plugin-ZIGBEE Beta
Bonjour @Loic ,
Serait-il possible d’ajouter ce nouveau modèle d’ampoule ? Il s’agit d’un modèle d’ampoule Led intelligente 5W RGBCW 12V MR16 Tuya, RGB avec en plus des LED blanc froid et chaud, et donc réglage de la couleur de blanc, et de l’intensité.
    "ieee": "00:12:4b:00:22:6d:63:01",
    "nwk": 61671,
    "status": 2,
    "lqi": "255",
    "rssi": "-55",
    "last_seen": "1615994823.2138467",
    "node_descriptor": "01:40:8e:00:00:50:a0:00:00:00:a0:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 528,
            "profile_id": 49246,
            "manufacturer": "eWeLight",
            "model": "ZB-CL01",
            "output_clusters": [],
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 1
                            "id": 1,
                            "name": "app_version",
                            "value": 13
                            "id": 2,
                            "name": "stack_version",
                            "value": 2
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "eWeLight"
                            "id": 5,
                            "name": "model",
                            "value": "ZB-CL01"
                            "id": 6,
                            "name": "date_code",
                            "value": "20201216"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "1.0.13"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 8,
                    "name": "Level control",
                    "attributes": []
                    "id": 768,
                    "name": "Color Control",
                    "attributes": []
            "id": 13,
            "status": 1,
            "device_type": 57694,
            "manufacturer": null,
            "model": null,
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
            "input_clusters": [
                    "id": 4096,
                    "attributes": []
    "signature": {
        "model": "ZB-CL01",
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "mac_capability_flags": 142,
            "manufacturer_code": 0,
            "maximum_buffer_size": 80,
            "maximum_incoming_transfer_size": 160,
            "server_mask": 0,
            "maximum_outgoing_transfer_size": 160,
        "endpoints": {
            "1": {
                "device_type": 528,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    8,
                    768
            "13": {
                "input_clusters": [
                    4096
                    4096
    "class": "zigpy.device"
lampe_spot_RGBCW_2-removebg-preview
Merci d’avance.
Un autre micromodule double switch sans neutre à ajouter
    "ieee": "84:71:27:ff:fe:0f:ee:86",
    "nwk": 36311,
    "status": 2,
    "lqi": "255",
    "rssi": "-56",
    "last_seen": "1616005539.2120028",
    "node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TZ3000_4js9lo5d",
            "model": "TS0012",
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 66
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "_TZ3000_4js9lo5d"
                            "id": 5,
                            "name": "model",
                            "value": "TS0012"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 3
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "name": "off_wait_time",
                            "value": 0
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
    "signature": {
        "model": "TS0012",
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
            "mac_capability_flags": 128,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    4,
                    5,
                    6
                    25,
                    10
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
516ezZuy6sL.AC_SL1000-removebg-preview
Merci d’avance @Loic :slight_smile:
Json déjà transmis ici
Je n’avais pas vu ce topic, merci :slight_smile:
Bonjour Loïc,
serait il possible de rajouter ce capteur de température et d’humidité :
    "ieee": "08:6b:d7:ff:fe:91:5e:af",
    "nwk": 60007,
    "status": 2,
    "lqi": "255",
    "rssi": "-49",
    "last_seen": "1616015205.3601403",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 770,
            "profile_id": 260,
            "manufacturer": "Konke",
            "model": "3AFE140103020000",
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 20
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "Konke"
                            "id": 5,
                            "name": "model",
                            "value": "3AFE140103020000"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 0
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": [
                            "id": 32,
                            "name": "battery_voltage",
                            "value": 28
                            "id": 33,
                            "name": "battery_percentage_remaining",
                            "value": 200
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1026,
                    "name": "Temperature Measurement",
                    "attributes": [
                            "id": 0,
                            "name": "measured_value",
                            "value": 1860
                    "id": 1029,
                    "name": "Relative Humidity Measurement",
                    "attributes": []
    "signature": {
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 770,
                "input_clusters": [
                    0,
                    1,
                    3,
                    1026,
                    1029
                    3
    "class": "zhaquirks.konke.temp"
konke temp
Merci !
Merci pour le travil effectué sur ce plugin qui, dans mon cas, fonctionne déjà mieux que deconz.
Serait-il possible d’ajouter le capteur d’inondation suivant (qui remonte normalement deux infos: présence d’eau et température):
    "ieee": "00:15:8d:00:06:51:7d:1e",
    "nwk": 9236,
    "status": 2,
    "lqi": "255",
    "rssi": "-54",
    "last_seen": "1616016836.1581962",
    "node_descriptor": "02:40:80:37:10:7f:64:00:00:00:64:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 1026,
            "profile_id": 260,
            "manufacturer": "LUMI",
            "model": "lumi.sensor_wleak.aq1",
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "BasicCluster",
                    "attributes": [
                            "id": 0,
                            "value": 1
                            "id": 1,
                            "value": 6
                            "id": 2,
                            "value": 2
                            "id": 3,
                            "value": 2
                            "id": 4,
                            "value": "LUMI"
                            "id": 5,
                            "name": "model",
                            "value": "lumi.sensor_wleak.aq1"
                            "id": 6,
                            "value": "20200310"
                            "id": 7,
                            "value": 3
                            "id": 16384,
                            "value": "3000-0001"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1,
                    "attributes": [
                            "id": 32,
                            "value": 31
                            "id": 33,
                            "value": 200
                    "id": 1280,
                    "name": "IAS Zone",
                    "attributes": [
                            "id": 16,
                            "name": "cie_addr",
                            "value": [
                                249,
                                188,
                                6,
                                255,
                                255,
                                46,
                                33,
                                0
    "signature": {
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
            "manufacturer_code": 4151,
            "maximum_buffer_size": 127,
            "maximum_incoming_transfer_size": 100,
            "server_mask": 0,
            "maximum_outgoing_transfer_size": 100,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "input_clusters": [
                    0,
                    3,
                    1,
                    1280
                    25
    "class": "zhaquirks.xiaomi.aqara.wleak_aq1"
aqara_SJCGQ11LM
Merci!
