][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0x7facd67e30>, 'INSERT OR REPLACE INTO attributes VALUES (?, ?, ?, ?, ?)', (04:cf:8c:df:3c:78:c0:b6, 1, 1, 33, 200)) completed
[2021-04-18 08:10:24][DEBUG] : Send to jeedom : {'devices': {'04:cf:8c:df:3c:78:c0:b6': {'1': {'1': {'32': {'value': '31', 'cluster_name': 'Power Configuration'}, '33': {'value': '200', 'cluster_name': 'Power Configuration'}}}}}}
[2021-04-18 08:10:24][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2021-04-18 08:10:24][DEBUG] : http://127.0.0.1:80 "POST /plugins/zigbee/core/php/jeeZigbee.php?apikey=05GuuscvB7miqS1AugbTCRdpBaulydwK HTTP/1.1" 200 0
[2021-04-18 08:12:25][DEBUG] : [DeviceHandler.prepare] Json arg : {'ieee': 'bc:33:ac:ff:fe:a8:60:7c', 'cmd': [{'endpoint': 1, 'cluster': 'on_off', 'command': 'on', 'await': 1}], 'allowQueue': False}
[2021-04-18 08:12:25][DEBUG] : Sending Zigbee request with tsn 1 under 2 request id, data: b'010101'
[2021-04-18 08:12:25][DEBUG] : Command Command.aps_data_request (18, 2, 0, <DeconzAddressEndpoint address_mode=2 address=0x99A4 endpoint=1>, 260, 6, 1, b'\x01\x01\x01', 2, 0)
[2021-04-18 08:12:25][DEBUG] : Send: 0x12170019001200020002a49901040106000103000101010200
[2021-04-18 08:12:25][DEBUG] : Frame received: 0x121700090002002202
[2021-04-18 08:12:25][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 2]
[2021-04-18 08:12:25][DEBUG] : Frame received: 0x0e18000700a600
[2021-04-18 08:12:25][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
[2021-04-18 08:12:25][DEBUG] : Command Command.aps_data_confirm (0,)
[2021-04-18 08:12:25][DEBUG] : Send: 0x04180007000000
[2021-04-18 08:12:25][DEBUG] : Frame received: 0x04180013000c00220202a4990101e100000000
[2021-04-18 08:12:25][DEBUG] : APS data confirm response for request with id 2: e1
[2021-04-18 08:12:25][DEBUG] : Request id: 0x02 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0x99a4 endpoint=1>, status: 0xe1
[2021-04-18 08:12:25][DEBUG] : Error while sending 2 req id frame: TXStatus.MAC_CHANNEL_ACCESS_FAILURE
[2021-04-18 08:12:25][DEBUG] : [0x99a4] Delivery error for seq # 0x01, on endpoint id 1 cluster 0x0006: message send failure
[2021-04-18 08:12:25][DEBUG] : Traceback (most recent call last):
File "/var/www/html/plugins/zigbee/resources/zigbeed/restServer.py", line 240, in put
await zdevices.command(self.json_args)
File "/var/www/html/plugins/zigbee/resources/zigbeed/zdevices.py", line 69, in command
await command()
File "/usr/local/lib/python3.7/dist-packages/zigpy/device.py", line 218, in request
self.nwk, dst_ep, cluster
zigpy.exceptions.DeliveryError: [0x99a4:1:0x0006]: Message send failure
[2021-04-18 08:12:25][INFO] : 200 PUT /device/command (127.0.0.1) 240.05ms
[2021-04-18 08:12:28][DEBUG] : [DeviceHandler.prepare] Json arg : {'ieee': 'bc:33:ac:ff:fe:a8:60:7c', 'cmd': [{'endpoint': 1, 'cluster': 'on_off', 'command': 'off', 'await': 1}], 'allowQueue': False}
[2021-04-18 08:12:28][DEBUG] : Sending Zigbee request with tsn 3 under 4 request id, data: b'010300'
[2021-04-18 08:12:28][DEBUG] : Command Command.aps_data_request (18, 4, 0, <DeconzAddressEndpoint address_mode=2 address=0x99A4 endpoint=1>, 260, 6, 1, b'\x01\x03\x00', 2, 0)
[2021-04-18 08:12:28][DEBUG] : Send: 0x12190019001200040002a49901040106000103000103000200
[2021-04-18 08:12:28][DEBUG] : Frame received: 0x121900090002002204
[2021-04-18 08:12:28][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 4]
[2021-04-18 08:12:29][DEBUG] : Frame received: 0x0e1a000700a600
[2021-04-18 08:12:29][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
[2021-04-18 08:12:29][DEBUG] : Command Command.aps_data_confirm (0,)
[2021-04-18 08:12:29][DEBUG] : Send: 0x041a0007000000
[2021-04-18 08:12:29][DEBUG] : Frame received: 0x041a0013000c00220402a4990101e100000000
[2021-04-18 08:12:29][DEBUG] : APS data confirm response for request with id 4: e1
[2021-04-18 08:12:29][DEBUG] : Request id: 0x04 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0x99a4 endpoint=1>, status: 0xe1
[2021-04-18 08:12:29][DEBUG] : Error while sending 4 req id frame: TXStatus.MAC_CHANNEL_ACCESS_FAILURE
[2021-04-18 08:12:29][DEBUG] : [0x99a4] Delivery error for seq # 0x03, on endpoint id 1 cluster 0x0006: message send failure
