plugin-ZIGBEE Beta
Bonjour a tous petit souci sur cette interupteur tuya zigbee
bien reconnu en temps que tel mais non fonctionel pour ma part
je suis sur zigate usb ttl …dernier firmware a jour
voici les info brut
    "ieee": "84:71:27:ff:fe:d0:91:87",
    "nwk": 25185,
    "status": 2,
    "lqi": "93",
    "rssi": "0",
    "last_seen": "1616239847.9573977",
    "node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 6,
            "profile_id": 260,
            "manufacturer": "_TZ3000_vp6clf9d",
            "model": "TS0044",
            "output_clusters": [
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 67
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_vp6clf9d"
                            "id": 5,
                            "name": "model",
                            "value": "TS0044"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": [
                            "id": 33,
                            "name": "battery_percentage_remaining",
                            "value": 134
                    "id": 6,
                    "name": "TS004X_cluster",
                    "attributes": []
            "id": 2,
            "status": 1,
            "device_type": 6,
            "profile_id": 260,
            "manufacturer": null,
            "model": null,
            "output_clusters": [],
            "input_clusters": [
                    "id": 1,
                    "attributes": []
                    "id": 6,
                    "attributes": []
            "id": 3,
            "status": 1,
            "device_type": 6,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 1,
                    "attributes": []
                    "id": 6,
                    "attributes": []
            "id": 4,
            "status": 1,
            "device_type": 6,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 1,
                    "attributes": []
                    "id": 6,
                    "attributes": []
    "signature": {
        "model": "TS0044",
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
            "mac_capability_flags": 128,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 6,
                "input_clusters": [
                    0,
                    1,
                    6
                    10,
                    25
            "2": {
                "profile_id": 260,
                "device_type": 6,
                "input_clusters": [
                    1,
                    6
            "3": {
                "profile_id": 260,
                "device_type": 6,
                "input_clusters": [
                    1,
                    6
            "4": {
                "profile_id": 260,
                "device_type": 6,
                "input_clusters": [
                    1,
                    6
    "class": "zhaquirks.tuya.ts0044"
je rajoute le log d’installation des dependances
Launch install of zigbee dependancy
Get:1 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Hit:2 http://deb.debian.org/debian buster InRelease
Get:3 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
Get:5 http://security.debian.org/debian-security buster/updates/main Sources [179 kB]
Fetched 296 kB in 1s (306 kB/s)
Reading package lists...
Skipping serial as it is not installed.
Building dependency tree...
Reading state information...
The following packages will be REMOVED:
python3-serial
0 upgraded, 0 newly installed, 1 to remove and 2 not upgraded.
After this operation, 379 kB disk space will be freed.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 68712 files and directories currently installed.)
Removing python3-serial (3.4-4) ...
python3-pip is already the newest version (18.1-5).
python3-setuptools is already the newest version (40.8.0-1).
python3 is already the newest version (3.7.3-1).
python3-dev is already the newest version (3.7.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.21.0-1).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Cache entry deserialization failed, entry ignored
Requirement already up-to-date: wheel in /usr/local/lib/python3.7/dist-packages (0.36.2)
Collecting pyserial
Using cached https://files.pythonhosted.org/packages/07/bc/587a445451b253b285629263eb51c2d8e9bcea4fc97826266d186f96f558/pyserial-3.5-py2.py3-none-any.whl
Installing collected packages: pyserial
Successfully installed pyserial-3.5
Collecting zigpy
Downloading https://files.pythonhosted.org/packages/da/15/c7953e3a34d710adae37e32bc7609855b6f0f95b589d821340f2074cb301/zigpy-0.33.0-py3-none-any.whl (117kB)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.12.1)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.9.9)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.7.3)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.16.1)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (5.1.0)
Collecting chardet<4.0,>=2.0 (from aiohttp->zigpy)
Downloading https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl (133kB)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (20.3.0)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (3.7.4.3)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (1.6.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (3.0.1)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy) (2.10)
Installing collected packages: zigpy, chardet
Found existing installation: zigpy 0.32.0
Uninstalling zigpy-0.32.0:
Successfully uninstalled zigpy-0.32.0
Found existing installation: chardet 4.0.0
Uninstalling chardet-4.0.0:
Successfully uninstalled chardet-4.0.0
Successfully installed chardet-3.0.4 zigpy-0.33.0
Collecting bellows
Downloading https://files.pythonhosted.org/packages/16/65/ba637a9e135606a1545d237c9912d07a4f682745020bd0fdea2fcd42958a/bellows-0.23.1-py3-none-any.whl (167kB)
Collecting click-log>=0.2.1 (from bellows)
Downloading https://files.pythonhosted.org/packages/38/52/a9dbb622f40ceeb09df141d855062cc9fbb38011f0ad8caee0cd840f399c/click_log-0.3.2-py2.py3-none-any.whl
Requirement already satisfied, skipping upgrade: click in /usr/local/lib/python3.7/dist-packages (from bellows) (7.1.2)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from bellows) (0.12.1)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from bellows) (0.5)
Requirement already satisfied, skipping upgrade: pure-pcapy3==1.0.1 in /usr/local/lib/python3.7/dist-packages (from bellows) (1.0.1)
Requirement already satisfied, skipping upgrade: zigpy>=0.21.0 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.33.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->bellows) (3.5)
Requirement already satisfied, skipping upgrade: setuptools in /usr/local/lib/python3.7/dist-packages (from pure-pcapy3==1.0.1->bellows) (53.0.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (3.7.3)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (3.9.9)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.21.0->bellows) (0.16.1)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (3.0.1)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (20.3.0)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (3.0.4)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (1.6.3)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (3.7.4.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.21.0->bellows) (5.1.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.21.0->bellows) (2.10)
Installing collected packages: click-log, bellows
Found existing installation: click-log 0.2.0
Uninstalling click-log-0.2.0:
Successfully uninstalled click-log-0.2.0
Found existing installation: bellows 0.21.0
Uninstalling bellows-0.21.0:
Successfully uninstalled bellows-0.21.0
Successfully installed bellows-0.23.1 click-log-0.3.2
Collecting zha-quirks
Downloading https://files.pythonhosted.org/packages/c4/c4/2c21d115a47d750fbfd9b49b95f2b9ce781d0fca676fe696c082b455871c/zha_quirks-0.0.54-py3-none-any.whl (206kB)