Nickel !!! MErci @Loic!!!
Par contre le nom tu l’as pris où ? Sur AliExpress ils donnent « Signal extender », que je t’ai traduit par « Répétiteur » et là je vois « Range extender »…
Sinon, je sais qu’il ne fait rien que répéter mais il y a même pas une commande info ?
Personne arbitre j’ai decidé de plus me battre donc je fais ce qu’on me demande dès le début (après tout c’est bien ce que veulent les utilisateurs qu’on fasse tout ce qu’il demande tout de suite) juste quand ya un retour arrière ben la j’arrête.
C’est deja présent ce capteur et non pas de température.
Toute les conf ont été ajoutée
Tu devrais pas avoir de commande normalement, pour le nom ca me choque pas range extender
J’ai acheté une ampoule Lexman chez Leroy Merlin, E27 blanche chaud-froid.
==> Problème résolu : rallonge USB et rapprocher l’ampoule
Il semblerait que ce soit une LXEK-7. (oui, pas de faute de frappe, c’est ce que donne le json)
Cependant, lors de l’inclusion, je n’ai aucune commande.
Si je sélectionne manuellement ce qui me semble bon : Adeo - LEXK-7, cela me crée des commandes qui ne fonctionne pas.
Eteindre mon ampoule donne un message d’erreur.
Erreur lors de la requete : http://127.0.0.1:8090/device/command(PUT), data : {"ieee":"5c:02:72:ff:fe:46:0a:fe","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0xc51b:1:0x0006]: Message send failure","code":0}
Pour compléter les infos :
  • La clef fonctionne bien avec une strip Lidl.
  • j’ai 1 clef Deconz avec le plugin Deconz, et une autre clef Deconz pour les tests avec ce plugin Zigbee
  • J’ai mis sur le démon 2 car le démon 1 était utilisé lors de mes 1er tests avec ma 1ère clefs
Voici le Json
    "ieee": "5c:02:72:ff:fe:46:0a:fe",
    "nwk": 50459,
    "status": 2,
    "lqi": "167",
    "rssi": "-73",
    "last_seen": "1616053883.506197",
    "node_descriptor": "01:40:8e:77:12:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 268,
            "profile_id": 260,
            "manufacturer": "Adeo",
            "model": "LXEK-7",
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 1
                            "id": 2,
                            "value": 2
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "Adeo"
                            "id": 5,
                            "name": "model",
                            "value": "LXEK-7"
                            "id": 6,
                            "value": "20200521"
                            "id": 7,
                            "value": 1
                            "id": 16384,
                            "value": "2.3.0"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 8,
                    "attributes": [
                            "id": 0,
                            "name": "current_level",
                            "value": 254
                    "id": 768,
                    "attributes": [
                            "id": 3,
                            "name": "current_x",
                            "value": 29991
                            "id": 4,
                            "name": "current_y",
                            "value": 26872
                            "id": 7,
                            "name": "color_temperature",
                            "value": 370
                    "id": 4096,
                    "attributes": []
                    "id": 64642,
                    "name": "Manufacturer Specific",
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "LXEK-7",
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "manufacturer_code": 4727,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 268,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    8,
                    768,
                    4096,
                    64642
                    25
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
Merci @Loic !
2 messages ont été fusionnés à un sujet existant : plugin-ZIGBEE Beta BlaBla
Re-Bonjour @Loic,
Je n’arrive pas à trouver l’équipement mentionné ici dans le plugin, et donc à configurer mes modules avec.
Est-ce normal ? Sous quel nom est-il répertorié ?
Merci d’avance.
Elle est sous Prise intelligente ON/OFF et 2 ports USB
Super merci :slight_smile: Je ne la voyais pas dans la liste (pourtant avec le plugin mis à jour hier), mais en rafraîchissant la page et en mettant la version d’aujourd’hui c’est bon !
Je viens de changer de clé et en refaisant ma conf, j’ai vu qu’il y a une régression d’image sur les interrupteur tuya sans neutre:
Normalement c’est sensé être la même image que pour le TYZB01_qeqvmvti.TS0011.png
Merci pour le retour. (Sur deconz j’avais une température remontée ce qui m’a fait croire que c’était le cas.)
bonjour
Télécommande_Lidl_seule-removebg-preview
    "ieee": "bc:33:ac:ff:fe:86:3d:29",
    "nwk": 58728,
    "status": 2,
    "lqi": "255",
    "rssi": "-36",
    "last_seen": "1615169330.1766362",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 260,
            "profile_id": 260,
            "manufacturer": "_TYZB01_bngwdjsr",
            "model": "TS1001",
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
chez moi inclusion ok mais pas de changement de valeur sur appuis de bouton
fonctionne elle correctement chez quelqu un ?