[2021-04-18 08:12:29][DEBUG] : Traceback (most recent call last):
await command()
[2021-04-18 08:12:29][INFO] : 200 PUT /device/command (127.0.0.1) 148.18ms
[2021-04-18 08:12:34][DEBUG] : [ApplicationHandler.prepare] Json arg : None
[2021-04-18 08:12:34][INFO] : 200 GET /application/info (127.0.0.1) 6.68ms
[2021-04-18 08:12:34][DEBUG] : [NetworkHandler.prepare] Json arg : None
[2021-04-18 08:12:34][DEBUG] : [map.scan] Done scanning. Total 2 neighbours
[2021-04-18 08:12:34][DEBUG] : [map.scan] Done scanning. Total 0 neighbours
[2021-04-18 08:12:34][INFO] : 200 GET /network/map (127.0.0.1) 11.46ms
[2021-04-18 08:12:34][DEBUG] : [DeviceHandler.prepare] Json arg : None
[2021-04-18 08:12:34][DEBUG] : [0x99a4:1] Manufacturer: _TZ3000_dbou1ap4
[2021-04-18 08:12:34][DEBUG] : [0x99a4:1] Model: TS0505A
[2021-04-18 08:12:34][DEBUG] : [0x8dfb:11] Manufacturer: _TZ3000_wamqdr3f
[2021-04-18 08:12:34][DEBUG] : [0x8dfb:11] Model: TS011F
[2021-04-18 08:12:34][DEBUG] : [0x139b:1] Manufacturer: LUMI
[2021-04-18 08:12:34][DEBUG] : [0x139b:1] Model: lumi.sen_ill.mgl01
[2021-04-18 08:12:34][DEBUG] : [0x00d3:1] Manufacturer: eWeLight
[2021-04-18 08:12:34][DEBUG] : [0x00d3:1] Model: ZB-CL01
[2021-04-18 08:12:34][DEBUG] : [0x1e6f:1] Manufacturer: _TYZB01_bngwdjsr
[2021-04-18 08:12:34][DEBUG] : [0x1e6f:1] Model: TS1001
[2021-04-18 08:12:34][DEBUG] : [0x82b7:1] Manufacturer: eWeLight
[2021-04-18 08:12:34][DEBUG] : [0x82b7:1] Model: ZB-CL01
[2021-04-18 08:12:34][DEBUG] : [0xcd83:1] Manufacturer: eWeLink
[2021-04-18 08:12:34][DEBUG] : [0xcd83:1] Model: MS01
[2021-04-18 08:12:34][DEBUG] : [0x8ebf:1] Manufacturer: _TYZB01_qezuin6k
[2021-04-18 08:12:34][DEBUG] : [0x8ebf:1] Model: TS110F
[2021-04-18 08:12:34][INFO] : 200 GET /device/all?with_attributes=0 (127.0.0.1) 32.26ms
[2021-04-18 08:12:37][DEBUG] : [NetworkHandler.prepare] Json arg : None
[2021-04-18 08:12:37][DEBUG] : [map.scan] Done scanning. Total 2 neighbours
[2021-04-18 08:12:37][DEBUG] : [map.scan] Done scanning. Total 0 neighbours
[2021-04-18 08:12:37][INFO] : 200 GET /network/map (127.0.0.1) 12.86ms
[2021-04-18 08:12:52][DEBUG] : [DeviceHandler.prepare] Json arg : {'ieee': '00:21:2e:ff:ff:06:bc:5a'}
[2021-04-18 08:12:52][WARNING] : [00:21:2e:ff:ff:06:bc:5a][zdevices.get_basic_info] Begin get basic info from device
[2021-04-18 08:12:52][WARNING] : [00:21:2e:ff:ff:06:bc:5a][zdevices.get_basic_info] End point found
[2021-04-18 08:12:52][DEBUG] : Sending Zigbee request with tsn 5 under 6 request id, data: b'00050004000500'
[2021-04-18 08:12:52][DEBUG] : Command Command.aps_data_request (22, 6, 0, <DeconzAddressEndpoint address_mode=2 address=0x0000 endpoint=1>, 260, 0, 1, b'\x00\x05\x00\x04\x00\x05\x00', 2, 0)
[2021-04-18 08:12:52][DEBUG] : Send: 0x121b001d00160006000200000104010000010700000500040005000200
[2021-04-18 08:12:52][DEBUG] : Frame received: 0x121b00090002002206
[2021-04-18 08:12:52][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 6]
[2021-04-18 08:12:52][DEBUG] : Frame received: 0x0e1c000700ae00
[2021-04-18 08:12:52][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|APSDE_DATA_CONFIRM|2: 174>, 0]
[2021-04-18 08:12:52][DEBUG] : Command Command.aps_data_indication (1, 1)
[2021-04-18 08:12:52][DEBUG] : Send: 0x171c000800010001
[2021-04-18 08:12:52][DEBUG] : Frame received: 0x171c0025001e002602000001020000010401000007000005000400050000af23896222000c
[2021-04-18 08:12:52][DEBUG] : APS data indication response: [30, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 38>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, 260, 0, b'\x00\x05\x00\x04\x00\x05\x00', 0, 175, 35, 137, 98, 34, 0, 12]
[2021-04-18 08:12:52][DEBUG] : [0x0000:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=5 command_id=Command.Read_Attributes>
[2021-04-18 08:12:52][DEBUG] : [0x0000:1:0x0000] ZCL request 0x0000: [[4, 5]]
[2021-04-18 08:12:52][INFO] : [00:21:2e:ff:ff:06:bc:5a][listener.general_command] Cluster: <zigpy.zcl.clusters.general.Basic object at 0x7fac4b2710> ClusterId: 0x0000 command_id: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=5 command_id=Command.Read_Attributes> args: ([[4, 5]],)
[2021-04-18 08:12:52][DEBUG] : 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, ep: 1, profile: 0x0104, cluster_id: 0x0000, data: b'00050004000500'