Requirement already satisfied, skipping upgrade: zigpy>=0.32.0 in /usr/local/lib/python3.7/dist-packages (from zha-quirks) (0.33.0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.32.0->zha-quirks) (1.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.32.0->zha-quirks) (3.9.9)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.32.0->zha-quirks) (0.12.1)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.32.0->zha-quirks) (3.7.3)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.32.0->zha-quirks) (0.16.1)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (3.0.1)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (20.3.0)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (5.1.0)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (3.0.4)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (3.7.4.3)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (1.6.3)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.32.0->zha-quirks) (2.10)
Installing collected packages: zha-quirks
Found existing installation: zha-quirks 0.0.53
Uninstalling zha-quirks-0.0.53:
Successfully uninstalled zha-quirks-0.0.53
Successfully installed zha-quirks-0.0.54
Collecting zigpy_znp
Downloading https://files.pythonhosted.org/packages/70/bc/854b0163b55a8265a8bb339d0dfa92d239e74a1898f94d90bd1cad750fca/zigpy_znp-0.4.0-py3-none-any.whl (108kB)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.12.1)
Requirement already satisfied, skipping upgrade: zigpy>=0.25.0 in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.33.0)
Requirement already satisfied, skipping upgrade: coloredlogs in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (15.0)
Requirement already satisfied, skipping upgrade: async-timeout in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (3.0.1)
Requirement already satisfied, skipping upgrade: pyserial-asyncio; platform_system != "Windows" in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.5)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (0.16.1)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (3.9.9)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (1.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.25.0->zigpy_znp) (3.7.3)
Requirement already satisfied, skipping upgrade: humanfriendly>=9.1 in /usr/local/lib/python3.7/dist-packages (from coloredlogs->zigpy_znp) (9.1)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio; platform_system != "Windows"->zigpy_znp) (3.5)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.25.0->zigpy_znp) (3.7.4.3)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (1.6.3)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (3.0.4)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (5.1.0)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.25.0->zigpy_znp) (20.3.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.25.0->zigpy_znp) (2.10)
Installing collected packages: zigpy-znp
Found existing installation: zigpy-znp 0.3.0
Uninstalling zigpy-znp-0.3.0:
Successfully uninstalled zigpy-znp-0.3.0
Successfully installed zigpy-znp-0.4.0
Requirement already up-to-date: zigpy-xbee in /usr/local/lib/python3.7/dist-packages (0.13.0)
Requirement already satisfied, skipping upgrade: zigpy>=0.23.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.33.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.5)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.16.1)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.9.9)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.12.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (1.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.7.3)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-xbee) (3.5)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.23.0->zigpy-xbee) (3.7.4.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.1)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.4)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (5.1.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (1.6.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (20.3.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.23.0->zigpy-xbee) (2.10)
Requirement already up-to-date: zigpy-deconz in /usr/local/lib/python3.7/dist-packages (0.11.1)
Requirement already satisfied, skipping upgrade: zigpy>=0.24.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.33.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.5)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (0.12.1)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (3.9.9)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (0.16.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (1.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.24.0->zigpy-deconz) (3.7.3)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-deconz) (3.5)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.24.0->zigpy-deconz) (3.7.4.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (3.0.1)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (5.1.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (1.6.3)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (3.0.4)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.24.0->zigpy-deconz) (20.3.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.24.0->zigpy-deconz) (2.10)
Requirement already up-to-date: zigpy-zigate in /usr/local/lib/python3.7/dist-packages (0.7.4)
Requirement already satisfied, skipping upgrade: pyusb in /usr/lib/python3/dist-packages (from zigpy-zigate) (1.0.2)
Requirement already satisfied, skipping upgrade: zigpy>=0.22.2 in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.33.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.5)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.16.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (1.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.9.9)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.7.3)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.12.1)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-zigate) (3.5)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.22.2->zigpy-zigate) (3.7.4.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (20.3.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (1.6.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.1)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.4)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (5.1.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.22.2->zigpy-zigate) (2.10)
Requirement already up-to-date: zigpy-cc in /usr/local/lib/python3.7/dist-packages (0.5.2)
Requirement already satisfied, skipping upgrade: zigpy>=0.23.1 in /usr/local/lib/python3.7/dist-packages (from zigpy-cc) (0.33.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-cc) (0.5)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (3.7.3)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (0.16.1)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (3.9.9)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (0.12.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.1->zigpy-cc) (1.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-cc) (3.5)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (3.7.4.3)
Requirement already satisfied, skipping upgrade: chardet<4.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (3.0.4)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (3.0.1)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (5.1.0)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (20.3.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.1->zigpy-cc) (1.6.3)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.23.1->zigpy-cc) (2.10)
Requirement already up-to-date: tornado in /usr/local/lib/python3.7/dist-packages (6.1)
Everything is successfully installed!
