De plus en plus de modules sont disponibles sous des références similaires TZ3000_xxxx model TS0011 ou TS0012 selon s’ils ont 1 ou 2 relais, avec ou sans neutre.
Certains ont déjà été remontés sur plugin-zigbee Beta
A priori, pas celui-ci identifié en QS-Zigbee-S04-2C-L
A priori, fonctionne comme le
"ieee": "84:71:27:ff:fe:10:42:7a",
"nwk": 44250,
"status": 2,
"lqi": "151",
"rssi": "-58",
"last_seen": "1615921886.8995278",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": "_TZ3000_4js9lo5d",
"model": "TS0012",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 66
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_4js9lo5d"
"id": 5,
"name": "model",
"value": "TS0012"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16385,
"name": "on_time",
"value": 0
"id": 16386,
"name": "off_wait_time",
"value": 0
"id": 2,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16385,
"name": "on_time",
"value": 0
"id": 16386,
"value": 0
"signature": {
"model": "TS0012",
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
0,
4,
5,
6
25,
10
"2": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
4,
5,
6
"class": "zigpy.device"