3 messages ont été fusionnés à un sujet existant : plugin-ZIGBEE Beta BlaBla
En complément à mon dernier message, il y a une différence entre l’interrupteur double (ayant la partie puissance) et la commande sans fil seule.
Existe en version mono ou double inter. Ca fait 4 références différentes.
C’est idem pour les volets
Concernant le plugin, il semble y avoir l’inter double mais pas la commande sans fil double que j’ai spécifié dans mon message afin que tu puisses l’intégrer.
Idem pour la commande sans fil de volet
Lut, une question : à terme une fois le plugin en stable, les JSON de config des modules seront externalisés (dépôt GIT à part) ? Ca permettrait de pouvoir les mettre à jours sans mettre à jour le plugin trop souvent, voir même faciliter les Pull Request…
Merci ca sera corrigé dans la beta de demain
Je ne pense pas car ca complique mon travails
@Loic
Tout d’abord, merci pour votre travail.
J’ai une question concernant votre module « Zigbee Curtain Moude » QS-Zigbee-C01 "(je laisse le message d’origine ci-dessous)
Il m’est impossible de définir le temps d’action. Par défaut, il est de 10 secondes. Les stores ont besoin d’un peu plus de temps.
Serait-il possible d’ajouter l’option de réglage de l’heure?
Merci à nouveau.
Je ne sais pas ce que veux dire : temps d’action…
Le temps que l’action de lever ou d’abaisser le store s’exécute.
Désolé pour la différence linguistique, j’utilise un traducteur.
A ok j’ai rien dans le zigbee pour agir la dessus et aucune idée de comment ca marche, normalement c’est automatique il faudrait donc voir avec le fabricant du module.
Aucune requête ou question particulière ici.
Juste des remerciements : j’utilise ce plugin depuis maintenant quelques semaines et je trouve que, question intégration, c’est vraiment le top. Merci pour le travail.
Le fait de pouvoir avoir 2 daemons avec 2 gateways distinctes, c’est vraiment super. Pour info : je n’ai trouvé nul part ailleurs cette possibilité. Pour tout avouer, ayant été plus que séduit par son interface, j’étais à deux doigts de passer à Home Assistant, mais c’est le plugin Zigbee qui m’a retenu chez Jeedom.
J’utilise 2 gateways Lidl/Silvercrest hackées (merci à Paul Banks pour le travail), une dans mon appartement et une dans mon atelier, situé au sous-sol et ça marche nickel.
Voir début de réponse ici ?
Deja lu relu et rerelu ca n’a pas se sens au niveau zigbee ya une transformation faite derriere que je ne connais pas. Au niveau zigbee je n’ai pas de commande de calibration https://github.com/zigpy/zigpy/blob/dev/zigpy/zcl/clusters/closures.py#L430
Je pense que dans votre application mobile, gardez la possibilité de configurer le temps d’action, comme je le vois dans une vidéo YouTube.
Serait-ce l’id10? Je ne sais pas si c’est possible.
En revanche, s’il n’est pas possible de le faire directement depuis le plugin … serait-il utile d’acheter votre passerelle pour changer la configuration par défaut de 10s?
Tu peux essayer de changer la valeur du 10 depuis la configuration du module dans jeedom voir si c’est ca car la comme ca je peux pas te repondre.
J’essaierai. Je te le dirai dans un moment.
Ca c’est le cluster time c’est pour donner l’heure au module rien a voir avec le temps de monté/descente
Pouvez-vous penser à faire quelque chose?
Si vous le souhaitez, vous pouvez laisser une connexion à tester.
Malheureusement je peux rien faire tant que le fabricant ne donne pas l’information sur comment lancer un calibrage ou modifier le reglage a la main je ne peux rien faire.
